--- ray/src/px/normtiff.c 1998/10/26 17:30:50 3.2 +++ ray/src/px/normtiff.c 2004/01/02 11:42:37 3.7 @@ -1,18 +1,15 @@ -/* Copyright (c) 1998 Silicon Graphics, Inc. */ - #ifndef lint -static char SCCSid[] = "$SunId$ SGI"; +static const char RCSid[] = "$Id: normtiff.c,v 3.7 2004/01/02 11:42:37 schorsch Exp $"; #endif - /* * Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF */ -#undef NOPROTO -#define NOPROTO 1 - #include #include +#include +#include + #include "tiffio.h" #include "color.h" #include "tonemap.h" @@ -38,14 +35,27 @@ short ortab[8] = { /* orientation conversion table */ 0 }; -extern FILE *openpicture(); +typedef struct { + FILE *fp; /* file pointer */ + char fmt[32]; /* picture format */ + double pa; /* pixel aspect ratio */ + RESOLU rs; /* picture resolution */ +} PICTURE; +extern PICTURE *openpicture(); -main(argc, argv) -int argc; -char *argv[]; +#define closepicture(p) (fclose((p)->fp),free((void *)(p))) + +static gethfunc headline; + + +int +main( + int argc, + char *argv[] +) { - FILE *fin = NULL; + PICTURE *pin = NULL; TIFF *tin = NULL; int i, rval; @@ -94,7 +104,7 @@ char *argv[]; goto userr; } if (argc-i < 2) goto userr; - if ((fin = openpicture(argv[i])) == NULL && + if ((pin = openpicture(argv[i])) == NULL && (tin = TIFFOpen(argv[i], "r")) == NULL) { fprintf(stderr, "%s: cannot open or interpret file \"%s\"\n", argv[0], argv[i]); @@ -105,9 +115,9 @@ char *argv[]; argv[0], argv[i+1]); exit(1); } - if (fin != NULL) { - rval = tmap_picture(argv[i], fin); - fclose(fin); + if (pin != NULL) { + rval = tmap_picture(argv[i], pin); + closepicture(pin); } else { rval = tmap_tiff(argv[i], tin); TIFFClose(tin); @@ -122,13 +132,31 @@ userr: } -FILE * +static int +headline( /* process line from header */ + char *s, + void *pp +) +{ + register char *cp; + + for (cp = s; *cp; cp++) + if (*cp & 0x80) + return(-1); /* non-ascii in header */ + if (isaspect(s)) + ((PICTURE *)pp)->pa *= aspectval(s); + else + formatval(((PICTURE *)pp)->fmt, s); + return(0); +} + + +PICTURE * openpicture(fname) /* open/check Radiance picture file */ char *fname; { FILE *fp; - char inpfmt[32]; - int xsiz, ysiz; + register PICTURE *pp; register char *cp; /* check filename suffix */ if (fname == NULL) return(NULL); @@ -144,58 +172,49 @@ char *fname; /* else try opening it */ if ((fp = fopen(fname, "r")) == NULL) return(NULL); - /* check format */ - strcpy(inpfmt, PICFMT); - if (checkheader(fp, inpfmt, NULL) < 0 || - fgetresolu(&xsiz, &ysiz, fp) < 0) { - fclose(fp); /* failed test -- close file */ + /* allocate struct */ + if ((pp = (PICTURE *)malloc(sizeof(PICTURE))) == NULL) + return(NULL); /* serious error -- should exit? */ + pp->fp = fp; pp->fmt[0] = '\0'; pp->pa = 1.; + /* load header */ + if (getheader(fp, headline, pp) < 0) { + closepicture(pp); return(NULL); } + if (!pp->fmt[0]) /* assume RGBE if unspecified */ + strcpy(pp->fmt, COLRFMT); + if (!globmatch(PICFMT, pp->fmt) || !fgetsresolu(&pp->rs, fp)) { + closepicture(pp); /* failed test -- close file */ + return(NULL); + } rewind(fp); /* passed test -- rewind file */ - return(fp); + return(pp); } -getpixrat(s, pr) /* get pixel aspect ratio */ -char *s; -double *pr; -{ - if (isaspect(s)) - *pr *= aspectval(s); -} - - int -tmap_picture(fname, fp) /* tone map Radiance picture */ +tmap_picture(fname, pp) /* tone map Radiance picture */ char *fname; -FILE *fp; +register PICTURE *pp; { - double pixrat; - int ord; uint16 orient; int xsiz, ysiz; BYTE *pix; /* read and tone map picture */ if (tmMapPicture(&pix, &xsiz, &ysiz, flags, - rgbp, gamv, lddyn, ldmax, fname, fp) != TM_E_OK) + rgbp, gamv, lddyn, ldmax, fname, pp->fp) != TM_E_OK) return(-1); - /* get relevant header info. */ - rewind(fp); - pixrat = 1.; - getheader(fp, getpixrat, &pixrat); - if ((ord = fgetresolu(&xsiz, &ysiz, fp)) < 0) - orient = 0; - else - for (orient = 8; --orient; ) - if (ortab[orient] == ord) - break; + /* figure out TIFF orientation */ + for (orient = 8; --orient; ) + if (ortab[orient] == pp->rs.rt) + break; orient++; /* put out our image */ if (putimage(orient, (uint32)xsiz, (uint32)ysiz, - 72., 72./pixrat, 2, pix) != 0) + 72., 72./pp->pa, 2, pix) != 0) return(-1); /* free data and we're done */ - free((char *)pix); + free((void *)pix); return(0); } @@ -210,14 +229,7 @@ TIFF *tp; BYTE *pix; /* check to make sure it's SGILOG */ TIFFGetFieldDefaulted(tp, TIFFTAG_PHOTOMETRIC, &phot); - if (phot != PHOTOMETRIC_LOGLUV && phot != PHOTOMETRIC_LOGL) { - if (!(flags & TM_F_NOSTDERR)) { - fputs(fname, stderr); - fputs(": TIFF must be in SGILOG format\n", stderr); - } - return(-1); - } - if (phot == PHOTOMETRIC_LOGL) + if ((phot == PHOTOMETRIC_LOGL) | (phot == PHOTOMETRIC_MINISBLACK)) flags |= TM_F_BW; /* read and tone map TIFF */ if (tmMapTIFF(&pix, &xsiz, &ysiz, flags, @@ -233,7 +245,7 @@ TIFF *tp; xres, yres, resunit, pix) != 0) return(-1); /* free data and we're done */ - free((char *)pix); + free((void *)pix); return(0); }
