root/radiance/ray/src/px/panim.c
Revision: 2.5
Committed: Mon Nov 10 12:28:56 2003 UTC (21 years, 6 months ago) by schorsch
Fixed size of command line buffers, and allow spaces in input file paths.
2 static const char RCSid[] = "$Id: panim.c,v 2.4 2003/10/27 10:24:51 schorsch Exp $";
5 * Send pictures to PC animation system.
6 *
7 * 6/20/88
8 */
9
10 #include <stdio.h>
11 #include <string.h>
12
13 #include "rtprocess.h"
14 #include "random.h"
15 #include "color.h"
16 #include "clntrpc.h"
17 #include "scan.h"
18
19 #define GAMMA 2.0 /* gamma correction factor */
20
21
22 char *pcom = NULL; /* pipe command */
23
24 BYTE gammamap[256]; /* gamma correction table */
25
26
27 main(argc, argv)
28 int argc;
29 char *argv[];
30 {
31 char *progname;
32 int nframes;
33 int port = PCPROGRAM;
34 /* initialize */
35 compgamma();
36 for (progname = *argv++; --argc; argv++)
37 if (!strcmp(*argv, "-p") && argv[1]) {
38 port = atoi(*++argv); argc--;
39 } else if (!strcmp(*argv, "-u") && argv[1]) {
40 pcom = *++argv; argc--;
41 } else
42 break;
43 if (!argc) {
44 fputs("Usage: ", stderr);
45 fputs(progname, stderr);
46 fputs(" [-p port] [-u uncompress] hostname [-c copies][-r record] [frame] ..\n",
47 stderr);
48 exit(1);
49 }
50 scry_open(*argv++, TCP, port);
51 scry_set_compress(NONE);
52 scry_set_image(TARGA_IMAGE);
53 scry_set_record(PREVIEW);
54 scry_set_copy_num(3);
55 /* send frames */
56 nframes = 0;
57 for ( ; --argc; argv++)
58 if (!strcmp(*argv, "-r") && argv[1]) {
59 scry_set_record(atoi(*++argv)); argc--;
60 } else if (!strcmp(*argv, "-c") && argv[1]) {
61 scry_set_copy_num(atoi(*++argv)); argc--;
62 } else {
63 sendframe(*argv);
64 nframes++;
65 }
66 if (nframes == 0) /* get stdin */
67 sendframe(NULL);
68 /* clean up */
69 scry_close();
70 exit(0);
71 }
72
73
74 sendframe(file) /* convert and send a frame */
75 char *file;
76 {
77 char command[PATH_MAX];
78 COLR scanin[SCANLINE];
79 int xres, yres;
80 int xbeg, ybeg;
81 FILE *fp;
82 int y;
83 register int x;
84 /* open file */
85 if (file == NULL) {
86 if (pcom != NULL)
87 fp = popen(pcom, "r");
88 else
89 fp = stdin;
90 file = "<stdin>";
91 } else {
92 if (pcom != NULL) {
93 sprintf(command, "( %s ) < \"%s\"", pcom, file);
94 fp = popen(command, "r");
95 } else
96 fp = fopen(file, "r");
97 }
98 if (fp == NULL) {
99 perror(file);
100 exit(1);
101 }
102 /* get dimensions */
103 getheader(fp, NULL);
104 if (checkheader(fp, COLRFMT, NULL) < 0) {
105 fputs(file, stderr);
106 fputs(": not a Radiance picture\n", stderr);
107 exit(1);
108 }
109 if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
110 xres > SCANLINE || yres > NUMSCANS) {
111 fputs(file, stderr);
112 fputs(": bad picture size\n", stderr);
113 exit(1);
114 }
115 /* compute center */
116 xbeg = (SCANLINE-xres)/2;
117 ybeg = (NUMSCANS-yres)/2;
118 /* clear output */
119 memset(sc_frame_arr, '\0', sizeof(sc_frame_arr));
120 /* get frame */
121 for (y = yres-1; y >= 0; y--) {
122 if (freadcolrs(scanin, xres, fp) < 0) {
123 fputs(file, stderr);
124 fputs(": read error\n", stderr);
125 exit(1);
126 }
127 normcolrs(scanin, xres, 0); /* normalize */
128 for (x = 0; x < xres; x++) /* convert */
129 sc_frame_arr[y+ybeg][x+xbeg] =
130 ((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
131 | ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
132 | (gammamap[scanin[x][BLU]]+(random()&7))>>3;
133 }
134 /* send frame */
135 scry_send_frame();
136 /* close file */
137 if (pcom != NULL)
138 pclose(fp);
139 else
140 fclose(fp);
141 }
142
143
144 compgamma() /* compute gamma correction map */
145 {
146 extern double pow();
147 register int i, val;
148
149 for (i = 0; i < 256; i++) {
150 val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0;
151 if (val > 248) val = 248;
152 gammamap[i] = val;
153 }
154 }
