root/radiance/ray/src/px/panim.c
Revision: 2.2
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.1: +1 -4 lines
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.2 static const char RCSid[] = "$Id$";
3 greg 1.1 #endif
4     /*
5     * Send pictures to PC animation system.
6     *
7     * 6/20/88
8     */
9
10     #include <stdio.h>
11
12     #include "random.h"
13     #include "color.h"
14     #include "clntrpc.h"
15     #include "scan.h"
16
17     #define GAMMA 2.0 /* gamma correction factor */
18
19 greg 1.5 FILE *popen();
20
21     char *pcom = NULL; /* pipe command */
22
23 greg 1.1 BYTE gammamap[256]; /* gamma correction table */
24
25
26     main(argc, argv)
27     int argc;
28     char *argv[];
29     {
30     char *progname;
31     int nframes;
32     int port = PCPROGRAM;
33     /* initialize */
34     compgamma();
35     for (progname = *argv++; --argc; argv++)
36     if (!strcmp(*argv, "-p") && argv[1]) {
37     port = atoi(*++argv); argc--;
38 greg 1.5 } else if (!strcmp(*argv, "-u") && argv[1]) {
39     pcom = *++argv; argc--;
40 greg 1.1 } else
41     break;
42     if (!argc) {
43     fputs("Usage: ", stderr);
44     fputs(progname, stderr);
45 greg 1.5 fputs(" [-p port] [-u uncompress] hostname [-c copies][-r record] [frame] ..\n",
46 greg 1.1 stderr);
47     exit(1);
48     }
49     scry_open(*argv++, TCP, port);
50     scry_set_compress(NONE);
51     scry_set_image(TARGA_IMAGE);
52     scry_set_record(PREVIEW);
53     scry_set_copy_num(3);
54     /* send frames */
55     nframes = 0;
56     for ( ; --argc; argv++)
57     if (!strcmp(*argv, "-r") && argv[1]) {
58     scry_set_record(atoi(*++argv)); argc--;
59     } else if (!strcmp(*argv, "-c") && argv[1]) {
60     scry_set_copy_num(atoi(*++argv)); argc--;
61     } else {
62     sendframe(*argv);
63     nframes++;
64     }
65     if (nframes == 0) /* get stdin */
66     sendframe(NULL);
67     /* clean up */
68     scry_close();
69     exit(0);
70     }
71
72
73     sendframe(file) /* convert and send a frame */
74     char *file;
75     {
76 greg 1.5 char command[128];
77 greg 1.1 COLR scanin[SCANLINE];
78     int xres, yres;
79     int xbeg, ybeg;
80     FILE *fp;
81 greg 1.3 int y;
82     register int x;
83 greg 1.1 /* open file */
84     if (file == NULL) {
85 greg 1.5 if (pcom != NULL)
86     fp = popen(pcom, "r");
87     else
88     fp = stdin;
89 greg 1.1 file = "<stdin>";
90 greg 1.5 } else {
91     if (pcom != NULL) {
92     sprintf(command, "( %s ) < %s", pcom, file);
93     fp = popen(command, "r");
94     } else
95     fp = fopen(file, "r");
96     }
97     if (fp == NULL) {
98 greg 1.1 perror(file);
99     exit(1);
100     }
101     /* get dimensions */
102     getheader(fp, NULL);
103 greg 1.8 if (checkheader(fp, COLRFMT, NULL) < 0) {
104     fputs(file, stderr);
105     fputs(": not a Radiance picture\n", stderr);
106     exit(1);
107     }
108 greg 1.2 if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
109 greg 1.1 xres > SCANLINE || yres > NUMSCANS) {
110     fputs(file, stderr);
111     fputs(": bad picture size\n", stderr);
112     exit(1);
113     }
114     /* compute center */
115     xbeg = (SCANLINE-xres)/2;
116     ybeg = (NUMSCANS-yres)/2;
117     /* clear output */
118     bzero(sc_frame_arr, sizeof(sc_frame_arr));
119     /* get frame */
120 greg 1.3 for (y = yres-1; y >= 0; y--) {
121 greg 1.1 if (freadcolrs(scanin, xres, fp) < 0) {
122     fputs(file, stderr);
123     fputs(": read error\n", stderr);
124     exit(1);
125     }
126 greg 1.4 normcolrs(scanin, xres, 0); /* normalize */
127 greg 1.3 for (x = 0; x < xres; x++) /* convert */
128     sc_frame_arr[y+ybeg][x+xbeg] =
129     ((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
130     | ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
131     | (gammamap[scanin[x][BLU]]+(random()&7))>>3;
132 greg 1.1 }
133     /* send frame */
134     scry_send_frame();
135     /* close file */
136 greg 1.5 if (pcom != NULL)
137     pclose(fp);
138     else
139     fclose(fp);
140 greg 1.1 }
141
142
143     compgamma() /* compute gamma correction map */
144     {
145     extern double pow();
146     register int i, val;
147
148     for (i = 0; i < 256; i++) {
149 greg 1.7 val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0;
150 greg 1.1 if (val > 248) val = 248;
151     gammamap[i] = val;
152     }
153     }
