--- ray/src/px/normpat.csh 1991/01/04 16:54:25 1.3 +++ ray/src/px/normpat.csh 1991/01/04 23:36:35 1.5 @@ -2,8 +2,11 @@ # SCCSid "$SunId$ LBL" # # Normalize a pattern for tiling (-b option blends edges) by removing -# lowest frequencies from image and reducing to standard size (-r option) +# lowest frequencies from image (-f option) and reducing to +# standard size (-r option) # +set ha=$0 +set ha=$ha:t set pf="pfilt -e 2" while ($#argv > 0) switch ($argv[1]) @@ -11,7 +14,12 @@ while ($#argv > 0) shift argv set pf="$pf -x $argv[1] -y $argv[1] -p 1" breaksw + case -f: + set ha="$ha -f" + set dofsub + breaksw case -b: + set ha="$ha -b" set blend breaksw case -v: @@ -29,13 +37,37 @@ dofiles: onintr quit set td=/usr/tmp/np$$ mkdir $td -set ha=$0 -set ha=$ha:t -if ( $?blend ) then - set ha="$ha -b" -else - mknod $td/hf p -endif +cat > $td/coef.fmt << '_EOF_' + rcx=${ $1 }; rcy=${ $2 }; rsx=${ $3 }; rsy=${ $4 }; +rcxcy=${ $5 }; rcxsy=${ $6 }; rsxcy=${ $7 }; rsxsy=${ $8 }; + gcx=${ $9 }; gcy=${ $10 }; gsx=${ $11 }; gsy=${ $12 }; +gcxcy=${ $13 }; gcxsy=${ $14 }; gsxcy=${ $15 }; gsxsy=${ $16 }; + bcx=${ $17 }; bcy=${ $18 }; bsx=${ $19 }; bsy=${ $20 }; +bcxcy=${ $21 }; bcxsy=${ $22 }; bsxcy=${ $23 }; bsxsy=${ $24 }; +'_EOF_' +cat > $td/coef.cal << '_EOF_' +$1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy; +$5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy; +$9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy; +$13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy; +$17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy; +$21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy; +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI*($1+.5)/xres; wy=2*PI*($2+.5)/yres; +'_EOF_' +cat > $td/fsub.cal << '_EOF_' +ro=ri(1)-rcx*cx-rcy*cy-rsx*sx-rsy*sy + -rcxcy*cx*cy-rcxsy*cx*sy-rsxcy*sx*cy-rsxsy*sx*sy; +go=gi(1)-gcx*cx-gcy*cy-gsx*sx-gsy*sy + -gcxcy*cx*cy-gcxsy*cx*sy-gsxcy*sx*cy-gsxsy*sx*sy; +bo=bi(1)-bcx*cx-bcy*cy-bsx*sx-bsy*sy + -bcxcy*cx*cy-bcxsy*cx*sy-bsxcy*sx*cy-bsxsy*sx*sy; +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI*(x+.5)/xres; wy=2*PI*(y+.5)/yres; +PI=3.14159265358979323846; +'_EOF_' foreach f ($*) if ( $?verb ) then echo $f\: @@ -51,28 +83,25 @@ w q _EOF_ set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` + if ( ! $?dofsub ) then + mv $td/pf $td/hf + goto donefsub + endif if ( $?verb ) then echo computing Fourier coefficients... endif - set coef=`pfilt -1 -x 32 -y 32 $td/pf | pvalue -h -b | rcalc -e '$1=2*$3*cos(wx);$2=2*$3*cos(wy);$3=2*$3*sin(wx);$4=2*$3*sin(wy);$5=4*$3*cos(wx)*cos(wy);$6=4*$3*cos(wx)*sin(wy);$7=4*$3*sin(wx)*cos(wy);$8=4*$3*sin(wx)*sin(wy);' -e 'wx=2*PI/32*$1;wy=2*PI/32*$2' | total -m` + pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ + | rcalc -f $td/coef.cal -e 'xres=32;yres=32' \ + | total -m | rcalc -o $td/coef.fmt \ + > $td/coef if ( $?verb ) then - echo "cosx cosy sinx siny" - echo $coef[1-4] - echo "cosx*cosy cosx*siny sinx*cosy sinx*siny" - echo $coef[5-8] + cat $td/coef echo removing low frequencies... endif - if ( ! $?blend ) then - ( getinfo - < $td/hf >> $f & ) > /dev/null - endif - pcomb -e 'ro=f*ri(1);go=f*gi(1);bo=f*bi(1);f=(i-fc-fs-f0-f1)/i' \ - -e 'i=.263*ri(1)+.655*gi(1)+.082*bi(1)' \ - -e "fc=$coef[1]*cos(wx)+$coef[2]*cos(wy)" \ - -e "fs=$coef[3]*sin(wx)+$coef[4]*sin(wy)" \ - -e "f0=$coef[5]*cos(wx)*cos(wy)+$coef[6]*cos(wx)*sin(wy)" \ - -e "f1=$coef[7]*sin(wx)*cos(wy)+$coef[8]*sin(wx)*sin(wy)" \ - -e "wx=2*3.1416/$resolu[1]*x;wy=2*3.1416/$resolu[2]*y" \ + pcomb -f $td/fsub.cal -f $td/coef \ + -e "xres=$resolu[1];yres=$resolu[2]" \ $td/pf > $td/hf + donefsub: if ( $?blend ) then if ( $?verb ) then echo blending edges... @@ -99,6 +128,8 @@ _EOF_ $td/bottom $td/top > $td/top.patch pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \ | getinfo - >> $f + else + getinfo - < $td/hf >> $f endif if ( $?verb ) then echo $f done.
