--- ray/src/px/pcomb.c 2003/07/21 22:30:18 2.26 +++ ray/src/px/pcomb.c 2004/06/08 19:48:30 2.33 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pcomb.c,v 2.26 2003/07/21 22:30:18 schorsch Exp $"; +static const char RCSid[] = "$Id: pcomb.c,v 2.33 2004/06/08 19:48:30 greg Exp $"; #endif /* * Combine picture files according to calcomp functions. @@ -7,8 +7,9 @@ static const char RCSid[] = "$Id: pcomb.c,v 2.26 2003/ * 1/4/89 */ -#include "standard.h" #include "platform.h" +#include "standard.h" +#include "rtprocess.h" #include "color.h" #include "calcomp.h" #include "view.h" @@ -32,6 +33,7 @@ int nfiles; /* number of input files */ char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */ +char StandardInput[] = ""; char Command[] = ""; char vcolin[3][4] = {"ri", "gi", "bi"}; char vcolout[3][4] = {"ro", "go", "bo"}; @@ -69,18 +71,30 @@ char *progname; /* global argv[0] */ int wrongformat = 0; int gotview; -FILE *popen(); -extern char *emalloc(); +static gethfunc tabputs; +static void checkfile(void); +static double rgb_bright(COLOR clr); +static double xyz_bright(COLOR clr); +static void init(void); +static void combine(void); +static void advance(void); +static double l_expos(char *nam); +static double l_pixaspect(char *nm); +static double l_colin(char *nam); +static double l_ray(char *nam); +static double l_psize(char *nm); -main(argc, argv) -int argc; -char *argv[]; +int +main( + int argc, + char *argv[] +) { int original; double f; - int a, i; + int a; SET_DEFAULT_BINARY(); SET_FILE_BINARY(stdin); SET_FILE_BINARY(stdout); @@ -123,7 +137,7 @@ char *argv[]; if (argv[a][0] == '-') switch (argv[a][1]) { case '\0': - input[nfiles].name = ""; + input[nfiles].name = StandardInput; input[nfiles].fp = stdin; break; case 'o': @@ -216,11 +230,15 @@ usage: eputs( " [-w][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] pic ..]\n"); quit(1); + return 1; /* pro forma return */ } -tabputs(s) /* put out string preceded by a tab */ -char *s; +static int +tabputs( /* put out string preceded by a tab */ + char *s, + void *p +) { char fmt[32]; double d; @@ -252,7 +270,8 @@ char *s; } -checkfile() /* ready a file */ +static void +checkfile(void) /* ready a file */ { register int i; /* process header */ @@ -291,17 +310,19 @@ checkfile() /* ready a file */ } -double -rgb_bright(clr) -COLOR clr; +static double +rgb_bright( + COLOR clr +) { return(bright(clr)); } -double -xyz_bright(clr) -COLOR clr; +static double +xyz_bright( + COLOR clr +) { return(clr[CIEY]); } @@ -310,9 +331,11 @@ COLOR clr; double (*ourbright)() = rgb_bright; -init() /* perform final setup */ +static void +init(void) /* perform final setup */ { - double l_colin(), l_expos(), l_pixaspect(), l_ray(), l_psize(); + double l_colin(char *), l_expos(char *), l_pixaspect(char *), + l_ray(char *), l_psize(char *); register int i; /* define constants */ varset("PI", ':', PI); @@ -339,7 +362,8 @@ init() /* perform final setup */ } -combine() /* combine pictures */ +static void +combine(void) /* combine pictures */ { EPNODE *coldef[3], *brtdef; COLOR *scanout; @@ -397,7 +421,8 @@ combine() /* combine pictures */ } -advance() /* read in data for next scanline */ +static void +advance(void) /* read in data for next scanline */ { int ytarget; register COLOR *st; @@ -425,9 +450,10 @@ advance() /* read in data for next scanline */ } -double -l_expos(nam) /* return picture exposure */ -register char *nam; +static double +l_expos( /* return picture exposure */ + register char *nam +) { register int fn, n; @@ -442,11 +468,12 @@ register char *nam; return(colval(input[fn].expos,n)); eputs("Bad call to l_expos()!\n"); quit(1); + return 1; /* pro forma return */ } -double -l_pixaspect() /* return pixel aspect ratio */ +static double +l_pixaspect(char *nm) /* return pixel aspect ratio */ { register int fn; @@ -457,9 +484,10 @@ l_pixaspect() /* return pixel aspect ratio */ } -double -l_colin(nam) /* return color value for picture */ -register char *nam; +static double +l_colin( /* return color value for picture */ + register char *nam +) { int fn; register int n, xoff, yoff; @@ -508,12 +536,14 @@ register char *nam; return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n)); eputs("Bad call to l_colin()!\n"); quit(1); + return 1; /* pro forma return */ } -double -l_ray(nam) /* return ray origin or direction */ -register char *nam; +static double +l_ray( /* return ray origin or direction */ + register char *nam +) { static unsigned long ltick[MAXINP]; static FVECT lorg[MAXINP], ldir[MAXINP]; @@ -547,11 +577,12 @@ register char *nam; return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]); eputs("Bad call to l_ray()!\n"); quit(1); + return 1; /* pro forma return */ } -double -l_psize() /* compute pixel size in steradians */ +static double +l_psize(char *nm) /* compute pixel size in steradians */ { static unsigned long ltick[MAXINP]; static double psize[MAXINP]; @@ -596,26 +627,23 @@ l_psize() /* compute pixel size in steradians */ } -void -wputs(msg) -char *msg; +extern void +wputs(char *msg) { if (!nowarn) eputs(msg); } -void -eputs(msg) -char *msg; +extern void +eputs(char *msg) { fputs(msg, stderr); } -void -quit(code) /* exit gracefully */ -int code; +extern void +quit(int code) /* exit gracefully */ { register int i; /* close input files */
