root/radiance/ray/src/px/pcomb.c
Revision: 2.39
Committed: Fri Sep 8 21:38:25 2006 UTC (18 years, 8 months ago) by greg
Changes since 2.38: +19 -10 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.39 static const char RCSid[] = "$Id: pcomb.c,v 2.38 2005/05/25 04:44:25 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Combine picture files according to calcomp functions.
6     *
7     * 1/4/89
8     */
9
10 greg 2.28 #include "platform.h"
11 greg 2.33 #include "standard.h"
12 schorsch 2.29 #include "rtprocess.h"
13 greg 1.1 #include "color.h"
14     #include "calcomp.h"
15 greg 2.10 #include "view.h"
16
17 greg 2.38 #define MAXINP 512 /* maximum number of input files */
18 greg 2.22 #define WINSIZ 64 /* scanline window size */
19 greg 2.13 #define MIDSCN ((WINSIZ-1)/2+1)
20 greg 1.1
21     struct {
22 greg 1.19 char *name; /* file or command name */
23 greg 1.1 FILE *fp; /* stream pointer */
24 greg 2.10 VIEW vw; /* view for picture */
25     RESOLU rs; /* image resolution and orientation */
26 greg 2.17 float pa; /* pixel aspect ratio */
27 greg 1.14 COLOR *scan[WINSIZ]; /* input scanline window */
28 greg 1.3 COLOR coef; /* coefficient */
29 greg 1.17 COLOR expos; /* recorded exposure */
30 greg 1.1 } input[MAXINP]; /* input pictures */
31
32     int nfiles; /* number of input files */
33
34 greg 2.16 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
35
36 greg 2.31 char StandardInput[] = "<stdin>";
37 greg 2.6 char Command[] = "<Command>";
38 greg 1.21 char vcolin[3][4] = {"ri", "gi", "bi"};
39     char vcolout[3][4] = {"ro", "go", "bo"};
40 greg 1.15 char vbrtin[] = "li";
41     char vbrtout[] = "lo";
42 greg 1.21 char vcolexp[3][4] = {"re", "ge", "be"};
43 greg 1.17 char vbrtexp[] = "le";
44 greg 2.18 char vpixaspect[] = "pa";
45 greg 1.1
46 greg 2.18 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
47 greg 2.10
48 greg 2.17 char vpsize[] = "S";
49
50 greg 1.18 char vnfiles[] = "nfiles";
51 greg 2.18 char vwhteff[] = "WE";
52 greg 1.18 char vxmax[] = "xmax";
53     char vymax[] = "ymax";
54     char vxres[] = "xres";
55     char vyres[] = "yres";
56     char vxpos[] = "x";
57     char vypos[] = "y";
58 greg 1.1
59     int nowarn = 0; /* no warning messages? */
60
61 greg 1.18 int xmax = 0, ymax = 0; /* input resolution */
62 greg 1.9
63 greg 1.18 int xscan, yscan; /* input position */
64 greg 1.1
65 greg 1.18 int xres, yres; /* output resolution */
66 greg 1.1
67 greg 1.18 int xpos, ypos; /* output position */
68
69 greg 2.10 char *progname; /* global argv[0] */
70
71 greg 2.39 int echoheader = 1;
72 greg 1.10 int wrongformat = 0;
73 greg 2.10 int gotview;
74 greg 1.1
75 greg 1.10
76 greg 2.39 static gethfunc headline;
77 schorsch 2.32 static void checkfile(void);
78     static double rgb_bright(COLOR clr);
79     static double xyz_bright(COLOR clr);
80     static void init(void);
81     static void combine(void);
82     static void advance(void);
83     static double l_expos(char *nam);
84     static double l_pixaspect(char *nm);
85     static double l_colin(char *nam);
86     static double l_ray(char *nam);
87     static double l_psize(char *nm);
88
89
90     int
91     main(
92     int argc,
93     char *argv[]
94     )
95 greg 1.1 {
96 greg 1.18 int original;
97 greg 1.3 double f;
98 schorsch 2.32 int a;
99 schorsch 2.23 SET_DEFAULT_BINARY();
100     SET_FILE_BINARY(stdin);
101     SET_FILE_BINARY(stdout);
102 greg 2.10 progname = argv[0];
103 greg 1.15 /* scan options */
104     for (a = 1; a < argc; a++) {
105 greg 1.1 if (argv[a][0] == '-')
106     switch (argv[a][1]) {
107     case 'x':
108     case 'y':
109 greg 1.18 a++;
110 greg 1.15 continue;
111 greg 1.1 case 'w':
112     nowarn = !nowarn;
113 greg 1.15 continue;
114 greg 2.39 case 'h':
115     echoheader = !echoheader;
116     continue;
117 greg 1.1 case 'f':
118     case 'e':
119 greg 1.16 a++;
120 greg 1.15 continue;
121 greg 1.1 }
122 greg 1.15 break;
123     }
124 greg 2.14 newheader("RADIANCE", stdout); /* start header */
125 greg 2.22 fputnow(stdout);
126 greg 1.15 /* process files */
127 greg 1.17 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
128 greg 1.3 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
129 greg 1.17 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
130 schorsch 2.26 input[nfiles].vw = stdview;
131 greg 2.17 input[nfiles].pa = 1.0;
132 greg 1.17 }
133 greg 1.1 nfiles = 0;
134 greg 1.18 original = 0;
135 greg 1.1 for ( ; a < argc; a++) {
136     if (nfiles >= MAXINP) {
137     eputs(argv[0]);
138     eputs(": too many picture files\n");
139     quit(1);
140     }
141 greg 1.3 if (argv[a][0] == '-')
142     switch (argv[a][1]) {
143     case '\0':
144 greg 2.31 input[nfiles].name = StandardInput;
145 greg 1.3 input[nfiles].fp = stdin;
146     break;
147 greg 1.17 case 'o':
148     original++;
149 greg 1.22 continue;
150 greg 1.3 case 's':
151     f = atof(argv[++a]);
152     scalecolor(input[nfiles].coef, f);
153     continue;
154     case 'c':
155     colval(input[nfiles].coef,RED)*=atof(argv[++a]);
156     colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
157     colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
158     continue;
159     default:
160     goto usage;
161     }
162     else {
163 greg 2.2 if (argv[a][0] == '!') {
164 greg 2.6 input[nfiles].name = Command;
165 greg 2.2 input[nfiles].fp = popen(argv[a]+1, "r");
166     } else {
167     input[nfiles].name = argv[a];
168     input[nfiles].fp = fopen(argv[a], "r");
169     }
170 greg 1.1 if (input[nfiles].fp == NULL) {
171 greg 1.6 perror(argv[a]);
172 greg 1.1 quit(1);
173     }
174     }
175 greg 1.16 checkfile();
176 greg 1.18 if (original) {
177     colval(input[nfiles].coef,RED) /=
178     colval(input[nfiles].expos,RED);
179     colval(input[nfiles].coef,GRN) /=
180     colval(input[nfiles].expos,GRN);
181     colval(input[nfiles].coef,BLU) /=
182     colval(input[nfiles].expos,BLU);
183 greg 2.22 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
184 greg 1.18 }
185     nfiles++;
186 greg 1.17 original = 0;
187 greg 1.15 }
188 greg 1.18 init(); /* set constants */
189 greg 1.15 /* go back and get expressions */
190     for (a = 1; a < argc; a++) {
191     if (argv[a][0] == '-')
192     switch (argv[a][1]) {
193     case 'x':
194 greg 1.21 varset(vxres, ':', eval(argv[++a]));
195 greg 1.18 continue;
196 greg 1.15 case 'y':
197 greg 1.21 varset(vyres, ':', eval(argv[++a]));
198 greg 1.16 continue;
199 greg 1.15 case 'w':
200     continue;
201     case 'f':
202     fcompile(argv[++a]);
203     continue;
204     case 'e':
205     scompile(argv[++a], NULL, 0);
206     continue;
207     }
208     break;
209     }
210 greg 1.18 /* set/get output resolution */
211     if (!vardefined(vxres))
212     varset(vxres, ':', (double)xmax);
213     if (!vardefined(vyres))
214     varset(vyres, ':', (double)ymax);
215     xres = varvalue(vxres) + .5;
216     yres = varvalue(vyres) + .5;
217     if (xres <= 0 || yres <= 0) {
218     eputs(argv[0]);
219     eputs(": illegal output resolution\n");
220     quit(1);
221     }
222 greg 1.15 /* complete header */
223     printargs(argc, argv, stdout);
224 greg 2.16 if (strcmp(ourfmt, PICFMT))
225     fputformat(ourfmt, stdout); /* print format if known */
226 greg 1.15 putchar('\n');
227 greg 1.23 fprtresolu(xres, yres, stdout);
228 greg 1.15 /* combine pictures */
229     combine();
230     quit(0);
231     usage:
232     eputs("Usage: ");
233     eputs(argv[0]);
234     eputs(
235 greg 2.39 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] pic ..]\n");
236 greg 1.15 quit(1);
237 schorsch 2.32 return 1; /* pro forma return */
238 greg 1.15 }
239
240
241 schorsch 2.30 static int
242 greg 2.39 headline( /* check header line & echo if requested */
243 schorsch 2.30 char *s,
244     void *p
245     )
246 greg 1.15 {
247     char fmt[32];
248     double d;
249     COLOR ctmp;
250
251 greg 2.14 if (isheadid(s)) /* header id */
252 gwlarson 2.21 return(0); /* don't echo */
253 greg 2.14 if (formatval(fmt, s)) { /* check format */
254 greg 2.16 if (globmatch(ourfmt, fmt)) {
255     wrongformat = 0;
256     strcpy(ourfmt, fmt);
257     } else
258 greg 2.22 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
259 gwlarson 2.21 return(0); /* don't echo */
260 greg 1.17 }
261     if (isexpos(s)) { /* exposure */
262     d = exposval(s);
263     scalecolor(input[nfiles].expos, d);
264     } else if (iscolcor(s)) { /* color correction */
265 greg 1.15 colcorval(ctmp, s);
266 greg 1.17 multcolor(input[nfiles].expos, ctmp);
267 greg 2.18 } else if (isaspect(s))
268 greg 2.17 input[nfiles].pa *= aspectval(s);
269 greg 2.18 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
270 greg 2.10 gotview++;
271 greg 2.39
272     if (echoheader) { /* echo line */
273     putchar('\t');
274     return(fputs(s, stdout));
275     }
276     return(0);
277 greg 1.16 }
278 greg 1.15
279 greg 1.16
280 schorsch 2.32 static void
281     checkfile(void) /* ready a file */
282 greg 1.16 {
283     register int i;
284     /* process header */
285 greg 2.10 gotview = 0;
286 greg 2.39 if (echoheader) {
287     fputs(input[nfiles].name, stdout);
288     fputs(":\n", stdout);
289     }
290     getheader(input[nfiles].fp, headline, NULL);
291 greg 2.22 if (wrongformat < 0) {
292 greg 1.16 eputs(input[nfiles].name);
293 greg 2.22 eputs(": not a Radiance picture\n");
294 greg 1.16 quit(1);
295     }
296 greg 2.22 if (wrongformat > 0) {
297     wputs(input[nfiles].name);
298     wputs(": warning -- incompatible picture format\n");
299     }
300 greg 2.10 if (!gotview || setview(&input[nfiles].vw) != NULL)
301     input[nfiles].vw.type = 0;
302     if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
303 greg 1.16 eputs(input[nfiles].name);
304     eputs(": bad picture size\n");
305     quit(1);
306     }
307 greg 1.18 if (xmax == 0 && ymax == 0) {
308 greg 2.10 xmax = scanlen(&input[nfiles].rs);
309     ymax = numscans(&input[nfiles].rs);
310     } else if (scanlen(&input[nfiles].rs) != xmax ||
311     numscans(&input[nfiles].rs) != ymax) {
312 greg 1.16 eputs(input[nfiles].name);
313     eputs(": resolution mismatch\n");
314     quit(1);
315     }
316     /* allocate scanlines */
317     for (i = 0; i < WINSIZ; i++)
318 greg 1.18 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
319 greg 1.15 }
320
321
322 schorsch 2.32 static double
323     rgb_bright(
324     COLOR clr
325     )
326 greg 2.16 {
327     return(bright(clr));
328     }
329
330
331 schorsch 2.32 static double
332     xyz_bright(
333     COLOR clr
334     )
335 greg 2.16 {
336     return(clr[CIEY]);
337     }
338
339
340     double (*ourbright)() = rgb_bright;
341
342
343 schorsch 2.32 static void
344     init(void) /* perform final setup */
345 greg 1.15 {
346 greg 1.16 register int i;
347 greg 1.15 /* define constants */
348 greg 2.19 varset("PI", ':', PI);
349 greg 1.15 varset(vnfiles, ':', (double)nfiles);
350 greg 1.18 varset(vxmax, ':', (double)xmax);
351     varset(vymax, ':', (double)ymax);
352 greg 1.15 /* set functions */
353     for (i = 0; i < 3; i++) {
354 greg 1.17 funset(vcolexp[i], 1, ':', l_expos);
355 greg 1.15 funset(vcolin[i], 1, '=', l_colin);
356     }
357 greg 1.17 funset(vbrtexp, 1, ':', l_expos);
358 greg 1.15 funset(vbrtin, 1, '=', l_colin);
359 greg 2.18 funset(vpixaspect, 1, ':', l_pixaspect);
360     for (i = 0; i < 7; i++)
361 greg 2.10 funset(vray[i], 1, '=', l_ray);
362 greg 2.17 funset(vpsize, 1, '=', l_psize);
363 greg 2.16 /* set brightness function */
364 greg 2.18 if (!strcmp(ourfmt, CIEFMT)) {
365     varset(vwhteff, ':', 1.0);
366 greg 2.16 ourbright = xyz_bright;
367 greg 2.18 } else
368     varset(vwhteff, ':', WHTEFFICACY);
369 greg 1.1 }
370
371
372 schorsch 2.32 static void
373     combine(void) /* combine pictures */
374 greg 1.1 {
375 greg 1.8 EPNODE *coldef[3], *brtdef;
376 greg 1.1 COLOR *scanout;
377 greg 1.8 double d;
378 greg 1.1 register int i, j;
379     /* check defined variables */
380 greg 1.4 for (j = 0; j < 3; j++) {
381     if (vardefined(vcolout[j]))
382     coldef[j] = eparse(vcolout[j]);
383     else
384     coldef[j] = NULL;
385     }
386 greg 1.8 if (vardefined(vbrtout))
387     brtdef = eparse(vbrtout);
388     else
389     brtdef = NULL;
390 greg 1.1 /* allocate scanline */
391     scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
392 greg 1.18 /* set input position */
393     yscan = ymax+MIDSCN;
394 greg 1.1 /* combine files */
395     for (ypos = yres-1; ypos >= 0; ypos--) {
396 greg 1.14 advance();
397 greg 1.11 varset(vypos, '=', (double)ypos);
398 greg 1.8 for (xpos = 0; xpos < xres; xpos++) {
399 greg 1.18 xscan = (long)xpos*xmax/xres;
400 greg 1.11 varset(vxpos, '=', (double)xpos);
401 greg 1.8 eclock++;
402     if (brtdef != NULL) {
403     d = evalue(brtdef);
404     if (d < 0.0)
405     d = 0.0;
406     setcolor(scanout[xpos], d, d, d);
407     } else {
408     for (j = 0; j < 3; j++) {
409     if (coldef[j] != NULL) {
410 greg 1.13 d = evalue(coldef[j]);
411 greg 1.8 } else {
412 greg 1.13 d = 0.0;
413 greg 1.8 for (i = 0; i < nfiles; i++)
414 greg 1.18 d += colval(input[i].scan[MIDSCN][xscan],j);
415 greg 1.1 }
416 greg 1.13 if (d < 0.0)
417     d = 0.0;
418     colval(scanout[xpos],j) = d;
419 greg 1.8 }
420 greg 1.1 }
421 greg 1.8 }
422     if (fwritescan(scanout, xres, stdout) < 0) {
423     perror("write error");
424     quit(1);
425     }
426 greg 1.1 }
427 greg 2.22 efree((char *)scanout);
428 greg 1.1 }
429
430
431 schorsch 2.32 static void
432     advance(void) /* read in data for next scanline */
433 greg 1.14 {
434 greg 1.18 int ytarget;
435 greg 1.14 register COLOR *st;
436     register int i, j;
437
438 greg 1.18 for (ytarget = (long)ypos*ymax/yres; yscan > ytarget; yscan--)
439     for (i = 0; i < nfiles; i++) {
440     st = input[i].scan[WINSIZ-1];
441     for (j = WINSIZ-1; j > 0; j--) /* rotate window */
442     input[i].scan[j] = input[i].scan[j-1];
443     input[i].scan[0] = st;
444     if (yscan <= MIDSCN) /* hit bottom? */
445     continue;
446 greg 2.4 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
447 greg 1.18 eputs(input[i].name);
448     eputs(": read error\n");
449     quit(1);
450     }
451 greg 2.37 for (j = 0; j < xmax; j++) /* adjust color */
452     multcolor(st[j], input[i].coef);
453 greg 1.14 }
454     }
455
456
457 schorsch 2.32 static double
458     l_expos( /* return picture exposure */
459     register char *nam
460     )
461 greg 1.1 {
462 greg 1.15 register int fn, n;
463 greg 1.14
464 greg 1.18 fn = argument(1) - .5;
465     if (fn < 0 || fn >= nfiles)
466     return(1.0);
467 greg 1.17 if (nam == vbrtexp)
468 greg 2.16 return((*ourbright)(input[fn].expos));
469 greg 1.15 n = 3;
470     while (n--)
471 greg 1.17 if (nam == vcolexp[n])
472     return(colval(input[fn].expos,n));
473     eputs("Bad call to l_expos()!\n");
474 greg 1.15 quit(1);
475 schorsch 2.32 return 1; /* pro forma return */
476 greg 1.15 }
477
478
479 schorsch 2.32 static double
480 greg 2.27 l_pixaspect(char *nm) /* return pixel aspect ratio */
481 greg 2.18 {
482     register int fn;
483
484     fn = argument(1) - .5;
485     if (fn < 0 || fn >= nfiles)
486     return(1.0);
487     return(input[fn].pa);
488     }
489
490
491 schorsch 2.32 static double
492     l_colin( /* return color value for picture */
493     register char *nam
494     )
495 greg 1.15 {
496     int fn;
497     register int n, xoff, yoff;
498     double d;
499
500 greg 2.18 fn = argument(1) - .5;
501 greg 1.16 if (fn < 0 || fn >= nfiles) {
502 greg 1.15 errno = EDOM;
503     return(0.0);
504     }
505 greg 1.14 xoff = yoff = 0;
506     n = nargum();
507     if (n >= 2) {
508     d = argument(2);
509     if (d < 0.0) {
510     xoff = d-.5;
511 greg 1.18 if (xscan+xoff < 0)
512     xoff = -xscan;
513 greg 1.14 } else {
514     xoff = d+.5;
515 greg 1.18 if (xscan+xoff >= xmax)
516     xoff = xmax-1-xscan;
517 greg 1.14 }
518     }
519     if (n >= 3) {
520     d = argument(3);
521     if (d < 0.0) {
522     yoff = d-.5;
523     if (yoff+MIDSCN < 0)
524     yoff = -MIDSCN;
525 greg 1.18 if (yscan+yoff < 0)
526     yoff = -yscan;
527 greg 1.14 } else {
528     yoff = d+.5;
529     if (yoff+MIDSCN >= WINSIZ)
530     yoff = WINSIZ-1-MIDSCN;
531 greg 1.18 if (yscan+yoff >= ymax)
532     yoff = ymax-1-yscan;
533 greg 1.14 }
534     }
535 greg 1.15 if (nam == vbrtin)
536 greg 2.16 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
537 greg 1.15 n = 3;
538     while (n--)
539     if (nam == vcolin[n])
540 greg 1.18 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
541 greg 1.15 eputs("Bad call to l_colin()!\n");
542 greg 2.10 quit(1);
543 schorsch 2.32 return 1; /* pro forma return */
544 greg 2.10 }
545
546
547 schorsch 2.32 static double
548     l_ray( /* return ray origin or direction */
549     register char *nam
550     )
551 greg 2.10 {
552 greg 2.15 static unsigned long ltick[MAXINP];
553 greg 2.10 static FVECT lorg[MAXINP], ldir[MAXINP];
554 greg 2.18 static double ldist[MAXINP];
555 schorsch 2.25 RREAL loc[2];
556 greg 2.10 int fn;
557     register int i;
558
559 greg 2.18 fn = argument(1) - .5;
560 greg 2.10 if (fn < 0 || fn >= nfiles) {
561     errno = EDOM;
562     return(0.0);
563     }
564 greg 2.22 if (ltick[fn] != eclock) { /* need to compute? */
565 greg 2.10 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
566     ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
567 greg 2.20 ldist[fn] = -1.0;
568 greg 2.10 if (input[fn].vw.type == 0)
569 greg 2.12 errno = EDOM;
570 greg 2.10 else {
571 greg 2.11 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
572 greg 2.18 ldist[fn] = viewray(lorg[fn], ldir[fn],
573     &input[fn].vw, loc[0], loc[1]);
574 greg 2.10 }
575 greg 2.18 ltick[fn] = eclock;
576 greg 2.10 }
577 greg 2.18 if (nam == vray[i=6])
578     return(ldist[fn]);
579 greg 2.10 while (i--)
580     if (nam == vray[i])
581     return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
582     eputs("Bad call to l_ray()!\n");
583 greg 1.15 quit(1);
584 schorsch 2.32 return 1; /* pro forma return */
585 greg 2.17 }
586
587
588 schorsch 2.32 static double
589 greg 2.27 l_psize(char *nm) /* compute pixel size in steradians */
590 greg 2.17 {
591     static unsigned long ltick[MAXINP];
592     static double psize[MAXINP];
593 greg 2.18 FVECT dir0, org, dirx, diry;
594 schorsch 2.25 RREAL locx[2], locy[2];
595 greg 2.17 double d;
596     int fn;
597 greg 2.18 register int i;
598 greg 2.17
599     d = argument(1);
600 greg 2.18 if (d < .5 || d >= nfiles+.5) {
601 greg 2.17 errno = EDOM;
602     return(0.0);
603     }
604 greg 2.18 fn = d - .5;
605 greg 2.22 if (ltick[fn] != eclock) { /* need to compute? */
606 greg 2.18 psize[fn] = 0.0;
607     if (input[fn].vw.type == 0)
608 greg 2.17 errno = EDOM;
609 greg 2.18 else if (input[fn].vw.type != VT_PAR &&
610 greg 2.36 funvalue(vray[6], 1, &d) >= -FTINY) {
611 greg 2.18 for (i = 0; i < 3; i++)
612     dir0[i] = funvalue(vray[3+i], 1, &d);
613     pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
614     pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
615     if (viewray(org, dirx, &input[fn].vw,
616 greg 2.35 locx[0], locx[1]) >= -FTINY &&
617 greg 2.18 viewray(org, diry, &input[fn].vw,
618 greg 2.35 locy[0], locy[1]) >= -FTINY) {
619 greg 2.17 /* approximate solid angle */
620 greg 2.18 for (i = 0; i < 3; i++) {
621     dirx[i] -= dir0[i];
622     diry[i] -= dir0[i];
623     }
624     fcross(dir0, dirx, diry);
625 greg 2.35 psize[fn] = VLEN(dir0);
626 greg 2.17 }
627     }
628 greg 2.18 ltick[fn] = eclock;
629     }
630 greg 2.17 return(psize[fn]);
631 greg 1.1 }
632
633
634 schorsch 2.29 extern void
635     wputs(char *msg)
636 greg 1.1 {
637     if (!nowarn)
638     eputs(msg);
639     }
640
641
642 schorsch 2.29 extern void
643     eputs(char *msg)
644 greg 1.1 {
645     fputs(msg, stderr);
646     }
647
648
649 schorsch 2.29 extern void
650     quit(int code) /* exit gracefully */
651 greg 2.4 {
652 greg 2.5 register int i;
653     /* close input files */
654     for (i = 0; i < nfiles; i++)
655 greg 2.6 if (input[i].name == Command)
656     pclose(input[i].fp);
657     else
658     fclose(input[i].fp);
659 greg 1.1 exit(code);
660     }
