--- ray/src/px/oki20c.c 1989/10/20 13:53:58 1.5 +++ ray/src/px/oki20c.c 1990/07/10 09:07:48 1.9 @@ -24,7 +24,15 @@ static char SCCSid[] = "$SunId$ LBL"; #define sub_add(sub) (2-(sub)) /* map subtractive to additive pri. */ +#ifdef BSD +#define clearlbuf() bzero((char *)lpat, sizeof(lpat)) +#else +#define clearlbuf() (void)memset((char *)lpat, 0, sizeof(lpat)) +#endif +long lpat[NCOLS][3]; + + main(argc, argv) int argc; char *argv[]; @@ -45,7 +53,7 @@ char *fname; { FILE *input; int xres, yres; - COLOR scanline[NCOLS]; + COLR scanline[NCOLS]; int i; if (fname == NULL) { @@ -68,12 +76,15 @@ char *fname; } /* set line spacing (overlap for knitting) */ fputs("\0333\042", stdout); + /* clear line buffer */ + clearlbuf(); /* put out scanlines */ for (i = yres-1; i >= 0; i--) { - if (freadscan(scanline, xres, input) < 0) { + if (freadcolrs(scanline, xres, input) < 0) { fprintf(stderr, "%s: read error (y=%d)\n", fname, i); return(-1); } + normcolrs(scanline, xres, 0); plotscan(scanline, xres, i); } /* advance page */ @@ -86,11 +97,10 @@ char *fname; plotscan(scan, len, y) /* plot a scanline */ -COLOR scan[]; +COLR scan[]; int len; int y; { - static long pat[NCOLS][3]; int bpos; register long c; register int i, j; @@ -99,7 +109,7 @@ int y; for (j = 0; j < 3; j++) for (i = 0; i < len; i++) - pat[i][j] |= (long)colbit(scan[i],i,j) << bpos; + lpat[i][j] |= (long)colbit(scan[i],i,j) << bpos; } else { @@ -110,9 +120,9 @@ int y; putchar(len & 255); putchar(len >> 8); for (i = 0; i < len; i++) { - c = pat[i][j] | colbit(scan[i],i,j); + c = lpat[i][j] | colbit(scan[i],i,j); /* repeat this row */ - pat[i][j] = (c & 1) << 23; + lpat[i][j] = (c & 1) << 23; putchar(c>>16); putchar(c>>8 & 255); putchar(c & 255); @@ -125,21 +135,20 @@ int y; colbit(col, x, s) /* determine bit value for primary at x */ -COLOR col; +COLR col; register int x; int s; { - static float cerr[NCOLS][3]; - static double err[3]; - double b; + static int cerr[NCOLS][3]; + static int err[3]; + int b; register int a, ison; a = sub_add(s); /* use additive primary */ - b = colval(col,a); - if (b > 1.0) b = 1.0; + b = col[a]; err[a] += b + cerr[x][a]; - ison = err[a] < 0.5; - if (!ison) err[a] -= 1.0; - cerr[x][a] = err[a] *= 0.5; + ison = err[a] < 128; + if (!ison) err[a] -= 256; + cerr[x][a] = err[a] /= 2; return(ison); }
