root/radiance/ray/src/px/pcomb.c
Revision: 2.8
Committed: Fri Oct 2 16:22:51 1992 UTC (31 years, 8 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Combine picture files according to calcomp functions.
9 *
10 * 1/4/89
11 */
12
13 #include <stdio.h>
14
15 #ifdef MSDOS
16 #include <fcntl.h>
17 #endif
18
19 #include <math.h>
20
21 #include <errno.h>
22
23 #include "color.h"
24
25 #include "resolu.h"
26
27 #include "calcomp.h"
28
29 #define MAXINP 32 /* maximum number of input files */
30 #define WINSIZ 9 /* scanline window size */
31 #define MIDSCN 4 /* current scan position */
32
33 struct {
34 char *name; /* file or command name */
35 FILE *fp; /* stream pointer */
36 COLOR *scan[WINSIZ]; /* input scanline window */
37 COLOR coef; /* coefficient */
38 COLOR expos; /* recorded exposure */
39 } input[MAXINP]; /* input pictures */
40
41 int nfiles; /* number of input files */
42
43 char Command[] = "<Command>";
44 char vcolin[3][4] = {"ri", "gi", "bi"};
45 char vcolout[3][4] = {"ro", "go", "bo"};
46 char vbrtin[] = "li";
47 char vbrtout[] = "lo";
48 char vcolexp[3][4] = {"re", "ge", "be"};
49 char vbrtexp[] = "le";
50
51 char vnfiles[] = "nfiles";
52 char vxmax[] = "xmax";
53 char vymax[] = "ymax";
54 char vxres[] = "xres";
55 char vyres[] = "yres";
56 char vxpos[] = "x";
57 char vypos[] = "y";
58
59 int nowarn = 0; /* no warning messages? */
60
61 int xmax = 0, ymax = 0; /* input resolution */
62
63 int xscan, yscan; /* input position */
64
65 int xres, yres; /* output resolution */
66
67 int xpos, ypos; /* output position */
68
69 int wrongformat = 0;
70
71 FILE *popen();
72
73 extern char *emalloc();
74
75
76 main(argc, argv)
77 int argc;
78 char *argv[];
79 {
80 int original;
81 double f;
82 int a, i;
83 #ifdef MSDOS
84 extern int _fmode;
85 _fmode = O_BINARY;
86 setmode(fileno(stdin), O_BINARY);
87 setmode(fileno(stdout), O_BINARY);
88 #endif
89 /* scan options */
90 for (a = 1; a < argc; a++) {
91 if (argv[a][0] == '-')
92 switch (argv[a][1]) {
93 case 'x':
94 case 'y':
95 a++;
96 continue;
97 case 'w':
98 nowarn = !nowarn;
99 continue;
100 case 'f':
101 case 'e':
102 a++;
103 continue;
104 }
105 break;
106 }
107 /* process files */
108 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
109 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
110 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
111 }
112 nfiles = 0;
113 original = 0;
114 for ( ; a < argc; a++) {
115 if (nfiles >= MAXINP) {
116 eputs(argv[0]);
117 eputs(": too many picture files\n");
118 quit(1);
119 }
120 if (argv[a][0] == '-')
121 switch (argv[a][1]) {
122 case '\0':
123 input[nfiles].name = "<stdin>";
124 input[nfiles].fp = stdin;
125 break;
126 case 'o':
127 original++;
128 continue;
129 case 's':
130 f = atof(argv[++a]);
131 scalecolor(input[nfiles].coef, f);
132 continue;
133 case 'c':
134 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
135 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
136 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
137 continue;
138 default:
139 goto usage;
140 }
141 else {
142 if (argv[a][0] == '!') {
143 input[nfiles].name = Command;
144 input[nfiles].fp = popen(argv[a]+1, "r");
145 } else {
146 input[nfiles].name = argv[a];
147 input[nfiles].fp = fopen(argv[a], "r");
148 }
149 if (input[nfiles].fp == NULL) {
150 perror(argv[a]);
151 quit(1);
152 }
153 }
154 checkfile();
155 if (original) {
156 colval(input[nfiles].coef,RED) /=
157 colval(input[nfiles].expos,RED);
158 colval(input[nfiles].coef,GRN) /=
159 colval(input[nfiles].expos,GRN);
160 colval(input[nfiles].coef,BLU) /=
161 colval(input[nfiles].expos,BLU);
162 }
163 nfiles++;
164 original = 0;
165 }
166 init(); /* set constants */
167 /* go back and get expressions */
168 for (a = 1; a < argc; a++) {
169 if (argv[a][0] == '-')
170 switch (argv[a][1]) {
171 case 'x':
172 varset(vxres, ':', eval(argv[++a]));
173 continue;
174 case 'y':
175 varset(vyres, ':', eval(argv[++a]));
176 continue;
177 case 'w':
178 continue;
179 case 'f':
180 fcompile(argv[++a]);
181 continue;
182 case 'e':
183 scompile(argv[++a], NULL, 0);
184 continue;
185 }
186 break;
187 }
188 /* set/get output resolution */
189 if (!vardefined(vxres))
190 varset(vxres, ':', (double)xmax);
191 if (!vardefined(vyres))
192 varset(vyres, ':', (double)ymax);
193 xres = varvalue(vxres) + .5;
194 yres = varvalue(vyres) + .5;
195 if (xres <= 0 || yres <= 0) {
196 eputs(argv[0]);
197 eputs(": illegal output resolution\n");
198 quit(1);
199 }
200 /* complete header */
201 printargs(argc, argv, stdout);
202 fputformat(COLRFMT, stdout);
203 putchar('\n');
204 fprtresolu(xres, yres, stdout);
205 /* combine pictures */
206 combine();
207 quit(0);
208 usage:
209 eputs("Usage: ");
210 eputs(argv[0]);
211 eputs(
212 " [-w][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] pic ..]\n");
213 quit(1);
214 }
215
216
217 tputs(s) /* put out string preceded by a tab */
218 char *s;
219 {
220 char fmt[32];
221 double d;
222 COLOR ctmp;
223
224 if (isformat(s)) { /* check format */
225 formatval(fmt, s);
226 wrongformat = strcmp(fmt, COLRFMT);
227 return; /* don't echo */
228 }
229 if (isexpos(s)) { /* exposure */
230 d = exposval(s);
231 scalecolor(input[nfiles].expos, d);
232 } else if (iscolcor(s)) { /* color correction */
233 colcorval(ctmp, s);
234 multcolor(input[nfiles].expos, ctmp);
235 }
236 /* echo line */
237 putchar('\t');
238 fputs(s, stdout);
239 }
240
241
242 checkfile() /* ready a file */
243 {
244 int xinp, yinp;
245 register int i;
246 /* process header */
247 fputs(input[nfiles].name, stdout);
248 fputs(":\n", stdout);
249 getheader(input[nfiles].fp, tputs, NULL);
250 if (wrongformat) {
251 eputs(input[nfiles].name);
252 eputs(": not in Radiance picture format\n");
253 quit(1);
254 }
255 if (fgetresolu(&xinp, &yinp, input[nfiles].fp) < 0) {
256 eputs(input[nfiles].name);
257 eputs(": bad picture size\n");
258 quit(1);
259 }
260 if (xmax == 0 && ymax == 0) {
261 xmax = xinp;
262 ymax = yinp;
263 } else if (xinp != xmax || yinp != ymax) {
264 eputs(input[nfiles].name);
265 eputs(": resolution mismatch\n");
266 quit(1);
267 }
268 /* allocate scanlines */
269 for (i = 0; i < WINSIZ; i++)
270 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
271 }
272
273
274 init() /* perform final setup */
275 {
276 double l_colin(), l_expos();
277 register int i;
278 /* define constants */
279 varset(vnfiles, ':', (double)nfiles);
280 varset(vxmax, ':', (double)xmax);
281 varset(vymax, ':', (double)ymax);
282 /* set functions */
283 for (i = 0; i < 3; i++) {
284 funset(vcolexp[i], 1, ':', l_expos);
285 funset(vcolin[i], 1, '=', l_colin);
286 }
287 funset(vbrtexp, 1, ':', l_expos);
288 funset(vbrtin, 1, '=', l_colin);
289 }
290
291
292 combine() /* combine pictures */
293 {
294 EPNODE *coldef[3], *brtdef;
295 COLOR *scanout;
296 double d;
297 register int i, j;
298 /* check defined variables */
299 for (j = 0; j < 3; j++) {
300 if (vardefined(vcolout[j]))
301 coldef[j] = eparse(vcolout[j]);
302 else
303 coldef[j] = NULL;
304 }
305 if (vardefined(vbrtout))
306 brtdef = eparse(vbrtout);
307 else
308 brtdef = NULL;
309 /* allocate scanline */
310 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
311 /* set input position */
312 yscan = ymax+MIDSCN;
313 /* combine files */
314 for (ypos = yres-1; ypos >= 0; ypos--) {
315 advance();
316 varset(vypos, '=', (double)ypos);
317 for (xpos = 0; xpos < xres; xpos++) {
318 xscan = (long)xpos*xmax/xres;
319 varset(vxpos, '=', (double)xpos);
320 eclock++;
321 if (brtdef != NULL) {
322 d = evalue(brtdef);
323 if (d < 0.0)
324 d = 0.0;
325 setcolor(scanout[xpos], d, d, d);
326 } else {
327 for (j = 0; j < 3; j++) {
328 if (coldef[j] != NULL) {
329 d = evalue(coldef[j]);
330 } else {
331 d = 0.0;
332 for (i = 0; i < nfiles; i++)
333 d += colval(input[i].scan[MIDSCN][xscan],j);
334 }
335 if (d < 0.0)
336 d = 0.0;
337 colval(scanout[xpos],j) = d;
338 }
339 }
340 }
341 if (fwritescan(scanout, xres, stdout) < 0) {
342 perror("write error");
343 quit(1);
344 }
345 }
346 efree(scanout);
347 }
348
349
350 advance() /* read in data for next scanline */
351 {
352 int ytarget;
353 register COLOR *st;
354 register int i, j;
355
356 for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--)
357 for (i = 0; i < nfiles; i++) {
358 st = input[i].scan[WINSIZ-1];
359 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
360 input[i].scan[j] = input[i].scan[j-1];
361 input[i].scan[0] = st;
362 if (yscan <= MIDSCN) /* hit bottom? */
363 continue;
364 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
365 eputs(input[i].name);
366 eputs(": read error\n");
367 quit(1);
368 }
369 if (fabs(colval(input[i].coef,RED)-1.0) > 1e-3 ||
370 fabs(colval(input[i].coef,GRN)-1.0) > 1e-3 ||
371 fabs(colval(input[i].coef,BLU)-1.0) > 1e-3)
372 for (j = 0; j < xmax; j++) /* adjust color */
373 multcolor(st[j], input[i].coef);
374 }
375 }
376
377
378 double
379 l_expos(nam) /* return picture exposure */
380 register char *nam;
381 {
382 register int fn, n;
383
384 fn = argument(1) - .5;
385 if (fn < 0 || fn >= nfiles)
386 return(1.0);
387 if (nam == vbrtexp)
388 return(bright(input[fn].expos));
389 n = 3;
390 while (n--)
391 if (nam == vcolexp[n])
392 return(colval(input[fn].expos,n));
393 eputs("Bad call to l_expos()!\n");
394 quit(1);
395 }
396
397
398 double
399 l_colin(nam) /* return color value for picture */
400 register char *nam;
401 {
402 int fn;
403 register int n, xoff, yoff;
404 double d;
405
406 d = argument(1);
407 if (d > -.5 && d < .5)
408 return((double)nfiles);
409 fn = d - .5;
410 if (fn < 0 || fn >= nfiles) {
411 errno = EDOM;
412 return(0.0);
413 }
414 xoff = yoff = 0;
415 n = nargum();
416 if (n >= 2) {
417 d = argument(2);
418 if (d < 0.0) {
419 xoff = d-.5;
420 if (xscan+xoff < 0)
421 xoff = -xscan;
422 } else {
423 xoff = d+.5;
424 if (xscan+xoff >= xmax)
425 xoff = xmax-1-xscan;
426 }
427 }
428 if (n >= 3) {
429 d = argument(3);
430 if (d < 0.0) {
431 yoff = d-.5;
432 if (yoff+MIDSCN < 0)
433 yoff = -MIDSCN;
434 if (yscan+yoff < 0)
435 yoff = -yscan;
436 } else {
437 yoff = d+.5;
438 if (yoff+MIDSCN >= WINSIZ)
439 yoff = WINSIZ-1-MIDSCN;
440 if (yscan+yoff >= ymax)
441 yoff = ymax-1-yscan;
442 }
443 }
444 if (nam == vbrtin)
445 return(bright(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
446 n = 3;
447 while (n--)
448 if (nam == vcolin[n])
449 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
450 eputs("Bad call to l_colin()!\n");
451 quit(1);
452 }
453
454
455 wputs(msg)
456 char *msg;
457 {
458 if (!nowarn)
459 eputs(msg);
460 }
461
462
463 eputs(msg)
464 char *msg;
465 {
466 fputs(msg, stderr);
467 }
468
469
470 quit(code) /* exit gracefully */
471 int code;
472 {
473 register int i;
474 /* close input files */
475 for (i = 0; i < nfiles; i++)
476 if (input[i].name == Command)
477 pclose(input[i].fp);
478 else
479 fclose(input[i].fp);
480 exit(code);
481 }
