root/radiance/ray/src/px/normtiff.c
Revision: 3.5
Committed: Mon Jul 14 04:56:54 2003 UTC (21 years, 10 months ago) by greg
Changes since 3.4: +2 -9 lines
2 static const char RCSid[] = "$Id: normtiff.c,v 3.4 2003/02/22 02:07:27 greg Exp $";
5 * Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF
6 */
7
8 #include <stdio.h>
9 #include <math.h>
10 #include <time.h>
11 #include "tiffio.h"
12 #include "color.h"
13 #include "tonemap.h"
14 #include "resolu.h"
15
16
17 TIFF *tifout; /* TIFF output */
18 int flags = TM_F_CAMERA; /* tone-mapping flags */
19 RGBPRIMP rgbp = stdprims; /* display primaries */
20 RGBPRIMS myprims; /* overriding display primaries */
21 double ldmax = 100.; /* maximum display luminance */
22 double lddyn = 32.; /* display dynamic range */
23 double gamv = 2.2; /* display gamma value */
24
25 short ortab[8] = { /* orientation conversion table */
26 YMAJOR|YDECR,
27 YMAJOR|YDECR|XDECR,
28 YMAJOR|XDECR,
29 YMAJOR,
30 YDECR,
31 XDECR|YDECR,
32 XDECR,
33 0
34 };
35
36 typedef struct {
37 FILE *fp; /* file pointer */
38 char fmt[32]; /* picture format */
39 double pa; /* pixel aspect ratio */
40 RESOLU rs; /* picture resolution */
41 } PICTURE;
42
43 extern PICTURE *openpicture();
44
45 #define closepicture(p) (fclose((p)->fp),free((void *)(p)))
46
47
48 main(argc, argv)
49 int argc;
50 char *argv[];
51 {
52 PICTURE *pin = NULL;
53 TIFF *tin = NULL;
54 int i, rval;
55
56 for (i = 1; i < argc && argv[i][0] == '-'; i++)
57 switch (argv[i][1]) {
58 case 'h': /* human observer settings */
59 flags = TM_F_HUMAN;
60 break;
61 case 's': /* toggle human contrast */
62 flags ^= TM_F_HCONTR;
63 break;
64 case 'c': /* toggle mesopic sens. */
65 flags ^= TM_F_MESOPIC;
66 break;
67 case 'l': /* toggle linear mapping */
68 flags ^= TM_F_LINEAR;
69 break;
70 case 'b': /* toggle greyscale output */
71 flags ^= TM_F_BW;
72 break;
73 case 'g': /* set display gamma */
74 if (argc-i < 2) goto userr;
75 gamv = atof(argv[++i]);
76 break;
77 case 'u': /* set display maximum */
78 if (argc-i < 2) goto userr;
79 ldmax = atof(argv[++i]);
80 break;
81 case 'd': /* set display dynamic range */
82 if (argc-i < 2) goto userr;
83 lddyn = atof(argv[++i]);
84 break;
85 case 'p': /* set display primaries */
86 if (argc-i < 9) goto userr;
87 myprims[RED][CIEX] = atof(argv[++i]);
88 myprims[RED][CIEY] = atof(argv[++i]);
89 myprims[GRN][CIEX] = atof(argv[++i]);
90 myprims[GRN][CIEY] = atof(argv[++i]);
91 myprims[BLU][CIEX] = atof(argv[++i]);
92 myprims[BLU][CIEY] = atof(argv[++i]);
93 myprims[WHT][CIEX] = atof(argv[++i]);
94 myprims[WHT][CIEY] = atof(argv[++i]);
95 rgbp = myprims;
96 break;
97 default:
98 goto userr;
99 }
100 if (argc-i < 2) goto userr;
101 if ((pin = openpicture(argv[i])) == NULL &&
102 (tin = TIFFOpen(argv[i], "r")) == NULL) {
103 fprintf(stderr, "%s: cannot open or interpret file \"%s\"\n",
104 argv[0], argv[i]);
105 exit(1);
106 }
107 if ((tifout = TIFFOpen(argv[i+1], "w")) == NULL) {
108 fprintf(stderr, "%s: cannot open output TIFF \"%s\"\n",
109 argv[0], argv[i+1]);
110 exit(1);
111 }
112 if (pin != NULL) {
113 rval = tmap_picture(argv[i], pin);
114 closepicture(pin);
115 } else {
116 rval = tmap_tiff(argv[i], tin);
117 TIFFClose(tin);
118 }
119 TIFFClose(tifout);
120 exit(rval==0 ? 0 : 1);
121 userr:
122 fprintf(stderr,
123 "Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-p xr yr xg yg xb yb xw yw] input.{tif|pic} output.tif\n",
124 argv[0]);
125 exit(1);
126 }
127
128
129 int
130 headline(s, pp) /* process line from header */
131 char *s;
132 register PICTURE *pp;
133 {
134 register char *cp;
135
136 for (cp = s; *cp; cp++)
137 if (*cp & 0x80)
138 return(-1); /* non-ascii in header */
139 if (isaspect(s))
140 pp->pa *= aspectval(s);
141 else
142 formatval(pp->fmt, s);
143 return(0);
144 }
145
146
147 PICTURE *
148 openpicture(fname) /* open/check Radiance picture file */
149 char *fname;
150 {
151 FILE *fp;
152 register PICTURE *pp;
153 register char *cp;
154 /* check filename suffix */
155 if (fname == NULL) return(NULL);
156 for (cp = fname; *cp; cp++)
157 ;
158 while (cp > fname && cp[-1] != '.')
159 if (*--cp == '/') {
160 cp = fname;
161 break;
162 }
163 if (cp > fname && !strncmp(cp, "tif", 3))
164 return(NULL); /* assume it's a TIFF */
165 /* else try opening it */
166 if ((fp = fopen(fname, "r")) == NULL)
167 return(NULL);
168 /* allocate struct */
169 if ((pp = (PICTURE *)malloc(sizeof(PICTURE))) == NULL)
170 return(NULL); /* serious error -- should exit? */
171 pp->fp = fp; pp->fmt[0] = '\0'; pp->pa = 1.;
172 /* load header */
173 if (getheader(fp, headline, (char *)pp) < 0) {
174 closepicture(pp);
175 return(NULL);
176 }
177 if (!pp->fmt[0]) /* assume RGBE if unspecified */
178 strcpy(pp->fmt, COLRFMT);
179 if (!globmatch(PICFMT, pp->fmt) || !fgetsresolu(&pp->rs, fp)) {
180 closepicture(pp); /* failed test -- close file */
181 return(NULL);
182 }
183 rewind(fp); /* passed test -- rewind file */
184 return(pp);
185 }
186
187
188 int
189 tmap_picture(fname, pp) /* tone map Radiance picture */
190 char *fname;
191 register PICTURE *pp;
192 {
193 uint16 orient;
194 int xsiz, ysiz;
195 BYTE *pix;
196 /* read and tone map picture */
197 if (tmMapPicture(&pix, &xsiz, &ysiz, flags,
198 rgbp, gamv, lddyn, ldmax, fname, pp->fp) != TM_E_OK)
199 return(-1);
200 /* figure out TIFF orientation */
201 for (orient = 8; --orient; )
202 if (ortab[orient] == pp->rs.rt)
203 break;
204 orient++;
205 /* put out our image */
206 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
207 72., 72./pp->pa, 2, pix) != 0)
208 return(-1);
209 /* free data and we're done */
210 free((void *)pix);
211 return(0);
212 }
213
214
215 tmap_tiff(fname, tp) /* tone map SGILOG TIFF */
216 char *fname;
217 TIFF *tp;
218 {
219 float xres, yres;
220 uint16 orient, resunit, phot;
221 int xsiz, ysiz;
222 BYTE *pix;
223 /* check to make sure it's SGILOG */
224 TIFFGetFieldDefaulted(tp, TIFFTAG_PHOTOMETRIC, &phot);
225 if (phot == PHOTOMETRIC_LOGL | phot == PHOTOMETRIC_MINISBLACK)
226 flags |= TM_F_BW;
227 /* read and tone map TIFF */
228 if (tmMapTIFF(&pix, &xsiz, &ysiz, flags,
229 rgbp, gamv, lddyn, ldmax, fname, tp) != TM_E_OK)
230 return(-1);
231 /* get relevant tags */
232 TIFFGetFieldDefaulted(tp, TIFFTAG_RESOLUTIONUNIT, &resunit);
233 TIFFGetFieldDefaulted(tp, TIFFTAG_XRESOLUTION, &xres);
234 TIFFGetFieldDefaulted(tp, TIFFTAG_YRESOLUTION, &yres);
235 TIFFGetFieldDefaulted(tp, TIFFTAG_ORIENTATION, &orient);
236 /* put out our image */
237 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
238 xres, yres, resunit, pix) != 0)
239 return(-1);
240 /* free data and we're done */
241 free((void *)pix);
242 return(0);
243 }
244
245
246 putimage(or, xs, ys, xr, yr, ru, pd) /* write out our image */
247 uint16 or;
248 uint32 xs, ys;
249 float xr, yr;
250 uint16 ru;
251 BYTE *pd;
252 {
253 register int y;
254 uint32 rowsperstrip;
255
256 TIFFSetField(tifout, TIFFTAG_COMPRESSION, COMPRESSION_NONE);
257 if (flags & TM_F_BW) {
258 TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC,
259 PHOTOMETRIC_MINISBLACK);
260 TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 1);
261 } else {
262 TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC, PHOTOMETRIC_RGB);
263 TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 3);
264 }
265 if (rgbp != stdprims) {
266 TIFFSetField(tifout, TIFFTAG_PRIMARYCHROMATICITIES,
267 (float *)rgbp);
268 TIFFSetField(tifout, TIFFTAG_WHITEPOINT, (float *)rgbp[WHT]);
269 }
270 TIFFSetField(tifout, TIFFTAG_BITSPERSAMPLE, 8);
271 TIFFSetField(tifout, TIFFTAG_IMAGEWIDTH, xs);
272 TIFFSetField(tifout, TIFFTAG_IMAGELENGTH, ys);
273 TIFFSetField(tifout, TIFFTAG_RESOLUTIONUNIT, ru);
274 TIFFSetField(tifout, TIFFTAG_XRESOLUTION, xr);
275 TIFFSetField(tifout, TIFFTAG_YRESOLUTION, yr);
276 TIFFSetField(tifout, TIFFTAG_PLANARCONFIG, PLANARCONFIG_CONTIG);
277 TIFFSetField(tifout, TIFFTAG_ORIENTATION, or);
278 /* compute good strip size */
279 rowsperstrip = 8192/TIFFScanlineSize(tifout);
280 if (rowsperstrip < 1) rowsperstrip = 1;
281 TIFFSetField(tifout, TIFFTAG_ROWSPERSTRIP, rowsperstrip);
282 /* write out scanlines */
283 if (flags & TM_F_BW) {
284 for (y = 0; y < ys; y++)
285 if (TIFFWriteScanline(tifout, pd + y*xs, y, 0) < 0)
286 goto writerr;
287 } else {
288 for (y = 0; y < ys; y++)
289 if (TIFFWriteScanline(tifout, pd + y*3*xs, y, 0) < 0)
290 goto writerr;
291 }
292 return(0); /* all done! */
293 writerr:
294 fputs("Error writing TIFF output\n", stderr);
295 return(-1);
296 }
