root/radiance/ray/src/px/normtiff.c
Fri May 20 02:06:39 2011 UTC (13 years, 11 months ago) by greg
Changes since 3.12: +5 -5 lines
Diff to previous 3.12 , to selected 3.5
Sat Dec 4 00:24:43 2010 UTC (14 years, 5 months ago) by greg
Changes since 3.11: +3 -1 lines
Diff to previous 3.11 , to selected 3.5
Added binary mode setting
Mon Nov 10 19:08:19 2008 UTC (16 years, 6 months ago) by greg
Diff to previous 3.10 , to selected 3.5
Tue Sep 26 12:26:02 2006 UTC (18 years, 7 months ago) by greg
CVS Tags: rad3R8, rad3R9
Changes since 3.9: +3 -2 lines
Diff to previous 3.9 , to selected 3.5
Fixed bug in pixel aspect ratio for some image orientations
Tue Jun 14 22:23:31 2005 UTC (19 years, 11 months ago) by greg
Changes since 3.8: +13 -9 lines
Diff to previous 3.8 , to selected 3.5
Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
Changes since 3.7: +34 -18 lines
Diff to previous 3.7 , to selected 3.5
Fri Jan 2 11:42:37 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 3.6: +18 -11 lines
Diff to previous 3.6 , to selected 3.5
Sun Jul 27 22:12:03 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 3.5
Revision 3.5 - (view) (download) (annotate) - [selected]
Mon Jul 14 04:56:54 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.4: +2 -9 lines
Diff to previous 3.4
Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Changes since 3.3: +7 -12 lines
Diff to previous 3.3 , to selected 3.5
Tue Oct 27 08:54:37 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.2: +57 -40 lines
Diff to previous 3.2 , to selected 3.5
modified openpicture to store header information
Mon Oct 26 17:30:50 1998 UTC (26 years, 6 months ago) by gwlarson
Changes since 3.1: +22 -12 lines
Diff to previous 3.1 , to selected 3.5
improved error reporting methods
Mon Oct 26 17:05:28 1998 UTC (26 years, 6 months ago) by gwlarson
Diff to selected 3.5
