--- ray/src/px/normpat.csh 1991/01/03 18:01:36 1.1 +++ ray/src/px/normpat.csh 2008/08/25 04:50:32 2.7 @@ -1,19 +1,147 @@ #!/bin/csh -f -# SCCSid "$SunId$ LBL" +# RCSid: $Id: normpat.csh,v 2.7 2008/08/25 04:50:32 greg Exp $ # -# Normalize a picture to make it suitable as a tiling pattern. -# This script reduces the image and removes the lowest frequencies. +# Normalize a pattern for tiling (-b option blends edges) by removing +# lowest frequencies from image (-f option) and reducing to +# standard size (-r option) # +set ha=$0 +set ha=$ha:t +set pf="pfilt -e 2" +while ($#argv > 0) + switch ($argv[1]) + case -r: + shift argv + set pf="$pf -x $argv[1] -y $argv[1] -p 1 -r .67" + breaksw + case -f: + set ha="$ha -f" + set dofsub + breaksw + case -b: + set ha="$ha -b" + set blend + breaksw + case -v: + set verb + breaksw + case -*: + echo bad option $argv[1] + exit 1 + default: + goto dofiles + endsw + shift argv +end +dofiles: +onintr quit +set td=`mktemp -d /tmp/np.XXXXXX` +goto skipthis +cat > $td/coef.fmt << '_EOF_' + rm:${ $25 }; gm:${ $26 }; bm:${ $27 }; + rcx:${ $1 }; gcx:${ $9 }; bcx:${ $17 }; + rcy:${ $2 }; gcy:${ $10 }; bcy:${ $18 }; + rsx:${ $3 }; gsx:${ $11 }; bsx:${ $19 }; + rsy:${ $4 }; gsy:${ $12 }; bsy:${ $20 }; +rcxcy:${ $5 }; gcxcy:${ $13 }; bcxcy:${ $21 }; +rcxsy:${ $6 }; gcxsy:${ $14 }; bcxsy:${ $22 }; +rsxcy:${ $7 }; gsxcy:${ $15 }; bsxcy:${ $23 }; +rsxsy:${ $8 }; gsxsy:${ $16 }; bsxsy:${ $24 }; +'_EOF_' +cat > $td/coef.cal << '_EOF_' +$1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy; +$5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy; +$9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy; +$13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy; +$17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy; +$21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy; +$25=$3; $26=$4; $27=$5; +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI/xres*($1+.5); wy=2*PI/yres*($2+.5); +'_EOF_' +cat > $td/fsub.cal << '_EOF_' +PI:3.14159265358979323846; +ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy + +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy); +go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy + +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy); +bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy + +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy); +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI/xres*(x+.5); wy=2*PI/yres*(y+.5); +'_EOF_' +skipthis: foreach f ($*) - pfilt -e 2 -x 128 -y 128 -p 1 $f > np$$ - set resolu=`getinfo -d < np$$ | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` - set coef=`pfilt -1 -x 32 -y 32 np$$ | pvalue -h -b | rcalc -e '$1=2*$3*cos(wx);$2=2*$3*cos(wy);$3=2*$3*sin(wx);$4=2*$3*sin(wy);$5=4*$3*cos(wx)*cos(wy);$6=4*$3*cos(wx)*sin(wy);$7=4*$3*sin(wx)*cos(wy);$8=4*$3*sin(wx)*sin(wy);' -e 'wx=2*PI/32*$1;wy=2*PI/32*$2' | total -m` - pcomb -e 'ro=ri(1)*f;go=gi(1)*f;bo=bi(1)*f;f=1-fc-fs-f0-f1' \ - -e "fc=$coef[1]*cos(wx)+$coef[2]*cos(wy)" \ - -e "fs=$coef[3]*sin(wx)+$coef[4]*sin(wy)" \ - -e "f0=$coef[5]*cos(wx)*cos(wy)+$coef[6]*cos(wx)*sin(wy)" \ - -e "f1=$coef[7]*sin(wx)*cos(wy)+$coef[8]*sin(wx)*sin(wy)" \ - -e "wx=2*3.1416/$resolu[1]*x;wy=2*3.1416/$resolu[2]*y" \ - np$$ > $f - rm np$$ + if ( $?verb ) then + echo $f\: + echo adjusting exposure/size... + endif + $pf $f > $td/pf + getinfo < $td/pf > $f + ed - $f << _EOF_ +i +$ha +. +w +q +_EOF_ + set resolu=`getinfo -d < $td/pf | sed 's/-Y \([1-9][0-9]*\) +X \([1-9][0-9]*\)/\2 \1/'` + if ( ! $?dofsub ) then + mv $td/pf $td/hf + goto donefsub + endif + # if ( $?verb ) then + # echo computing Fourier coefficients... + # endif + # pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ + # | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \ + # | total -m | rcalc -o $td/coef.fmt \ + # > $td/coef + if ( $?verb ) then + # cat $td/coef + echo removing low frequencies... + endif + pgblur -r `ev "sqrt($resolu[1]*$resolu[2])/8"` $td/pf > $td/lf + pcomb -e 's=1/li(2);ro=s*ri(1);go=s*gi(1);bo=s*bi(1)' \ + $td/pf $td/lf > $td/hf + # pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf + donefsub: + if ( $?blend ) then + if ( $?verb ) then + echo blending edges... + endif + @ mar= $resolu[1] - 3 + @ les= $resolu[1] - 1 + pcompos -x 1 $td/hf 0 0 | pfilt -1 -x 3 > $td/left + pcompos $td/hf -$les 0 | pfilt -1 -x 3 > $td/right + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \ + $td/right $td/left > $td/left.patch + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \ + $td/left $td/right > $td/right.patch + pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \ + > $td/hflr + @ mar= $resolu[2] - 3 + @ les= $resolu[2] - 1 + pcompos -y 1 $td/hflr 0 0 | pfilt -1 -y 3 > $td/bottom + pcompos $td/hflr 0 -$les | pfilt -1 -y 3 > $td/top + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \ + $td/top $td/bottom > $td/bottom.patch + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \ + $td/bottom $td/top > $td/top.patch + pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \ + | getinfo - >> $f + else + getinfo - < $td/hf >> $f + endif + if ( $?verb ) then + echo $f done. + endif end +quit: +rm -rf $td
