root/radiance/ray/src/px/pcomb.c
Revision: 2.44
Committed: Mon Aug 10 04:26:38 2009 UTC (15 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0, rad4R2, rad4R1, rad4R0, rad4R2P1
Upped limit on open files to 1024
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.44 static const char RCSid[] = "$Id: pcomb.c,v 2.43 2008/11/10 19:08:19 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * Combine picture files according to calcomp functions.
6     *
7     * 1/4/89
8     */
9
10 greg 2.28 #include "platform.h"
11 greg 2.33 #include "standard.h"
12 schorsch 2.29 #include "rtprocess.h"
13 greg 1.1 #include "color.h"
14     #include "calcomp.h"
15 greg 2.10 #include "view.h"
16
17 greg 2.44 #define MAXINP 1024 /* maximum number of input files */
18 greg 2.22 #define WINSIZ 64 /* scanline window size */
19 greg 2.13 #define MIDSCN ((WINSIZ-1)/2+1)
20 greg 1.1
21     struct {
22 greg 1.19 char *name; /* file or command name */
23 greg 1.1 FILE *fp; /* stream pointer */
24 greg 2.10 VIEW vw; /* view for picture */
25     RESOLU rs; /* image resolution and orientation */
26 greg 2.17 float pa; /* pixel aspect ratio */
27 greg 1.14 COLOR *scan[WINSIZ]; /* input scanline window */
28 greg 1.3 COLOR coef; /* coefficient */
29 greg 1.17 COLOR expos; /* recorded exposure */
30 greg 1.1 } input[MAXINP]; /* input pictures */
31
32     int nfiles; /* number of input files */
33
34 greg 2.16 char ourfmt[LPICFMT+1] = PICFMT; /* input picture format */
35
36 greg 2.31 char StandardInput[] = "<stdin>";
37 greg 2.6 char Command[] = "<Command>";
38 greg 1.21 char vcolin[3][4] = {"ri", "gi", "bi"};
39     char vcolout[3][4] = {"ro", "go", "bo"};
40 greg 1.15 char vbrtin[] = "li";
41     char vbrtout[] = "lo";
42 greg 1.21 char vcolexp[3][4] = {"re", "ge", "be"};
43 greg 1.17 char vbrtexp[] = "le";
44 greg 2.18 char vpixaspect[] = "pa";
45 greg 1.1
46 greg 2.18 char vray[7][4] = {"Ox", "Oy", "Oz", "Dx", "Dy", "Dz", "T"};
47 greg 2.10
48 greg 2.17 char vpsize[] = "S";
49
50 greg 1.18 char vnfiles[] = "nfiles";
51 greg 2.18 char vwhteff[] = "WE";
52 greg 1.18 char vxmax[] = "xmax";
53     char vymax[] = "ymax";
54     char vxres[] = "xres";
55     char vyres[] = "yres";
56     char vxpos[] = "x";
57     char vypos[] = "y";
58 greg 1.1
59     int nowarn = 0; /* no warning messages? */
60
61 greg 1.18 int xmax = 0, ymax = 0; /* input resolution */
62 greg 1.9
63 greg 1.18 int xscan, yscan; /* input position */
64 greg 1.1
65 greg 1.18 int xres, yres; /* output resolution */
66 greg 1.1
67 greg 1.18 int xpos, ypos; /* output position */
68
69 greg 2.10 char *progname; /* global argv[0] */
70
71 greg 2.39 int echoheader = 1;
72 greg 1.10 int wrongformat = 0;
73 greg 2.10 int gotview;
74 greg 1.1
75 greg 1.10
76 greg 2.39 static gethfunc headline;
77 schorsch 2.32 static void checkfile(void);
78     static double rgb_bright(COLOR clr);
79     static double xyz_bright(COLOR clr);
80     static void init(void);
81     static void combine(void);
82     static void advance(void);
83     static double l_expos(char *nam);
84     static double l_pixaspect(char *nm);
85     static double l_colin(char *nam);
86     static double l_ray(char *nam);
87     static double l_psize(char *nm);
88
89
90     int
91     main(
92     int argc,
93     char *argv[]
94     )
95 greg 1.1 {
96 greg 1.18 int original;
97 greg 1.3 double f;
98 schorsch 2.32 int a;
99 schorsch 2.23 SET_DEFAULT_BINARY();
100     SET_FILE_BINARY(stdin);
101     SET_FILE_BINARY(stdout);
102 greg 2.10 progname = argv[0];
103 greg 1.15 /* scan options */
104     for (a = 1; a < argc; a++) {
105 greg 1.1 if (argv[a][0] == '-')
106     switch (argv[a][1]) {
107     case 'x':
108     case 'y':
109 greg 1.18 a++;
110 greg 1.15 continue;
111 greg 1.1 case 'w':
112     nowarn = !nowarn;
113 greg 1.15 continue;
114 greg 2.39 case 'h':
115     echoheader = !echoheader;
116     continue;
117 greg 1.1 case 'f':
118     case 'e':
119 greg 1.16 a++;
120 greg 1.15 continue;
121 greg 1.1 }
122 greg 1.15 break;
123     }
124 greg 2.14 newheader("RADIANCE", stdout); /* start header */
125 greg 2.22 fputnow(stdout);
126 greg 1.15 /* process files */
127 greg 1.17 for (nfiles = 0; nfiles < MAXINP; nfiles++) {
128 greg 1.3 setcolor(input[nfiles].coef, 1.0, 1.0, 1.0);
129 greg 1.17 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
130 schorsch 2.26 input[nfiles].vw = stdview;
131 greg 2.17 input[nfiles].pa = 1.0;
132 greg 1.17 }
133 greg 1.1 nfiles = 0;
134 greg 1.18 original = 0;
135 greg 1.1 for ( ; a < argc; a++) {
136     if (nfiles >= MAXINP) {
137     eputs(argv[0]);
138     eputs(": too many picture files\n");
139     quit(1);
140     }
141 greg 1.3 if (argv[a][0] == '-')
142     switch (argv[a][1]) {
143     case '\0':
144 greg 2.31 input[nfiles].name = StandardInput;
145 greg 1.3 input[nfiles].fp = stdin;
146     break;
147 greg 1.17 case 'o':
148     original++;
149 greg 1.22 continue;
150 greg 1.3 case 's':
151     f = atof(argv[++a]);
152     scalecolor(input[nfiles].coef, f);
153     continue;
154     case 'c':
155     colval(input[nfiles].coef,RED)*=atof(argv[++a]);
156     colval(input[nfiles].coef,GRN)*=atof(argv[++a]);
157     colval(input[nfiles].coef,BLU)*=atof(argv[++a]);
158     continue;
159     default:
160     goto usage;
161     }
162     else {
163 greg 2.2 if (argv[a][0] == '!') {
164 greg 2.6 input[nfiles].name = Command;
165 greg 2.2 input[nfiles].fp = popen(argv[a]+1, "r");
166     } else {
167     input[nfiles].name = argv[a];
168     input[nfiles].fp = fopen(argv[a], "r");
169     }
170 greg 1.1 if (input[nfiles].fp == NULL) {
171 greg 1.6 perror(argv[a]);
172 greg 1.1 quit(1);
173     }
174     }
175 greg 1.16 checkfile();
176 greg 1.18 if (original) {
177     colval(input[nfiles].coef,RED) /=
178     colval(input[nfiles].expos,RED);
179     colval(input[nfiles].coef,GRN) /=
180     colval(input[nfiles].expos,GRN);
181     colval(input[nfiles].coef,BLU) /=
182     colval(input[nfiles].expos,BLU);
183 greg 2.22 setcolor(input[nfiles].expos, 1.0, 1.0, 1.0);
184 greg 1.18 }
185     nfiles++;
186 greg 1.17 original = 0;
187 greg 1.15 }
188 greg 1.18 init(); /* set constants */
189 greg 1.15 /* go back and get expressions */
190     for (a = 1; a < argc; a++) {
191     if (argv[a][0] == '-')
192     switch (argv[a][1]) {
193     case 'x':
194 greg 1.21 varset(vxres, ':', eval(argv[++a]));
195 greg 1.18 continue;
196 greg 1.15 case 'y':
197 greg 1.21 varset(vyres, ':', eval(argv[++a]));
198 greg 1.16 continue;
199 greg 1.15 case 'w':
200     continue;
201 greg 2.40 case 'h':
202     continue;
203 greg 1.15 case 'f':
204     fcompile(argv[++a]);
205     continue;
206     case 'e':
207     scompile(argv[++a], NULL, 0);
208     continue;
209     }
210     break;
211     }
212 greg 1.18 /* set/get output resolution */
213     if (!vardefined(vxres))
214     varset(vxres, ':', (double)xmax);
215     if (!vardefined(vyres))
216     varset(vyres, ':', (double)ymax);
217     xres = varvalue(vxres) + .5;
218     yres = varvalue(vyres) + .5;
219     if (xres <= 0 || yres <= 0) {
220     eputs(argv[0]);
221     eputs(": illegal output resolution\n");
222     quit(1);
223     }
224 greg 1.15 /* complete header */
225     printargs(argc, argv, stdout);
226 greg 2.16 if (strcmp(ourfmt, PICFMT))
227     fputformat(ourfmt, stdout); /* print format if known */
228 greg 1.15 putchar('\n');
229 greg 1.23 fprtresolu(xres, yres, stdout);
230 greg 1.15 /* combine pictures */
231     combine();
232     quit(0);
233     usage:
234     eputs("Usage: ");
235     eputs(argv[0]);
236     eputs(
237 greg 2.43 " [-w][-h][-x xr][-y yr][-e expr][-f file] [ [-o][-s f][-c r g b] hdr ..]\n");
238 greg 1.15 quit(1);
239 schorsch 2.32 return 1; /* pro forma return */
240 greg 1.15 }
241
242
243 schorsch 2.30 static int
244 greg 2.39 headline( /* check header line & echo if requested */
245 schorsch 2.30 char *s,
246     void *p
247     )
248 greg 1.15 {
249     char fmt[32];
250     double d;
251     COLOR ctmp;
252
253 greg 2.14 if (isheadid(s)) /* header id */
254 gwlarson 2.21 return(0); /* don't echo */
255 greg 2.14 if (formatval(fmt, s)) { /* check format */
256 greg 2.16 if (globmatch(ourfmt, fmt)) {
257     wrongformat = 0;
258     strcpy(ourfmt, fmt);
259     } else
260 greg 2.22 wrongformat = globmatch(PICFMT, fmt) ? 1 : -1;
261 gwlarson 2.21 return(0); /* don't echo */
262 greg 1.17 }
263     if (isexpos(s)) { /* exposure */
264     d = exposval(s);
265     scalecolor(input[nfiles].expos, d);
266     } else if (iscolcor(s)) { /* color correction */
267 greg 1.15 colcorval(ctmp, s);
268 greg 1.17 multcolor(input[nfiles].expos, ctmp);
269 greg 2.18 } else if (isaspect(s))
270 greg 2.17 input[nfiles].pa *= aspectval(s);
271 greg 2.18 else if (isview(s) && sscanview(&input[nfiles].vw, s) > 0)
272 greg 2.10 gotview++;
273 greg 2.39
274     if (echoheader) { /* echo line */
275     putchar('\t');
276     return(fputs(s, stdout));
277     }
278     return(0);
279 greg 1.16 }
280 greg 1.15
281 greg 1.16
282 schorsch 2.32 static void
283     checkfile(void) /* ready a file */
284 greg 1.16 {
285     register int i;
286     /* process header */
287 greg 2.10 gotview = 0;
288 greg 2.39 if (echoheader) {
289     fputs(input[nfiles].name, stdout);
290     fputs(":\n", stdout);
291     }
292     getheader(input[nfiles].fp, headline, NULL);
293 greg 2.22 if (wrongformat < 0) {
294 greg 1.16 eputs(input[nfiles].name);
295 greg 2.22 eputs(": not a Radiance picture\n");
296 greg 1.16 quit(1);
297     }
298 greg 2.22 if (wrongformat > 0) {
299     wputs(input[nfiles].name);
300     wputs(": warning -- incompatible picture format\n");
301     }
302 greg 2.10 if (!gotview || setview(&input[nfiles].vw) != NULL)
303     input[nfiles].vw.type = 0;
304     if (!fgetsresolu(&input[nfiles].rs, input[nfiles].fp)) {
305 greg 1.16 eputs(input[nfiles].name);
306     eputs(": bad picture size\n");
307     quit(1);
308     }
309 greg 1.18 if (xmax == 0 && ymax == 0) {
310 greg 2.10 xmax = scanlen(&input[nfiles].rs);
311     ymax = numscans(&input[nfiles].rs);
312     } else if (scanlen(&input[nfiles].rs) != xmax ||
313     numscans(&input[nfiles].rs) != ymax) {
314 greg 1.16 eputs(input[nfiles].name);
315     eputs(": resolution mismatch\n");
316     quit(1);
317     }
318     /* allocate scanlines */
319     for (i = 0; i < WINSIZ; i++)
320 greg 1.18 input[nfiles].scan[i] = (COLOR *)emalloc(xmax*sizeof(COLOR));
321 greg 1.15 }
322
323
324 schorsch 2.32 static double
325     rgb_bright(
326     COLOR clr
327     )
328 greg 2.16 {
329     return(bright(clr));
330     }
331
332
333 schorsch 2.32 static double
334     xyz_bright(
335     COLOR clr
336     )
337 greg 2.16 {
338     return(clr[CIEY]);
339     }
340
341
342     double (*ourbright)() = rgb_bright;
343
344
345 schorsch 2.32 static void
346     init(void) /* perform final setup */
347 greg 1.15 {
348 greg 1.16 register int i;
349 greg 1.15 /* define constants */
350 greg 2.19 varset("PI", ':', PI);
351 greg 1.15 varset(vnfiles, ':', (double)nfiles);
352 greg 1.18 varset(vxmax, ':', (double)xmax);
353     varset(vymax, ':', (double)ymax);
354 greg 1.15 /* set functions */
355     for (i = 0; i < 3; i++) {
356 greg 1.17 funset(vcolexp[i], 1, ':', l_expos);
357 greg 1.15 funset(vcolin[i], 1, '=', l_colin);
358     }
359 greg 1.17 funset(vbrtexp, 1, ':', l_expos);
360 greg 1.15 funset(vbrtin, 1, '=', l_colin);
361 greg 2.18 funset(vpixaspect, 1, ':', l_pixaspect);
362     for (i = 0; i < 7; i++)
363 greg 2.10 funset(vray[i], 1, '=', l_ray);
364 greg 2.17 funset(vpsize, 1, '=', l_psize);
365 greg 2.16 /* set brightness function */
366 greg 2.18 if (!strcmp(ourfmt, CIEFMT)) {
367     varset(vwhteff, ':', 1.0);
368 greg 2.16 ourbright = xyz_bright;
369 greg 2.18 } else
370     varset(vwhteff, ':', WHTEFFICACY);
371 greg 1.1 }
372
373
374 schorsch 2.32 static void
375     combine(void) /* combine pictures */
376 greg 1.1 {
377 greg 1.8 EPNODE *coldef[3], *brtdef;
378 greg 1.1 COLOR *scanout;
379 greg 1.8 double d;
380 greg 1.1 register int i, j;
381     /* check defined variables */
382 greg 1.4 for (j = 0; j < 3; j++) {
383     if (vardefined(vcolout[j]))
384     coldef[j] = eparse(vcolout[j]);
385     else
386     coldef[j] = NULL;
387     }
388 greg 1.8 if (vardefined(vbrtout))
389     brtdef = eparse(vbrtout);
390     else
391     brtdef = NULL;
392 greg 1.1 /* allocate scanline */
393     scanout = (COLOR *)emalloc(xres*sizeof(COLOR));
394 greg 1.18 /* set input position */
395     yscan = ymax+MIDSCN;
396 greg 1.1 /* combine files */
397     for (ypos = yres-1; ypos >= 0; ypos--) {
398 greg 1.14 advance();
399 greg 1.11 varset(vypos, '=', (double)ypos);
400 greg 1.8 for (xpos = 0; xpos < xres; xpos++) {
401 greg 2.42 xscan = (xpos+.5)*xmax/xres;
402 greg 1.11 varset(vxpos, '=', (double)xpos);
403 greg 1.8 eclock++;
404     if (brtdef != NULL) {
405     d = evalue(brtdef);
406     if (d < 0.0)
407     d = 0.0;
408     setcolor(scanout[xpos], d, d, d);
409     } else {
410     for (j = 0; j < 3; j++) {
411     if (coldef[j] != NULL) {
412 greg 1.13 d = evalue(coldef[j]);
413 greg 1.8 } else {
414 greg 1.13 d = 0.0;
415 greg 1.8 for (i = 0; i < nfiles; i++)
416 greg 1.18 d += colval(input[i].scan[MIDSCN][xscan],j);
417 greg 1.1 }
418 greg 1.13 if (d < 0.0)
419     d = 0.0;
420     colval(scanout[xpos],j) = d;
421 greg 1.8 }
422 greg 1.1 }
423 greg 1.8 }
424     if (fwritescan(scanout, xres, stdout) < 0) {
425     perror("write error");
426     quit(1);
427     }
428 greg 1.1 }
429 greg 2.22 efree((char *)scanout);
430 greg 1.1 }
431
432
433 schorsch 2.32 static void
434     advance(void) /* read in data for next scanline */
435 greg 1.14 {
436 greg 1.18 int ytarget;
437 greg 1.14 register COLOR *st;
438     register int i, j;
439
440 greg 2.42 for (ytarget = (ypos+.5)*ymax/yres; yscan > ytarget; yscan--)
441 greg 1.18 for (i = 0; i < nfiles; i++) {
442     st = input[i].scan[WINSIZ-1];
443     for (j = WINSIZ-1; j > 0; j--) /* rotate window */
444     input[i].scan[j] = input[i].scan[j-1];
445     input[i].scan[0] = st;
446     if (yscan <= MIDSCN) /* hit bottom? */
447     continue;
448 greg 2.4 if (freadscan(st, xmax, input[i].fp) < 0) { /* read */
449 greg 1.18 eputs(input[i].name);
450     eputs(": read error\n");
451     quit(1);
452     }
453 greg 2.37 for (j = 0; j < xmax; j++) /* adjust color */
454     multcolor(st[j], input[i].coef);
455 greg 1.14 }
456     }
457
458
459 schorsch 2.32 static double
460     l_expos( /* return picture exposure */
461 greg 2.42 char *nam
462 schorsch 2.32 )
463 greg 1.1 {
464 greg 2.42 int fn, n;
465     double d;
466 greg 1.14
467 greg 2.42 d = argument(1);
468     if (d <= -0.5 || d >= nfiles+0.5) {
469     errno = EDOM;
470     return(0.0);
471     }
472     if (d < 0.5)
473     return((double)nfiles);
474     fn = d - 0.5;
475 greg 1.17 if (nam == vbrtexp)
476 greg 2.16 return((*ourbright)(input[fn].expos));
477 greg 1.15 n = 3;
478     while (n--)
479 greg 1.17 if (nam == vcolexp[n])
480     return(colval(input[fn].expos,n));
481     eputs("Bad call to l_expos()!\n");
482 greg 1.15 quit(1);
483 schorsch 2.32 return 1; /* pro forma return */
484 greg 1.15 }
485
486
487 schorsch 2.32 static double
488 greg 2.27 l_pixaspect(char *nm) /* return pixel aspect ratio */
489 greg 2.18 {
490 greg 2.42 int fn;
491     double d;
492 greg 2.18
493 greg 2.42 d = argument(1);
494     if (d <= -0.5 || d >= nfiles+0.5) {
495     errno = EDOM;
496     return(0.0);
497     }
498     if (d < 0.5)
499     return((double)nfiles);
500     fn = d - 0.5;
501 greg 2.18 return(input[fn].pa);
502     }
503
504
505 schorsch 2.32 static double
506     l_colin( /* return color value for picture */
507     register char *nam
508     )
509 greg 1.15 {
510     int fn;
511     register int n, xoff, yoff;
512     double d;
513
514 greg 2.42 d = argument(1);
515     if (d <= -0.5 || d >= nfiles+0.5) {
516 greg 1.15 errno = EDOM;
517     return(0.0);
518     }
519 greg 2.42 if (d < 0.5)
520     return((double)nfiles);
521     fn = d - 0.5;
522 greg 1.14 xoff = yoff = 0;
523     n = nargum();
524     if (n >= 2) {
525     d = argument(2);
526     if (d < 0.0) {
527     xoff = d-.5;
528 greg 1.18 if (xscan+xoff < 0)
529     xoff = -xscan;
530 greg 1.14 } else {
531     xoff = d+.5;
532 greg 1.18 if (xscan+xoff >= xmax)
533     xoff = xmax-1-xscan;
534 greg 1.14 }
535     }
536     if (n >= 3) {
537     d = argument(3);
538     if (d < 0.0) {
539     yoff = d-.5;
540     if (yoff+MIDSCN < 0)
541     yoff = -MIDSCN;
542 greg 1.18 if (yscan+yoff < 0)
543     yoff = -yscan;
544 greg 1.14 } else {
545     yoff = d+.5;
546     if (yoff+MIDSCN >= WINSIZ)
547     yoff = WINSIZ-1-MIDSCN;
548 greg 1.18 if (yscan+yoff >= ymax)
549     yoff = ymax-1-yscan;
550 greg 1.14 }
551     }
552 greg 1.15 if (nam == vbrtin)
553 greg 2.16 return((*ourbright)(input[fn].scan[MIDSCN+yoff][xscan+xoff]));
554 greg 1.15 n = 3;
555     while (n--)
556     if (nam == vcolin[n])
557 greg 1.18 return(colval(input[fn].scan[MIDSCN+yoff][xscan+xoff],n));
558 greg 1.15 eputs("Bad call to l_colin()!\n");
559 greg 2.10 quit(1);
560 schorsch 2.32 return 1; /* pro forma return */
561 greg 2.10 }
562
563
564 schorsch 2.32 static double
565     l_ray( /* return ray origin or direction */
566     register char *nam
567     )
568 greg 2.10 {
569 greg 2.15 static unsigned long ltick[MAXINP];
570 greg 2.10 static FVECT lorg[MAXINP], ldir[MAXINP];
571 greg 2.18 static double ldist[MAXINP];
572 schorsch 2.25 RREAL loc[2];
573 greg 2.42 double d;
574 greg 2.10 int fn;
575     register int i;
576
577 greg 2.42 d = argument(1);
578     if (d <= -0.5 || d >= nfiles+0.5) {
579 greg 2.10 errno = EDOM;
580     return(0.0);
581     }
582 greg 2.42 if (d < 0.5)
583     return((double)nfiles);
584     fn = d - 0.5;
585 greg 2.22 if (ltick[fn] != eclock) { /* need to compute? */
586 greg 2.10 lorg[fn][0] = lorg[fn][1] = lorg[fn][2] = 0.0;
587     ldir[fn][0] = ldir[fn][1] = ldir[fn][2] = 0.0;
588 greg 2.20 ldist[fn] = -1.0;
589 greg 2.10 if (input[fn].vw.type == 0)
590 greg 2.12 errno = EDOM;
591 greg 2.10 else {
592 greg 2.11 pix2loc(loc, &input[fn].rs, xscan, ymax-1-yscan);
593 greg 2.18 ldist[fn] = viewray(lorg[fn], ldir[fn],
594     &input[fn].vw, loc[0], loc[1]);
595 greg 2.10 }
596 greg 2.18 ltick[fn] = eclock;
597 greg 2.10 }
598 greg 2.18 if (nam == vray[i=6])
599     return(ldist[fn]);
600 greg 2.10 while (i--)
601     if (nam == vray[i])
602     return(i < 3 ? lorg[fn][i] : ldir[fn][i-3]);
603     eputs("Bad call to l_ray()!\n");
604 greg 1.15 quit(1);
605 schorsch 2.32 return 1; /* pro forma return */
606 greg 2.17 }
607
608
609 schorsch 2.32 static double
610 greg 2.27 l_psize(char *nm) /* compute pixel size in steradians */
611 greg 2.17 {
612     static unsigned long ltick[MAXINP];
613     static double psize[MAXINP];
614 greg 2.18 FVECT dir0, org, dirx, diry;
615 schorsch 2.25 RREAL locx[2], locy[2];
616 greg 2.17 double d;
617     int fn;
618 greg 2.18 register int i;
619 greg 2.17
620     d = argument(1);
621 greg 2.42 if (d <= -0.5 || d >= nfiles+0.5) {
622 greg 2.17 errno = EDOM;
623     return(0.0);
624     }
625 greg 2.42 if (d < 0.5)
626     return((double)nfiles);
627     fn = d - 0.5;
628 greg 2.22 if (ltick[fn] != eclock) { /* need to compute? */
629 greg 2.18 psize[fn] = 0.0;
630     if (input[fn].vw.type == 0)
631 greg 2.17 errno = EDOM;
632 greg 2.18 else if (input[fn].vw.type != VT_PAR &&
633 greg 2.36 funvalue(vray[6], 1, &d) >= -FTINY) {
634 greg 2.18 for (i = 0; i < 3; i++)
635     dir0[i] = funvalue(vray[3+i], 1, &d);
636     pix2loc(locx, &input[fn].rs, xscan+1, ymax-1-yscan);
637     pix2loc(locy, &input[fn].rs, xscan, ymax-yscan);
638     if (viewray(org, dirx, &input[fn].vw,
639 greg 2.35 locx[0], locx[1]) >= -FTINY &&
640 greg 2.18 viewray(org, diry, &input[fn].vw,
641 greg 2.35 locy[0], locy[1]) >= -FTINY) {
642 greg 2.17 /* approximate solid angle */
643 greg 2.18 for (i = 0; i < 3; i++) {
644     dirx[i] -= dir0[i];
645     diry[i] -= dir0[i];
646     }
647     fcross(dir0, dirx, diry);
648 greg 2.35 psize[fn] = VLEN(dir0);
649 greg 2.17 }
650     }
651 greg 2.18 ltick[fn] = eclock;
652     }
653 greg 2.17 return(psize[fn]);
654 greg 1.1 }
655
656
657 schorsch 2.29 extern void
658     wputs(char *msg)
659 greg 1.1 {
660     if (!nowarn)
661     eputs(msg);
662     }
663
664
665 schorsch 2.29 extern void
666     eputs(char *msg)
667 greg 1.1 {
668     fputs(msg, stderr);
669     }
670
671
672 schorsch 2.29 extern void
673     quit(int code) /* exit gracefully */
674 greg 2.4 {
675 greg 2.5 register int i;
676     /* close input files */
677     for (i = 0; i < nfiles; i++)
678 greg 2.6 if (input[i].name == Command)
679     pclose(input[i].fp);
680     else
681     fclose(input[i].fp);
682 greg 1.1 exit(code);
683     }
