1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: normtiff.c,v 3.7 2004/01/02 11:42:37 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF |
6 |
7 |
8 |
#include <stdio.h> |
9 |
#include <math.h> |
10 |
#include <time.h> |
11 |
#include <string.h> |
12 |
13 |
#include "tiffio.h" |
14 |
#include "color.h" |
15 |
#include "tonemap.h" |
16 |
#include "tmaptiff.h" |
17 |
#include "resolu.h" |
18 |
19 |
20 |
TIFF *tifout; /* TIFF output */ |
21 |
int flags = TM_F_CAMERA; /* tone-mapping flags */ |
22 |
RGBPRIMP rgbp = stdprims; /* display primaries */ |
23 |
RGBPRIMS myprims; /* overriding display primaries */ |
24 |
double ldmax = 100.; /* maximum display luminance */ |
25 |
double lddyn = 32.; /* display dynamic range */ |
26 |
double gamv = 2.2; /* display gamma value */ |
27 |
28 |
short ortab[8] = { /* orientation conversion table */ |
29 |
YMAJOR|YDECR, |
30 |
YMAJOR|YDECR|XDECR, |
31 |
YMAJOR|XDECR, |
32 |
YMAJOR, |
33 |
YDECR, |
34 |
XDECR|YDECR, |
35 |
XDECR, |
36 |
0 |
37 |
38 |
39 |
typedef struct { |
40 |
FILE *fp; /* file pointer */ |
41 |
char fmt[32]; /* picture format */ |
42 |
double pa; /* pixel aspect ratio */ |
43 |
RESOLU rs; /* picture resolution */ |
44 |
} PICTURE; |
45 |
46 |
//extern PICTURE *openpicture(); |
47 |
48 |
#define closepicture(p) (fclose((p)->fp),free((void *)(p))) |
49 |
50 |
static gethfunc headline; |
51 |
52 |
static int headline(char *s, void *pp); |
53 |
static PICTURE * openpicture(char *fname); |
54 |
static int tmap_picture(char *fname, PICTURE *pp); |
55 |
static int tmap_tiff(char *fname, TIFF *tp); |
56 |
static int putimage(uint16 or, uint32 xs, uint32 ys, float xr, float yr, |
57 |
uint16 ru, BYTE *pd); |
58 |
59 |
60 |
int |
61 |
main( |
62 |
int argc, |
63 |
char *argv[] |
64 |
65 |
66 |
PICTURE *pin = NULL; |
67 |
TIFF *tin = NULL; |
68 |
int i, rval; |
69 |
70 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) |
71 |
switch (argv[i][1]) { |
72 |
case 'h': /* human observer settings */ |
73 |
flags = TM_F_HUMAN; |
74 |
break; |
75 |
case 's': /* toggle human contrast */ |
76 |
flags ^= TM_F_HCONTR; |
77 |
break; |
78 |
case 'c': /* toggle mesopic sens. */ |
79 |
flags ^= TM_F_MESOPIC; |
80 |
break; |
81 |
case 'l': /* toggle linear mapping */ |
82 |
flags ^= TM_F_LINEAR; |
83 |
break; |
84 |
case 'b': /* toggle greyscale output */ |
85 |
flags ^= TM_F_BW; |
86 |
break; |
87 |
case 'g': /* set display gamma */ |
88 |
if (argc-i < 2) goto userr; |
89 |
gamv = atof(argv[++i]); |
90 |
break; |
91 |
case 'u': /* set display maximum */ |
92 |
93 |
ldmax = atof(argv[++i]); |
94 |
break; |
95 |
case 'd': /* set display dynamic range */ |
96 |
97 |
lddyn = atof(argv[++i]); |
98 |
break; |
99 |
case 'p': /* set display primaries */ |
100 |
if (argc-i < 9) goto userr; |
101 |
myprims[RED][CIEX] = atof(argv[++i]); |
102 |
myprims[RED][CIEY] = atof(argv[++i]); |
103 |
myprims[GRN][CIEX] = atof(argv[++i]); |
104 |
myprims[GRN][CIEY] = atof(argv[++i]); |
105 |
myprims[BLU][CIEX] = atof(argv[++i]); |
106 |
myprims[BLU][CIEY] = atof(argv[++i]); |
107 |
myprims[WHT][CIEX] = atof(argv[++i]); |
108 |
myprims[WHT][CIEY] = atof(argv[++i]); |
109 |
rgbp = myprims; |
110 |
break; |
111 |
default: |
112 |
goto userr; |
113 |
114 |
115 |
if ((pin = openpicture(argv[i])) == NULL && |
116 |
(tin = TIFFOpen(argv[i], "r")) == NULL) { |
117 |
fprintf(stderr, "%s: cannot open or interpret file \"%s\"\n", |
118 |
argv[0], argv[i]); |
119 |
exit(1); |
120 |
121 |
if ((tifout = TIFFOpen(argv[i+1], "w")) == NULL) { |
122 |
fprintf(stderr, "%s: cannot open output TIFF \"%s\"\n", |
123 |
argv[0], argv[i+1]); |
124 |
exit(1); |
125 |
126 |
if (pin != NULL) { |
127 |
rval = tmap_picture(argv[i], pin); |
128 |
closepicture(pin); |
129 |
} else { |
130 |
rval = tmap_tiff(argv[i], tin); |
131 |
TIFFClose(tin); |
132 |
133 |
TIFFClose(tifout); |
134 |
exit(rval==0 ? 0 : 1); |
135 |
userr: |
136 |
fprintf(stderr, |
137 |
"Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-p xr yr xg yg xb yb xw yw] input.{tif|pic} output.tif\n", |
138 |
argv[0]); |
139 |
exit(1); |
140 |
141 |
142 |
143 |
static int |
144 |
headline( /* process line from header */ |
145 |
char *s, |
146 |
void *pp |
147 |
148 |
149 |
register char *cp; |
150 |
151 |
for (cp = s; *cp; cp++) |
152 |
if (*cp & 0x80) |
153 |
return(-1); /* non-ascii in header */ |
154 |
if (isaspect(s)) |
155 |
((PICTURE *)pp)->pa *= aspectval(s); |
156 |
else |
157 |
formatval(((PICTURE *)pp)->fmt, s); |
158 |
return(0); |
159 |
160 |
161 |
162 |
static PICTURE * |
163 |
openpicture( /* open/check Radiance picture file */ |
164 |
char *fname |
165 |
166 |
167 |
FILE *fp; |
168 |
register PICTURE *pp; |
169 |
170 |
/* check filename suffix */ |
171 |
if (fname == NULL) return(NULL); |
172 |
for (cp = fname; *cp; cp++) |
173 |
174 |
while (cp > fname && cp[-1] != '.') |
175 |
if (*--cp == '/') { |
176 |
cp = fname; |
177 |
break; |
178 |
179 |
if (cp > fname && !strncmp(cp, "tif", 3)) |
180 |
return(NULL); /* assume it's a TIFF */ |
181 |
/* else try opening it */ |
182 |
if ((fp = fopen(fname, "r")) == NULL) |
183 |
return(NULL); |
184 |
/* allocate struct */ |
185 |
if ((pp = (PICTURE *)malloc(sizeof(PICTURE))) == NULL) |
186 |
return(NULL); /* serious error -- should exit? */ |
187 |
pp->fp = fp; pp->fmt[0] = '\0'; pp->pa = 1.; |
188 |
/* load header */ |
189 |
if (getheader(fp, headline, pp) < 0) { |
190 |
closepicture(pp); |
191 |
return(NULL); |
192 |
193 |
if (!pp->fmt[0]) /* assume RGBE if unspecified */ |
194 |
strcpy(pp->fmt, COLRFMT); |
195 |
if (!globmatch(PICFMT, pp->fmt) || !fgetsresolu(&pp->rs, fp)) { |
196 |
closepicture(pp); /* failed test -- close file */ |
197 |
return(NULL); |
198 |
199 |
rewind(fp); /* passed test -- rewind file */ |
200 |
return(pp); |
201 |
202 |
203 |
204 |
static int |
205 |
tmap_picture( /* tone map Radiance picture */ |
206 |
char *fname, |
207 |
register PICTURE *pp |
208 |
209 |
210 |
uint16 orient; |
211 |
int xsiz, ysiz; |
212 |
BYTE *pix; |
213 |
/* read and tone map picture */ |
214 |
if (tmMapPicture(&pix, &xsiz, &ysiz, flags, |
215 |
rgbp, gamv, lddyn, ldmax, fname, pp->fp) != TM_E_OK) |
216 |
return(-1); |
217 |
/* figure out TIFF orientation */ |
218 |
for (orient = 8; --orient; ) |
219 |
if (ortab[orient] == pp->rs.rt) |
220 |
break; |
221 |
orient++; |
222 |
/* put out our image */ |
223 |
if (putimage(orient, (uint32)xsiz, (uint32)ysiz, |
224 |
72., 72./pp->pa, 2, pix) != 0) |
225 |
return(-1); |
226 |
/* free data and we're done */ |
227 |
free((void *)pix); |
228 |
return(0); |
229 |
230 |
231 |
232 |
static int |
233 |
tmap_tiff( /* tone map SGILOG TIFF */ |
234 |
char *fname, |
235 |
TIFF *tp |
236 |
237 |
238 |
float xres, yres; |
239 |
uint16 orient, resunit, phot; |
240 |
int xsiz, ysiz; |
241 |
BYTE *pix; |
242 |
/* check to make sure it's SGILOG */ |
243 |
TIFFGetFieldDefaulted(tp, TIFFTAG_PHOTOMETRIC, &phot); |
244 |
if ((phot == PHOTOMETRIC_LOGL) | (phot == PHOTOMETRIC_MINISBLACK)) |
245 |
flags |= TM_F_BW; |
246 |
/* read and tone map TIFF */ |
247 |
if (tmMapTIFF(&pix, &xsiz, &ysiz, flags, |
248 |
rgbp, gamv, lddyn, ldmax, fname, tp) != TM_E_OK) |
249 |
return(-1); |
250 |
/* get relevant tags */ |
251 |
TIFFGetFieldDefaulted(tp, TIFFTAG_RESOLUTIONUNIT, &resunit); |
252 |
TIFFGetFieldDefaulted(tp, TIFFTAG_XRESOLUTION, &xres); |
253 |
TIFFGetFieldDefaulted(tp, TIFFTAG_YRESOLUTION, &yres); |
254 |
TIFFGetFieldDefaulted(tp, TIFFTAG_ORIENTATION, &orient); |
255 |
256 |
257 |
xres, yres, resunit, pix) != 0) |
258 |
return(-1); |
259 |
260 |
261 |
return(0); |
262 |
263 |
264 |
265 |
static int |
266 |
putimage( /* write out our image */ |
267 |
uint16 or, |
268 |
uint32 xs, |
269 |
uint32 ys, |
270 |
float xr, |
271 |
float yr, |
272 |
uint16 ru, |
273 |
BYTE *pd |
274 |
275 |
276 |
register int y; |
277 |
uint32 rowsperstrip; |
278 |
279 |
TIFFSetField(tifout, TIFFTAG_COMPRESSION, COMPRESSION_NONE); |
280 |
if (flags & TM_F_BW) { |
281 |
TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC, |
282 |
PHOTOMETRIC_MINISBLACK); |
283 |
TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 1); |
284 |
} else { |
285 |
TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC, PHOTOMETRIC_RGB); |
286 |
TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 3); |
287 |
288 |
if (rgbp != stdprims) { |
289 |
TIFFSetField(tifout, TIFFTAG_PRIMARYCHROMATICITIES, |
290 |
(float *)rgbp); |
291 |
TIFFSetField(tifout, TIFFTAG_WHITEPOINT, (float *)rgbp[WHT]); |
292 |
293 |
TIFFSetField(tifout, TIFFTAG_BITSPERSAMPLE, 8); |
294 |
TIFFSetField(tifout, TIFFTAG_IMAGEWIDTH, xs); |
295 |
TIFFSetField(tifout, TIFFTAG_IMAGELENGTH, ys); |
296 |
TIFFSetField(tifout, TIFFTAG_RESOLUTIONUNIT, ru); |
297 |
TIFFSetField(tifout, TIFFTAG_XRESOLUTION, xr); |
298 |
TIFFSetField(tifout, TIFFTAG_YRESOLUTION, yr); |
299 |
TIFFSetField(tifout, TIFFTAG_PLANARCONFIG, PLANARCONFIG_CONTIG); |
300 |
TIFFSetField(tifout, TIFFTAG_ORIENTATION, or); |
301 |
/* compute good strip size */ |
302 |
rowsperstrip = 8192/TIFFScanlineSize(tifout); |
303 |
if (rowsperstrip < 1) rowsperstrip = 1; |
304 |
TIFFSetField(tifout, TIFFTAG_ROWSPERSTRIP, rowsperstrip); |
305 |
/* write out scanlines */ |
306 |
307 |
for (y = 0; y < ys; y++) |
308 |
if (TIFFWriteScanline(tifout, pd + y*xs, y, 0) < 0) |
309 |
goto writerr; |
310 |
} else { |
311 |
312 |
if (TIFFWriteScanline(tifout, pd + y*3*xs, y, 0) < 0) |
313 |
goto writerr; |
314 |
315 |
return(0); /* all done! */ |
316 |
writerr: |
317 |
fputs("Error writing TIFF output\n", stderr); |
318 |
return(-1); |
319 |
