--- ray/src/px/normtiff.c 2004/03/28 20:33:14 3.8 +++ ray/src/px/normtiff.c 2006/09/26 12:26:02 3.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: normtiff.c,v 3.8 2004/03/28 20:33:14 schorsch Exp $"; +static const char RCSid[] = "$Id: normtiff.c,v 3.10 2006/09/26 12:26:02 greg Exp $"; #endif /* * Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF @@ -43,17 +43,17 @@ typedef struct { RESOLU rs; /* picture resolution */ } PICTURE; -//extern PICTURE *openpicture(); +uint16 comp = COMPRESSION_NONE; /* TIFF compression mode */ #define closepicture(p) (fclose((p)->fp),free((void *)(p))) static gethfunc headline; -static int headline(char *s, void *pp); -static PICTURE * openpicture(char *fname); -static int tmap_picture(char *fname, PICTURE *pp); -static int tmap_tiff(char *fname, TIFF *tp); -static int putimage(uint16 or, uint32 xs, uint32 ys, float xr, float yr, +static int headline(char *s, void *pp); +static PICTURE *openpicture(char *fname); +static int tmap_picture(char *fname, PICTURE *pp); +static int tmap_tiff(char *fname, TIFF *tp); +static int putimage(uint16 or, uint32 xs, uint32 ys, float xr, float yr, uint16 ru, BYTE *pd); @@ -96,6 +96,9 @@ main( if (argc-i < 2) goto userr; lddyn = atof(argv[++i]); break; + case 'z': /* LZW compression */ + comp = COMPRESSION_LZW; + break; case 'p': /* set display primaries */ if (argc-i < 9) goto userr; myprims[RED][CIEX] = atof(argv[++i]); @@ -134,7 +137,7 @@ main( exit(rval==0 ? 0 : 1); userr: fprintf(stderr, -"Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-p xr yr xg yg xb yb xw yw] input.{tif|pic} output.tif\n", +"Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-z][-p xr yr xg yg xb yb xw yw] input.{tif|pic} output.tif\n", argv[0]); exit(1); } @@ -208,6 +211,7 @@ tmap_picture( /* tone map Radiance picture */ ) { uint16 orient; + double paspect = (pp->rs.rt & YMAJOR) ? pp->pa : 1./pp->pa; int xsiz, ysiz; BYTE *pix; /* read and tone map picture */ @@ -221,7 +225,7 @@ tmap_picture( /* tone map Radiance picture */ orient++; /* put out our image */ if (putimage(orient, (uint32)xsiz, (uint32)ysiz, - 72., 72./pp->pa, 2, pix) != 0) + 72., 72./paspect, 2, pix) != 0) return(-1); /* free data and we're done */ free((void *)pix); @@ -269,7 +273,7 @@ putimage( /* write out our image */ uint32 ys, float xr, float yr, - uint16 ru, + uint16 ru, BYTE *pd ) { @@ -294,6 +298,7 @@ putimage( /* write out our image */ TIFFSetField(tifout, TIFFTAG_IMAGEWIDTH, xs); TIFFSetField(tifout, TIFFTAG_IMAGELENGTH, ys); TIFFSetField(tifout, TIFFTAG_RESOLUTIONUNIT, ru); + TIFFSetField(tifout, TIFFTAG_COMPRESSION, comp); TIFFSetField(tifout, TIFFTAG_XRESOLUTION, xr); TIFFSetField(tifout, TIFFTAG_YRESOLUTION, yr); TIFFSetField(tifout, TIFFTAG_PLANARCONFIG, PLANARCONFIG_CONTIG);
