root/Development/ray/src/px/panim.c
Revision: 2.6
Committed: Fri Jan 2 10:25:13 2004 UTC (22 years ago) by schorsch
CVS Tags: rad3R6P1, rad3R6
Fixed missing third argument in calls to getheader().
# User Rev Content
1 greg 1.1 #ifndef lint
2 schorsch 2.6 static const char RCSid[] = "$Id: panim.c,v 2.5 2003/11/10 12:28:56 schorsch Exp $";
3 greg 1.1 #endif
4     /*
5     * Send pictures to PC animation system.
6     *
7     * 6/20/88
8     */
9
10     #include <stdio.h>
11 schorsch 2.3 #include <string.h>
12 greg 1.1
13 schorsch 2.4 #include "rtprocess.h"
14 greg 1.1 #include "random.h"
15     #include "color.h"
16     #include "clntrpc.h"
17     #include "scan.h"
18
19     #define GAMMA 2.0 /* gamma correction factor */
20
21 greg 1.5
22     char *pcom = NULL; /* pipe command */
23
24 greg 1.1 BYTE gammamap[256]; /* gamma correction table */
25
26
27     main(argc, argv)
28     int argc;
29     char *argv[];
30     {
31     char *progname;
32     int nframes;
33     int port = PCPROGRAM;
34     /* initialize */
35     compgamma();
36     for (progname = *argv++; --argc; argv++)
37     if (!strcmp(*argv, "-p") && argv[1]) {
38     port = atoi(*++argv); argc--;
39 greg 1.5 } else if (!strcmp(*argv, "-u") && argv[1]) {
40     pcom = *++argv; argc--;
41 greg 1.1 } else
42     break;
43     if (!argc) {
44     fputs("Usage: ", stderr);
45     fputs(progname, stderr);
46 greg 1.5 fputs(" [-p port] [-u uncompress] hostname [-c copies][-r record] [frame] ..\n",
47 greg 1.1 stderr);
48     exit(1);
49     }
50     scry_open(*argv++, TCP, port);
51     scry_set_compress(NONE);
52     scry_set_image(TARGA_IMAGE);
53     scry_set_record(PREVIEW);
54     scry_set_copy_num(3);
55     /* send frames */
56     nframes = 0;
57     for ( ; --argc; argv++)
58     if (!strcmp(*argv, "-r") && argv[1]) {
59     scry_set_record(atoi(*++argv)); argc--;
60     } else if (!strcmp(*argv, "-c") && argv[1]) {
61     scry_set_copy_num(atoi(*++argv)); argc--;
62     } else {
63     sendframe(*argv);
64     nframes++;
65     }
66     if (nframes == 0) /* get stdin */
67     sendframe(NULL);
68     /* clean up */
69     scry_close();
70     exit(0);
71     }
72
73
74     sendframe(file) /* convert and send a frame */
75     char *file;
76     {
77 schorsch 2.5 char command[PATH_MAX];
78 greg 1.1 COLR scanin[SCANLINE];
79     int xres, yres;
80     int xbeg, ybeg;
81     FILE *fp;
82 greg 1.3 int y;
83     register int x;
84 greg 1.1 /* open file */
85     if (file == NULL) {
86 greg 1.5 if (pcom != NULL)
87     fp = popen(pcom, "r");
88     else
89     fp = stdin;
90 greg 1.1 file = "<stdin>";
91 greg 1.5 } else {
92     if (pcom != NULL) {
93 schorsch 2.5 sprintf(command, "( %s ) < \"%s\"", pcom, file);
94 greg 1.5 fp = popen(command, "r");
95     } else
96     fp = fopen(file, "r");
97     }
98     if (fp == NULL) {
99 greg 1.1 perror(file);
100     exit(1);
101     }
102     /* get dimensions */
103 schorsch 2.6 getheader(fp, NULL, NULL);
104 greg 1.8 if (checkheader(fp, COLRFMT, NULL) < 0) {
105     fputs(file, stderr);
106     fputs(": not a Radiance picture\n", stderr);
107     exit(1);
108     }
109 greg 1.2 if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
110 greg 1.1 xres > SCANLINE || yres > NUMSCANS) {
111     fputs(file, stderr);
112     fputs(": bad picture size\n", stderr);
113     exit(1);
114     }
115     /* compute center */
116     xbeg = (SCANLINE-xres)/2;
117     ybeg = (NUMSCANS-yres)/2;
118     /* clear output */
119 schorsch 2.3 memset(sc_frame_arr, '\0', sizeof(sc_frame_arr));
120 greg 1.1 /* get frame */
121 greg 1.3 for (y = yres-1; y >= 0; y--) {
122 greg 1.1 if (freadcolrs(scanin, xres, fp) < 0) {
123     fputs(file, stderr);
124     fputs(": read error\n", stderr);
125     exit(1);
126     }
127 greg 1.4 normcolrs(scanin, xres, 0); /* normalize */
128 greg 1.3 for (x = 0; x < xres; x++) /* convert */
129     sc_frame_arr[y+ybeg][x+xbeg] =
130     ((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
131     | ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
132     | (gammamap[scanin[x][BLU]]+(random()&7))>>3;
133 greg 1.1 }
134     /* send frame */
135     scry_send_frame();
136     /* close file */
137 greg 1.5 if (pcom != NULL)
138     pclose(fp);
139     else
140     fclose(fp);
141 greg 1.1 }
142
143
144     compgamma() /* compute gamma correction map */
145     {
146     extern double pow();
147     register int i, val;
148
149     for (i = 0; i < 256; i++) {
150 greg 1.7 val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0;
151 greg 1.1 if (val > 248) val = 248;
152     gammamap[i] = val;
153     }
154     }
