root/Development/ray/src/px/oki20.c
Revision 2.14
Fri Nov 5 03:31:38 2004 UTC (21 years ago) by greg
FILE REMOVED
Sun Mar 28 20:33:14 2004 UTC (21 years, 7 months ago) by schorsch
Changes since 2.12: +25 -13 lines
Diff to previous 2.12
Mon Nov 10 12:28:56 2003 UTC (22 years ago) by schorsch
Changes since 2.11: +6 -5 lines
Fixed size of command line buffers, and allow spaces in input file paths.
Mon Oct 27 10:24:51 2003 UTC (22 years ago) by schorsch
Changes since 2.10: +2 -3 lines
Various compatibility fixes.
Thu Jun 5 19:29:34 2003 UTC (22 years, 5 months ago) by schorsch
Changes since 2.9: +5 -10 lines
Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.8: +2 -4 lines
Mon Aug 2 14:39:06 1993 UTC (32 years, 3 months ago) by greg
Changes since 2.7: +0 -3 lines
removed questionable line buffer setting
Thu Oct 8 10:05:20 1992 UTC (33 years, 1 month ago) by greg
fixed comment at top
Mon Sep 21 12:13:33 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.5: +18 -8 lines
Changes for PC port
Fri Jul 3 10:46:27 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.4: +4 -10 lines
slight improvement in clearing of new print buffer
Fri Jul 3 10:30:07 1992 UTC (33 years, 4 months ago) by greg
Changes since 2.3: +35 -23 lines
made more efficint use of ribbon by skipping white areas
Fri Jul 3 08:59:24 1992 UTC (33 years, 4 months ago) by greg
removed limit on number of rows in output
Sat Apr 18 09:10:51 1992 UTC (33 years, 6 months ago) by greg
changed handling of file name for pipes
Sat Apr 11 16:31:07 1992 UTC (33 years, 7 months ago) by greg
