--- ray/src/px/normpat.csh 1993/06/02 15:49:27 2.3 +++ ray/src/px/normpat.csh 2005/02/16 05:40:11 2.6 @@ -1,5 +1,5 @@ #!/bin/csh -f -# SCCSid "$SunId$ LBL" +# RCSid: $Id: normpat.csh,v 2.6 2005/02/16 05:40:11 greg Exp $ # # Normalize a pattern for tiling (-b option blends edges) by removing # lowest frequencies from image (-f option) and reducing to @@ -35,8 +35,9 @@ while ($#argv > 0) end dofiles: onintr quit -set td=/usr/tmp/np$$ +set td=/tmp/np$$ mkdir $td +goto skipthis cat > $td/coef.fmt << '_EOF_' rm:${ $25 }; gm:${ $26 }; bm:${ $27 }; rcx:${ $1 }; gcx:${ $9 }; bcx:${ $17 }; @@ -72,6 +73,7 @@ cx=cos(wx); cy=cos(wy); sx=sin(wx); sy=sin(wy); wx=2*PI/xres*(x+.5); wy=2*PI/yres*(y+.5); '_EOF_' +skipthis: foreach f ($*) if ( $?verb ) then echo $f\: @@ -86,23 +88,26 @@ $ha w q _EOF_ - set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` + set resolu=`getinfo -d < $td/pf | sed 's/-Y \([1-9][0-9]*\) +X \([1-9][0-9]*\)/\2 \1/'` if ( ! $?dofsub ) then mv $td/pf $td/hf goto donefsub endif + # if ( $?verb ) then + # echo computing Fourier coefficients... + # endif + # pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ + # | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \ + # | total -m | rcalc -o $td/coef.fmt \ + # > $td/coef if ( $?verb ) then - echo computing Fourier coefficients... - endif - pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ - | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \ - | total -m | rcalc -o $td/coef.fmt \ - > $td/coef - if ( $?verb ) then - cat $td/coef + # cat $td/coef echo removing low frequencies... endif - pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf + pgblur -r `ev "sqrt($resolu[1]*$resolu[2])/8"` $td/pf > $td/lf + pcomb -e 's=1/li(2);ro=s*ri(1);go=s*gi(1);bo=s*bi(1)' \ + $td/pf $td/lf > $td/hf + # pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf donefsub: if ( $?blend ) then if ( $?verb ) then
