root/radiance/ray/src/px/panim.c
Revision: 1.4
Committed: Fri Jan 26 08:17:35 1990 UTC (35 years, 3 months ago) by greg
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Send pictures to PC animation system.
9 *
10 * 6/20/88
11 */
12
13 #include <stdio.h>
14 #include <rasterfile.h>
15
16 #include "random.h"
17 #include "color.h"
18 #include "clntrpc.h"
19 #include "scan.h"
20
21 #define GAMMA 2.0 /* gamma correction factor */
22
23 BYTE gammamap[256]; /* gamma correction table */
24
25
26 main(argc, argv)
27 int argc;
28 char *argv[];
29 {
30 char *progname;
31 int nframes;
32 int port = PCPROGRAM;
33 /* initialize */
34 compgamma();
35 for (progname = *argv++; --argc; argv++)
36 if (!strcmp(*argv, "-p") && argv[1]) {
37 port = atoi(*++argv); argc--;
38 } else
39 break;
40 if (!argc) {
41 fputs("Usage: ", stderr);
42 fputs(progname, stderr);
43 fputs(" [-p port] hostname [-c copies][-r record] [frame] ..\n",
44 stderr);
45 exit(1);
46 }
47 scry_open(*argv++, TCP, port);
48 scry_set_compress(NONE);
49 scry_set_image(TARGA_IMAGE);
50 scry_set_record(PREVIEW);
51 scry_set_copy_num(3);
52 /* send frames */
53 nframes = 0;
54 for ( ; --argc; argv++)
55 if (!strcmp(*argv, "-r") && argv[1]) {
56 scry_set_record(atoi(*++argv)); argc--;
57 } else if (!strcmp(*argv, "-c") && argv[1]) {
58 scry_set_copy_num(atoi(*++argv)); argc--;
59 } else {
60 sendframe(*argv);
61 nframes++;
62 }
63 if (nframes == 0) /* get stdin */
64 sendframe(NULL);
65 /* clean up */
66 scry_close();
67 exit(0);
68 }
69
70
71 sendframe(file) /* convert and send a frame */
72 char *file;
73 {
74 COLR scanin[SCANLINE];
75 int xres, yres;
76 int xbeg, ybeg;
77 FILE *fp;
78 int y;
79 register int x;
80 /* open file */
81 if (file == NULL) {
82 fp = stdin;
83 file = "<stdin>";
84 } else if ((fp = fopen(file, "r")) == NULL) {
85 perror(file);
86 exit(1);
87 }
88 /* get dimensions */
89 getheader(fp, NULL);
90 if (fgetresolu(&xres, &yres, fp) != (YMAJOR|YDECR) ||
91 xres > SCANLINE || yres > NUMSCANS) {
92 fputs(file, stderr);
93 fputs(": bad picture size\n", stderr);
94 exit(1);
95 }
96 /* compute center */
97 xbeg = (SCANLINE-xres)/2;
98 ybeg = (NUMSCANS-yres)/2;
99 /* clear output */
100 bzero(sc_frame_arr, sizeof(sc_frame_arr));
101 /* get frame */
102 for (y = yres-1; y >= 0; y--) {
103 if (freadcolrs(scanin, xres, fp) < 0) {
104 fputs(file, stderr);
105 fputs(": read error\n", stderr);
106 exit(1);
107 }
108 normcolrs(scanin, xres, 0); /* normalize */
109 for (x = 0; x < xres; x++) /* convert */
110 sc_frame_arr[y+ybeg][x+xbeg] =
111 ((gammamap[scanin[x][RED]]+(random()&7))&0xf8)<<7
112 | ((gammamap[scanin[x][GRN]]+(random()&7))&0xf8)<<2
113 | (gammamap[scanin[x][BLU]]+(random()&7))>>3;
114 }
115 /* send frame */
116 scry_send_frame();
117 /* close file */
118 fclose(fp);
119 }
120
121
122 compgamma() /* compute gamma correction map */
123 {
124 extern double pow();
125 register int i, val;
126
127 for (i = 0; i < 256; i++) {
128 val = pow(i/256.0, 1.0/GAMMA) * 256.0;
129 if (val > 248) val = 248;
130 gammamap[i] = val;
131 }
132 }
