root/radiance/ray/src/px/normpat.csh
Revision: 1.4
Committed: Fri Jan 4 23:01:51 1991 UTC (34 years, 6 months ago) by greg
Content type: application/x-csh
Changes since 1.3: +38 -12 lines
changed to Fourier analysis on each primary color
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Normalize a pattern for tiling (-b option blends edges) by removing
5 # lowest frequencies from image and reducing to standard size (-r option)
6 #
7 set pf="pfilt -e 2"
8 while ($#argv > 0)
9 switch ($argv[1])
10 case -r:
11 shift argv
12 set pf="$pf -x $argv[1] -y $argv[1] -p 1"
13 breaksw
14 case -b:
15 set blend
16 breaksw
17 case -v:
18 set verb
19 breaksw
20 case -*:
21 echo bad option $argv[1]
22 exit 1
23 default:
24 goto dofiles
25 endsw
26 shift argv
27 end
28 dofiles:
29 onintr quit
30 set td=/usr/tmp/np$$
31 mkdir $td
32 set ha=$0
33 set ha=$ha:t
34 if ( $?blend ) then
35 set ha="$ha -b"
36 else
37 mknod $td/hf p
38 endif
39 cat > $td/coef.fmt << '_EOF_'
40 rcx=${ $1 }; rcy=${ $2 }; rsx=${ $3 }; rsy=${ $4 };
41 rcxcy=${ $5 }; rcxsy=${ $6 }; rsxcy=${ $7 }; rsxsy=${ $8 };
42 gcx=${ $9 }; gcy=${ $10 }; gsx=${ $11 }; gsy=${ $12 };
43 gcxcy=${ $13 }; gcxsy=${ $14 }; gsxcy=${ $15 }; gsxsy=${ $16 };
44 bcx=${ $17 }; bcy=${ $18 }; bsx=${ $19 }; bsy=${ $20 };
45 bcxcy=${ $21 }; bcxsy=${ $22 }; bsxcy=${ $23 }; bsxsy=${ $24 };
46 '_EOF_'
47 cat > $td/coef.cal << '_EOF_'
48 $1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy;
49 $5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy;
50 $9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy;
51 $13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy;
52 $17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy;
53 $21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy;
54 cx=cos(wx); cy=cos(wy);
55 sx=sin(wx); sy=sin(wy);
56 wx=2*PI*($1+.5)/xres; wy=2*PI*($2+.5)/yres;
57 '_EOF_'
58 cat > $td/fsub.cal << '_EOF_'
59 ro=ri(1)-rcx*cx-rcy*cy-rsx*sx-rsy*sy
60 -rcxcy*cx*cy-rcxsy*cx*sy-rsxcy*sx*cy-rsxsy*sx*sy;
61 go=gi(1)-gcx*cx-gcy*cy-gsx*sx-gsy*sy
62 -gcxcy*cx*cy-gcxsy*cx*sy-gsxcy*sx*cy-gsxsy*sx*sy;
63 bo=bi(1)-bcx*cx-bcy*cy-bsx*sx-bsy*sy
64 -bcxcy*cx*cy-bcxsy*cx*sy-bsxcy*sx*cy-bsxsy*sx*sy;
65 cx=cos(wx); cy=cos(wy);
66 sx=sin(wx); sy=sin(wy);
67 wx=2*PI*(x+.5)/xres; wy=2*PI*(y+.5)/yres;
68 PI=3.14159265358979323846;
69 '_EOF_'
70 foreach f ($*)
71 if ( $?verb ) then
72 echo $f\:
73 echo adjusting exposure/size...
74 endif
75 $pf $f > $td/pf
76 getinfo < $td/pf > $f
77 ed - $f << _EOF_
78 i
79 $ha
80 .
81 w
82 q
83 _EOF_
84 set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'`
85 if ( $?verb ) then
86 echo computing Fourier coefficients...
87 endif
88 pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \
89 | rcalc -f $td/coef.cal -e 'xres=32;yres=32' \
90 | total -m | rcalc -o $td/coef.fmt \
91 > $td/coef
92 if ( $?verb ) then
93 cat $td/coef
94 echo removing low frequencies...
95 endif
96 if ( ! $?blend ) then
97 ( getinfo - < $td/hf >> $f & ) > /dev/null
98 endif
99 pcomb -f $td/fsub.cal -f $td/coef \
100 -e "xres=$resolu[1];yres=$resolu[2]" \
101 $td/pf > $td/hf
102 if ( $?blend ) then
103 if ( $?verb ) then
104 echo blending edges...
105 endif
106 @ mar= $resolu[1] - 3
107 pcompos -x 3 $td/hf 0 0 > $td/left
108 pcompos $td/hf -$mar 0 > $td/right
109 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
110 -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \
111 $td/right $td/left > $td/left.patch
112 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
113 -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \
114 $td/left $td/right > $td/right.patch
115 pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \
116 > $td/hflr
117 @ mar= $resolu[2] - 3
118 pcompos -y 3 $td/hflr 0 0 > $td/bottom
119 pcompos $td/hflr 0 -$mar > $td/top
120 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
121 -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \
122 $td/top $td/bottom > $td/bottom.patch
123 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
124 -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \
125 $td/bottom $td/top > $td/top.patch
126 pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \
127 | getinfo - >> $f
128 endif
129 if ( $?verb ) then
130 echo $f done.
131 endif
132 end
133 quit:
134 rm -rf $td
