--- ray/src/px/normpat.csh 1991/01/04 12:05:59 1.2 +++ ray/src/px/normpat.csh 1991/01/05 08:38:50 1.6 @@ -2,8 +2,11 @@ # SCCSid "$SunId$ LBL" # # Normalize a pattern for tiling (-b option blends edges) by removing -# lowest frequencies from image and reducing to standard size (-r option) +# lowest frequencies from image (-f option) and reducing to +# standard size (-r option) # +set ha=$0 +set ha=$ha:t set pf="pfilt -e 2" while ($#argv > 0) switch ($argv[1]) @@ -11,9 +14,17 @@ while ($#argv > 0) shift argv set pf="$pf -x $argv[1] -y $argv[1] -p 1" breaksw + case -f: + set ha="$ha -f" + set dofsub + breaksw case -b: + set ha="$ha -b" set blend breaksw + case -v: + set verb + breaksw case -*: echo bad option $argv[1] exit 1 @@ -26,16 +37,46 @@ dofiles: onintr quit set td=/usr/tmp/np$$ mkdir $td -set ha=$0 -set ha=$ha:t -if ( $?blend ) then - set ha="$ha -b" -else - mknod $td/hf p -endif +cat > $td/coef.fmt << '_EOF_' + rm=${ $25 }; gm=${ $26 }; bm=${ $27 }; + rcx=${ $1 }; gcx=${ $9 }; bcx=${ $17 }; + rcy=${ $2 }; gcy=${ $10 }; bcy=${ $18 }; + rsx=${ $3 }; gsx=${ $11 }; bsx=${ $19 }; + rsy=${ $4 }; gsy=${ $12 }; bsy=${ $20 }; +rcxcy=${ $5 }; gcxcy=${ $13 }; bcxcy=${ $21 }; +rcxsy=${ $6 }; gcxsy=${ $14 }; bcxsy=${ $22 }; +rsxcy=${ $7 }; gsxcy=${ $15 }; bsxcy=${ $23 }; +rsxsy=${ $8 }; gsxsy=${ $16 }; bsxsy=${ $24 }; +'_EOF_' +cat > $td/coef.cal << '_EOF_' +$1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy; +$5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy; +$9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy; +$13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy; +$17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy; +$21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy; +$25=$3; $26=$4; $27=$5; +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI*($1+.5)/xres; wy=2*PI*($2+.5)/yres; +'_EOF_' +cat > $td/fsub.cal << '_EOF_' +ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy + +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy); +go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy + +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy); +bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy + +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy); +cx=cos(wx); cy=cos(wy); +sx=sin(wx); sy=sin(wy); +wx=2*PI*(x+.5)/xres; wy=2*PI*(y+.5)/yres; +PI=3.14159265358979323846; +'_EOF_' foreach f ($*) - echo $f\: - echo adjusting size/exposure... + if ( $?verb ) then + echo $f\: + echo adjusting exposure/size... + endif $pf $f > $td/pf getinfo < $td/pf > $f ed - $f << _EOF_ @@ -45,26 +86,30 @@ $ha w q _EOF_ - if ( ! $?blend ) then - getinfo - < $td/hf >> $f & - endif set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'` - echo computing Fourier coefficients... - set coef=`pfilt -1 -x 32 -y 32 $td/pf | pvalue -h -b | rcalc -e '$1=2*$3*cos(wx);$2=2*$3*cos(wy);$3=2*$3*sin(wx);$4=2*$3*sin(wy);$5=4*$3*cos(wx)*cos(wy);$6=4*$3*cos(wx)*sin(wy);$7=4*$3*sin(wx)*cos(wy);$8=4*$3*sin(wx)*sin(wy);' -e 'wx=2*PI/32*$1;wy=2*PI/32*$2' | total -m` - echo "cosx cosy sinx siny" - echo $coef[1-4] - echo "cosx*cosy cosx*siny sinx*cosy sinx*siny" - echo $coef[5-8] - echo removing low frequencies... - pcomb -e 'ro=ri(1)*f;go=gi(1)*f;bo=bi(1)*f;f=1-fc-fs-f0-f1' \ - -e "fc=$coef[1]*cos(wx)+$coef[2]*cos(wy)" \ - -e "fs=$coef[3]*sin(wx)+$coef[4]*sin(wy)" \ - -e "f0=$coef[5]*cos(wx)*cos(wy)+$coef[6]*cos(wx)*sin(wy)" \ - -e "f1=$coef[7]*sin(wx)*cos(wy)+$coef[8]*sin(wx)*sin(wy)" \ - -e "wx=2*3.1416/$resolu[1]*x;wy=2*3.1416/$resolu[2]*y" \ + if ( ! $?dofsub ) then + mv $td/pf $td/hf + goto donefsub + endif + if ( $?verb ) then + echo computing Fourier coefficients... + endif + pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \ + | rcalc -f $td/coef.cal -e 'xres=32;yres=32' \ + | total -m | rcalc -o $td/coef.fmt \ + > $td/coef + if ( $?verb ) then + cat $td/coef + echo removing low frequencies... + endif + pcomb -f $td/fsub.cal -f $td/coef \ + -e "xres=$resolu[1];yres=$resolu[2]" \ $td/pf > $td/hf + donefsub: if ( $?blend ) then - echo blending edges... + if ( $?verb ) then + echo blending edges... + endif @ mar= $resolu[1] - 3 pcompos -x 3 $td/hf 0 0 > $td/left pcompos $td/hf -$mar 0 > $td/right @@ -87,8 +132,12 @@ _EOF_ $td/bottom $td/top > $td/top.patch pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \ | getinfo - >> $f + else + getinfo - < $td/hf >> $f endif - echo $f done. + if ( $?verb ) then + echo $f done. + endif end quit: rm -rf $td
