root/radiance/ray/src/px/panim.c
Revision: 1.5
Committed: Wed Feb 28 11:39:09 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.4: +24 -4 lines
added decompression capability
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Send pictures to PC animation system.
9 *
10 * 6/20/88
11 */
12
13 #include <stdio.h>
14 #include <rasterfile.h>
15
16 #include "random.h"
17 #include "color.h"
18 #include "clntrpc.h"
19 #include "scan.h"
20
21 #define GAMMA 2.0 /* gamma correction factor */
22
23 FILE *popen();
24
25 char *pcom = NULL; /* pipe command */
26
27 BYTE gammamap[256]; /* gamma correction table */
28
29
30 main(argc, argv)
31 int argc;
32 char *argv[];
33 {
34 char *progname;
35 int nframes;
36 int port = PCPROGRAM;
37 /* initialize */
38 compgamma();
39 for (progname = *argv++; --argc; argv++)
40 if (!strcmp(*argv, "-p") && argv[1]) {
41 port = atoi(*++argv); argc--;
42 } else if (!strcmp(*argv, "-u") && argv[1]) {
43 pcom = *++argv; argc--;
44 } else
45 break;
46 if (!argc) {
47 fputs("Usage: ", stderr);
48 fputs(progname, stderr);
49 fputs(" [-p port] [-u uncompress] hostname [-c copies][-r record] [frame] ..\n",
50 stderr);
51 exit(1);
52 }
53 scry_open(*argv++, TCP, port);
54 scry_set_compress(NONE);
55 scry_set_image(TARGA_IMAGE);
56 scry_set_record(PREVIEW);
57 scry_set_copy_num(3);
58 /* send frames */
59 nframes = 0;
60 for ( ; --argc; argv++)
61 if (!strcmp(*argv, "-r") && argv[1]) {
62 scry_set_record(atoi(*++argv)); argc--;
63 } else if (!strcmp(*argv, "-c") && argv[1]) {
64 scry_set_copy_num(atoi(*++argv)); argc--;
65 } else {
66 sendframe(*argv);
67 nframes++;
68 }
69 if (nframes == 0) /* get stdin */
70 sendframe(NULL);
71 /* clean up */
72 scry_close();
73 exit(0);
74 }
75
76
77 sendframe(file) /* convert and send a frame */
78 char *file;
79 {
80 char command[128];
81 COLR scanin[SCANLINE];
82 int xres, yres;
83 int xbeg, ybeg;
84 FILE *fp;
85 int y;
86 register int x;
87 /* open file */
88 if (file == NULL) {
89 if (pcom != NULL)
90 fp = popen(pcom, "r");
91 else
92 fp = stdin;
93 file = "<stdin>";
94 } else {
95 if (pcom != NULL) {
96 sprintf(command, "( %s ) < %s", pcom, file);
97 fp = popen(command, "r");
98 } else
99 fp = fopen(file, "r");
100 }
101 if (fp == NULL) {
102 perror(file);
103 exit(1);
104 }
105 /* get dimensions */
106 getheader(fp, NULL);
107 if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
108 xres > SCANLINE || yres > NUMSCANS) {
109 fputs(file, stderr);
110 fputs(": bad picture size\n", stderr);
111 exit(1);
112 }
113 /* compute center */
114 xbeg = (SCANLINE-xres)/2;
115 ybeg = (NUMSCANS-yres)/2;
116 /* clear output */
117 bzero(sc_frame_arr, sizeof(sc_frame_arr));
118 /* get frame */
119 for (y = yres-1; y >= 0; y--) {
120 if (freadcolrs(scanin, xres, fp) < 0) {
121 fputs(file, stderr);
122 fputs(": read error\n", stderr);
123 exit(1);
124 }
125 normcolrs(scanin, xres, 0); /* normalize */
126 for (x = 0; x < xres; x++) /* convert */
127 sc_frame_arr[y+ybeg][x+xbeg] =
128 ((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
129 | ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
130 | (gammamap[scanin[x][BLU]]+(random()&7))>>3;
131 }
132 /* send frame */
133 scry_send_frame();
134 /* close file */
135 if (pcom != NULL)
136 pclose(fp);
137 else
138 fclose(fp);
139 }
140
141
142 compgamma() /* compute gamma correction map */
143 {
144 extern double pow();
145 register int i, val;
146
147 for (i = 0; i < 256; i++) {
148 val = pow(i/256.0, 1.0/GAMMA) * 256.0;
149 if (val > 248) val = 248;
150 gammamap[i] = val;
151 }
152 }
