root/radiance/ray/src/px/normpat.csh
Revision: 2.6
Committed: Wed Feb 16 05:40:11 2005 UTC (20 years, 2 months ago) by greg
Content type: application/x-csh
CVS Tags: rad3R7P2, rad3R7P1, rad3R8, rad3R9
# User Rev Content
1 greg 1.1 #!/bin/csh -f
2 greg 2.6 # RCSid: $Id: normpat.csh,v 2.5 2004/01/29 22:18:26 greg Exp $
3 greg 1.1 #
4 greg 1.2 # Normalize a pattern for tiling (-b option blends edges) by removing
5 greg 1.5 # lowest frequencies from image (-f option) and reducing to
6     # standard size (-r option)
7 greg 1.1 #
8 greg 1.5 set ha=$0
9     set ha=$ha:t
10 greg 1.2 set pf="pfilt -e 2"
11     while ($#argv > 0)
12     switch ($argv[1])
13     case -r:
14     shift argv
15 greg 1.8 set pf="$pf -x $argv[1] -y $argv[1] -p 1 -r .67"
16 greg 1.2 breaksw
17 greg 1.5 case -f:
18     set ha="$ha -f"
19     set dofsub
20     breaksw
21 greg 1.2 case -b:
22 greg 1.5 set ha="$ha -b"
23 greg 1.2 set blend
24     breaksw
25 greg 1.3 case -v:
26     set verb
27     breaksw
28 greg 1.2 case -*:
29     echo bad option $argv[1]
30     exit 1
31     default:
32     goto dofiles
33     endsw
34     shift argv
35     end
36     dofiles:
37     onintr quit
38 greg 2.6 set td=/tmp/np$$
39 greg 1.2 mkdir $td
40 greg 2.5 goto skipthis
41 greg 1.4 cat > $td/coef.fmt << '_EOF_'
42 greg 2.2 rm:${ $25 }; gm:${ $26 }; bm:${ $27 };
43     rcx:${ $1 }; gcx:${ $9 }; bcx:${ $17 };
44     rcy:${ $2 }; gcy:${ $10 }; bcy:${ $18 };
45     rsx:${ $3 }; gsx:${ $11 }; bsx:${ $19 };
46     rsy:${ $4 }; gsy:${ $12 }; bsy:${ $20 };
47     rcxcy:${ $5 }; gcxcy:${ $13 }; bcxcy:${ $21 };
48     rcxsy:${ $6 }; gcxsy:${ $14 }; bcxsy:${ $22 };
49     rsxcy:${ $7 }; gsxcy:${ $15 }; bsxcy:${ $23 };
50     rsxsy:${ $8 }; gsxsy:${ $16 }; bsxsy:${ $24 };
51 greg 1.4 '_EOF_'
52     cat > $td/coef.cal << '_EOF_'
53     $1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy;
54     $5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy;
55     $9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy;
56     $13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy;
57     $17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy;
58     $21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy;
59 greg 1.6 $25=$3; $26=$4; $27=$5;
60 greg 1.4 cx=cos(wx); cy=cos(wy);
61     sx=sin(wx); sy=sin(wy);
62 greg 2.3 wx=2*PI/xres*($1+.5); wy=2*PI/yres*($2+.5);
63 greg 1.4 '_EOF_'
64     cat > $td/fsub.cal << '_EOF_'
65 greg 2.2 PI:3.14159265358979323846;
66 greg 1.6 ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy
67     +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy);
68     go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy
69     +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy);
70     bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy
71     +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy);
72 greg 1.4 cx=cos(wx); cy=cos(wy);
73     sx=sin(wx); sy=sin(wy);
74 greg 2.3 wx=2*PI/xres*(x+.5); wy=2*PI/yres*(y+.5);
75 greg 1.4 '_EOF_'
76 greg 2.5 skipthis:
77 greg 1.1 foreach f ($*)
78 greg 1.3 if ( $?verb ) then
79     echo $f\:
80     echo adjusting exposure/size...
81     endif
82 greg 1.2 $pf $f > $td/pf
83     getinfo < $td/pf > $f
84     ed - $f << _EOF_
85     i
86     $ha
87     .
88     w
89     q
90     _EOF_
91 greg 2.5 set resolu=`getinfo -d < $td/pf | sed 's/-Y \([1-9][0-9]*\) +X \([1-9][0-9]*\)/\2 \1/'`
92 greg 1.5 if ( ! $?dofsub ) then
93     mv $td/pf $td/hf
94     goto donefsub
95     endif
96 greg 2.5 # if ( $?verb ) then
97     # echo computing Fourier coefficients...
98     # endif
99     # pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \
100     # | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \
101     # | total -m | rcalc -o $td/coef.fmt \
102     # > $td/coef
103 greg 1.3 if ( $?verb ) then
104 greg 2.5 # cat $td/coef
105 greg 1.3 echo removing low frequencies...
106     endif
107 greg 2.5 pgblur -r `ev "sqrt($resolu[1]*$resolu[2])/8"` $td/pf > $td/lf
108     pcomb -e 's=1/li(2);ro=s*ri(1);go=s*gi(1);bo=s*bi(1)' \
109     $td/pf $td/lf > $td/hf
110     # pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf
111 greg 1.5 donefsub:
112 greg 1.2 if ( $?blend ) then
113 greg 1.3 if ( $?verb ) then
114     echo blending edges...
115     endif
116 greg 1.2 @ mar= $resolu[1] - 3
117 greg 1.7 @ les= $resolu[1] - 1
118     pcompos -x 1 $td/hf 0 0 | pfilt -1 -x 3 > $td/left
119     pcompos $td/hf -$les 0 | pfilt -1 -x 3 > $td/right
120 greg 1.2 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
121     -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \
122     $td/right $td/left > $td/left.patch
123     pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
124     -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \
125     $td/left $td/right > $td/right.patch
126     pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \
127     > $td/hflr
128     @ mar= $resolu[2] - 3
129 greg 1.7 @ les= $resolu[2] - 1
130     pcompos -y 1 $td/hflr 0 0 | pfilt -1 -y 3 > $td/bottom
131     pcompos $td/hflr 0 -$les | pfilt -1 -y 3 > $td/top
132 greg 1.2 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
133     -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \
134     $td/top $td/bottom > $td/bottom.patch
135     pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
136     -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \
137     $td/bottom $td/top > $td/top.patch
138     pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \
139     | getinfo - >> $f
140 greg 1.5 else
141     getinfo - < $td/hf >> $f
142 greg 1.2 endif
143 greg 1.3 if ( $?verb ) then
144     echo $f done.
145     endif
146 greg 1.1 end
147 greg 1.2 quit:
148     rm -rf $td
