root/radiance/ray/src/px/pcomb.c
Revision: 2.53
Committed: Fri Mar 18 18:31:47 2022 UTC (3 years, 3 months ago) by greg
Changes since 2.52: +21 -16 lines
fix(pcomb): Changed behavior to elide exposure from indented header for evalglare
2 static const char RCSid[] = "$Id: pcomb.c,v 2.52 2019/04/03 20:16:31 greg Exp $";
5 * Combine picture files according to calcomp functions.
6 *
7 * 1/4/89
8 */
9
10 #include "platform.h"
11 #include "standard.h"
12 #include "paths.h"
13 #include "color.h"
14 #include "calcomp.h"
15 #include "view.h"
16
17 #define MAXINP 1024 /* maximum number of input files */
18 #define WINSIZ 127 /* scanline window size */
19 #define MIDSCN ((WINSIZ-1)/2+1)
20
21 struct {
22 char *name; /* file or command name */
23 FILE *fp; /* stream pointer */
24 VIEW vw; /* view for picture */
25 RESOLU rs; /* image resolution and orientation */
26 float pa; /* pixel aspect ratio */
27 COLOR *scan[WINSIZ]; /* input scanline window */
28 COLOR coef; /* coefficient */
29 COLOR expos; /* recorded exposure */
30 } input[MAXINP]; /* input pictures */
31
32 int nfiles; /* number of input files */
33
34 VIEW *commvp = NULL; /* common view parameters */
35
36 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
37
38 char StandardInput[] = "<stdin>";
39 char Command[] = "<Command>";
40 char vcolin[3][4] = {"ri", "gi", "bi"};
41 char vcolout[3][4] = {"ro", "go", "bo"};
42 char vbrtin[] = "li";
43 char vbrtout[] = "lo";
44 char vcolexp[3][4] = {"re", "ge", "be"};
45 char vbrtexp[] = "le";
46 char vpixaspect[] = "pa";
47
48 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
49
50 char vpsize[] = "S";
51
52 char vnfiles[] = "nfiles";
53 char vwhteff[] = "WE";
54 char vxmax[] = "xmax";
55 char vymax[] = "ymax";
56 char vxres[] = "xres";
57 char vyres[] = "yres";
58 char vxpos[] = "x";
59 char vypos[] = "y";
60
61 int nowarn = 0; /* no warning messages? */
62
63 int xmax = 0, ymax = 0; /* input resolution */
64
65 int xscan, yscan; /* input position */
66
67 int xres, yres; /* output resolution */
68
69 int xpos, ypos; /* output position */
70
71 char *progname; /* global argv[0] */
72
73 int echoheader = 1;
74 int wrongformat = 0;
75 int gotview;
76
77
78 static gethfunc headline;
79 static void checkfile(int orig);
80 static double rgb_bright(COLOR clr);
81 static double xyz_bright(COLOR clr);
82 static void init(void);
83 static void combine(void);
84 static void advance(void);
85 static double l_expos(char *nam);
86 static double l_pixaspect(char *nm);
87 static double l_colin(char *nam);
88 static double l_ray(char *nam);
89 static double l_psize(char *nm);
90
91
92 int
93 main(
94 int argc,
95 char *argv[]
96 )
97 {
98 int original;
99 double f;
100 int a;
101
102 SET_DEFAULT_BINARY();
103 SET_FILE_BINARY(stdin);
104 SET_FILE_BINARY(stdout);
105 progname = argv[0];
106 esupport |= E_VARIABLE|E_FUNCTION|E_RCONST;
107 esupport &= ~(E_OUTCHAN|E_INCHAN);
108 /* scan options */
109 for (a = 1; a < argc; a++) {
110 if (argv[a][0] == '-')
111 switch (argv[a][1]) {
112 case 'x':
113 case 'y':
114 a++;
115 continue;
116 case 'w':
117 nowarn = !nowarn;
118 continue;
119 case 'h':
120 echoheader = !echoheader;
121 continue;
122 case 'f':
123 case 'e':
124 a++;
125 continue;
126 }
127 break;
128 }
129 newheader("RADIANCE", stdout); /* start header */
130 fputnow(stdout);
131 /* process files */
132 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
133 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
134 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
135 input[nfiles].vw = stdview;
136 input[nfiles].pa = 1.0;
137 }
138 nfiles = 0;
139 original = 0;
140 for ( ; a < argc; a++) {
141 if (nfiles >= MAXINP) {
142 eputs(argv[0]);
143 eputs(": too many picture files\n");
144 quit(1);
145 }
146 if (argv[a][0] == '-')
147 switch (argv[a][1]) {
148 case '\0':
149 input[nfiles].name = StandardInput;
150 input[nfiles].fp = stdin;
151 break;
152 case 'o':
153 original++;
154 continue;
155 case 's':
156 f = atof(argv[++a]);
157 scalecolor(input[nfiles].coef, f);
158 continue;
159 case 'c':
160 colval(input[nfiles].coef,RED)*=atof(argv[++a]);
161 colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
162 colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
163 continue;
164 default:
165 goto usage;
166 }
167 else {
168 if (argv[a][0] == '!') {
169 input[nfiles].name = Command;
170 input[nfiles].fp = popen(argv[a]+1, "r");
171 } else {
172 input[nfiles].name = argv[a];
173 input[nfiles].fp = fopen(argv[a], "r");
174 }
175 if (input[nfiles].fp == NULL) {
176 perror(argv[a]);
177 quit(1);
178 }
179 }
180 checkfile(original);
181 nfiles++;
182 original = 0;
183 }
184 init(); /* set constants */
185 /* go back and get expressions */
186 for (a = 1; a < argc; a++) {
187 char *fpath;
188 if (argv[a][0] == '-')
189 switch (argv[a][1]) {
190 case 'x':
191 varset(vxres, ':', eval(argv[++a]));
192 continue;
193 case 'y':
194 varset(vyres, ':', eval(argv[++a]));
195 continue;
196 case 'w':
197 continue;
198 case 'h':
199 continue;
200 case 'f':
201 fpath = getpath(argv[++a], getrlibpath(), 0);
202 if (fpath == NULL) {
203 eputs(argv[0]);
204 eputs(": cannot find file '");
205 eputs(argv[a]);
206 eputs("'\n");
207 quit(1);
208 }
209 fcompile(fpath);
210 continue;
211 case 'e':
212 scompile(argv[++a], NULL, 0);
213 continue;
214 }
215 break;
216 }
217 /* get output resolution */
218 xres = varvalue(vxres) + .5;
219 yres = varvalue(vyres) + .5;
220 if (xres <= 0 || yres <= 0) {
221 eputs(argv[0]);
222 eputs(": illegal output resolution\n");
223 quit(1);
224 }
225 /* complete header */
226 printargs(argc, argv, stdout);
227 if (commvp != NULL) {
228 fputs(VIEWSTR, stdout);
229 fprintview(commvp, stdout);
230 fputc('\n', stdout);
231 }
232 if (strcmp(ourfmt, PICFMT))
233 fputformat(ourfmt, stdout); /* print format if known */
234 putchar('\n');
235 fprtresolu(xres, yres, stdout);
236 /* combine pictures */
237 combine();
238 quit(0);
239 usage:
240 eputs("Usage: ");
241 eputs(argv[0]);
242 eputs(
243 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
244 quit(1);
245 return 1; /* pro forma return */
246 }
247
248
249 static int
250 headline( /* check header line & echo if requested */
251 char *s,
252 void *p
253 )
254 {
255 int orig = *(int *)p;
256 char fmt[MAXFMTLEN];
257 double d;
258 COLOR ctmp;
259
260 if (isheadid(s)) /* header id */
261 return(0); /* don't echo */
262 if (formatval(fmt, s)) { /* check format */
263 if (globmatch(ourfmt, fmt)) {
264 wrongformat = 0;
265 strcpy(ourfmt, fmt);
266 } else
267 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
268 return(0); /* don't echo */
269 }
270 if (orig) { /* undo exposure? */
271 if (isexpos(s)) {
272 d = 1./exposval(s);
273 scalecolor(input[nfiles].coef, d);
274 return(0); /* don't echo */
275 }
276 if (iscolcor(s)) {
277 int i;
278 colcorval(ctmp, s);
279 for (i = 3; i--; )
280 colval(input[nfiles].coef,i) /= colval(ctmp,i);
281 return(0); /* don't echo */
282 }
283 } else if (isexpos(s)) { /* record exposure? */
284 d = exposval(s);
285 scalecolor(input[nfiles].expos, d);
286 } else if (iscolcor(s)) {
287 colcorval(ctmp, s);
288 multcolor(input[nfiles].expos, ctmp);
289 } else if (isaspect(s))
290 input[nfiles].pa *= aspectval(s);
291 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
292 gotview++;
293
294 if (echoheader) { /* echo line */
295 putchar('\t');
296 return(fputs(s, stdout));
297 }
298 return(0);
299 }
300
301
302 static void
303 checkfile(int orig) /* ready a file */
304 {
305 int i;
306 /* process header */
307 gotview = 0;
308 if (echoheader) {
309 fputs(input[nfiles].name, stdout);
310 fputs(":\n", stdout);
311 }
312 getheader(input[nfiles].fp, headline, &orig);
313 if (wrongformat < 0) {
314 eputs(input[nfiles].name);
315 eputs(": not a Radiance picture\n");
316 quit(1);
317 }
318 if (wrongformat > 0) {
319 wputs(input[nfiles].name);
320 wputs(": warning -- incompatible picture format\n");
321 }
322 if (!gotview || setview(&input[nfiles].vw) != NULL)
323 input[nfiles].vw.type = 0;
324 else if (commvp == NULL)
325 commvp = &input[nfiles].vw;
326 if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
327 eputs(input[nfiles].name);
328 eputs(": bad picture size\n");
329 quit(1);
330 }
331 if (xmax == 0 && ymax == 0) {
332 xmax = scanlen(&input[nfiles].rs);
333 ymax = numscans(&input[nfiles].rs);
334 } else if (scanlen(&input[nfiles].rs) != xmax ||
335 numscans(&input[nfiles].rs) != ymax) {
336 eputs(input[nfiles].name);
337 eputs(": resolution mismatch\n");
338 quit(1);
339 }
340 /* allocate scanlines */
341 for (i = 0; i < WINSIZ; i++)
342 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
343 }
344
345
346 static double
347 rgb_bright(
348 COLOR clr
349 )
350 {
351 return(bright(clr));
352 }
353
354
355 static double
356 xyz_bright(
357 COLOR clr
358 )
359 {
360 return(clr[CIEY]);
361 }
362
363
364 double (*ourbright)() = rgb_bright;
365
366
367 static void
368 init(void) /* perform final setup */
369 {
370 int i;
371 /* define constants */
372 varset("PI", ':', PI);
373 varset(vnfiles, ':', (double)nfiles);
374 varset(vxmax, ':', (double)xmax);
375 varset(vymax, ':', (double)ymax);
376 /* set functions */
377 for (i = 0; i < 3; i++) {
378 funset(vcolexp[i], 1, ':', l_expos);
379 funset(vcolin[i], 1, '=', l_colin);
380 }
381 funset(vbrtexp, 1, ':', l_expos);
382 funset(vbrtin, 1, '=', l_colin);
383 funset(vpixaspect, 1, ':', l_pixaspect);
384 for (i = 0; i < 7; i++)
385 funset(vray[i], 1, '=', l_ray);
386 funset(vpsize, 1, '=', l_psize);
387 /* set brightness function */
388 if (!strcmp(ourfmt, CIEFMT)) {
389 varset(vwhteff, ':', 1.0);
390 ourbright = xyz_bright;
391 } else
392 varset(vwhteff, ':', WHTEFFICACY);
393 /* these may be overridden */
394 varset(vxres, ':', (double)xmax);
395 varset(vyres, ':', (double)ymax);
396 }
397
398
399 static void
400 combine(void) /* combine pictures */
401 {
402 EPNODE *coldef[3], *brtdef;
403 COLOR *scanout;
404 double d;
405 int i, j;
406 /* check defined variables */
407 for (j = 0; j < 3; j++) {
408 if (vardefined(vcolout[j]))
409 coldef[j] = eparse(vcolout[j]);
410 else
411 coldef[j] = NULL;
412 }
413 if (vardefined(vbrtout))
414 brtdef = eparse(vbrtout);
415 else
416 brtdef = NULL;
417 /* allocate scanline */
418 scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
419 /* set input position */
420 yscan = ymax+MIDSCN;
421 /* combine files */
422 for (ypos = yres-1; ypos >= 0; ypos--) {
423 advance();
424 varset(vypos, '=', (double)ypos);
425 for (xpos = 0; xpos < xres; xpos++) {
426 xscan = (xpos+.5)*xmax/xres;
427 varset(vxpos, '=', (double)xpos);
428 eclock++;
429 if (brtdef != NULL) {
430 d = evalue(brtdef);
431 if (d < 0.0)
432 d = 0.0;
433 setcolor(scanout[xpos], d, d, d);
434 } else {
435 for (j = 0; j < 3; j++) {
436 if (coldef[j] != NULL) {
437 d = evalue(coldef[j]);
438 } else {
439 d = 0.0;
440 for (i = 0; i < nfiles; i++)
441 d += colval(input[i].scan[MIDSCN][xscan],j);
442 }
443 if (d < 0.0)
444 d = 0.0;
445 colval(scanout[xpos],j) = d;
446 }
447 }
448 }
449 if (fwritescan(scanout, xres, stdout) < 0) {
450 perror("write error");
451 quit(1);
452 }
453 }
454 efree((char *)scanout);
455 }
456
457
458 static void
459 advance(void) /* read in data for next scanline */
460 {
461 int ytarget;
462 COLOR *st;
463 int i, j;
464
465 for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
466 for (i = 0; i < nfiles; i++) {
467 st = input[i].scan[WINSIZ-1];
468 for (j = WINSIZ-1; j > 0; j--) /* rotate window */
469 input[i].scan[j] = input[i].scan[j-1];
470 input[i].scan[0] = st;
471 if (yscan <= MIDSCN) /* hit bottom? */
472 continue;
473 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
474 eputs(input[i].name);
475 eputs(": read error\n");
476 quit(1);
477 }
478 for (j = 0; j < xmax; j++) /* adjust color */
479 multcolor(st[j], input[i].coef);
480 }
481 }
482
483
484 static double
485 l_expos( /* return picture exposure */
486 char *nam
487 )
488 {
489 int fn, n;
490 double d;
491
492 d = argument(1);
493 if (d <= -0.5 || d >= nfiles+0.5) {
494 errno = EDOM;
495 return(0.0);
496 }
497 if (d < 0.5)
498 return((double)nfiles);
499 fn = d - 0.5;
500 if (nam == vbrtexp)
501 return((*ourbright)(input[fn].expos));
502 n = 3;
503 while (n--)
504 if (nam == vcolexp[n])
505 return(colval(input[fn].expos,n));
506 eputs("Bad call to l_expos()!\n");
507 quit(1);
508 return 1; /* pro forma return */
509 }
510
511
512 static double
513 l_pixaspect(char *nm) /* return pixel aspect ratio */
514 {
515 int fn;
516 double d;
517
518 d = argument(1);
519 if (d <= -0.5 || d >= nfiles+0.5) {
520 errno = EDOM;
521 return(0.0);
522 }
523 if (d < 0.5)
524 return((double)nfiles);
525 fn = d - 0.5;
526 return(input[fn].pa);
527 }
528
529
530 static double
531 l_colin( /* return color value for picture */
532 char *nam
533 )
534 {
535 int fn;
536 int n, xoff, yoff;
537 double d;
538
539 d = argument(1);
540 if (d <= -0.5 || d >= nfiles+0.5) {
541 errno = EDOM;
542 return(0.0);
543 }
544 if (d < 0.5)
545 return((double)nfiles);
546 fn = d - 0.5;
547 xoff = yoff = 0;
548 n = nargum();
549 if (n >= 2) {
550 d = argument(2);
551 if (d < 0.0) {
552 xoff = d-.5;
553 if (xscan+xoff < 0)
554 xoff = -xscan;
555 } else {
556 xoff = d+.5;
557 if (xscan+xoff >= xmax)
558 xoff = xmax-1-xscan;
559 }
560 }
561 if (n >= 3) {
562 d = argument(3);
563 if (d < 0.0) {
564 yoff = d-.5;
565 if (yoff+MIDSCN < 0)
566 yoff = -MIDSCN;
567 if (yscan+yoff < 0)
568 yoff = -yscan;
569 } else {
570 yoff = d+.5;
571 if (yoff+MIDSCN >= WINSIZ)
572 yoff = WINSIZ-1-MIDSCN;
573 if (yscan+yoff >= ymax)
574 yoff = ymax-1-yscan;
575 }
576 }
577 if (nam == vbrtin)
578 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
579 n = 3;
580 while (n--)
581 if (nam == vcolin[n])
582 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
583 eputs("Bad call to l_colin()!\n");
584 quit(1);
585 return 1; /* pro forma return */
586 }
587
588
589 static double
590 l_ray( /* return ray origin or direction */
591 char *nam
592 )
593 {
594 static unsigned long ltick[MAXINP];
595 static FVECT lorg[MAXINP], ldir[MAXINP];
596 static double ldist[MAXINP];
597 RREAL loc[2];
598 double d;
599 int fn;
600 int i;
601
602 d = argument(1);
603 if (d <= -0.5 || d >= nfiles+0.5) {
604 errno = EDOM;
605 return(0.0);
606 }
607 if (d < 0.5)
608 return((double)nfiles);
609 fn = d - 0.5;
610 if (ltick[fn] != eclock) { /* need to compute? */
611 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
612 ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
613 ldist[fn] = -1.0;
614 if (input[fn].vw.type == 0)
615 errno = EDOM;
616 else {
617 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
618 ldist[fn] = viewray(lorg[fn], ldir[fn],
619 &input[fn].vw, loc[0], loc[1]);
620 }
621 ltick[fn] = eclock;
622 }
623 if (nam == vray[i=6])
624 return(ldist[fn]);
625 while (i--)
626 if (nam == vray[i])
627 return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
628 eputs("Bad call to l_ray()!\n");
629 quit(1);
630 return 1; /* pro forma return */
631 }
632
633
634 static double
635 l_psize(char *nm) /* compute pixel size in steradians */
636 {
637 static unsigned long ltick[MAXINP];
638 static double psize[MAXINP];
639 FVECT dir0, org, dirx, diry;
640 RREAL locx[2], locy[2];
641 double d;
642 int fn;
643 int i;
644
645 d = argument(1);
646 if (d <= -0.5 || d >= nfiles+0.5) {
647 errno = EDOM;
648 return(0.0);
649 }
650 if (d < 0.5)
651 return((double)nfiles);
652 fn = d - 0.5;
653 if (ltick[fn] != eclock) { /* need to compute? */
654 psize[fn] = 0.0;
655 if (input[fn].vw.type == 0)
656 errno = EDOM;
657 else if (input[fn].vw.type != VT_PAR &&
658 funvalue(vray[6], 1, &d) >= -FTINY) {
659 for (i = 0; i < 3; i++)
660 dir0[i] = funvalue(vray[3+i], 1, &d);
661 pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
662 pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
663 if (viewray(org, dirx, &input[fn].vw,
664 locx[0], locx[1]) >= -FTINY &&
665 viewray(org, diry, &input[fn].vw,
666 locy[0], locy[1]) >= -FTINY) {
667 /* approximate solid angle */
668 for (i = 0; i < 3; i++) {
669 dirx[i] -= dir0[i];
670 diry[i] -= dir0[i];
671 }
672 fcross(dir0, dirx, diry);
673 psize[fn] = VLEN(dir0);
674 }
675 }
676 ltick[fn] = eclock;
677 }
678 return(psize[fn]);
679 }
680
681
682 extern void
683 wputs(char *msg)
684 {
685 if (!nowarn)
686 eputs(msg);
687 }
688
689
690 extern void
691 eputs(char *msg)
692 {
693 fputs(msg, stderr);
694 }
695
696
697 extern void
698 quit(int code) /* exit gracefully */
699 {
700 int i;
701 /* close input files */
702 for (i = 0; i < nfiles; i++)
703 if (input[i].name == Command)
704 pclose(input[i].fp);
705 else
706 fclose(input[i].fp);
707 exit(code);
708 }
