root/radiance/ray/src/px/normpat.csh
Revision: 1.7
Committed: Tue Jan 8 12:28:05 1991 UTC (34 years, 6 months ago) by greg
Content type: application/x-csh
Changes since 1.6: +6 -4 lines
changed blending to use one line from each edge
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Normalize a pattern for tiling (-b option blends edges) by removing
5 # lowest frequencies from image (-f option) and reducing to
6 # standard size (-r option)
7 #
8 set ha=$0
9 set ha=$ha:t
10 set pf="pfilt -e 2"
11 while ($#argv > 0)
12 switch ($argv[1])
13 case -r:
14 shift argv
15 set pf="$pf -x $argv[1] -y $argv[1] -p 1"
16 breaksw
17 case -f:
18 set ha="$ha -f"
19 set dofsub
20 breaksw
21 case -b:
22 set ha="$ha -b"
23 set blend
24 breaksw
25 case -v:
26 set verb
27 breaksw
28 case -*:
29 echo bad option $argv[1]
30 exit 1
31 default:
32 goto dofiles
33 endsw
34 shift argv
35 end
36 dofiles:
37 onintr quit
38 set td=/usr/tmp/np$$
39 mkdir $td
40 cat > $td/coef.fmt << '_EOF_'
41 rm=${ $25 }; gm=${ $26 }; bm=${ $27 };
42 rcx=${ $1 }; gcx=${ $9 }; bcx=${ $17 };
43 rcy=${ $2 }; gcy=${ $10 }; bcy=${ $18 };
44 rsx=${ $3 }; gsx=${ $11 }; bsx=${ $19 };
45 rsy=${ $4 }; gsy=${ $12 }; bsy=${ $20 };
46 rcxcy=${ $5 }; gcxcy=${ $13 }; bcxcy=${ $21 };
47 rcxsy=${ $6 }; gcxsy=${ $14 }; bcxsy=${ $22 };
48 rsxcy=${ $7 }; gsxcy=${ $15 }; bsxcy=${ $23 };
49 rsxsy=${ $8 }; gsxsy=${ $16 }; bsxsy=${ $24 };
50 '_EOF_'
51 cat > $td/coef.cal << '_EOF_'
52 $1=$3*2*cx; $2=$3*2*cy; $3=$3*2*sx; $4=$3*2*sy;
53 $5=$3*4*cx*cy; $6=$3*4*cx*sy; $7=$3*4*sx*cy; $8=$3*4*sx*sy;
54 $9=$4*2*cx; $10=$4*2*cy; $11=$4*2*sx; $12=$4*2*sy;
55 $13=$4*4*cx*cy; $14=$4*4*cx*sy; $15=$4*4*sx*cy; $16=$4*4*sx*sy;
56 $17=$5*2*cx; $18=$5*2*cy; $19=$5*2*sx; $20=$5*2*sy;
57 $21=$5*4*cx*cy; $22=$5*4*cx*sy; $23=$5*4*sx*cy; $24=$5*4*sx*sy;
58 $25=$3; $26=$4; $27=$5;
59 cx=cos(wx); cy=cos(wy);
60 sx=sin(wx); sy=sin(wy);
61 wx=2*PI*($1+.5)/xres; wy=2*PI*($2+.5)/yres;
62 '_EOF_'
63 cat > $td/fsub.cal << '_EOF_'
64 ro=ri(1)*rm/(rm+rcx*cx+rcy*cy+rsx*sx+rsy*sy
65 +rcxcy*cx*cy+rcxsy*cx*sy+rsxcy*sx*cy+rsxsy*sx*sy);
66 go=gi(1)*gm/(gm+gcx*cx+gcy*cy+gsx*sx+gsy*sy
67 +gcxcy*cx*cy+gcxsy*cx*sy+gsxcy*sx*cy+gsxsy*sx*sy);
68 bo=bi(1)*bm/(bm+bcx*cx+bcy*cy+bsx*sx+bsy*sy
69 +bcxcy*cx*cy+bcxsy*cx*sy+bsxcy*sx*cy+bsxsy*sx*sy);
70 cx=cos(wx); cy=cos(wy);
71 sx=sin(wx); sy=sin(wy);
72 wx=2*PI*(x+.5)/xres; wy=2*PI*(y+.5)/yres;
73 PI=3.14159265358979323846;
74 '_EOF_'
75 foreach f ($*)
76 if ( $?verb ) then
77 echo $f\:
78 echo adjusting exposure/size...
79 endif
80 $pf $f > $td/pf
81 getinfo < $td/pf > $f
82 ed - $f << _EOF_
83 i
84 $ha
85 .
86 w
87 q
88 _EOF_
89 set resolu=`getinfo -d < $td/pf | sed 's/-Y \([0-9]*\) +X \([0-9]*\)/\2 \1/'`
90 if ( ! $?dofsub ) then
91 mv $td/pf $td/hf
92 goto donefsub
93 endif
94 if ( $?verb ) then
95 echo computing Fourier coefficients...
96 endif
97 pfilt -1 -x 32 -y 32 $td/pf | pvalue -h \
98 | rcalc -f $td/coef.cal -e 'xres=32;yres=32' \
99 | total -m | rcalc -o $td/coef.fmt \
100 > $td/coef
101 if ( $?verb ) then
102 cat $td/coef
103 echo removing low frequencies...
104 endif
105 pcomb -f $td/fsub.cal -f $td/coef \
106 -e "xres=$resolu[1];yres=$resolu[2]" \
107 $td/pf > $td/hf
108 donefsub:
109 if ( $?blend ) then
110 if ( $?verb ) then
111 echo blending edges...
112 endif
113 @ mar= $resolu[1] - 3
114 @ les= $resolu[1] - 1
115 pcompos -x 1 $td/hf 0 0 | pfilt -1 -x 3 > $td/left
116 pcompos $td/hf -$les 0 | pfilt -1 -x 3 > $td/right
117 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
118 -e 'f(p)=(3-x)/7*p(1)+(4+x)/7*p(2)' \
119 $td/right $td/left > $td/left.patch
120 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
121 -e 'f(p)=(1+x)/7*p(1)+(6-x)/7*p(2)' \
122 $td/left $td/right > $td/right.patch
123 pcompos $td/hf 0 0 $td/left.patch 0 0 $td/right.patch $mar 0 \
124 > $td/hflr
125 @ mar= $resolu[2] - 3
126 @ les= $resolu[2] - 1
127 pcompos -y 1 $td/hflr 0 0 | pfilt -1 -y 3 > $td/bottom
128 pcompos $td/hflr 0 -$les | pfilt -1 -y 3 > $td/top
129 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
130 -e 'f(p)=(3-y)/7*p(1)+(4+y)/7*p(2)' \
131 $td/top $td/bottom > $td/bottom.patch
132 pcomb -e 'ro=f(ri);go=f(gi);bo=f(bi)' \
133 -e 'f(p)=(1+y)/7*p(1)+(6-y)/7*p(2)' \
134 $td/bottom $td/top > $td/top.patch
135 pcompos $td/hflr 0 0 $td/bottom.patch 0 0 $td/top.patch 0 $mar \
136 | getinfo - >> $f
137 else
138 getinfo - < $td/hf >> $f
139 endif
140 if ( $?verb ) then
141 echo $f done.
142 endif
143 end
144 quit:
145 rm -rf $td
