root/Development/ray/src/px/paintjet.c
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.5: +26 -14 lines
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.4: +5 -10 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.3: +2 -4 lines
Mon Sep 21 12:13:43 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +11 -3 lines
Changes for PC port
Mon Dec 23 22:35:34 1991 UTC (33 years, 10 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1
removed unnecessary static declarations
Tue Nov 12 16:05:33 1991 UTC (34 years ago) by greg
Diff to previous 1.7
Mon Nov 11 14:01:36 1991 UTC (34 years ago) by greg
Diff to previous 1.6
Mon May 6 13:14:26 1991 UTC (34 years, 6 months ago) by greg
Changes since 1.5: +4 -2 lines
Diff to previous 1.5
improved dithering slightly
Thu Apr 18 14:35:13 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +4 -1 lines
Diff to previous 1.4
Fri Jan 26 08:17:34 1990 UTC (35 years, 9 months ago) by greg
Diff to previous 1.3
Fri Oct 20 20:36:13 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.2: +1 -12 lines
Diff to previous 1.2
change to color normalization calls
Fri Oct 20 16:44:37 1989 UTC (36 years, 1 month ago) by greg
Changes since 1.1: +23 -12 lines
Diff to previous 1.1
eliminated unnecessary use of floating point color
Fri Oct 6 13:50:58 1989 UTC (36 years, 1 month ago) by greg
