| 1 |
/* Copyright (c) 1994 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Neural-Net quantization algorithm based on work of Anthony Dekker
| 9 |
| 10 |
| 11 |
#include "standard.h"
| 12 |
| 13 |
#include "color.h"
| 14 |
| 15 |
#include "random.h"
| 16 |
| 17 |
#ifdef COMPAT_MODE
| 18 |
#define neu_init new_histo
| 19 |
#define neu_pixel cnt_pixel
| 20 |
#define neu_colrs cnt_colrs
| 21 |
#define neu_clrtab new_clrtab
| 22 |
#define neu_map_pixel map_pixel
| 23 |
#define neu_map_colrs map_colrs
| 24 |
#define neu_dith_colrs dith_colrs
| 25 |
#endif
| 26 |
/* our color table (global) */
| 27 |
extern BYTE clrtab[256][3];
| 28 |
static int clrtabsiz;
| 29 |
| 30 |
#ifndef DEFSMPFAC
| 31 |
#ifdef SPEED
| 32 |
#define DEFSMPFAC (240/SPEED+3)
| 33 |
#else
| 34 |
#define DEFSMPFAC 30
| 35 |
#endif
| 36 |
#endif
| 37 |
| 38 |
int samplefac = DEFSMPFAC; /* sampling factor */
| 39 |
| 40 |
/* Samples array starts off holding spacing between adjacent
| 41 |
* samples, and ends up holding actual BGR sample values.
| 42 |
| 43 |
static BYTE *thesamples;
| 44 |
static int nsamples;
| 45 |
static BYTE *cursamp;
| 46 |
static long skipcount;
| 47 |
| 48 |
#define MAXSKIP (1<<24-1)
| 49 |
| 50 |
#define nskip(sp) ((long)(sp)[0]<<16|(long)(sp)[1]<<8|(long)(sp)[2])
| 51 |
| 52 |
#define setskip(sp,n) ((sp)[0]=(n)>>16,(sp)[1]=((n)>>8)&255,(sp)[2]=(n)&255)
| 53 |
| 54 |
| 55 |
neu_init(npixels) /* initialize our sample array */
| 56 |
long npixels;
| 57 |
| 58 |
register int nsleft;
| 59 |
register long sv;
| 60 |
double rval, cumprob;
| 61 |
long npleft;
| 62 |
| 63 |
nsamples = npixels/samplefac;
| 64 |
if (nsamples < 600)
| 65 |
return(-1);
| 66 |
thesamples = (BYTE *)malloc(nsamples*3);
| 67 |
if (thesamples == NULL)
| 68 |
return(-1);
| 69 |
cursamp = thesamples;
| 70 |
npleft = npixels;
| 71 |
nsleft = nsamples;
| 72 |
while (nsleft) {
| 73 |
rval = frandom(); /* random distance to next sample */
| 74 |
sv = 0;
| 75 |
cumprob = 0.;
| 76 |
while ((cumprob += (1.-cumprob)*nsleft/(npleft-sv)) < rval)
| 77 |
sv++;
| 78 |
if (nsleft == nsamples)
| 79 |
skipcount = sv;
| 80 |
else {
| 81 |
setskip(cursamp, sv);
| 82 |
cursamp += 3;
| 83 |
| 84 |
npleft -= sv+1;
| 85 |
nsleft--;
| 86 |
| 87 |
setskip(cursamp, npleft); /* tag on end to skip the rest */
| 88 |
| 89 |
return(0);
| 90 |
| 91 |
| 92 |
| 93 |
neu_pixel(col) /* add pixel to our samples */
| 94 |
register BYTE col[];
| 95 |
| 96 |
if (!skipcount--) {
| 97 |
skipcount = nskip(cursamp);
| 98 |
cursamp[0] = col[BLU];
| 99 |
cursamp[1] = col[GRN];
| 100 |
cursamp[2] = col[RED];
| 101 |
cursamp += 3;
| 102 |
| 103 |
| 104 |
| 105 |
| 106 |
neu_colrs(cs, n) /* add a scanline to our samples */
| 107 |
register COLR *cs;
| 108 |
register int n;
| 109 |
| 110 |
while (n > skipcount) {
| 111 |
cs += skipcount;
| 112 |
n -= skipcount+1;
| 113 |
| 114 |
cursamp[0] = cs[0][BLU];
| 115 |
cursamp[1] = cs[0][GRN];
| 116 |
cursamp[2] = cs[0][RED];
| 117 |
cs++;
| 118 |
cursamp += 3;
| 119 |
| 120 |
skipcount -= n;
| 121 |
| 122 |
| 123 |
| 124 |
neu_clrtab(ncolors) /* make new color table using ncolors */
| 125 |
int ncolors;
| 126 |
| 127 |
clrtabsiz = ncolors;
| 128 |
if (clrtabsiz > 256) clrtabsiz = 256;
| 129 |
initnet();
| 130 |
learn();
| 131 |
unbiasnet();
| 132 |
cpyclrtab();
| 133 |
inxbuild();
| 134 |
/* we're done with our samples */
| 135 |
free((char *)thesamples);
| 136 |
/* reset dithering function */
| 137 |
neu_dith_colrs((BYTE *)NULL, (COLR *)NULL, 0);
| 138 |
/* return new color table size */
| 139 |
return(clrtabsiz);
| 140 |
| 141 |
| 142 |
| 143 |
int
| 144 |
neu_map_pixel(col) /* get pixel for color */
| 145 |
| 146 |
| 147 |
return(inxsearch(col[BLU],col[GRN],col[RED]));
| 148 |
| 149 |
| 150 |
| 151 |
neu_map_colrs(bs, cs, n) /* convert a scanline to color index values */
| 152 |
register BYTE *bs;
| 153 |
register COLR *cs;
| 154 |
register int n;
| 155 |
| 156 |
while (n-- > 0) {
| 157 |
*bs++ = inxsearch(cs[0][BLU],cs[0][GRN],cs[0][RED]);
| 158 |
cs++;
| 159 |
| 160 |
| 161 |
| 162 |
| 163 |
neu_dith_colrs(bs, cs, n) /* convert scanline to dithered index values */
| 164 |
register BYTE *bs;
| 165 |
register COLR *cs;
| 166 |
int n;
| 167 |
| 168 |
static short (*cerr)[3] = NULL;
| 169 |
static int N = 0;
| 170 |
int err[3], errp[3];
| 171 |
register int x, i;
| 172 |
| 173 |
if (n != N) { /* get error propogation array */
| 174 |
if (N) {
| 175 |
free((char *)cerr);
| 176 |
cerr = NULL;
| 177 |
| 178 |
if (n)
| 179 |
cerr = (short (*)[3])malloc(3*n*sizeof(short));
| 180 |
if (cerr == NULL) {
| 181 |
N = 0;
| 182 |
map_colrs(bs, cs, n);
| 183 |
return;
| 184 |
| 185 |
N = n;
| 186 |
bzero((char *)cerr, 3*N*sizeof(short));
| 187 |
| 188 |
err[0] = err[1] = err[2] = 0;
| 189 |
for (x = 0; x < n; x++) {
| 190 |
for (i = 0; i < 3; i++) { /* dither value */
| 191 |
errp[i] = err[i];
| 192 |
err[i] += cerr[x][i];
| 193 |
#ifdef MAXERR
| 194 |
if (err[i] > MAXERR) err[i] = MAXERR;
| 195 |
else if (err[i] < -MAXERR) err[i] = -MAXERR;
| 196 |
#endif
| 197 |
err[i] += cs[x][i];
| 198 |
if (err[i] < 0) err[i] = 0;
| 199 |
else if (err[i] > 255) err[i] = 255;
| 200 |
| 201 |
bs[x] = inxsearch(err[BLU],err[GRN],err[RED]);
| 202 |
for (i = 0; i < 3; i++) { /* propagate error */
| 203 |
err[i] -= clrtab[bs[x]][i];
| 204 |
err[i] /= 3;
| 205 |
cerr[x][i] = err[i] + errp[i];
| 206 |
| 207 |
| 208 |
| 209 |
| 210 |
/* The following was adapted and modified from the original (GW) */
| 211 |
| 212 |
| 213 |
/* NeuQuant */
| 214 |
| 215 |
| 216 |
/* Copyright: Anthony Dekker, June 1994 */
| 217 |
| 218 |
/* This program performs colour quantization of graphics images (SUN */
| 219 |
/* raster files). It uses a Kohonen Neural Network. It produces */
| 220 |
/* better results than existing methods and runs faster, using minimal */
| 221 |
/* space (8kB plus the image itself). The algorithm is described in */
| 222 |
/* the paper "Kohonen Neural Networks for Optimal Colour Quantization" */
| 223 |
/* to appear in the journal "Network: Computation in Neural Systems". */
| 224 |
/* It is a significant improvement of an earlier algorithm. */
| 225 |
| 226 |
/* This program is distributed free for academic use or for evaluation */
| 227 |
/* by commercial organizations. */
| 228 |
| 229 |
/* Usage: NeuQuant -n inputfile > outputfile */
| 230 |
| 231 |
/* where n is a sampling factor for neural learning. */
| 232 |
| 233 |
/* Program performance compared with other methods is as follows: */
| 234 |
| 235 |
/* Algorithm | Av. CPU Time | Quantization Error */
| 236 |
| 237 |
/* NeuQuant -3 | 314 | 5.55 */
| 238 |
/* NeuQuant -10 | 119 | 5.97 */
| 239 |
/* NeuQuant -30 | 65 | 6.53 */
| 240 |
/* Oct-Trees | 141 | 8.96 */
| 241 |
/* Median Cut (XV -best) | 420 | 9.28 */
| 242 |
/* Median Cut (XV -slow) | 72 | 12.15 */
| 243 |
| 244 |
/* Author's address: Dept of ISCS, National University of Singapore */
| 245 |
/* Kent Ridge, Singapore 0511 */
| 246 |
/* Email: [email protected] */
| 247 |
| 248 |
| 249 |
#define bool int
| 250 |
#define false 0
| 251 |
#define true 1
| 252 |
| 253 |
#define initrad 32
| 254 |
#define radiusdec 30
| 255 |
#define alphadec 30
| 256 |
| 257 |
/* defs for freq and bias */
| 258 |
#define gammashift 10
| 259 |
#define betashift gammashift
| 260 |
#define intbiasshift 16
| 261 |
#define intbias (1<<intbiasshift)
| 262 |
#define gamma (1<<gammashift)
| 263 |
#define beta (intbias>>betashift)
| 264 |
#define betagamma (intbias<<(gammashift-betashift))
| 265 |
#define gammaphi (intbias<<(gammashift-8))
| 266 |
| 267 |
/* defs for rad and alpha */
| 268 |
#define maxrad (initrad+1)
| 269 |
#define radiusbiasshift 6
| 270 |
#define radiusbias (1<<radiusbiasshift)
| 271 |
#define initradius ((int) (initrad*radiusbias))
| 272 |
#define alphabiasshift 10
| 273 |
#define initalpha (1<<alphabiasshift)
| 274 |
#define radbiasshift 8
| 275 |
#define radbias (1<<radbiasshift)
| 276 |
#define alpharadbshift (alphabiasshift+radbiasshift)
| 277 |
#define alpharadbias (1<<alpharadbshift)
| 278 |
| 279 |
/* other defs */
| 280 |
#define netbiasshift 4
| 281 |
#define funnyshift (intbiasshift-netbiasshift)
| 282 |
#define maxnetval ((256<<netbiasshift)-1)
| 283 |
#define ncycles 100
| 284 |
#define jump1 499 /* prime */
| 285 |
#define jump2 491 /* prime */
| 286 |
#define jump3 487 /* any pic whose size was divisible by all */
| 287 |
#define jump4 503 /* four primes would be simply enormous */
| 288 |
| 289 |
/* cheater definitions (GW) */
| 290 |
#define thepicture thesamples
| 291 |
#define lengthcount (nsamples*3)
| 292 |
#define samplefac 1
| 293 |
| 294 |
typedef int pixel[4]; /* BGRc */
| 295 |
| 296 |
static pixel network[256];
| 297 |
| 298 |
static int netindex[256];
| 299 |
| 300 |
static int bias [256];
| 301 |
static int freq [256];
| 302 |
static int radpower[256]; /* actually need only go up to maxrad */
| 303 |
| 304 |
/* fixed space overhead 256*4+256+256+256+256 words = 256*8 = 8kB */
| 305 |
| 306 |
| 307 |
static
| 308 |
initnet()
| 309 |
| 310 |
register int i;
| 311 |
register int *p;
| 312 |
| 313 |
for (i=0; i<clrtabsiz; i++) {
| 314 |
p = network[i];
| 315 |
p[0] =
| 316 |
p[1] =
| 317 |
p[2] = (i<<(netbiasshift+8))/clrtabsiz;
| 318 |
freq[i] = intbias/clrtabsiz; /* 1/256 */
| 319 |
bias[i] = 0;
| 320 |
| 321 |
| 322 |
| 323 |
| 324 |
static
| 325 |
inxbuild()
| 326 |
| 327 |
register int i,j,smallpos,smallval;
| 328 |
register int *p,*q;
| 329 |
int start,previous;
| 330 |
| 331 |
previous = 0;
| 332 |
start = 0;
| 333 |
| 334 |
p = network[i];
| 335 |
smallpos = i;
| 336 |
smallval = p[1]; /* index on g */
| 337 |
/* find smallest in i+1..clrtabsiz-1 */
| 338 |
for (j=i+1; j<clrtabsiz; j++) {
| 339 |
q = network[j];
| 340 |
if (q[1] < smallval) { /* index on g */
| 341 |
smallpos = j;
| 342 |
smallval = q[1]; /* index on g */
| 343 |
| 344 |
| 345 |
q = network[smallpos];
| 346 |
if (i != smallpos) {
| 347 |
j = q[0]; q[0] = p[0]; p[0] = j;
| 348 |
j = q[1]; q[1] = p[1]; p[1] = j;
| 349 |
j = q[2]; q[2] = p[2]; p[2] = j;
| 350 |
j = q[3]; q[3] = p[3]; p[3] = j;
| 351 |
| 352 |
/* smallval entry is now in position i */
| 353 |
if (smallval != previous) {
| 354 |
netindex[previous] = (start+i)>>1;
| 355 |
for (j=previous+1; j<smallval; j++) netindex[j] = i;
| 356 |
previous = smallval;
| 357 |
start = i;
| 358 |
| 359 |
| 360 |
netindex[previous] = (start+255)>>1;
| 361 |
for (j=previous+1; j<256; j++) netindex[j] = 255;
| 362 |
| 363 |
| 364 |
| 365 |
static int
| 366 |
inxsearch(b,g,r) /* accepts real BGR values after net is unbiased */
| 367 |
register int b,g,r;
| 368 |
| 369 |
register int i,j,best,x,y,bestd;
| 370 |
register int *p;
| 371 |
| 372 |
bestd = 1000; /* biggest possible dist is 256*3 */
| 373 |
best = -1;
| 374 |
i = netindex[g]; /* index on g */
| 375 |
j = i-1;
| 376 |
| 377 |
while ((i<clrtabsiz) || (j>=0)) {
| 378 |
if (i<clrtabsiz) {
| 379 |
p = network[i];
| 380 |
x = p[1] - g; /* inx key */
| 381 |
if (x >= bestd) i = clrtabsiz; /* stop iter */
| 382 |
else {
| 383 |
i++;
| 384 |
if (x<0) x = -x;
| 385 |
y = p[0] - b;
| 386 |
if (y<0) y = -y;
| 387 |
x += y;
| 388 |
if (x<bestd) {
| 389 |
y = p[2] - r;
| 390 |
if (y<0) y = -y;
| 391 |
x += y; /* x holds distance */
| 392 |
if (x<bestd) {bestd=x; best=p[3];}
| 393 |
| 394 |
| 395 |
| 396 |
if (j>=0) {
| 397 |
p = network[j];
| 398 |
x = g - p[1]; /* inx key - reverse dif */
| 399 |
if (x >= bestd) j = -1; /* stop iter */
| 400 |
else {
| 401 |
j--;
| 402 |
if (x<0) x = -x;
| 403 |
y = p[0] - b;
| 404 |
if (y<0) y = -y;
| 405 |
x += y;
| 406 |
if (x<bestd) {
| 407 |
y = p[2] - r;
| 408 |
if (y<0) y = -y;
| 409 |
| 410 |
| 411 |
| 412 |
| 413 |
| 414 |
| 415 |
return(best);
| 416 |
| 417 |
| 418 |
| 419 |
static int
| 420 |
contest(b,g,r) /* accepts biased BGR values */
| 421 |
register int b,g,r;
| 422 |
| 423 |
register int i,best,bestbias,x,y,bestd,bestbiasd;
| 424 |
register int *p,*q, *pp;
| 425 |
| 426 |
bestd = ~(1<<31);
| 427 |
bestbiasd = bestd;
| 428 |
best = -1;
| 429 |
bestbias = best;
| 430 |
q = bias;
| 431 |
p = freq;
| 432 |
| 433 |
pp = network[i];
| 434 |
x = pp[0] - b;
| 435 |
if (x<0) x = -x;
| 436 |
y = pp[1] - g;
| 437 |
if (y<0) y = -y;
| 438 |
x += y;
| 439 |
y = pp[2] - r;
| 440 |
if (y<0) y = -y;
| 441 |
| 442 |
/* >> netbiasshift not needed if funnyshift used */
| 443 |
if (x<bestd) {bestd=x; best=i;}
| 444 |
y = x - ((*q)>>funnyshift); /* y holds biasd */
| 445 |
if (y<bestbiasd) {bestbiasd=y; bestbias=i;}
| 446 |
y = (*p >> betashift); /* y holds beta*freq */
| 447 |
*p -= y;
| 448 |
*q += (y<<gammashift);
| 449 |
p++;
| 450 |
q++;
| 451 |
| 452 |
freq[best] += beta;
| 453 |
bias[best] -= betagamma;
| 454 |
return(bestbias);
| 455 |
| 456 |
| 457 |
| 458 |
static
| 459 |
alterneigh(rad,i,b,g,r) /* accepts biased BGR values */
| 460 |
int rad,i;
| 461 |
register int b,g,r;
| 462 |
| 463 |
register int j,k,lo,hi,a;
| 464 |
register int *p, *q;
| 465 |
| 466 |
lo = i-rad;
| 467 |
if (lo<-1) lo= -1;
| 468 |
hi = i+rad;
| 469 |
if (hi>clrtabsiz) hi=clrtabsiz;
| 470 |
| 471 |
j = i+1;
| 472 |
k = i-1;
| 473 |
q = radpower;
| 474 |
while ((j<hi) || (k>lo)) {
| 475 |
a = (*(++q));
| 476 |
if (j<hi) {
| 477 |
p = network[j];
| 478 |
*p -= (a*(*p - b)) / alpharadbias;
| 479 |
p++;
| 480 |
*p -= (a*(*p - g)) / alpharadbias;
| 481 |
p++;
| 482 |
*p -= (a*(*p - r)) / alpharadbias;
| 483 |
j++;
| 484 |
| 485 |
if (k>lo) {
| 486 |
p = network[k];
| 487 |
| 488 |
p++;
| 489 |
| 490 |
p++;
| 491 |
| 492 |
k--;
| 493 |
| 494 |
| 495 |
| 496 |
| 497 |
| 498 |
static
| 499 |
altersingle(alpha,j,b,g,r) /* accepts biased BGR values */
| 500 |
register int alpha,j,b,g,r;
| 501 |
| 502 |
register int *q;
| 503 |
| 504 |
q = network[j]; /* alter hit neuron */
| 505 |
*q -= (alpha*(*q - b)) / initalpha;
| 506 |
q++;
| 507 |
*q -= (alpha*(*q - g)) / initalpha;
| 508 |
q++;
| 509 |
*q -= (alpha*(*q - r)) / initalpha;
| 510 |
| 511 |
| 512 |
| 513 |
static
| 514 |
learn()
| 515 |
| 516 |
register int i,j,b,g,r;
| 517 |
int radius,rad,alpha,step,delta,upto;
| 518 |
register unsigned char *p;
| 519 |
unsigned char *lim;
| 520 |
| 521 |
upto = lengthcount/(3*samplefac);
| 522 |
delta = upto/ncycles;
| 523 |
lim = thepicture + lengthcount;
| 524 |
p = thepicture;
| 525 |
alpha = initalpha;
| 526 |
radius = initradius;
| 527 |
rad = radius >> radiusbiasshift;
| 528 |
if (rad <= 1) rad = 0;
| 529 |
for (i=0; i<rad; i++)
| 530 |
radpower[i] = alpha*(((rad*rad - i*i)*radbias)/(rad*rad));
| 531 |
| 532 |
if ((lengthcount%jump1) != 0) step = 3*jump1;
| 533 |
else {
| 534 |
if ((lengthcount%jump2) !=0) step = 3*jump2;
| 535 |
else {
| 536 |
if ((lengthcount%jump3) !=0) step = 3*jump3;
| 537 |
else step = 3*jump4;
| 538 |
| 539 |
| 540 |
i = 0;
| 541 |
while (i < upto) {
| 542 |
b = p[0] << netbiasshift;
| 543 |
g = p[1] << netbiasshift;
| 544 |
r = p[2] << netbiasshift;
| 545 |
j = contest(b,g,r);
| 546 |
| 547 |
altersingle(alpha,j,b,g,r);
| 548 |
if (rad) alterneigh(rad,j,b,g,r);
| 549 |
/* alter neighbours */
| 550 |
| 551 |
p += step;
| 552 |
if (p >= lim) p -= lengthcount;
| 553 |
| 554 |
i++;
| 555 |
if (i%delta == 0) {
| 556 |
alpha -= alpha / alphadec;
| 557 |
radius -= radius / radiusdec;
| 558 |
| 559 |
| 560 |
for (j=0; j<rad; j++)
| 561 |
radpower[j] = alpha*(((rad*rad - j*j)*radbias)/(rad*rad));
| 562 |
| 563 |
| 564 |
| 565 |
| 566 |
static
| 567 |
unbiasnet()
| 568 |
| 569 |
int i,j;
| 570 |
| 571 |
| 572 |
for (j=0; j<3; j++)
| 573 |
network[i][j] >>= netbiasshift;
| 574 |
network[i][3] = i; /* record colour no */
| 575 |
| 576 |
| 577 |
| 578 |
/* Don't do this until the network has been unbiased */
| 579 |
| 580 |
static
| 581 |
cpyclrtab()
| 582 |
| 583 |
register int i,j,k;
| 584 |
| 585 |
for (j=0; j<clrtabsiz; j++) {
| 586 |
k = network[j][3];
| 587 |
| 588 |
clrtab[k][i] = network[j][2-i];
| 589 |
| 590 |
