root/radiance/ray/src/px/oki20c.c
Changes since 2.10: +2 -4 lines
Diff to previous 2.10 , to selected 1.7
Mon Aug 2 14:39:07 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.9: +0 -3 lines
Diff to previous 2.9 , to selected 1.7
removed questionable line buffer setting
Mon Sep 21 12:13:38 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.8: +20 -10 lines
Diff to previous 2.8 , to selected 1.7
Changes for PC port
Fri Jul 3 10:46:25 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.7: +25 -35 lines
Diff to previous 2.7 , to selected 1.7
slight improvement in clearing of new print buffer
Fri Jul 3 08:59:26 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.6 , to selected 1.7
removed limit on number of rows in output
Sat Apr 18 09:10:53 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.5: +5 -4 lines
Diff to previous 2.5 , to selected 1.7
changed handling of file name for pipes
Sat Apr 11 16:31:32 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.4 , to selected 1.7
added oki20
Wed Jan 29 16:51:40 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.3: +8 -2 lines
Diff to previous 2.3 , to selected 1.7
added automatic left to right image centering
Wed Jan 29 15:18:20 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.2: +29 -2 lines
Diff to previous 2.2 , to selected 1.7
added -p option for prefiltering and removed line buffering
Mon Dec 23 22:35:32 1991 UTC (32 years, 5 months ago) by greg
Changes since 2.1: +4 -4 lines
Diff to previous 2.1 , to selected 1.7
removed unnecessary static declarations
Tue Nov 12 16:05:03 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 1.7
Mon Nov 11 14:01:31 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 1.7
Mon May 6 13:14:23 1991 UTC (33 years ago) by greg
Diff to previous 1.10 , to selected 1.7
improved dithering slightly
Thu Apr 18 14:35:11 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.9: +4 -1 lines
Diff to previous 1.9 , to selected 1.7
Tue Jul 10 09:07:48 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.8: +13 -4 lines
Diff to previous 1.8 , to selected 1.7
fixed minor bug that repeated scanline from previous page
Fri Jan 26 08:17:33 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.7
Revision 1.7 - (view) (download) (annotate) - [selected]
Fri Oct 20 20:36:02 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +1 -12 lines
Diff to previous 1.6
change to color normalization calls
Fri Oct 20 16:44:34 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +23 -12 lines
eliminated unnecessary use of floating point color
Fri Oct 20 13:53:58 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +12 -22 lines
gave up on knitting, changed to 1 pixel overlap
Fri Oct 20 12:07:08 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +22 -16 lines
changed to 4x4 knit
Fri Oct 20 10:28:59 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +12 -7 lines
added knitting to reduce printline artifacts
Tue Sep 12 13:04:20 1989 UTC (34 years, 8 months ago) by greg
Thu Feb 2 10:49:21 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 1.7
