root/radiance/ray/src/px/normpat.csh
Revision: 2.7
Committed: Mon Aug 25 04:50:32 2008 UTC (15 years, 8 months ago) by greg
Content type: application/x-csh
CVS Tags: rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3
Made temporary files safe from malicious attackers
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 2.7 # RCSid: $Id: normpat.csh,v 2.6 2005/02/16 05:40:11 greg Exp $
3 greg 1.1 #
4 greg 1.2 # Normalize a pattern for tiling (-b option blends edges) by removing
5 greg 1.5 # lowest frequencies from image (-f option) and reducing to
6     # standard size (-r option)
7 greg 1.1 #
8 greg 1.5 set ha=$0
9     set ha=$ha:t
10 greg 1.2 set pf="pfilt -e 2"
11     while ($#argv > 0)
12     switch ($argv[1])
13     case -r:
14     shift argv
15 greg 1.8 set pf="$pf -x $argv[1] -y $argv[1] -p 1 -r .67"
16 greg 1.2 breaksw
17 greg 1.5 case -f:
18     set ha="$ha -f"
19     set dofsub
20     breaksw
21 greg 1.2 case -b:
22 greg 1.5 set ha="$ha -b"
23 greg 1.2 set blend
24     breaksw
25 greg 1.3 case -v:
26     set verb
27     breaksw
28 greg 1.2 case -*:
29     echo bad option $argv[1]
30     exit 1
31     default:
32     goto dofiles
33     endsw
34     shift argv
35     end
36     dofiles:
37     onintr quit
38 greg 2.7 set td=`mktemp -d /tmp/np.XXXXXX`
39 greg 2.5 goto skipthis
40 greg 1.4 cat > $td/coef.fmt << '_EOF_'
41 greg 2.2 rm:${ $25 }; gm:${ $26 }; bm:${ $27 };
42     rcx:${ $1 }; gcx:${ $9 }; bcx:${ $17 };
43     rcy:${ $2 }; gcy:${ $10 }; bcy:${ $18 };
44     rsx:${ $3 }; gsx:${ $11 }; bsx:${ $19 };
45     rsy:${ $4 }; gsy:${ $12 }; bsy:${ $20 };
46     rcxcy:${ $5 }; gcxcy:${ $13 }; bcxcy:${ $21 };
47     rcxsy:${ $6 }; gcxsy:${ $14 }; bcxsy:${ $22 };
48     rsxcy:${ $7 }; gsxcy:${ $15 }; bsxcy:${ $23 };
49     rsxsy:${ $8 }; gsxsy:${ $16 }; bsxsy:${ $24 };
50 greg 1.4 '_EOF_'
51     cat > $td/coef.cal << '_EOF_'
52     $1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy;
53     $5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy;
54     $9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy;
55     $13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy;
56     $17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy;
57     $21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy;
58 greg 1.6 $25=$3; $26=$4; $27=$5;
59 greg 1.4 cx=cos(wx); cy=cos(wy);
60     sx=sin(wx); sy=sin(wy);
61 greg 2.3 wx=2*PI/xres*($1+.5); wy=2*PI/yres*($2+.5);
62 greg 1.4 '_EOF_'
63     cat > $td/fsub.cal << '_EOF_'
64 greg 2.2 PI:3.14159265358979323846;
65 greg 1.6 ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy
66     +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy);
67     go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy
68     +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy);
69     bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy
70     +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy);
71 greg 1.4 cx=cos(wx); cy=cos(wy);
72     sx=sin(wx); sy=sin(wy);
73 greg 2.3 wx=2*PI/xres*(x+.5); wy=2*PI/yres*(y+.5);
74 greg 1.4 '_EOF_'
75 greg 2.5 skipthis:
76 greg 1.1 foreach f ($*)
77 greg 1.3 if ( $?verb ) then
78     echo $f\:
79     echo adjusting exposure/size...
80     endif
81 greg 1.2 $pf $f > $td/pf
82     getinfo < $td/pf > $f
83     ed - $f << _EOF_
84     i
85     $ha
86     .
87     w
88     q
89     _EOF_
90 greg 2.5 set resolu=`getinfo -d < $td/pf | sed 's/-Y \([1-9][0-9]*\) +X \([1-9][0-9]*\)/\2 \1/'`
91 greg 1.5 if ( ! $?dofsub ) then
92     mv $td/pf $td/hf
93     goto donefsub
94     endif
95 greg 2.5 # if ( $?verb ) then
96     # echo computing Fourier coefficients...
97     # endif
98     # pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \
99     # | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \
100     # | total -m | rcalc -o $td/coef.fmt \
101     # > $td/coef
102 greg 1.3 if ( $?verb ) then
103 greg 2.5 # cat $td/coef
104 greg 1.3 echo removing low frequencies...
105     endif
106 greg 2.5 pgblur -r `ev "sqrt($resolu[1]*$resolu[2])/8"` $td/pf > $td/lf
107     pcomb -e 's=1/li(2);ro=s*ri(1);go=s*gi(1);bo=s*bi(1)' \
108     $td/pf $td/lf > $td/hf
109     # pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf
110 greg 1.5 donefsub:
111 greg 1.2 if ( $?blend ) then
112 greg 1.3 if ( $?verb ) then
113     echo blending edges...
114     endif
115 greg 1.2 @ mar= $resolu[1] - 3
116 greg 1.7 @ les= $resolu[1] - 1
117     pcompos -x 1 $td/hf 0 0 | pfilt -1 -x 3 > $td/left
118     pcompos $td/hf -$les 0 | pfilt -1 -x 3 > $td/right
119 greg 1.2 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
120     -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \
121     $td/right $td/left > $td/left.patch
122     pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
123     -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \
124     $td/left $td/right > $td/right.patch
125     pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \
126     > $td/hflr
127     @ mar= $resolu[2] - 3
128 greg 1.7 @ les= $resolu[2] - 1
129     pcompos -y 1 $td/hflr 0 0 | pfilt -1 -y 3 > $td/bottom
130     pcompos $td/hflr 0 -$les | pfilt -1 -y 3 > $td/top
131 greg 1.2 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
132     -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \
133     $td/top $td/bottom > $td/bottom.patch
134     pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
135     -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \
136     $td/bottom $td/top > $td/top.patch
137     pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \
138     | getinfo - >> $f
139 greg 1.5 else
140     getinfo - < $td/hf >> $f
141 greg 1.2 endif
142 greg 1.3 if ( $?verb ) then
143     echo $f done.
144     endif
145 greg 1.1 end
146 greg 1.2 quit:
147     rm -rf $td
