1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: neuclrtab.c,v 2.10 2003/06/30 14:59:12 schorsch Exp $"; |
3 |
#endif |
4 |
5 |
* Neural-Net quantization algorithm based on work of Anthony Dekker |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <string.h> |
11 |
12 |
#include "standard.h" |
13 |
#include "color.h" |
14 |
#include "random.h" |
15 |
#include "clrtab.h" |
16 |
17 |
#ifdef COMPAT_MODE |
18 |
#define neu_init new_histo |
19 |
#define neu_pixel cnt_pixel |
20 |
#define neu_colrs cnt_colrs |
21 |
#define neu_clrtab new_clrtab |
22 |
#define neu_map_pixel map_pixel |
23 |
#define neu_map_colrs map_colrs |
24 |
#define neu_dith_colrs dith_colrs |
25 |
#endif |
26 |
/* our color table (global) */ |
27 |
extern BYTE clrtab[256][3]; |
28 |
static int clrtabsiz; |
29 |
30 |
#ifndef DEFSMPFAC |
31 |
#ifdef SPEED |
32 |
#define DEFSMPFAC (240/SPEED+3) |
33 |
#else |
34 |
#define DEFSMPFAC 30 |
35 |
#endif |
36 |
#endif |
37 |
38 |
int samplefac = DEFSMPFAC; /* sampling factor */ |
39 |
40 |
/* Samples array starts off holding spacing between adjacent |
41 |
* samples, and ends up holding actual BGR sample values. |
42 |
43 |
static BYTE *thesamples; |
44 |
static int nsamples; |
45 |
static BYTE *cursamp; |
46 |
static long skipcount; |
47 |
48 |
#define MAXSKIP (1<<24-1) |
49 |
50 |
#define nskip(sp) ((long)(sp)[0]<<16|(long)(sp)[1]<<8|(long)(sp)[2]) |
51 |
52 |
#define setskip(sp,n) ((sp)[0]=(n)>>16,(sp)[1]=((n)>>8)&255,(sp)[2]=(n)&255) |
53 |
54 |
static void initnet(void); |
55 |
static void inxbuild(void); |
56 |
static int inxsearch(int b, int g, int r); |
57 |
static int contest(int b, int g, int r); |
58 |
static void altersingle(int alpha, int i, int b, int g, int r); |
59 |
static void alterneigh(int rad, int i, int b, int g, int r); |
60 |
static void learn(void); |
61 |
static void unbiasnet(void); |
62 |
static void cpyclrtab(void); |
63 |
64 |
65 |
extern int |
66 |
neu_init( /* initialize our sample array */ |
67 |
long npixels |
68 |
69 |
70 |
register int nsleft; |
71 |
register long sv; |
72 |
double rval, cumprob; |
73 |
long npleft; |
74 |
75 |
nsamples = npixels/samplefac; |
76 |
if (nsamples < 600) |
77 |
return(-1); |
78 |
thesamples = (BYTE *)malloc(nsamples*3); |
79 |
if (thesamples == NULL) |
80 |
return(-1); |
81 |
cursamp = thesamples; |
82 |
npleft = npixels; |
83 |
nsleft = nsamples; |
84 |
while (nsleft) { |
85 |
rval = frandom(); /* random distance to next sample */ |
86 |
sv = 0; |
87 |
cumprob = 0.; |
88 |
while ((cumprob += (1.-cumprob)*nsleft/(npleft-sv)) < rval) |
89 |
sv++; |
90 |
if (nsleft == nsamples) |
91 |
skipcount = sv; |
92 |
else { |
93 |
setskip(cursamp, sv); |
94 |
cursamp += 3; |
95 |
96 |
npleft -= sv+1; |
97 |
nsleft--; |
98 |
99 |
setskip(cursamp, npleft); /* tag on end to skip the rest */ |
100 |
101 |
return(0); |
102 |
103 |
104 |
105 |
extern void |
106 |
neu_pixel( /* add pixel to our samples */ |
107 |
register BYTE col[] |
108 |
109 |
110 |
if (!skipcount--) { |
111 |
skipcount = nskip(cursamp); |
112 |
cursamp[0] = col[BLU]; |
113 |
cursamp[1] = col[GRN]; |
114 |
cursamp[2] = col[RED]; |
115 |
cursamp += 3; |
116 |
117 |
118 |
119 |
120 |
extern void |
121 |
neu_colrs( /* add a scanline to our samples */ |
122 |
register COLR *cs, |
123 |
register int n |
124 |
125 |
126 |
while (n > skipcount) { |
127 |
cs += skipcount; |
128 |
n -= skipcount+1; |
129 |
130 |
cursamp[0] = cs[0][BLU]; |
131 |
cursamp[1] = cs[0][GRN]; |
132 |
cursamp[2] = cs[0][RED]; |
133 |
cs++; |
134 |
cursamp += 3; |
135 |
136 |
skipcount -= n; |
137 |
138 |
139 |
140 |
extern int |
141 |
neu_clrtab( /* make new color table using ncolors */ |
142 |
int ncolors |
143 |
144 |
145 |
clrtabsiz = ncolors; |
146 |
if (clrtabsiz > 256) clrtabsiz = 256; |
147 |
initnet(); |
148 |
learn(); |
149 |
unbiasnet(); |
150 |
cpyclrtab(); |
151 |
inxbuild(); |
152 |
/* we're done with our samples */ |
153 |
free((void *)thesamples); |
154 |
/* reset dithering function */ |
155 |
neu_dith_colrs((BYTE *)NULL, (COLR *)NULL, 0); |
156 |
/* return new color table size */ |
157 |
return(clrtabsiz); |
158 |
159 |
160 |
161 |
extern int |
162 |
neu_map_pixel( /* get pixel for color */ |
163 |
164 |
165 |
166 |
return(inxsearch(col[BLU],col[GRN],col[RED])); |
167 |
168 |
169 |
170 |
extern void |
171 |
neu_map_colrs( /* convert a scanline to color index values */ |
172 |
register BYTE *bs, |
173 |
174 |
register int n |
175 |
176 |
177 |
while (n-- > 0) { |
178 |
*bs++ = inxsearch(cs[0][BLU],cs[0][GRN],cs[0][RED]); |
179 |
cs++; |
180 |
181 |
182 |
183 |
184 |
extern void |
185 |
neu_dith_colrs( /* convert scanline to dithered index values */ |
186 |
187 |
188 |
int n |
189 |
190 |
191 |
static short (*cerr)[3] = NULL; |
192 |
static int N = 0; |
193 |
int err[3], errp[3]; |
194 |
register int x, i; |
195 |
196 |
if (n != N) { /* get error propogation array */ |
197 |
if (N) { |
198 |
free((void *)cerr); |
199 |
cerr = NULL; |
200 |
201 |
if (n) |
202 |
cerr = (short (*)[3])malloc(3*n*sizeof(short)); |
203 |
if (cerr == NULL) { |
204 |
N = 0; |
205 |
map_colrs(bs, cs, n); |
206 |
return; |
207 |
208 |
N = n; |
209 |
memset((char *)cerr, '\0', 3*N*sizeof(short)); |
210 |
211 |
err[0] = err[1] = err[2] = 0; |
212 |
for (x = 0; x < n; x++) { |
213 |
for (i = 0; i < 3; i++) { /* dither value */ |
214 |
errp[i] = err[i]; |
215 |
err[i] += cerr[x][i]; |
216 |
#ifdef MAXERR |
217 |
if (err[i] > MAXERR) err[i] = MAXERR; |
218 |
else if (err[i] < -MAXERR) err[i] = -MAXERR; |
219 |
#endif |
220 |
err[i] += cs[x][i]; |
221 |
if (err[i] < 0) err[i] = 0; |
222 |
else if (err[i] > 255) err[i] = 255; |
223 |
224 |
bs[x] = inxsearch(err[BLU],err[GRN],err[RED]); |
225 |
for (i = 0; i < 3; i++) { /* propagate error */ |
226 |
err[i] -= clrtab[bs[x]][i]; |
227 |
err[i] /= 3; |
228 |
cerr[x][i] = err[i] + errp[i]; |
229 |
230 |
231 |
232 |
233 |
/* The following was adapted and modified from the original (GW) */ |
234 |
235 |
/* cheater definitions (GW) */ |
236 |
#define thepicture thesamples |
237 |
#define lengthcount (nsamples*3) |
238 |
#define samplefac 1 |
239 |
240 |
241 |
242 |
/* NeuQuant */ |
243 |
244 |
245 |
/* Copyright: Anthony Dekker, November 1994 */ |
246 |
247 |
/* This program performs colour quantization of graphics images (SUN */ |
248 |
/* raster files). It uses a Kohonen Neural Network. It produces */ |
249 |
/* better results than existing methods and runs faster, using minimal */ |
250 |
/* space (8kB plus the image itself). The algorithm is described in */ |
251 |
/* the paper "Kohonen Neural Networks for Optimal Colour Quantization" */ |
252 |
/* to appear in the journal "Network: Computation in Neural Systems". */ |
253 |
/* It is a significant improvement of an earlier algorithm. */ |
254 |
255 |
/* This program is distributed free for academic use or for evaluation */ |
256 |
/* by commercial organizations. */ |
257 |
258 |
/* Usage: NeuQuant -n inputfile > outputfile */ |
259 |
260 |
/* where n is a sampling factor for neural learning. */ |
261 |
262 |
/* Program performance compared with other methods is as follows: */ |
263 |
264 |
/* Algorithm | Av. CPU Time | Quantization Error */ |
265 |
266 |
/* NeuQuant -3 | 314 | 5.55 */ |
267 |
/* NeuQuant -10 | 119 | 5.97 */ |
268 |
/* NeuQuant -30 | 65 | 6.53 */ |
269 |
/* Oct-Trees | 141 | 8.96 */ |
270 |
/* Median Cut (XV -best) | 420 | 9.28 */ |
271 |
/* Median Cut (XV -slow) | 72 | 12.15 */ |
272 |
273 |
/* Author's address: Dept of ISCS, National University of Singapore */ |
274 |
/* Kent Ridge, Singapore 0511 */ |
275 |
/* Email: [email protected] */ |
276 |
277 |
278 |
#define bool int |
279 |
#define false 0 |
280 |
#define true 1 |
281 |
282 |
/* network defs */ |
283 |
#define netsize clrtabsiz /* number of colours - can change this */ |
284 |
#define maxnetpos (netsize-1) |
285 |
#define netbiasshift 4 /* bias for colour values */ |
286 |
#define ncycles 100 /* no. of learning cycles */ |
287 |
288 |
/* defs for freq and bias */ |
289 |
#define intbiasshift 16 /* bias for fractions */ |
290 |
#define intbias (((int) 1)<<intbiasshift) |
291 |
#define gammashift 10 /* gamma = 1024 */ |
292 |
#define gamma (((int) 1)<<gammashift) |
293 |
#define betashift 10 |
294 |
#define beta (intbias>>betashift) /* beta = 1/1024 */ |
295 |
#define betagamma (intbias<<(gammashift-betashift)) |
296 |
297 |
/* defs for decreasing radius factor */ |
298 |
#define initrad (256>>3) /* for 256 cols, radius starts */ |
299 |
#define radiusbiasshift 6 /* at 32.0 biased by 6 bits */ |
300 |
#define radiusbias (((int) 1)<<radiusbiasshift) |
301 |
#define initradius (initrad*radiusbias) /* and decreases by a */ |
302 |
#define radiusdec 30 /* factor of 1/30 each cycle */ |
303 |
304 |
/* defs for decreasing alpha factor */ |
305 |
#define alphabiasshift 10 /* alpha starts at 1.0 */ |
306 |
#define initalpha (((int) 1)<<alphabiasshift) |
307 |
int alphadec; /* biased by 10 bits */ |
308 |
309 |
/* radbias and alpharadbias used for radpower calculation */ |
310 |
#define radbiasshift 8 |
311 |
#define radbias (((int) 1)<<radbiasshift) |
312 |
#define alpharadbshift (alphabiasshift+radbiasshift) |
313 |
#define alpharadbias (((int) 1)<<alpharadbshift) |
314 |
315 |
/* four primes near 500 - assume no image has a length so large */ |
316 |
/* that it is divisible by all four primes */ |
317 |
#define prime1 499 |
318 |
#define prime2 491 |
319 |
#define prime3 487 |
320 |
#define prime4 503 |
321 |
322 |
typedef int pixel[4]; /* BGRc */ |
323 |
pixel network[256]; |
324 |
325 |
int netindex[256]; /* for network lookup - really 256 */ |
326 |
327 |
int bias [256]; /* bias and freq arrays for learning */ |
328 |
int freq [256]; |
329 |
int radpower[initrad]; /* radpower for precomputation */ |
330 |
331 |
332 |
/* initialise network in range (0,0,0) to (255,255,255) */ |
333 |
334 |
static void |
335 |
initnet(void) |
336 |
337 |
register int i; |
338 |
register int *p; |
339 |
340 |
for (i=0; i<netsize; i++) { |
341 |
p = network[i]; |
342 |
p[0] = p[1] = p[2] = (i << (netbiasshift+8))/netsize; |
343 |
freq[i] = intbias/netsize; /* 1/netsize */ |
344 |
bias[i] = 0; |
345 |
346 |
347 |
348 |
349 |
/* do after unbias - insertion sort of network and build netindex[0..255] */ |
350 |
351 |
static void |
352 |
inxbuild(void) |
353 |
354 |
register int i,j,smallpos,smallval; |
355 |
register int *p,*q; |
356 |
int previouscol,startpos; |
357 |
358 |
previouscol = 0; |
359 |
startpos = 0; |
360 |
361 |
p = network[i]; |
362 |
smallpos = i; |
363 |
smallval = p[1]; /* index on g */ |
364 |
/* find smallest in i..netsize-1 */ |
365 |
for (j=i+1; j<netsize; j++) { |
366 |
q = network[j]; |
367 |
if (q[1] < smallval) { /* index on g */ |
368 |
smallpos = j; |
369 |
smallval = q[1]; /* index on g */ |
370 |
371 |
372 |
q = network[smallpos]; |
373 |
/* swap p (i) and q (smallpos) entries */ |
374 |
if (i != smallpos) { |
375 |
j = q[0]; q[0] = p[0]; p[0] = j; |
376 |
j = q[1]; q[1] = p[1]; p[1] = j; |
377 |
j = q[2]; q[2] = p[2]; p[2] = j; |
378 |
j = q[3]; q[3] = p[3]; p[3] = j; |
379 |
380 |
/* smallval entry is now in position i */ |
381 |
if (smallval != previouscol) { |
382 |
netindex[previouscol] = (startpos+i)>>1; |
383 |
for (j=previouscol+1; j<smallval; j++) netindex[j] = i; |
384 |
previouscol = smallval; |
385 |
startpos = i; |
386 |
387 |
388 |
netindex[previouscol] = (startpos+maxnetpos)>>1; |
389 |
for (j=previouscol+1; j<256; j++) netindex[j] = maxnetpos; /* really 256 */ |
390 |
391 |
392 |
393 |
static int |
394 |
inxsearch( /* accepts real BGR values after net is unbiased */ |
395 |
register int b, |
396 |
register int g, |
397 |
register int r |
398 |
399 |
400 |
register int i,j,dist,a,bestd; |
401 |
register int *p; |
402 |
int best; |
403 |
404 |
bestd = 1000; /* biggest possible dist is 256*3 */ |
405 |
best = -1; |
406 |
i = netindex[g]; /* index on g */ |
407 |
j = i-1; /* start at netindex[g] and work outwards */ |
408 |
409 |
while ((i<netsize) || (j>=0)) { |
410 |
if (i<netsize) { |
411 |
p = network[i]; |
412 |
dist = p[1] - g; /* inx key */ |
413 |
if (dist >= bestd) i = netsize; /* stop iter */ |
414 |
else { |
415 |
i++; |
416 |
if (dist<0) dist = -dist; |
417 |
a = p[0] - b; if (a<0) a = -a; |
418 |
dist += a; |
419 |
if (dist<bestd) { |
420 |
a = p[2] - r; if (a<0) a = -a; |
421 |
dist += a; |
422 |
if (dist<bestd) {bestd=dist; best=p[3];} |
423 |
424 |
425 |
426 |
if (j>=0) { |
427 |
p = network[j]; |
428 |
dist = g - p[1]; /* inx key - reverse dif */ |
429 |
if (dist >= bestd) j = -1; /* stop iter */ |
430 |
else { |
431 |
j--; |
432 |
433 |
434 |
dist += a; |
435 |
if (dist<bestd) { |
436 |
437 |
dist += a; |
438 |
439 |
440 |
441 |
442 |
443 |
return(best); |
444 |
445 |
446 |
447 |
/* finds closest neuron (min dist) and updates freq */ |
448 |
/* finds best neuron (min dist-bias) and returns position */ |
449 |
/* for frequently chosen neurons, freq[i] is high and bias[i] is negative */ |
450 |
/* bias[i] = gamma*((1/netsize)-freq[i]) */ |
451 |
452 |
static int |
453 |
contest( /* accepts biased BGR values */ |
454 |
register int b, |
455 |
register int g, |
456 |
register int r |
457 |
458 |
459 |
register int i,dist,a,biasdist,betafreq; |
460 |
int bestpos,bestbiaspos,bestd,bestbiasd; |
461 |
register int *p,*f, *n; |
462 |
463 |
bestd = ~(((int) 1)<<31); |
464 |
bestbiasd = bestd; |
465 |
bestpos = -1; |
466 |
bestbiaspos = bestpos; |
467 |
p = bias; |
468 |
f = freq; |
469 |
470 |
471 |
n = network[i]; |
472 |
dist = n[0] - b; if (dist<0) dist = -dist; |
473 |
a = n[1] - g; if (a<0) a = -a; |
474 |
dist += a; |
475 |
a = n[2] - r; if (a<0) a = -a; |
476 |
dist += a; |
477 |
if (dist<bestd) {bestd=dist; bestpos=i;} |
478 |
biasdist = dist - ((*p)>>(intbiasshift-netbiasshift)); |
479 |
if (biasdist<bestbiasd) {bestbiasd=biasdist; bestbiaspos=i;} |
480 |
betafreq = (*f >> betashift); |
481 |
*f++ -= betafreq; |
482 |
*p++ += (betafreq<<gammashift); |
483 |
484 |
freq[bestpos] += beta; |
485 |
bias[bestpos] -= betagamma; |
486 |
return(bestbiaspos); |
487 |
488 |
489 |
490 |
/* move neuron i towards (b,g,r) by factor alpha */ |
491 |
492 |
static void |
493 |
altersingle( /* accepts biased BGR values */ |
494 |
register int alpha, |
495 |
register int i, |
496 |
register int b, |
497 |
register int g, |
498 |
register int r |
499 |
500 |
501 |
register int *n; |
502 |
503 |
n = network[i]; /* alter hit neuron */ |
504 |
*n -= (alpha*(*n - b)) / initalpha; |
505 |
n++; |
506 |
*n -= (alpha*(*n - g)) / initalpha; |
507 |
n++; |
508 |
*n -= (alpha*(*n - r)) / initalpha; |
509 |
510 |
511 |
512 |
/* move neurons adjacent to i towards (b,g,r) by factor */ |
513 |
/* alpha*(1-((i-j)^2/[r]^2)) precomputed as radpower[|i-j|]*/ |
514 |
515 |
static void |
516 |
alterneigh( /* accents biased BGR values */ |
517 |
int rad, |
518 |
int i, |
519 |
register int b, |
520 |
register int g, |
521 |
register int r |
522 |
523 |
524 |
register int j,k,lo,hi,a; |
525 |
register int *p, *q; |
526 |
527 |
lo = i-rad; if (lo<-1) lo= -1; |
528 |
hi = i+rad; if (hi>netsize) hi=netsize; |
529 |
530 |
j = i+1; |
531 |
k = i-1; |
532 |
q = radpower; |
533 |
while ((j<hi) || (k>lo)) { |
534 |
a = (*(++q)); |
535 |
if (j<hi) { |
536 |
p = network[j]; |
537 |
*p -= (a*(*p - b)) / alpharadbias; |
538 |
p++; |
539 |
*p -= (a*(*p - g)) / alpharadbias; |
540 |
p++; |
541 |
*p -= (a*(*p - r)) / alpharadbias; |
542 |
j++; |
543 |
544 |
if (k>lo) { |
545 |
p = network[k]; |
546 |
547 |
p++; |
548 |
549 |
p++; |
550 |
551 |
k--; |
552 |
553 |
554 |
555 |
556 |
557 |
static void |
558 |
learn(void) |
559 |
560 |
register int i,j,b,g,r; |
561 |
int radius,rad,alpha,step,delta,samplepixels; |
562 |
register unsigned char *p; |
563 |
unsigned char *lim; |
564 |
565 |
alphadec = 30 + ((samplefac-1)/3); |
566 |
p = thepicture; |
567 |
lim = thepicture + lengthcount; |
568 |
samplepixels = lengthcount/(3*samplefac); |
569 |
delta = samplepixels/ncycles; |
570 |
alpha = initalpha; |
571 |
radius = initradius; |
572 |
573 |
rad = radius >> radiusbiasshift; |
574 |
if (rad <= 1) rad = 0; |
575 |
for (i=0; i<rad; i++) |
576 |
radpower[i] = alpha*(((rad*rad - i*i)*radbias)/(rad*rad)); |
577 |
578 |
if ((lengthcount%prime1) != 0) step = 3*prime1; |
579 |
else { |
580 |
if ((lengthcount%prime2) !=0) step = 3*prime2; |
581 |
else { |
582 |
if ((lengthcount%prime3) !=0) step = 3*prime3; |
583 |
else step = 3*prime4; |
584 |
585 |
586 |
587 |
i = 0; |
588 |
while (i < samplepixels) { |
589 |
b = p[0] << netbiasshift; |
590 |
g = p[1] << netbiasshift; |
591 |
r = p[2] << netbiasshift; |
592 |
j = contest(b,g,r); |
593 |
594 |
altersingle(alpha,j,b,g,r); |
595 |
if (rad) alterneigh(rad,j,b,g,r); /* alter neighbours */ |
596 |
597 |
p += step; |
598 |
if (p >= lim) p -= lengthcount; |
599 |
600 |
i++; |
601 |
if (i%delta == 0) { |
602 |
alpha -= alpha / alphadec; |
603 |
radius -= radius / radiusdec; |
604 |
605 |
606 |
for (j=0; j<rad; j++) |
607 |
radpower[j] = alpha*(((rad*rad - j*j)*radbias)/(rad*rad)); |
608 |
609 |
610 |
611 |
612 |
/* unbias network to give 0..255 entries */ |
613 |
/* which can then be used for colour map */ |
614 |
/* and record position i to prepare for sort */ |
615 |
616 |
static void |
617 |
unbiasnet(void) |
618 |
619 |
int i,j; |
620 |
621 |
622 |
for (j=0; j<3; j++) |
623 |
network[i][j] >>= netbiasshift; |
624 |
network[i][3] = i; /* record colour no */ |
625 |
626 |
627 |
628 |
629 |
/* Don't do this until the network has been unbiased (GW) */ |
630 |
631 |
static void |
632 |
cpyclrtab(void) |
633 |
634 |
register int i,j,k; |
635 |
636 |
for (j=0; j<netsize; j++) { |
637 |
k = network[j][3]; |
638 |
for (i = 0; i < 3; i++) |
639 |
clrtab[k][i] = network[j][2-i]; |
640 |
641 |
