--- ray/src/px/pcomb.c 1991/05/23 13:46:05 1.14 +++ ray/src/px/pcomb.c 1991/05/24 17:14:49 1.17 @@ -29,14 +29,17 @@ struct { FILE *fp; /* stream pointer */ COLOR *scan[WINSIZ]; /* input scanline window */ COLOR coef; /* coefficient */ + COLOR expos; /* recorded exposure */ } input[MAXINP]; /* input pictures */ int nfiles; /* number of input files */ char *vcolin[3] = {"ri", "gi", "bi"}; char *vcolout[3] = {"ro", "go", "bo"}; -#define vbrtin "li" -#define vbrtout "lo" +char vbrtin[] = "li"; +char vbrtout[] = "lo"; +char *vcolexp[3] = {"re", "ge", "be"}; +char vbrtexp[] = "le"; #define vnfiles "nfiles" #define vxres "xres" @@ -55,78 +58,37 @@ int xpos, ypos; /* picture position */ int wrongformat = 0; -tputs(s) /* put out string preceded by a tab */ -char *s; -{ - char fmt[32]; - double d; - COLOR ctmp; - - if (isformat(s)) { /* check format */ - formatval(fmt, s); - wrongformat = strcmp(fmt, COLRFMT); - } else if (original && isexpos(s)) { /* exposure */ - d = 1.0/exposval(s); - scalecolor(input[nfiles].coef, d); - } else if (original && iscolcor(s)) { /* color correction */ - colcorval(ctmp, s); - colval(input[nfiles].coef,RED) /= colval(ctmp,RED); - colval(input[nfiles].coef,GRN) /= colval(ctmp,GRN); - colval(input[nfiles].coef,BLU) /= colval(ctmp,BLU); - } else { /* echo unaffected line */ - putchar('\t'); - fputs(s, stdout); - } - -} - - main(argc, argv) int argc; char *argv[]; { - extern double l_redin(), l_grnin(), l_bluin(), l_brtin(), atof(); double f; int a, i; - - funset(vcolin[RED], 1, '=', l_redin); - funset(vcolin[GRN], 1, '=', l_grnin); - funset(vcolin[BLU], 1, '=', l_bluin); - funset(vbrtin, 1, '=', l_brtin); - - for (a = 1; a < argc; a++) + /* scan options */ + for (a = 1; a < argc; a++) { if (argv[a][0] == '-') switch (argv[a][1]) { - case '\0': - case 's': - case 'c': - goto getfiles; case 'x': xres = atoi(argv[++a]); - break; + continue; case 'y': yres = atoi(argv[++a]); - break; + continue; case 'w': nowarn = !nowarn; - break; - case 'o': - original = !original; - break; + continue; case 'f': - fcompile(argv[++a]); - break; case 'e': - scompile(argv[++a], NULL, 0); - break; - default: - goto usage; + a++; + continue; } - else - break; -getfiles: - for (nfiles = 0; nfiles < MAXINP; nfiles++) + break; + } + /* process files */ + for (nfiles = 0; nfiles < MAXINP; nfiles++) { setcolor(input[nfiles].coef, 1.0, 1.0, 1.0); + setcolor(input[nfiles].expos, 1.0, 1.0, 1.0); + } nfiles = 0; for ( ; a < argc; a++) { if (nfiles >= MAXINP) { @@ -140,6 +102,9 @@ getfiles: input[nfiles].name = ""; input[nfiles].fp = stdin; break; + case 'o': + original++; + break; case 's': f = atof(argv[++a]); scalecolor(input[nfiles].coef, f); @@ -160,37 +125,36 @@ getfiles: quit(1); } } - fputs(input[nfiles].name, stdout); - fputs(":\n", stdout); - getheader(input[nfiles].fp, tputs, NULL); - if (wrongformat) { - eputs(input[nfiles].name); - eputs(": not in Radiance picture format\n"); - quit(1); - } - if (fgetresolu(&xpos, &ypos, input[nfiles].fp) != - (YMAJOR|YDECR)) { - eputs(input[nfiles].name); - eputs(": bad picture size\n"); - quit(1); - } - if (xres == 0 && yres == 0) { - xres = xpos; - yres = ypos; - } else if (xpos != xres || ypos != yres) { - eputs(argv[0]); - eputs(": resolution mismatch\n"); - quit(1); - } - for (i = 0; i < WINSIZ; i++) - input[nfiles].scan[i] = - (COLOR *)emalloc(xres*sizeof(COLOR)); + checkfile(); + original = 0; nfiles++; } + init(); /* set constant expressions */ + /* go back and get expressions */ + for (a = 1; a < argc; a++) { + if (argv[a][0] == '-') + switch (argv[a][1]) { + case 'x': + case 'y': + a++; + continue; + case 'w': + continue; + case 'f': + fcompile(argv[++a]); + continue; + case 'e': + scompile(argv[++a], NULL, 0); + continue; + } + break; + } + /* complete header */ printargs(argc, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); fputresolu(YMAJOR|YDECR, xres, yres, stdout); + /* combine pictures */ combine(); quit(0); usage: @@ -202,6 +166,90 @@ usage: } +tputs(s) /* put out string preceded by a tab */ +char *s; +{ + char fmt[32]; + double d; + COLOR ctmp; + + if (isformat(s)) { /* check format */ + formatval(fmt, s); + wrongformat = strcmp(fmt, COLRFMT); + return; /* don't echo */ + } + if (isexpos(s)) { /* exposure */ + d = exposval(s); + scalecolor(input[nfiles].expos, d); + if (original) + scalecolor(input[nfiles].coef, 1.0/d); + } else if (iscolcor(s)) { /* color correction */ + colcorval(ctmp, s); + multcolor(input[nfiles].expos, ctmp); + if (original) { + colval(input[nfiles].coef,RED) /= colval(ctmp,RED); + colval(input[nfiles].coef,GRN) /= colval(ctmp,GRN); + colval(input[nfiles].coef,BLU) /= colval(ctmp,BLU); + } + } + /* echo line */ + putchar('\t'); + fputs(s, stdout); +} + + +checkfile() /* ready a file */ +{ + register int i; + /* process header */ + fputs(input[nfiles].name, stdout); + fputs(":\n", stdout); + getheader(input[nfiles].fp, tputs, NULL); + if (wrongformat) { + eputs(input[nfiles].name); + eputs(": not in Radiance picture format\n"); + quit(1); + } + if (fgetresolu(&xpos, &ypos, input[nfiles].fp) != (YMAJOR|YDECR)) { + eputs(input[nfiles].name); + eputs(": bad picture size\n"); + quit(1); + } + if (xres == 0 && yres == 0) { + xres = xpos; + yres = ypos; + } else if (xpos != xres || ypos != yres) { + eputs(input[nfiles].name); + eputs(": resolution mismatch\n"); + quit(1); + } + /* allocate scanlines */ + for (i = 0; i < WINSIZ; i++) + input[nfiles].scan[i] = (COLOR *)emalloc(xres*sizeof(COLOR)); +} + + +init() /* perform final setup */ +{ + double l_colin(), l_expos(); + register int i; + /* prime input */ + for (ypos = yres+(MIDSCN-1); ypos >= yres; ypos--) + advance(); + /* define constants */ + varset(vnfiles, ':', (double)nfiles); + varset(vxres, ':', (double)xres); + varset(vyres, ':', (double)yres); + /* set functions */ + for (i = 0; i < 3; i++) { + funset(vcolexp[i], 1, ':', l_expos); + funset(vcolin[i], 1, '=', l_colin); + } + funset(vbrtexp, 1, ':', l_expos); + funset(vbrtin, 1, '=', l_colin); +} + + combine() /* combine pictures */ { EPNODE *coldef[3], *brtdef; @@ -219,14 +267,8 @@ combine() /* combine pictures */ brtdef = eparse(vbrtout); else brtdef = NULL; - /* define constants */ - varset(vnfiles, ':', (double)nfiles); - varset(vxres, ':', (double)xres); - varset(vyres, ':', (double)yres); /* allocate scanline */ scanout = (COLOR *)emalloc(xres*sizeof(COLOR)); - /* initialize input */ - initinp(); /* combine files */ for (ypos = yres-1; ypos >= 0; ypos--) { advance(); @@ -263,13 +305,6 @@ combine() /* combine pictures */ } -initinp() /* initilize scan windows */ -{ - for (ypos = yres+(MIDSCN-1); ypos >= yres; ypos--) - advance(); -} - - advance() /* read in next scanline */ { register COLOR *st; @@ -294,20 +329,47 @@ advance() /* read in next scanline */ double -colin(ci) /* return color value for picture */ -register int ci; +l_expos(nam) /* return picture exposure */ +register char *nam; { - int n, fn; - register int xoff, yoff; + register int fn, n; double d; - fn = (d = argument(1)) - .5; - if (d <= -.5 || fn >= nfiles) { + d = argument(1); + if (d > -.5 && d < .5) + return((double)nfiles); + fn = d - .5; + if (fn < 0 || fn >= nfiles) { errno = EDOM; return(0.0); } - if (d < .5) + if (nam == vbrtexp) + return(bright(input[fn].expos)); + n = 3; + while (n--) + if (nam == vcolexp[n]) + return(colval(input[fn].expos,n)); + eputs("Bad call to l_expos()!\n"); + quit(1); +} + + +double +l_colin(nam) /* return color value for picture */ +register char *nam; +{ + int fn; + register int n, xoff, yoff; + double d; + + d = argument(1); + if (d > -.5 && d < .5) return((double)nfiles); + fn = d - .5; + if (fn < 0 || fn >= nfiles) { + errno = EDOM; + return(0.0); + } xoff = yoff = 0; n = nargum(); if (n >= 2) { @@ -338,37 +400,14 @@ register int ci; yoff = yres-1-ypos; } } - if (ci == BRT) + if (nam == vbrtin) return(bright(input[fn].scan[MIDSCN+yoff][xpos+xoff])); - return(colval(input[fn].scan[MIDSCN+yoff][xpos+xoff],ci)); -} - - -double -l_redin() /* get red color */ -{ - return(colin(RED)); -} - - -double -l_grnin() /* get green color */ -{ - return(colin(GRN)); -} - - -double -l_bluin() /* get blue color */ -{ - return(colin(BLU)); -} - - -double -l_brtin() /* get brightness value */ -{ - return(colin(BRT)); + n = 3; + while (n--) + if (nam == vcolin[n]) + return(colval(input[fn].scan[MIDSCN+yoff][xpos+xoff],n)); + eputs("Bad call to l_colin()!\n"); + quit(1); }
