--- ray/src/px/normpat.csh 1991/01/04 23:01:51 1.4 +++ ray/src/px/normpat.csh 1993/06/02 15:49:27 2.3 @@ -2,16 +2,24 @@ # SCCSid "$SunId$ LBL" # # Normalize a pattern for tiling (-b option blends edges) by removing -# lowest frequencies from image and reducing to standard size (-r option) +# lowest frequencies from image (-f option) and reducing to +# standard size (-r option) # +set ha=$0 +set ha=$ha:t set pf="pfilt -e 2" while ($#argv > 0) switch ($argv[1]) case -r: shift argv - set pf="$pf -x $argv[1] -y $argv[1] -p 1" + set pf="$pf -x $argv[1] -y $argv[1] -p 1 -r .67" breaksw + case -f: + set ha="$ha -f" + set dofsub + breaksw case -b: + set ha="$ha -b" set blend breaksw case -v: @@ -29,20 +37,16 @@ dofiles: onintr quit set td=/usr/tmp/np$$ mkdir $td -set ha=$0 -set ha=$ha:t -if ( $?blend ) then - set ha="$ha -b" -else - mknod $td/hf p -endif cat > $td/coef.fmt << '_EOF_' - rcx=${ $1 }; rcy=${ $2 }; rsx=${ $3 }; rsy=${ $4 }; -rcxcy=${ $5 }; rcxsy=${ $6 }; rsxcy=${ $7 }; rsxsy=${ $8 }; - gcx=${ $9 }; gcy=${ $10 }; gsx=${ $11 }; gsy=${ $12 }; -gcxcy=${ $13 }; gcxsy=${ $14 }; gsxcy=${ $15 }; gsxsy=${ $16 }; - bcx=${ $17 }; bcy=${ $18 }; bsx=${ $19 }; bsy=${ $20 }; -bcxcy=${ $21 }; bcxsy=${ $22 }; bsxcy=${ $23 }; bsxsy=${ $24 }; + rm:${ $25 }; gm:${ $26 }; bm:${ $27 }; + rcx:${ $1 }; gcx:${ $9 }; bcx:${ $17 }; + rcy:${ $2 }; gcy:${ $10 }; bcy:${ $18 }; + rsx:${ $3 }; gsx:${ $11 }; bsx:${ $19 }; + rsy:${ $4 }; gsy:${ $12 }; bsy:${ $20 }; +rcxcy:${ $5 }; gcxcy:${ $13 }; bcxcy:${ $21 }; +rcxsy:${ $6 }; gcxsy:${ $14 }; bcxsy:${ $22 }; +rsxcy:${ $7 }; gsxcy:${ $15 }; bsxcy:${ $23 }; +rsxsy:${ $8 }; gsxsy:${ $16 }; bsxsy:${ $24 }; '_EOF_' cat > $td/coef.cal << '_EOF_' $1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy; @@ -51,21 +55,22 @@ $9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy; $13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy; $17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy; $21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy; +$25=$3; $26=$4; $27=$5; cx=cos(wx); cy=cos(wy); sx=sin(wx); sy=sin(wy); -wx=2*PI*($1+.5)/xres; wy=2*PI*($2+.5)/yres; +wx=2*PI/xres*($1+.5); wy=2*PI/yres*($2+.5); '_EOF_' cat > $td/fsub.cal << '_EOF_' -ro=ri(1)-rcx*cx-rcy*cy-rsx*sx-rsy*sy - -rcxcy*cx*cy-rcxsy*cx*sy-rsxcy*sx*cy-rsxsy*sx*sy; -go=gi(1)-gcx*cx-gcy*cy-gsx*sx-gsy*sy - -gcxcy*cx*cy-gcxsy*cx*sy-gsxcy*sx*cy-gsxsy*sx*sy; -bo=bi(1)-bcx*cx-bcy*cy-bsx*sx-bsy*sy - -bcxcy*cx*cy-bcxsy*cx*sy-bsxcy*sx*cy-bsxsy*sx*sy; +PI:3.14159265358979323846; +ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy + +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy); +go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy + +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy); +bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy + +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy); cx=cos(wx); cy=cos(wy); sx=sin(wx); sy=sin(wy); -wx=2*PI*(x+.5)/xres; wy=2*PI*(y+.5)/yres; -PI=3.14159265358979323846; +wx=2*PI/xres*(x+.5); wy=2*PI/yres*(y+.5); '_EOF_' foreach f ($*) if ( $?verb ) then @@ -82,30 +87,31 @@ w q _EOF_ set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` + if ( ! $?dofsub ) then + mv $td/pf $td/hf + goto donefsub + endif if ( $?verb ) then echo computing Fourier coefficients... endif pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ - | rcalc -f $td/coef.cal -e 'xres=32;yres=32' \ + | rcalc -e 'xres:32;yres:32' -f $td/coef.cal \ | total -m | rcalc -o $td/coef.fmt \ > $td/coef if ( $?verb ) then cat $td/coef echo removing low frequencies... endif - if ( ! $?blend ) then - ( getinfo - < $td/hf >> $f & ) > /dev/null - endif - pcomb -f $td/fsub.cal -f $td/coef \ - -e "xres=$resolu[1];yres=$resolu[2]" \ - $td/pf > $td/hf + pcomb -f $td/coef -f $td/fsub.cal $td/pf > $td/hf + donefsub: if ( $?blend ) then if ( $?verb ) then echo blending edges... endif @ mar= $resolu[1] - 3 - pcompos -x 3 $td/hf 0 0 > $td/left - pcompos $td/hf -$mar 0 > $td/right + @ les= $resolu[1] - 1 + pcompos -x 1 $td/hf 0 0 | pfilt -1 -x 3 > $td/left + pcompos $td/hf -$les 0 | pfilt -1 -x 3 > $td/right pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \ $td/right $td/left > $td/left.patch @@ -115,8 +121,9 @@ _EOF_ pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \ > $td/hflr @ mar= $resolu[2] - 3 - pcompos -y 3 $td/hflr 0 0 > $td/bottom - pcompos $td/hflr 0 -$mar > $td/top + @ les= $resolu[2] - 1 + pcompos -y 1 $td/hflr 0 0 | pfilt -1 -y 3 > $td/bottom + pcompos $td/hflr 0 -$les | pfilt -1 -y 3 > $td/top pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \ $td/top $td/bottom > $td/bottom.patch @@ -125,6 +132,8 @@ _EOF_ $td/bottom $td/top > $td/top.patch pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \ | getinfo - >> $f + else + getinfo - < $td/hf >> $f endif if ( $?verb ) then echo $f done.
