--- ray/src/px/pcomb.c 1991/05/24 14:46:14 1.15 +++ ray/src/px/pcomb.c 1991/08/19 13:43:33 1.22 @@ -22,45 +22,51 @@ static char SCCSid[] = "$SunId$ LBL"; #define WINSIZ 9 /* scanline window size */ #define MIDSCN 4 /* current scan position */ -#define BRT (-1) /* special index for brightness */ - struct { - char *name; /* file name */ + char *name; /* file or command name */ FILE *fp; /* stream pointer */ COLOR *scan[WINSIZ]; /* input scanline window */ COLOR coef; /* coefficient */ + COLOR expos; /* recorded exposure */ } input[MAXINP]; /* input pictures */ int nfiles; /* number of input files */ -char *vcolin[3] = {"ri", "gi", "bi"}; -char *vcolout[3] = {"ro", "go", "bo"}; +char vcolin[3][4] = {"ri", "gi", "bi"}; +char vcolout[3][4] = {"ro", "go", "bo"}; char vbrtin[] = "li"; char vbrtout[] = "lo"; -char *vcolcoef[3] = {"rc", "gc", "bc"}; -char vbrtcoef[] = "lc"; +char vcolexp[3][4] = {"re", "ge", "be"}; +char vbrtexp[] = "le"; -#define vnfiles "nfiles" -#define vxres "xres" -#define vyres "yres" -#define vxpos "x" -#define vypos "y" +char vnfiles[] = "nfiles"; +char vxmax[] = "xmax"; +char vymax[] = "ymax"; +char vxres[] = "xres"; +char vyres[] = "yres"; +char vxpos[] = "x"; +char vypos[] = "y"; int nowarn = 0; /* no warning messages? */ -int original = 0; /* origninal values? */ +int xmax = 0, ymax = 0; /* input resolution */ -int xres=0, yres=0; /* picture resolution */ +int xscan, yscan; /* input position */ -int xpos, ypos; /* picture position */ +int xres, yres; /* output resolution */ +int xpos, ypos; /* output position */ + int wrongformat = 0; +FILE *popen(); + main(argc, argv) int argc; char *argv[]; { + int original; double f; int a, i; /* scan options */ @@ -68,27 +74,26 @@ char *argv[]; if (argv[a][0] == '-') switch (argv[a][1]) { case 'x': - xres = atoi(argv[++a]); - continue; case 'y': - yres = atoi(argv[++a]); + a++; continue; case 'w': nowarn = !nowarn; continue; - case 'o': - original = !original; - continue; case 'f': case 'e': + a++; continue; } break; } /* process files */ - for (nfiles = 0; nfiles < MAXINP; nfiles++) + for (nfiles = 0; nfiles < MAXINP; nfiles++) { setcolor(input[nfiles].coef, 1.0, 1.0, 1.0); + setcolor(input[nfiles].expos, 1.0, 1.0, 1.0); + } nfiles = 0; + original = 0; for ( ; a < argc; a++) { if (nfiles >= MAXINP) { eputs(argv[0]); @@ -101,6 +106,9 @@ char *argv[]; input[nfiles].name = ""; input[nfiles].fp = stdin; break; + case 'o': + original++; + continue; case 's': f = atof(argv[++a]); scalecolor(input[nfiles].coef, f); @@ -115,23 +123,38 @@ char *argv[]; } else { input[nfiles].name = argv[a]; - input[nfiles].fp = fopen(argv[a], "r"); + input[nfiles].fp = argv[a][0]=='!' ? + popen(argv[a]+1, "r") : + fopen(argv[a], "r"); if (input[nfiles].fp == NULL) { perror(argv[a]); quit(1); } } + checkfile(); + if (original) { + colval(input[nfiles].coef,RED) /= + colval(input[nfiles].expos,RED); + colval(input[nfiles].coef,GRN) /= + colval(input[nfiles].expos,GRN); + colval(input[nfiles].coef,BLU) /= + colval(input[nfiles].expos,BLU); + } nfiles++; + original = 0; } - initfiles(); /* initialize files and variables */ + init(); /* set constants */ /* go back and get expressions */ for (a = 1; a < argc; a++) { if (argv[a][0] == '-') switch (argv[a][1]) { case 'x': + varset(vxres, ':', eval(argv[++a])); + continue; case 'y': + varset(vyres, ':', eval(argv[++a])); + continue; case 'w': - case 'o': continue; case 'f': fcompile(argv[++a]); @@ -142,6 +165,18 @@ char *argv[]; } break; } + /* set/get output resolution */ + if (!vardefined(vxres)) + varset(vxres, ':', (double)xmax); + if (!vardefined(vyres)) + varset(vyres, ':', (double)ymax); + xres = varvalue(vxres) + .5; + yres = varvalue(vyres) + .5; + if (xres <= 0 || yres <= 0) { + eputs(argv[0]); + eputs(": illegal output resolution\n"); + quit(1); + } /* complete header */ printargs(argc, argv, stdout); fputformat(COLRFMT, stdout); @@ -154,7 +189,7 @@ usage: eputs("Usage: "); eputs(argv[0]); eputs( -" [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] pic ..]\n"); +" [-w][-x xr][-y yr][-e expr][-f file] [ [-s f][-c r g b] pic ..]\n"); quit(1); } @@ -169,65 +204,67 @@ char *s; if (isformat(s)) { /* check format */ formatval(fmt, s); wrongformat = strcmp(fmt, COLRFMT); - } else if (original && isexpos(s)) { /* exposure */ - d = 1.0/exposval(s); - scalecolor(input[nfiles].coef, d); - } else if (original && iscolcor(s)) { /* color correction */ + return; /* don't echo */ + } + if (isexpos(s)) { /* exposure */ + d = exposval(s); + scalecolor(input[nfiles].expos, d); + } else if (iscolcor(s)) { /* color correction */ colcorval(ctmp, s); - colval(input[nfiles].coef,RED) /= colval(ctmp,RED); - colval(input[nfiles].coef,GRN) /= colval(ctmp,GRN); - colval(input[nfiles].coef,BLU) /= colval(ctmp,BLU); - } else { /* echo unaffected line */ - putchar('\t'); - fputs(s, stdout); + multcolor(input[nfiles].expos, ctmp); } - + /* echo line */ + putchar('\t'); + fputs(s, stdout); } -initfiles() /* ready files and set variables */ +checkfile() /* ready a file */ { - double l_colin(), l_coef(); - register int n, i; - /* process picture headers */ - for (n = 0; n < nfiles; n++) { - fputs(input[n].name, stdout); - fputs(":\n", stdout); - getheader(input[n].fp, tputs, NULL); - if (wrongformat) { - eputs(input[n].name); - eputs(": not in Radiance picture format\n"); - quit(1); - } - if (fgetresolu(&xpos, &ypos, input[n].fp) != (YMAJOR|YDECR)) { - eputs(input[n].name); - eputs(": bad picture size\n"); - quit(1); - } - if (xres == 0 && yres == 0) { - xres = xpos; - yres = ypos; - } else if (xpos != xres || ypos != yres) { - eputs(input[n].name); - eputs(": resolution mismatch\n"); - quit(1); - } - for (i = 0; i < WINSIZ; i++) - input[n].scan[i] = (COLOR *)emalloc(xres*sizeof(COLOR)); + int xinp, yinp; + register int i; + /* process header */ + fputs(input[nfiles].name, stdout); + fputs(":\n", stdout); + getheader(input[nfiles].fp, tputs, NULL); + if (wrongformat) { + eputs(input[nfiles].name); + eputs(": not in Radiance picture format\n"); + quit(1); } - /* prime input */ - for (ypos = yres+(MIDSCN-1); ypos >= yres; ypos--) - advance(); + if (fgetresolu(&xinp, &yinp, input[nfiles].fp) != (YMAJOR|YDECR)) { + eputs(input[nfiles].name); + eputs(": bad picture size\n"); + quit(1); + } + if (xmax == 0 && ymax == 0) { + xmax = xinp; + ymax = yinp; + } else if (xinp != xmax || yinp != ymax) { + eputs(input[nfiles].name); + eputs(": resolution mismatch\n"); + quit(1); + } + /* allocate scanlines */ + for (i = 0; i < WINSIZ; i++) + input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR)); +} + + +init() /* perform final setup */ +{ + double l_colin(), l_expos(); + register int i; /* define constants */ varset(vnfiles, ':', (double)nfiles); - varset(vxres, ':', (double)xres); - varset(vyres, ':', (double)yres); + varset(vxmax, ':', (double)xmax); + varset(vymax, ':', (double)ymax); /* set functions */ for (i = 0; i < 3; i++) { - funset(vcolcoef[i], 1, ':', l_coef); + funset(vcolexp[i], 1, ':', l_expos); funset(vcolin[i], 1, '=', l_colin); } - funset(vbrtcoef, 1, ':', l_coef); + funset(vbrtexp, 1, ':', l_expos); funset(vbrtin, 1, '=', l_colin); } @@ -251,11 +288,14 @@ combine() /* combine pictures */ brtdef = NULL; /* allocate scanline */ scanout = (COLOR *)emalloc(xres*sizeof(COLOR)); + /* set input position */ + yscan = ymax+MIDSCN; /* combine files */ for (ypos = yres-1; ypos >= 0; ypos--) { advance(); varset(vypos, '=', (double)ypos); for (xpos = 0; xpos < xres; xpos++) { + xscan = (long)xpos*xmax/xres; varset(vxpos, '=', (double)xpos); eclock++; if (brtdef != NULL) { @@ -270,7 +310,7 @@ combine() /* combine pictures */ } else { d = 0.0; for (i = 0; i < nfiles; i++) - d += colval(input[i].scan[MIDSCN][xpos],j); + d += colval(input[i].scan[MIDSCN][xscan],j); } if (d < 0.0) d = 0.0; @@ -287,50 +327,47 @@ combine() /* combine pictures */ } -advance() /* read in next scanline */ +advance() /* read in data for next scanline */ { + int ytarget; register COLOR *st; register int i, j; - for (i = 0; i < nfiles; i++) { - st = input[i].scan[WINSIZ-1]; - for (j = WINSIZ-1; j > 0; j--) /* rotate window */ - input[i].scan[j] = input[i].scan[j-1]; - input[i].scan[0] = st; - if (ypos < MIDSCN) /* hit bottom */ - continue; - if (freadscan(st, xres, input[i].fp) < 0) { - eputs(input[i].name); - eputs(": read error\n"); - quit(1); + for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--) + for (i = 0; i < nfiles; i++) { + st = input[i].scan[WINSIZ-1]; + for (j = WINSIZ-1; j > 0; j--) /* rotate window */ + input[i].scan[j] = input[i].scan[j-1]; + input[i].scan[0] = st; + if (yscan <= MIDSCN) /* hit bottom? */ + continue; + if (freadscan(st, xmax, input[i].fp) < 0) { /* read */ + eputs(input[i].name); + eputs(": read error\n"); + quit(1); + } + for (j = 0; j < xmax; j++) /* adjust color */ + multcolor(st[j], input[i].coef); } - for (j = 0; j < xres; j++) /* adjust color */ - multcolor(st[j], input[i].coef); - } } double -l_coef(nam) /* return picture coefficients */ +l_expos(nam) /* return picture exposure */ register char *nam; { register int fn, n; - double d; - fn = (d = argument(1)) - .5; - if (d <= -.5 || fn >= nfiles) { - errno = EDOM; - return(0.0); - } - if (d < .5) - return((double)nfiles); - if (nam == vbrtcoef) - return(bright(input[fn].coef)); + fn = argument(1) - .5; + if (fn < 0 || fn >= nfiles) + return(1.0); + if (nam == vbrtexp) + return(bright(input[fn].expos)); n = 3; while (n--) - if (nam == vcolcoef[n]) - return(colval(input[fn].coef,n)); - eputs("Bad call to l_coef()!\n"); + if (nam == vcolexp[n]) + return(colval(input[fn].expos,n)); + eputs("Bad call to l_expos()!\n"); quit(1); } @@ -343,25 +380,26 @@ register char *nam; register int n, xoff, yoff; double d; - fn = (d = argument(1)) - .5; - if (d <= -.5 || fn >= nfiles) { + d = argument(1); + if (d > -.5 && d < .5) + return((double)nfiles); + fn = d - .5; + if (fn < 0 || fn >= nfiles) { errno = EDOM; return(0.0); } - if (d < .5) - return((double)nfiles); xoff = yoff = 0; n = nargum(); if (n >= 2) { d = argument(2); if (d < 0.0) { xoff = d-.5; - if (xpos+xoff < 0) - xoff = -xpos; + if (xscan+xoff < 0) + xoff = -xscan; } else { xoff = d+.5; - if (xpos+xoff >= xres) - xoff = xres-1-xpos; + if (xscan+xoff >= xmax) + xoff = xmax-1-xscan; } } if (n >= 3) { @@ -370,22 +408,22 @@ register char *nam; yoff = d-.5; if (yoff+MIDSCN < 0) yoff = -MIDSCN; - if (ypos+yoff < 0) - yoff = -ypos; + if (yscan+yoff < 0) + yoff = -yscan; } else { yoff = d+.5; if (yoff+MIDSCN >= WINSIZ) yoff = WINSIZ-1-MIDSCN; - if (ypos+yoff >= yres) - yoff = yres-1-ypos; + if (yscan+yoff >= ymax) + yoff = ymax-1-yscan; } } if (nam == vbrtin) - return(bright(input[fn].scan[MIDSCN+yoff][xpos+xoff])); + return(bright(input[fn].scan[MIDSCN+yoff][xscan+xoff])); n = 3; while (n--) if (nam == vcolin[n]) - return(colval(input[fn].scan[MIDSCN+yoff][xpos+xoff],n)); + return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n)); eputs("Bad call to l_colin()!\n"); quit(1); }
