root/Development/ray/src/px/normtiff.c
Revision: 3.4
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 10 months ago) by greg
Changes since 3.3: +7 -12 lines
# User Rev Content
1 gwlarson 3.1 #ifndef lint
2 greg 3.4 static const char RCSid[] = "$Id$";
3 gwlarson 3.1 #endif
4     /*
5     * Tone map SGILOG TIFF or Radiance picture and output 24-bit RGB TIFF
6     */
7
8     #include <stdio.h>
9     #include <math.h>
10 greg 3.4 #include <time.h>
11 gwlarson 3.1 #include "tiffio.h"
12     #include "color.h"
13     #include "tonemap.h"
14     #include "resolu.h"
15
16
17     TIFF *tifout; /* TIFF output */
18     int flags = TM_F_CAMERA; /* tone-mapping flags */
19     RGBPRIMP rgbp = stdprims; /* display primaries */
20     RGBPRIMS myprims; /* overriding display primaries */
21     double ldmax = 100.; /* maximum display luminance */
22     double lddyn = 32.; /* display dynamic range */
23     double gamv = 2.2; /* display gamma value */
24
25     short ortab[8] = { /* orientation conversion table */
26     YMAJOR|YDECR,
27     YMAJOR|YDECR|XDECR,
28     YMAJOR|XDECR,
29     YMAJOR,
30     YDECR,
31     XDECR|YDECR,
32     XDECR,
33     0
34     };
35
36 gwlarson 3.3 typedef struct {
37     FILE *fp; /* file pointer */
38     char fmt[32]; /* picture format */
39     double pa; /* pixel aspect ratio */
40     RESOLU rs; /* picture resolution */
41     } PICTURE;
42 gwlarson 3.1
43 gwlarson 3.3 extern PICTURE *openpicture();
44 gwlarson 3.1
45 greg 3.4 #define closepicture(p) (fclose((p)->fp),free((void *)(p)))
46 gwlarson 3.3
47
48 gwlarson 3.1 main(argc, argv)
49     int argc;
50     char *argv[];
51     {
52 gwlarson 3.3 PICTURE *pin = NULL;
53 gwlarson 3.1 TIFF *tin = NULL;
54 gwlarson 3.2 int i, rval;
55 gwlarson 3.1
56     for (i = 1; i < argc && argv[i][0] == '-'; i++)
57     switch (argv[i][1]) {
58     case 'h': /* human observer settings */
59     flags = TM_F_HUMAN;
60     break;
61     case 's': /* toggle human contrast */
62     flags ^= TM_F_HCONTR;
63     break;
64     case 'c': /* toggle mesopic sens. */
65     flags ^= TM_F_MESOPIC;
66     break;
67     case 'l': /* toggle linear mapping */
68     flags ^= TM_F_LINEAR;
69     break;
70     case 'b': /* toggle greyscale output */
71     flags ^= TM_F_BW;
72     break;
73     case 'g': /* set display gamma */
74     if (argc-i < 2) goto userr;
75     gamv = atof(argv[++i]);
76     break;
77     case 'u': /* set display maximum */
78     if (argc-i < 2) goto userr;
79     ldmax = atof(argv[++i]);
80     break;
81     case 'd': /* set display dynamic range */
82     if (argc-i < 2) goto userr;
83     lddyn = atof(argv[++i]);
84     break;
85     case 'p': /* set display primaries */
86     if (argc-i < 9) goto userr;
87     myprims[RED][CIEX] = atof(argv[++i]);
88     myprims[RED][CIEY] = atof(argv[++i]);
89     myprims[GRN][CIEX] = atof(argv[++i]);
90     myprims[GRN][CIEY] = atof(argv[++i]);
91     myprims[BLU][CIEX] = atof(argv[++i]);
92     myprims[BLU][CIEY] = atof(argv[++i]);
93     myprims[WHT][CIEX] = atof(argv[++i]);
94     myprims[WHT][CIEY] = atof(argv[++i]);
95     rgbp = myprims;
96     break;
97     default:
98     goto userr;
99     }
100     if (argc-i < 2) goto userr;
101 gwlarson 3.3 if ((pin = openpicture(argv[i])) == NULL &&
102 gwlarson 3.1 (tin = TIFFOpen(argv[i], "r")) == NULL) {
103     fprintf(stderr, "%s: cannot open or interpret file \"%s\"\n",
104     argv[0], argv[i]);
105     exit(1);
106     }
107     if ((tifout = TIFFOpen(argv[i+1], "w")) == NULL) {
108     fprintf(stderr, "%s: cannot open output TIFF \"%s\"\n",
109     argv[0], argv[i+1]);
110     exit(1);
111     }
112 gwlarson 3.3 if (pin != NULL) {
113     rval = tmap_picture(argv[i], pin);
114     closepicture(pin);
115 gwlarson 3.1 } else {
116 gwlarson 3.2 rval = tmap_tiff(argv[i], tin);
117 gwlarson 3.1 TIFFClose(tin);
118     }
119     TIFFClose(tifout);
120 gwlarson 3.2 exit(rval==0 ? 0 : 1);
121 gwlarson 3.1 userr:
122     fprintf(stderr,
123     "Usage: %s [-h][-s][-c][-l][-b][-g gv][-d ld][-u lm][-p xr yr xg yg xb yb xw yw] input.{tif|pic} output.tif\n",
124     argv[0]);
125     exit(1);
126     }
127
128
129 gwlarson 3.3 int
130     headline(s, pp) /* process line from header */
131     char *s;
132     register PICTURE *pp;
133     {
134     register char *cp;
135
136     for (cp = s; *cp; cp++)
137     if (*cp & 0x80)
138     return(-1); /* non-ascii in header */
139     if (isaspect(s))
140     pp->pa *= aspectval(s);
141     else
142     formatval(pp->fmt, s);
143     return(0);
144     }
145
146
147     PICTURE *
148 gwlarson 3.1 openpicture(fname) /* open/check Radiance picture file */
149     char *fname;
150     {
151     FILE *fp;
152 gwlarson 3.3 register PICTURE *pp;
153 gwlarson 3.1 register char *cp;
154     /* check filename suffix */
155     if (fname == NULL) return(NULL);
156     for (cp = fname; *cp; cp++)
157     ;
158     while (cp > fname && cp[-1] != '.')
159     if (*--cp == '/') {
160     cp = fname;
161     break;
162     }
163     if (cp > fname && !strncmp(cp, "tif", 3))
164     return(NULL); /* assume it's a TIFF */
165     /* else try opening it */
166     if ((fp = fopen(fname, "r")) == NULL)
167     return(NULL);
168 gwlarson 3.3 /* allocate struct */
169     if ((pp = (PICTURE *)malloc(sizeof(PICTURE))) == NULL)
170     return(NULL); /* serious error -- should exit? */
171     pp->fp = fp; pp->fmt[0] = '\0'; pp->pa = 1.;
172     /* load header */
173 greg 3.4 if (getheader(fp, headline, (char *)pp) < 0) {
174 gwlarson 3.3 closepicture(pp);
175 gwlarson 3.1 return(NULL);
176     }
177 gwlarson 3.3 if (!pp->fmt[0]) /* assume RGBE if unspecified */
178     strcpy(pp->fmt, COLRFMT);
179     if (!globmatch(PICFMT, pp->fmt) || !fgetsresolu(&pp->rs, fp)) {
180     closepicture(pp); /* failed test -- close file */
181     return(NULL);
182     }
183 gwlarson 3.1 rewind(fp); /* passed test -- rewind file */
184 gwlarson 3.3 return(pp);
185 gwlarson 3.1 }
186
187
188 gwlarson 3.2 int
189 gwlarson 3.3 tmap_picture(fname, pp) /* tone map Radiance picture */
190 gwlarson 3.1 char *fname;
191 gwlarson 3.3 register PICTURE *pp;
192 gwlarson 3.1 {
193     uint16 orient;
194     int xsiz, ysiz;
195     BYTE *pix;
196     /* read and tone map picture */
197     if (tmMapPicture(&pix, &xsiz, &ysiz, flags,
198 gwlarson 3.3 rgbp, gamv, lddyn, ldmax, fname, pp->fp) != TM_E_OK)
199 gwlarson 3.2 return(-1);
200 gwlarson 3.3 /* figure out TIFF orientation */
201     for (orient = 8; --orient; )
202 greg 3.4 if (ortab[orient] == pp->rs.rt)
203 gwlarson 3.3 break;
204 gwlarson 3.1 orient++;
205     /* put out our image */
206 gwlarson 3.2 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
207 gwlarson 3.3 72., 72./pp->pa, 2, pix) != 0)
208 gwlarson 3.2 return(-1);
209 gwlarson 3.1 /* free data and we're done */
210 greg 3.4 free((void *)pix);
211 gwlarson 3.2 return(0);
212 gwlarson 3.1 }
213
214
215     tmap_tiff(fname, tp) /* tone map SGILOG TIFF */
216     char *fname;
217     TIFF *tp;
218     {
219     float xres, yres;
220     uint16 orient, resunit, phot;
221     int xsiz, ysiz;
222     BYTE *pix;
223     /* check to make sure it's SGILOG */
224     TIFFGetFieldDefaulted(tp, TIFFTAG_PHOTOMETRIC, &phot);
225     if (phot != PHOTOMETRIC_LOGLUV && phot != PHOTOMETRIC_LOGL) {
226 gwlarson 3.2 if (!(flags & TM_F_NOSTDERR)) {
227     fputs(fname, stderr);
228     fputs(": TIFF must be in SGILOG format\n", stderr);
229     }
230     return(-1);
231 gwlarson 3.1 }
232     if (phot == PHOTOMETRIC_LOGL)
233     flags |= TM_F_BW;
234     /* read and tone map TIFF */
235     if (tmMapTIFF(&pix, &xsiz, &ysiz, flags,
236     rgbp, gamv, lddyn, ldmax, fname, tp) != TM_E_OK)
237 gwlarson 3.2 return(-1);
238 gwlarson 3.1 /* get relevant tags */
239     TIFFGetFieldDefaulted(tp, TIFFTAG_RESOLUTIONUNIT, &resunit);
240     TIFFGetFieldDefaulted(tp, TIFFTAG_XRESOLUTION, &xres);
241     TIFFGetFieldDefaulted(tp, TIFFTAG_YRESOLUTION, &yres);
242     TIFFGetFieldDefaulted(tp, TIFFTAG_ORIENTATION, &orient);
243     /* put out our image */
244 gwlarson 3.2 if (putimage(orient, (uint32)xsiz, (uint32)ysiz,
245     xres, yres, resunit, pix) != 0)
246     return(-1);
247 gwlarson 3.1 /* free data and we're done */
248 greg 3.4 free((void *)pix);
249 gwlarson 3.2 return(0);
250 gwlarson 3.1 }
251
252
253     putimage(or, xs, ys, xr, yr, ru, pd) /* write out our image */
254     uint16 or;
255     uint32 xs, ys;
256     float xr, yr;
257     uint16 ru;
258     BYTE *pd;
259     {
260     register int y;
261     uint32 rowsperstrip;
262
263     TIFFSetField(tifout, TIFFTAG_COMPRESSION, COMPRESSION_NONE);
264     if (flags & TM_F_BW) {
265     TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC,
266     PHOTOMETRIC_MINISBLACK);
267     TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 1);
268     } else {
269     TIFFSetField(tifout, TIFFTAG_PHOTOMETRIC, PHOTOMETRIC_RGB);
270     TIFFSetField(tifout, TIFFTAG_SAMPLESPERPIXEL, 3);
271     }
272     if (rgbp != stdprims) {
273     TIFFSetField(tifout, TIFFTAG_PRIMARYCHROMATICITIES,
274     (float *)rgbp);
275     TIFFSetField(tifout, TIFFTAG_WHITEPOINT, (float *)rgbp[WHT]);
276     }
277     TIFFSetField(tifout, TIFFTAG_BITSPERSAMPLE, 8);
278     TIFFSetField(tifout, TIFFTAG_IMAGEWIDTH, xs);
279     TIFFSetField(tifout, TIFFTAG_IMAGELENGTH, ys);
280     TIFFSetField(tifout, TIFFTAG_RESOLUTIONUNIT, ru);
281     TIFFSetField(tifout, TIFFTAG_XRESOLUTION, xr);
282     TIFFSetField(tifout, TIFFTAG_YRESOLUTION, yr);
283     TIFFSetField(tifout, TIFFTAG_PLANARCONFIG, PLANARCONFIG_CONTIG);
284     TIFFSetField(tifout, TIFFTAG_ORIENTATION, or);
285     /* compute good strip size */
286     rowsperstrip = 8192/TIFFScanlineSize(tifout);
287     if (rowsperstrip < 1) rowsperstrip = 1;
288     TIFFSetField(tifout, TIFFTAG_ROWSPERSTRIP, rowsperstrip);
289     /* write out scanlines */
290     if (flags & TM_F_BW) {
291     for (y = 0; y < ys; y++)
292     if (TIFFWriteScanline(tifout, pd + y*xs, y, 0) < 0)
293     goto writerr;
294     } else {
295     for (y = 0; y < ys; y++)
296     if (TIFFWriteScanline(tifout, pd + y*3*xs, y, 0) < 0)
297     goto writerr;
298     }
299 gwlarson 3.2 return(0); /* all done! */
300 gwlarson 3.1 writerr:
301     fputs("Error writing TIFF output\n", stderr);
302 gwlarson 3.2 return(-1);
303 gwlarson 3.1 }
