root/radiance/ray/src/px/normpat.csh
Thu Jun 22 16:40:11 2023 UTC (2 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 1.6
fix(normpat,pacuity,vlpic): Made handling of resolution string more robust
Mon Aug 25 04:50:32 2008 UTC (16 years, 11 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.6 , to selected 1.6
Made temporary files safe from malicious attackers
Wed Feb 16 05:40:11 2005 UTC (20 years, 5 months ago) by greg
Diff to previous 2.5 , to selected 1.6
Thu Jan 29 22:18:26 2004 UTC (21 years, 6 months ago) by greg
Changes since 2.4: +16 -11 lines
Diff to previous 2.4 , to selected 1.6
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Diff to previous 2.3 , to selected 1.6
Wed Jun 2 15:49:27 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.2: +4 -6 lines
Diff to previous 2.2 , to selected 1.6
minor optimizations
Sun Jan 5 18:14:47 1992 UTC (33 years, 7 months ago) by greg
Changes since 2.1: +11 -11 lines
Diff to previous 2.1 , to selected 1.6
added constants for slightly faster pcomb computation
Tue Nov 12 16:04:37 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.8 , to selected 1.6
Tue Jan 8 12:45:06 1991 UTC (34 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 1.6
use pfilt -r for changes in resolution
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Tue Jan 8 12:28:05 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.6: +6 -4 lines
Diff to previous 1.6
changed blending to use one line from each edge
Revision 1.6 - (view) (download) (as text) (annotate) - [selected]
Sat Jan 5 08:38:50 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.5: +16 -12 lines
Diff to previous 1.5
fixed discoloration by changing to factor rather than sum in fsub
Fri Jan 4 23:36:35 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +16 -11 lines
Diff to previous 1.4 , to selected 1.6
made Fourier transform optional
Fri Jan 4 23:01:51 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +38 -12 lines
Diff to previous 1.3 , to selected 1.6
changed to Fourier analysis on each primary color
Fri Jan 4 16:54:25 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +28 -14 lines
Diff to previous 1.2 , to selected 1.6
fixed calculation of normalization
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Jan 4 12:05:59 1991 UTC (34 years, 7 months ago) by greg
Changes since 1.1: +82 -7 lines
Diff to previous 1.1 , to selected 1.6
added edge blending and resolution options
Thu Jan 3 18:01:36 1991 UTC (34 years, 7 months ago) by greg
Diff to selected 1.6
Links to HEAD: (view) (download) (as text) (annotate) Links to rad6R0: (view) (download) (as text) (annotate)
