| 1 |
/* Copyright (c) 1988 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Send pictures to PC animation system.
| 9 |
| 10 |
* 6/20/88
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
| 15 |
#include "random.h"
| 16 |
#include "color.h"
| 17 |
#include "clntrpc.h"
| 18 |
#include "scan.h"
| 19 |
| 20 |
#define GAMMA 2.0 /* gamma correction factor */
| 21 |
| 22 |
FILE *popen();
| 23 |
| 24 |
char *pcom = NULL; /* pipe command */
| 25 |
| 26 |
BYTE gammamap[256]; /* gamma correction table */
| 27 |
| 28 |
| 29 |
main(argc, argv)
| 30 |
int argc;
| 31 |
char *argv[];
| 32 |
| 33 |
char *progname;
| 34 |
int nframes;
| 35 |
int port = PCPROGRAM;
| 36 |
/* initialize */
| 37 |
compgamma();
| 38 |
for (progname = *argv++; --argc; argv++)
| 39 |
if (!strcmp(*argv, "-p") && argv[1]) {
| 40 |
port = atoi(*++argv); argc--;
| 41 |
} else if (!strcmp(*argv, "-u") && argv[1]) {
| 42 |
pcom = *++argv; argc--;
| 43 |
} else
| 44 |
break;
| 45 |
if (!argc) {
| 46 |
fputs("Usage: ", stderr);
| 47 |
fputs(progname, stderr);
| 48 |
fputs(" [-p port] [-u uncompress] hostname [-c copies][-r record] [frame] ..\n",
| 49 |
stderr);
| 50 |
exit(1);
| 51 |
| 52 |
scry_open(*argv++, TCP, port);
| 53 |
scry_set_compress(NONE);
| 54 |
scry_set_image(TARGA_IMAGE);
| 55 |
scry_set_record(PREVIEW);
| 56 |
scry_set_copy_num(3);
| 57 |
/* send frames */
| 58 |
nframes = 0;
| 59 |
for ( ; --argc; argv++)
| 60 |
if (!strcmp(*argv, "-r") && argv[1]) {
| 61 |
scry_set_record(atoi(*++argv)); argc--;
| 62 |
} else if (!strcmp(*argv, "-c") && argv[1]) {
| 63 |
scry_set_copy_num(atoi(*++argv)); argc--;
| 64 |
} else {
| 65 |
sendframe(*argv);
| 66 |
nframes++;
| 67 |
| 68 |
if (nframes == 0) /* get stdin */
| 69 |
sendframe(NULL);
| 70 |
/* clean up */
| 71 |
scry_close();
| 72 |
exit(0);
| 73 |
| 74 |
| 75 |
| 76 |
sendframe(file) /* convert and send a frame */
| 77 |
char *file;
| 78 |
| 79 |
char command[128];
| 80 |
COLR scanin[SCANLINE];
| 81 |
int xres, yres;
| 82 |
int xbeg, ybeg;
| 83 |
FILE *fp;
| 84 |
int y;
| 85 |
register int x;
| 86 |
/* open file */
| 87 |
if (file == NULL) {
| 88 |
if (pcom != NULL)
| 89 |
fp = popen(pcom, "r");
| 90 |
else
| 91 |
fp = stdin;
| 92 |
file = "<stdin>";
| 93 |
} else {
| 94 |
if (pcom != NULL) {
| 95 |
sprintf(command, "( %s ) < %s", pcom, file);
| 96 |
fp = popen(command, "r");
| 97 |
} else
| 98 |
fp = fopen(file, "r");
| 99 |
| 100 |
if (fp == NULL) {
| 101 |
perror(file);
| 102 |
exit(1);
| 103 |
| 104 |
/* get dimensions */
| 105 |
getheader(fp, NULL);
| 106 |
if (checkheader(fp, COLRFMT, NULL) < 0) {
| 107 |
fputs(file, stderr);
| 108 |
fputs(": not a Radiance picture\n", stderr);
| 109 |
exit(1);
| 110 |
| 111 |
if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
| 112 |
xres > SCANLINE || yres > NUMSCANS) {
| 113 |
| 114 |
fputs(": bad picture size\n", stderr);
| 115 |
exit(1);
| 116 |
| 117 |
/* compute center */
| 118 |
xbeg = (SCANLINE-xres)/2;
| 119 |
ybeg = (NUMSCANS-yres)/2;
| 120 |
/* clear output */
| 121 |
bzero(sc_frame_arr, sizeof(sc_frame_arr));
| 122 |
/* get frame */
| 123 |
for (y = yres-1; y >= 0; y--) {
| 124 |
if (freadcolrs(scanin, xres, fp) < 0) {
| 125 |
| 126 |
fputs(": read error\n", stderr);
| 127 |
exit(1);
| 128 |
| 129 |
normcolrs(scanin, xres, 0); /* normalize */
| 130 |
for (x = 0; x < xres; x++) /* convert */
| 131 |
sc_frame_arr[y+ybeg][x+xbeg] =
| 132 |
((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
| 133 |
| ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
| 134 |
| (gammamap[scanin[x][BLU]]+(random()&7))>>3;
| 135 |
| 136 |
/* send frame */
| 137 |
scry_send_frame();
| 138 |
/* close file */
| 139 |
if (pcom != NULL)
| 140 |
pclose(fp);
| 141 |
else
| 142 |
fclose(fp);
| 143 |
| 144 |
| 145 |
| 146 |
compgamma() /* compute gamma correction map */
| 147 |
| 148 |
extern double pow();
| 149 |
register int i, val;
| 150 |
| 151 |
for (i = 0; i < 256; i++) {
| 152 |
val = pow((i+0.5)/256.0, 1.0/GAMMA) * 256.0;
| 153 |
if (val > 248) val = 248;
| 154 |
gammamap[i] = val;
| 155 |
| 156 |
