root/Development/ray/src/px/pacuity.csh
Revision 3.7 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Jun 22 16:40:11 2023 UTC (2 years, 4 months ago) by greg
Changes since 3.6: +3 -2 lines
Diff to previous 3.6
fix(normpat,pacuity,vlpic): Made handling of resolution string more robust
Revision 3.6 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Nov 10 19:08:19 2008 UTC (17 years ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Changes since 3.5: +7 -7 lines
Diff to previous 3.5
Revision 3.5 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 05:40:11 2005 UTC (20 years, 8 months ago) by greg
Changes since 3.4: +2 -2 lines
Diff to previous 3.4
Revision 3.4 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 3.3
Revision 3.3 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Sep 25 16:30:22 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.2: +1 -1 lines
Diff to previous 3.2
fixed constant in formula
Revision 3.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Sep 23 09:49:56 1996 UTC (29 years, 1 month ago) by greg
Changes since 3.1: +3 -2 lines
Diff to previous 3.1
added safety for 0 luminances
Revision 3.1 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Sep 20 16:44:01 1996 UTC (29 years, 1 month ago) by greg
Links to HEAD: (view) (download) (as text) (annotate) Links to rad5R4: (view) (download) (as text) (annotate)
