root/radiance/ray/src/px/panim.c
Revision: 1.1
Committed: Thu Feb 2 10:49:22 1989 UTC (36 years, 3 months ago) by greg
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Send pictures to PC animation system.
9 *
10 * 6/20/88
11 */
12
13 #include <stdio.h>
14 #include <rasterfile.h>
15
16 #include "random.h"
17 #include "color.h"
18 #include "clntrpc.h"
19 #include "scan.h"
20
21 #define GAMMA 2.0 /* gamma correction factor */
22
23 BYTE gammamap[256]; /* gamma correction table */
24
25
26 main(argc, argv)
27 int argc;
28 char *argv[];
29 {
30 char *progname;
31 int nframes;
32 int port = PCPROGRAM;
33 /* initialize */
34 compgamma();
35 for (progname = *argv++; --argc; argv++)
36 if (!strcmp(*argv, "-p") && argv[1]) {
37 port = atoi(*++argv); argc--;
38 } else
39 break;
40 if (!argc) {
41 fputs("Usage: ", stderr);
42 fputs(progname, stderr);
43 fputs(" [-p port] hostname [-c copies][-r record] [frame] ..\n",
44 stderr);
45 exit(1);
46 }
47 scry_open(*argv++, TCP, port);
48 scry_set_compress(NONE);
49 scry_set_image(TARGA_IMAGE);
50 scry_set_record(PREVIEW);
51 scry_set_copy_num(3);
52 /* send frames */
53 nframes = 0;
54 for ( ; --argc; argv++)
55 if (!strcmp(*argv, "-r") && argv[1]) {
56 scry_set_record(atoi(*++argv)); argc--;
57 } else if (!strcmp(*argv, "-c") && argv[1]) {
58 scry_set_copy_num(atoi(*++argv)); argc--;
59 } else {
60 sendframe(*argv);
61 nframes++;
62 }
63 if (nframes == 0) /* get stdin */
64 sendframe(NULL);
65 /* clean up */
66 scry_close();
67 exit(0);
68 }
69
70
71 sendframe(file) /* convert and send a frame */
72 char *file;
73 {
74 COLR scanin[SCANLINE];
75 int xres, yres;
76 int xbeg, ybeg;
77 FILE *fp;
78 int j;
79 register int k, c;
80 register BYTE *in;
81 short *out;
82 /* open file */
83 if (file == NULL) {
84 fp = stdin;
85 file = "<stdin>";
86 } else if ((fp = fopen(file, "r")) == NULL) {
87 perror(file);
88 exit(1);
89 }
90 /* get dimensions */
91 getheader(fp, NULL);
92 if (fscanf(fp, "-Y %d +X %d\n", &yres, &xres) != 2 ||
93 xres > SCANLINE || yres > NUMSCANS) {
94 fputs(file, stderr);
95 fputs(": bad picture size\n", stderr);
96 exit(1);
97 }
98 /* compute center */
99 xbeg = (SCANLINE-xres)/2;
100 ybeg = (NUMSCANS-yres)/2;
101 /* clear output */
102 bzero(sc_frame_arr, sizeof(sc_frame_arr));
103 /* get frame */
104 for (j = yres-1; j >= 0; j--) {
105 if (freadcolrs(scanin, xres, fp) < 0) {
106 fputs(file, stderr);
107 fputs(": read error\n", stderr);
108 exit(1);
109 }
110 for (in = scanin[0], out = sc_frame_arr[ybeg+j]+xbeg;
111 in < scanin[xres]; in += 4, out++) {
112 k = in[EXP] - COLXS;
113 if (k >= 8) {
114 in[RED] =
115 in[GRN] =
116 in[BLU] = 255;
117 } else if (k <= -8) {
118 in[RED] =
119 in[GRN] =
120 in[BLU] = 0;
121 } else if (k > 0) {
122 c = in[RED] << k;
123 in[RED] = c > 255 ? 255 : c;
124 c = in[GRN] << k;
125 in[GRN] = c > 255 ? 255 : c;
126 c = in[BLU] << k;
127 in[BLU] = c > 255 ? 255 : c;
128 } else if (k < 0) {
129 in[RED] = in[RED] >> -k;
130 in[GRN] = in[GRN] >> -k;
131 in[BLU] = in[BLU] >> -k;
132 }
133 for (k = 0; k < 3; k++)
134 *out = *out<<5 | (gammamap[in[k]]+(random()&0x7))>>3;
135 }
136 }
137 /* send frame */
138 scry_send_frame();
139 /* close file */
140 fclose(fp);
141 }
142
143
144 compgamma() /* compute gamma correction map */
145 {
146 extern double pow();
147 register int i, val;
148
149 for (i = 0; i < 256; i++) {
150 val = pow(i/256.0, 1.0/GAMMA) * 256.0;
151 if (val > 248) val = 248;
152 gammamap[i] = val;
153 }
154 }
