--- ray/src/px/normpat.csh 1991/01/03 18:01:36 1.1 +++ ray/src/px/normpat.csh 1991/01/04 16:54:25 1.3 @@ -1,19 +1,108 @@ #!/bin/csh -f # SCCSid "$SunId$ LBL" # -# Normalize a picture to make it suitable as a tiling pattern. -# This script reduces the image and removes the lowest frequencies. +# Normalize a pattern for tiling (-b option blends edges) by removing +# lowest frequencies from image and reducing to standard size (-r option) # +set pf="pfilt -e 2" +while ($#argv > 0) + switch ($argv[1]) + case -r: + shift argv + set pf="$pf -x $argv[1] -y $argv[1] -p 1" + breaksw + case -b: + set blend + breaksw + case -v: + set verb + breaksw + case -*: + echo bad option $argv[1] + exit 1 + default: + goto dofiles + endsw + shift argv +end +dofiles: +onintr quit +set td=/usr/tmp/np$$ +mkdir $td +set ha=$0 +set ha=$ha:t +if ( $?blend ) then + set ha="$ha -b" +else + mknod $td/hf p +endif foreach f ($*) - pfilt -e 2 -x 128 -y 128 -p 1 $f > np$$ - set resolu=`getinfo -d < np$$ | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` - set coef=`pfilt -1 -x 32 -y 32 np$$ | pvalue -h -b | rcalc -e '$1=2*$3*cos(wx);$2=2*$3*cos(wy);$3=2*$3*sin(wx);$4=2*$3*sin(wy);$5=4*$3*cos(wx)*cos(wy);$6=4*$3*cos(wx)*sin(wy);$7=4*$3*sin(wx)*cos(wy);$8=4*$3*sin(wx)*sin(wy);' -e 'wx=2*PI/32*$1;wy=2*PI/32*$2' | total -m` - pcomb -e 'ro=ri(1)*f;go=gi(1)*f;bo=bi(1)*f;f=1-fc-fs-f0-f1' \ + if ( $?verb ) then + echo $f\: + echo adjusting exposure/size... + endif + $pf $f > $td/pf + getinfo < $td/pf > $f + ed - $f << _EOF_ +i +$ha +. +w +q +_EOF_ + set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` + if ( $?verb ) then + echo computing Fourier coefficients... + endif + set coef=`pfilt -1 -x 32 -y 32 $td/pf | pvalue -h -b | rcalc -e '$1=2*$3*cos(wx);$2=2*$3*cos(wy);$3=2*$3*sin(wx);$4=2*$3*sin(wy);$5=4*$3*cos(wx)*cos(wy);$6=4*$3*cos(wx)*sin(wy);$7=4*$3*sin(wx)*cos(wy);$8=4*$3*sin(wx)*sin(wy);' -e 'wx=2*PI/32*$1;wy=2*PI/32*$2' | total -m` + if ( $?verb ) then + echo "cosx cosy sinx siny" + echo $coef[1-4] + echo "cosx*cosy cosx*siny sinx*cosy sinx*siny" + echo $coef[5-8] + echo removing low frequencies... + endif + if ( ! $?blend ) then + ( getinfo - < $td/hf >> $f & ) > /dev/null + endif + pcomb -e 'ro=f*ri(1);go=f*gi(1);bo=f*bi(1);f=(i-fc-fs-f0-f1)/i' \ + -e 'i=.263*ri(1)+.655*gi(1)+.082*bi(1)' \ -e "fc=$coef[1]*cos(wx)+$coef[2]*cos(wy)" \ -e "fs=$coef[3]*sin(wx)+$coef[4]*sin(wy)" \ -e "f0=$coef[5]*cos(wx)*cos(wy)+$coef[6]*cos(wx)*sin(wy)" \ -e "f1=$coef[7]*sin(wx)*cos(wy)+$coef[8]*sin(wx)*sin(wy)" \ -e "wx=2*3.1416/$resolu[1]*x;wy=2*3.1416/$resolu[2]*y" \ - np$$ > $f - rm np$$ + $td/pf > $td/hf + if ( $?blend ) then + if ( $?verb ) then + echo blending edges... + endif + @ mar= $resolu[1] - 3 + pcompos -x 3 $td/hf 0 0 > $td/left + pcompos $td/hf -$mar 0 > $td/right + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \ + $td/right $td/left > $td/left.patch + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \ + $td/left $td/right > $td/right.patch + pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \ + > $td/hflr + @ mar= $resolu[2] - 3 + pcompos -y 3 $td/hflr 0 0 > $td/bottom + pcompos $td/hflr 0 -$mar > $td/top + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \ + $td/top $td/bottom > $td/bottom.patch + pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \ + -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \ + $td/bottom $td/top > $td/top.patch + pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \ + | getinfo - >> $f + endif + if ( $?verb ) then + echo $f done. + endif end +quit: +rm -rf $td
