root/radiance/ray/src/px/pcomb.c
Revision: 2.47
Committed: Fri Jan 12 00:50:17 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.46: +15 -12 lines
Added missing esupport settings for constant expression reduction
2 static const char RCSid[] = "$Id: pcomb.c,v 2.46 2016/08/01 00:08:53 greg Exp $";
5 * Combine picture files according to calcomp functions.
6 *
7 * 1/4/89
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "paths.h"
13 #include "color.h"
14 #include "calcomp.h"
15 #include "view.h"
16
17 #define MAXINP 1024 /* maximum number of input files */
18 #define WINSIZ 127 /* scanline window size */
19 #define MIDSCN ((WINSIZ-1)/2+1)
20
21 struct {
22 char *name; /* file or command name */
23 FILE *fp; /* stream pointer */
24 VIEW vw; /* view for picture */
25 RESOLU rs; /* image resolution and orientation */
26 float pa; /* pixel aspect ratio */
27 COLOR *scan[WINSIZ]; /* input scanline window */
28 COLOR coef; /* coefficient */
29 COLOR expos; /* recorded exposure */
30 } input[MAXINP]; /* input pictures */
31
32 int nfiles; /* number of input files */
33
34 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
35
36 char StandardInput[] = "<stdin>";
37 char Command[] = "<Command>";
38 char vcolin[3][4] = {"ri", "gi", "bi"};
39 char vcolout[3][4] = {"ro", "go", "bo"};
40 char vbrtin[] = "li";
41 char vbrtout[] = "lo";
42 char vcolexp[3][4] = {"re", "ge", "be"};
43 char vbrtexp[] = "le";
44 char vpixaspect[] = "pa";
45
46 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
47
48 char vpsize[] = "S";
49
50 char vnfiles[] = "nfiles";
51 char vwhteff[] = "WE";
52 char vxmax[] = "xmax";
53 char vymax[] = "ymax";
54 char vxres[] = "xres";
55 char vyres[] = "yres";
56 char vxpos[] = "x";
57 char vypos[] = "y";
58
59 int nowarn = 0; /* no warning messages? */
60
61 int xmax = 0, ymax = 0; /* input resolution */
62
63 int xscan, yscan; /* input position */
64
65 int xres, yres; /* output resolution */
66
67 int xpos, ypos; /* output position */
68
69 char *progname; /* global argv[0] */
70
71 int echoheader = 1;
72 int wrongformat = 0;
73 int gotview;
74
75
76 static gethfunc headline;
77 static void checkfile(void);
78 static double rgb_bright(COLOR clr);
79 static double xyz_bright(COLOR clr);
80 static void init(void);
81 static void combine(void);
82 static void advance(void);
83 static double l_expos(char *nam);
84 static double l_pixaspect(char *nm);
85 static double l_colin(char *nam);
86 static double l_ray(char *nam);
87 static double l_psize(char *nm);
88
89
90 int
91 main(
92 int argc,
93 char *argv[]
94 )
95 {
96 int original;
97 double f;
98 int a;
99
100 SET_DEFAULT_BINARY();
101 SET_FILE_BINARY(stdin);
102 SET_FILE_BINARY(stdout);
103 progname = argv[0];
104 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
105 esupport &= ~(E_OUTCHAN|E_INCHAN);
106 /* scan options */
107 for (a = 1; a < argc; a++) {
108 if (argv[a][0] == '-')
109 switch (argv[a][1]) {
110 case 'x':
111 case 'y':
112 a++;
113 continue;
114 case 'w':
115 nowarn = !nowarn;
116 continue;
117 case 'h':
118 echoheader = !echoheader;
119 continue;
120 case 'f':
121 case 'e':
122 a++;
123 continue;
124 }
125 break;
126 }
127 newheader("RADIANCE", stdout); /* start header */
128 fputnow(stdout);
129 /* process files */
130 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
131 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
132 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
133 input[nfiles].vw = stdview;
134 input[nfiles].pa = 1.0;
135 }
136 nfiles = 0;
137 original = 0;
138 for ( ; a < argc; a++) {
139 if (nfiles >= MAXINP) {
140 eputs(argv[0]);
141 eputs(": too many picture files\n");
142 quit(1);
143 }
144 if (argv[a][0] == '-')
145 switch (argv[a][1]) {
146 case '\0':
147 input[nfiles].name = StandardInput;
148 input[nfiles].fp = stdin;
149 break;
150 case 'o':
151 original++;
152 continue;
153 case 's':
154 f = atof(argv[++a]);
155 scalecolor(input[nfiles].coef, f);
156 continue;
157 case 'c':
158 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
159 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
160 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
161 continue;
162 default:
163 goto usage;
164 }
165 else {
166 if (argv[a][0] == '!') {
167 input[nfiles].name = Command;
168 input[nfiles].fp = popen(argv[a]+1, "r");
169 } else {
170 input[nfiles].name = argv[a];
171 input[nfiles].fp = fopen(argv[a], "r");
172 }
173 if (input[nfiles].fp == NULL) {
174 perror(argv[a]);
175 quit(1);
176 }
177 }
178 checkfile();
179 if (original) {
180 colval(input[nfiles].coef,RED) /=
181 colval(input[nfiles].expos,RED);
182 colval(input[nfiles].coef,GRN) /=
183 colval(input[nfiles].expos,GRN);
184 colval(input[nfiles].coef,BLU) /=
185 colval(input[nfiles].expos,BLU);
186 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
187 }
188 nfiles++;
189 original = 0;
190 }
191 init(); /* set constants */
192 /* go back and get expressions */
193 for (a = 1; a < argc; a++) {
194 if (argv[a][0] == '-')
195 switch (argv[a][1]) {
196 case 'x':
197 varset(vxres, ':', eval(argv[++a]));
198 continue;
199 case 'y':
200 varset(vyres, ':', eval(argv[++a]));
201 continue;
202 case 'w':
203 continue;
204 case 'h':
205 continue;
206 case 'f':
207 fcompile(argv[++a]);
208 continue;
209 case 'e':
210 scompile(argv[++a], NULL, 0);
211 continue;
212 }
213 break;
214 }
215 /* set/get output resolution */
216 if (!vardefined(vxres))
217 varset(vxres, ':', (double)xmax);
218 if (!vardefined(vyres))
219 varset(vyres, ':', (double)ymax);
220 xres = varvalue(vxres) + .5;
221 yres = varvalue(vyres) + .5;
222 if (xres <= 0 || yres <= 0) {
223 eputs(argv[0]);
224 eputs(": illegal output resolution\n");
225 quit(1);
226 }
227 /* complete header */
228 printargs(argc, argv, stdout);
229 if (strcmp(ourfmt, PICFMT))
230 fputformat(ourfmt, stdout); /* print format if known */
231 putchar('\n');
232 fprtresolu(xres, yres, stdout);
233 /* combine pictures */
234 combine();
235 quit(0);
236 usage:
237 eputs("Usage: ");
238 eputs(argv[0]);
239 eputs(
240 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
241 quit(1);
242 return 1; /* pro forma return */
243 }
244
245
246 static int
247 headline( /* check header line & echo if requested */
248 char *s,
249 void *p
250 )
251 {
252 char fmt[32];
253 double d;
254 COLOR ctmp;
255
256 if (isheadid(s)) /* header id */
257 return(0); /* don't echo */
258 if (formatval(fmt, s)) { /* check format */
259 if (globmatch(ourfmt, fmt)) {
260 wrongformat = 0;
261 strcpy(ourfmt, fmt);
262 } else
263 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
264 return(0); /* don't echo */
265 }
266 if (isexpos(s)) { /* exposure */
267 d = exposval(s);
268 scalecolor(input[nfiles].expos, d);
269 } else if (iscolcor(s)) { /* color correction */
270 colcorval(ctmp, s);
271 multcolor(input[nfiles].expos, ctmp);
272 } else if (isaspect(s))
273 input[nfiles].pa *= aspectval(s);
274 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
275 gotview++;
276
277 if (echoheader) { /* echo line */
278 putchar('\t');
279 return(fputs(s, stdout));
280 }
281 return(0);
282 }
283
284
285 static void
286 checkfile(void) /* ready a file */
287 {
288 int i;
289 /* process header */
290 gotview = 0;
291 if (echoheader) {
292 fputs(input[nfiles].name, stdout);
293 fputs(":\n", stdout);
294 }
295 getheader(input[nfiles].fp, headline, NULL);
296 if (wrongformat < 0) {
297 eputs(input[nfiles].name);
298 eputs(": not a Radiance picture\n");
299 quit(1);
300 }
301 if (wrongformat > 0) {
302 wputs(input[nfiles].name);
303 wputs(": warning -- incompatible picture format\n");
304 }
305 if (!gotview || setview(&input[nfiles].vw) != NULL)
306 input[nfiles].vw.type = 0;
307 if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
308 eputs(input[nfiles].name);
309 eputs(": bad picture size\n");
310 quit(1);
311 }
312 if (xmax == 0 && ymax == 0) {
313 xmax = scanlen(&input[nfiles].rs);
314 ymax = numscans(&input[nfiles].rs);
315 } else if (scanlen(&input[nfiles].rs) != xmax ||
316 numscans(&input[nfiles].rs) != ymax) {
317 eputs(input[nfiles].name);
318 eputs(": resolution mismatch\n");
319 quit(1);
320 }
321 /* allocate scanlines */
322 for (i = 0; i < WINSIZ; i++)
323 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
324 }
325
326
327 static double
328 rgb_bright(
329 COLOR clr
330 )
331 {
332 return(bright(clr));
333 }
334
335
336 static double
337 xyz_bright(
338 COLOR clr
339 )
340 {
341 return(clr[CIEY]);
342 }
343
344
345 double (*ourbright)() = rgb_bright;
346
347
348 static void
349 init(void) /* perform final setup */
350 {
351 int i;
352 /* define constants */
353 varset("PI", ':', PI);
354 varset(vnfiles, ':', (double)nfiles);
355 varset(vxmax, ':', (double)xmax);
356 varset(vymax, ':', (double)ymax);
357 /* set functions */
358 for (i = 0; i < 3; i++) {
359 funset(vcolexp[i], 1, ':', l_expos);
360 funset(vcolin[i], 1, '=', l_colin);
361 }
362 funset(vbrtexp, 1, ':', l_expos);
363 funset(vbrtin, 1, '=', l_colin);
364 funset(vpixaspect, 1, ':', l_pixaspect);
365 for (i = 0; i < 7; i++)
366 funset(vray[i], 1, '=', l_ray);
367 funset(vpsize, 1, '=', l_psize);
368 /* set brightness function */
369 if (!strcmp(ourfmt, CIEFMT)) {
370 varset(vwhteff, ':', 1.0);
371 ourbright = xyz_bright;
372 } else
373 varset(vwhteff, ':', WHTEFFICACY);
374 }
375
376
377 static void
378 combine(void) /* combine pictures */
379 {
380 EPNODE *coldef[3], *brtdef;
381 COLOR *scanout;
382 double d;
383 int i, j;
384 /* check defined variables */
385 for (j = 0; j < 3; j++) {
386 if (vardefined(vcolout[j]))
387 coldef[j] = eparse(vcolout[j]);
388 else
389 coldef[j] = NULL;
390 }
391 if (vardefined(vbrtout))
392 brtdef = eparse(vbrtout);
393 else
394 brtdef = NULL;
395 /* allocate scanline */
396 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
397 /* set input position */
398 yscan = ymax+MIDSCN;
399 /* combine files */
400 for (ypos = yres-1; ypos >= 0; ypos--) {
401 advance();
402 varset(vypos, '=', (double)ypos);
403 for (xpos = 0; xpos < xres; xpos++) {
404 xscan = (xpos+.5)*xmax/xres;
405 varset(vxpos, '=', (double)xpos);
406 eclock++;
407 if (brtdef != NULL) {
408 d = evalue(brtdef);
409 if (d < 0.0)
410 d = 0.0;
411 setcolor(scanout[xpos], d, d, d);
412 } else {
413 for (j = 0; j < 3; j++) {
414 if (coldef[j] != NULL) {
415 d = evalue(coldef[j]);
416 } else {
417 d = 0.0;
418 for (i = 0; i < nfiles; i++)
419 d += colval(input[i].scan[MIDSCN][xscan],j);
420 }
421 if (d < 0.0)
422 d = 0.0;
423 colval(scanout[xpos],j) = d;
424 }
425 }
426 }
427 if (fwritescan(scanout, xres, stdout) < 0) {
428 perror("write error");
429 quit(1);
430 }
431 }
432 efree((char *)scanout);
433 }
434
435
436 static void
437 advance(void) /* read in data for next scanline */
438 {
439 int ytarget;
440 COLOR *st;
441 int i, j;
442
443 for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
444 for (i = 0; i < nfiles; i++) {
445 st = input[i].scan[WINSIZ-1];
446 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
447 input[i].scan[j] = input[i].scan[j-1];
448 input[i].scan[0] = st;
449 if (yscan <= MIDSCN) /* hit bottom? */
450 continue;
451 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
452 eputs(input[i].name);
453 eputs(": read error\n");
454 quit(1);
455 }
456 for (j = 0; j < xmax; j++) /* adjust color */
457 multcolor(st[j], input[i].coef);
458 }
459 }
460
461
462 static double
463 l_expos( /* return picture exposure */
464 char *nam
465 )
466 {
467 int fn, n;
468 double d;
469
470 d = argument(1);
471 if (d <= -0.5 || d >= nfiles+0.5) {
472 errno = EDOM;
473 return(0.0);
474 }
475 if (d < 0.5)
476 return((double)nfiles);
477 fn = d - 0.5;
478 if (nam == vbrtexp)
479 return((*ourbright)(input[fn].expos));
480 n = 3;
481 while (n--)
482 if (nam == vcolexp[n])
483 return(colval(input[fn].expos,n));
484 eputs("Bad call to l_expos()!\n");
485 quit(1);
486 return 1; /* pro forma return */
487 }
488
489
490 static double
491 l_pixaspect(char *nm) /* return pixel aspect ratio */
492 {
493 int fn;
494 double d;
495
496 d = argument(1);
497 if (d <= -0.5 || d >= nfiles+0.5) {
498 errno = EDOM;
499 return(0.0);
500 }
501 if (d < 0.5)
502 return((double)nfiles);
503 fn = d - 0.5;
504 return(input[fn].pa);
505 }
506
507
508 static double
509 l_colin( /* return color value for picture */
510 char *nam
511 )
512 {
513 int fn;
514 int n, xoff, yoff;
515 double d;
516
517 d = argument(1);
518 if (d <= -0.5 || d >= nfiles+0.5) {
519 errno = EDOM;
520 return(0.0);
521 }
522 if (d < 0.5)
523 return((double)nfiles);
524 fn = d - 0.5;
525 xoff = yoff = 0;
526 n = nargum();
527 if (n >= 2) {
528 d = argument(2);
529 if (d < 0.0) {
530 xoff = d-.5;
531 if (xscan+xoff < 0)
532 xoff = -xscan;
533 } else {
534 xoff = d+.5;
535 if (xscan+xoff >= xmax)
536 xoff = xmax-1-xscan;
537 }
538 }
539 if (n >= 3) {
540 d = argument(3);
541 if (d < 0.0) {
542 yoff = d-.5;
543 if (yoff+MIDSCN < 0)
544 yoff = -MIDSCN;
545 if (yscan+yoff < 0)
546 yoff = -yscan;
547 } else {
548 yoff = d+.5;
549 if (yoff+MIDSCN >= WINSIZ)
550 yoff = WINSIZ-1-MIDSCN;
551 if (yscan+yoff >= ymax)
552 yoff = ymax-1-yscan;
553 }
554 }
555 if (nam == vbrtin)
556 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
557 n = 3;
558 while (n--)
559 if (nam == vcolin[n])
560 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
561 eputs("Bad call to l_colin()!\n");
562 quit(1);
563 return 1; /* pro forma return */
564 }
565
566
567 static double
568 l_ray( /* return ray origin or direction */
569 char *nam
570 )
571 {
572 static unsigned long ltick[MAXINP];
573 static FVECT lorg[MAXINP], ldir[MAXINP];
574 static double ldist[MAXINP];
575 RREAL loc[2];
576 double d;
577 int fn;
578 int i;
579
580 d = argument(1);
581 if (d <= -0.5 || d >= nfiles+0.5) {
582 errno = EDOM;
583 return(0.0);
584 }
585 if (d < 0.5)
586 return((double)nfiles);
587 fn = d - 0.5;
588 if (ltick[fn] != eclock) { /* need to compute? */
589 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
590 ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
591 ldist[fn] = -1.0;
592 if (input[fn].vw.type == 0)
593 errno = EDOM;
594 else {
595 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
596 ldist[fn] = viewray(lorg[fn], ldir[fn],
597 &input[fn].vw, loc[0], loc[1]);
598 }
599 ltick[fn] = eclock;
600 }
601 if (nam == vray[i=6])
602 return(ldist[fn]);
603 while (i--)
604 if (nam == vray[i])
605 return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
606 eputs("Bad call to l_ray()!\n");
607 quit(1);
608 return 1; /* pro forma return */
609 }
610
611
612 static double
613 l_psize(char *nm) /* compute pixel size in steradians */
614 {
615 static unsigned long ltick[MAXINP];
616 static double psize[MAXINP];
617 FVECT dir0, org, dirx, diry;
618 RREAL locx[2], locy[2];
619 double d;
620 int fn;
621 int i;
622
623 d = argument(1);
624 if (d <= -0.5 || d >= nfiles+0.5) {
625 errno = EDOM;
626 return(0.0);
627 }
628 if (d < 0.5)
629 return((double)nfiles);
630 fn = d - 0.5;
631 if (ltick[fn] != eclock) { /* need to compute? */
632 psize[fn] = 0.0;
633 if (input[fn].vw.type == 0)
634 errno = EDOM;
635 else if (input[fn].vw.type != VT_PAR &&
636 funvalue(vray[6], 1, &d) >= -FTINY) {
637 for (i = 0; i < 3; i++)
638 dir0[i] = funvalue(vray[3+i], 1, &d);
639 pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
640 pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
641 if (viewray(org, dirx, &input[fn].vw,
642 locx[0], locx[1]) >= -FTINY &&
643 viewray(org, diry, &input[fn].vw,
644 locy[0], locy[1]) >= -FTINY) {
645 /* approximate solid angle */
646 for (i = 0; i < 3; i++) {
647 dirx[i] -= dir0[i];
648 diry[i] -= dir0[i];
649 }
650 fcross(dir0, dirx, diry);
651 psize[fn] = VLEN(dir0);
652 }
653 }
654 ltick[fn] = eclock;
655 }
656 return(psize[fn]);
657 }
658
659
660 extern void
661 wputs(char *msg)
662 {
663 if (!nowarn)
664 eputs(msg);
665 }
666
667
668 extern void
669 eputs(char *msg)
670 {
671 fputs(msg, stderr);
672 }
673
674
675 extern void
676 quit(int code) /* exit gracefully */
677 {
678 int i;
679 /* close input files */
680 for (i = 0; i < nfiles; i++)
681 if (input[i].name == Command)
682 pclose(input[i].fp);
683 else
684 fclose(input[i].fp);
685 exit(code);
686 }
