| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: neuclrtab.c,v 2.13 2007/09/08 19:17:52 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Neural-Net quantization algorithm based on work of Anthony Dekker
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include <string.h>
| 11 |
| 12 |
#include "standard.h"
| 13 |
#include "color.h"
| 14 |
#include "random.h"
| 15 |
#include "clrtab.h"
| 16 |
| 17 |
#ifdef COMPAT_MODE
| 18 |
#define neu_init new_histo
| 19 |
#define neu_pixel cnt_pixel
| 20 |
#define neu_colrs cnt_colrs
| 21 |
#define neu_clrtab new_clrtab
| 22 |
#define neu_map_pixel map_pixel
| 23 |
#define neu_map_colrs map_colrs
| 24 |
#define neu_dith_colrs dith_colrs
| 25 |
#endif
| 26 |
/* our color table (global) */
| 27 |
extern uby8 clrtab[256][3];
| 28 |
static int clrtabsiz;
| 29 |
| 30 |
#ifndef DEFSMPFAC
| 31 |
#define DEFSMPFAC 3
| 32 |
#endif
| 33 |
| 34 |
int samplefac = DEFSMPFAC; /* sampling factor */
| 35 |
| 36 |
/* Samples array starts off holding spacing between adjacent
| 37 |
* samples, and ends up holding actual BGR sample values.
| 38 |
| 39 |
static uby8 *thesamples;
| 40 |
static int nsamples;
| 41 |
static uby8 *cursamp;
| 42 |
static long skipcount;
| 43 |
| 44 |
#define MAXSKIP (1<<24-1)
| 45 |
| 46 |
#define nskip(sp) ((long)(sp)[0]<<16|(long)(sp)[1]<<8|(long)(sp)[2])
| 47 |
| 48 |
#define setskip(sp,n) ((sp)[0]=(n)>>16,(sp)[1]=((n)>>8)&255,(sp)[2]=(n)&255)
| 49 |
| 50 |
static void initnet(void);
| 51 |
static void inxbuild(void);
| 52 |
static int inxsearch(int b, int g, int r);
| 53 |
static int contest(int b, int g, int r);
| 54 |
static void altersingle(int alpha, int i, int b, int g, int r);
| 55 |
static void alterneigh(int rad, int i, int b, int g, int r);
| 56 |
static void learn(void);
| 57 |
static void unbiasnet(void);
| 58 |
static void cpyclrtab(void);
| 59 |
| 60 |
| 61 |
extern int
| 62 |
neu_init( /* initialize our sample array */
| 63 |
long npixels
| 64 |
| 65 |
| 66 |
register int nsleft;
| 67 |
register long sv;
| 68 |
double rval, cumprob;
| 69 |
long npleft;
| 70 |
| 71 |
nsamples = npixels/samplefac;
| 72 |
if (nsamples < 600)
| 73 |
return(-1);
| 74 |
thesamples = (uby8 *)malloc(nsamples*3);
| 75 |
if (thesamples == NULL)
| 76 |
return(-1);
| 77 |
cursamp = thesamples;
| 78 |
npleft = npixels;
| 79 |
nsleft = nsamples;
| 80 |
while (nsleft) {
| 81 |
rval = frandom(); /* random distance to next sample */
| 82 |
sv = 0;
| 83 |
cumprob = 0.;
| 84 |
while ((cumprob += (1.-cumprob)*nsleft/(npleft-sv)) < rval)
| 85 |
sv++;
| 86 |
if (nsleft == nsamples)
| 87 |
skipcount = sv;
| 88 |
else {
| 89 |
setskip(cursamp, sv);
| 90 |
cursamp += 3;
| 91 |
| 92 |
npleft -= sv+1;
| 93 |
nsleft--;
| 94 |
| 95 |
setskip(cursamp, npleft); /* tag on end to skip the rest */
| 96 |
| 97 |
return(0);
| 98 |
| 99 |
| 100 |
| 101 |
extern void
| 102 |
neu_pixel( /* add pixel to our samples */
| 103 |
register uby8 col[]
| 104 |
| 105 |
| 106 |
if (!skipcount--) {
| 107 |
skipcount = nskip(cursamp);
| 108 |
cursamp[0] = col[BLU];
| 109 |
cursamp[1] = col[GRN];
| 110 |
cursamp[2] = col[RED];
| 111 |
cursamp += 3;
| 112 |
| 113 |
| 114 |
| 115 |
| 116 |
extern void
| 117 |
neu_colrs( /* add a scanline to our samples */
| 118 |
register COLR *cs,
| 119 |
register int n
| 120 |
| 121 |
| 122 |
while (n > skipcount) {
| 123 |
cs += skipcount;
| 124 |
n -= skipcount+1;
| 125 |
| 126 |
cursamp[0] = cs[0][BLU];
| 127 |
cursamp[1] = cs[0][GRN];
| 128 |
cursamp[2] = cs[0][RED];
| 129 |
cs++;
| 130 |
cursamp += 3;
| 131 |
| 132 |
skipcount -= n;
| 133 |
| 134 |
| 135 |
| 136 |
extern int
| 137 |
neu_clrtab( /* make new color table using ncolors */
| 138 |
int ncolors
| 139 |
| 140 |
| 141 |
clrtabsiz = ncolors;
| 142 |
if (clrtabsiz > 256) clrtabsiz = 256;
| 143 |
initnet();
| 144 |
learn();
| 145 |
unbiasnet();
| 146 |
cpyclrtab();
| 147 |
inxbuild();
| 148 |
/* we're done with our samples */
| 149 |
free((void *)thesamples);
| 150 |
/* reset dithering function */
| 151 |
neu_dith_colrs((uby8 *)NULL, (COLR *)NULL, 0);
| 152 |
/* return new color table size */
| 153 |
return(clrtabsiz);
| 154 |
| 155 |
| 156 |
| 157 |
extern int
| 158 |
neu_map_pixel( /* get pixel for color */
| 159 |
register uby8 col[]
| 160 |
| 161 |
| 162 |
return(inxsearch(col[BLU],col[GRN],col[RED]));
| 163 |
| 164 |
| 165 |
| 166 |
extern void
| 167 |
neu_map_colrs( /* convert a scanline to color index values */
| 168 |
register uby8 *bs,
| 169 |
register COLR *cs,
| 170 |
register int n
| 171 |
| 172 |
| 173 |
while (n-- > 0) {
| 174 |
*bs++ = inxsearch(cs[0][BLU],cs[0][GRN],cs[0][RED]);
| 175 |
cs++;
| 176 |
| 177 |
| 178 |
| 179 |
| 180 |
extern void
| 181 |
neu_dith_colrs( /* convert scanline to dithered index values */
| 182 |
register uby8 *bs,
| 183 |
register COLR *cs,
| 184 |
int n
| 185 |
| 186 |
| 187 |
static short (*cerr)[3] = NULL;
| 188 |
static int N = 0;
| 189 |
int err[3], errp[3];
| 190 |
register int x, i;
| 191 |
| 192 |
if (n != N) { /* get error propogation array */
| 193 |
if (N) {
| 194 |
free((void *)cerr);
| 195 |
cerr = NULL;
| 196 |
| 197 |
if (n)
| 198 |
cerr = (short (*)[3])malloc(3*n*sizeof(short));
| 199 |
if (cerr == NULL) {
| 200 |
N = 0;
| 201 |
map_colrs(bs, cs, n);
| 202 |
return;
| 203 |
| 204 |
N = n;
| 205 |
memset((char *)cerr, '\0', 3*N*sizeof(short));
| 206 |
| 207 |
err[0] = err[1] = err[2] = 0;
| 208 |
for (x = 0; x < n; x++) {
| 209 |
for (i = 0; i < 3; i++) { /* dither value */
| 210 |
errp[i] = err[i];
| 211 |
err[i] += cerr[x][i];
| 212 |
#ifdef MAXERR
| 213 |
if (err[i] > MAXERR) err[i] = MAXERR;
| 214 |
else if (err[i] < -MAXERR) err[i] = -MAXERR;
| 215 |
#endif
| 216 |
err[i] += cs[x][i];
| 217 |
if (err[i] < 0) err[i] = 0;
| 218 |
else if (err[i] > 255) err[i] = 255;
| 219 |
| 220 |
bs[x] = inxsearch(err[BLU],err[GRN],err[RED]);
| 221 |
for (i = 0; i < 3; i++) { /* propagate error */
| 222 |
err[i] -= clrtab[bs[x]][i];
| 223 |
err[i] /= 3;
| 224 |
cerr[x][i] = err[i] + errp[i];
| 225 |
| 226 |
| 227 |
| 228 |
| 229 |
/* The following was adapted and modified from the original (GW) */
| 230 |
| 231 |
/* cheater definitions (GW) */
| 232 |
#define thepicture thesamples
| 233 |
#define lengthcount (nsamples*3)
| 234 |
#define samplefac 1
| 235 |
| 236 |
/* NeuQuant Neural-Net Quantization Algorithm Interface
| 237 |
| 238 |
| 239 |
* Copyright (c) 1994 Anthony Dekker
| 240 |
| 241 |
* NEUQUANT Neural-Net quantization algorithm by Anthony Dekker, 1994.
| 242 |
* See "Kohonen neural networks for optimal colour quantization"
| 243 |
* in "Network: Computation in Neural Systems" Vol. 5 (1994) pp 351-367.
| 244 |
* for a discussion of the algorithm.
| 245 |
* See also http://members.ozemail.com.au/~dekker/NEUQUANT.HTML
| 246 |
| 247 |
* Any party obtaining a copy of these files from the author, directly or
| 248 |
* indirectly, is granted, free of charge, a full and unrestricted irrevocable,
| 249 |
* world-wide, paid up, royalty-free, nonexclusive right and license to deal
| 250 |
* in this software and documentation files (the "Software"), including without
| 251 |
* limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
| 252 |
* and/or sell copies of the Software, and to permit persons who receive
| 253 |
* copies from any such party to do so, with the only requirement being
| 254 |
* that this copyright notice remain intact.
| 255 |
| 256 |
| 257 |
#define bool int
| 258 |
#define false 0
| 259 |
#define true 1
| 260 |
| 261 |
/* network defs */
| 262 |
#define netsize clrtabsiz /* number of colours - can change this */
| 263 |
#define maxnetpos (netsize-1)
| 264 |
#define netbiasshift 4 /* bias for colour values */
| 265 |
#define ncycles 100 /* no. of learning cycles */
| 266 |
| 267 |
/* defs for freq and bias */
| 268 |
#define intbiasshift 16 /* bias for fractions */
| 269 |
#define intbias (((int) 1)<<intbiasshift)
| 270 |
#define gammashift 10 /* gamma = 1024 */
| 271 |
#define gamma (((int) 1)<<gammashift)
| 272 |
#define betashift 10
| 273 |
#define beta (intbias>>betashift) /* beta = 1/1024 */
| 274 |
#define betagamma (intbias<<(gammashift-betashift))
| 275 |
| 276 |
/* defs for decreasing radius factor */
| 277 |
#define initrad (256>>3) /* for 256 cols, radius starts */
| 278 |
#define radiusbiasshift 6 /* at 32.0 biased by 6 bits */
| 279 |
#define radiusbias (((int) 1)<<radiusbiasshift)
| 280 |
#define initradius (initrad*radiusbias) /* and decreases by a */
| 281 |
#define radiusdec 30 /* factor of 1/30 each cycle */
| 282 |
| 283 |
/* defs for decreasing alpha factor */
| 284 |
#define alphabiasshift 10 /* alpha starts at 1.0 */
| 285 |
#define initalpha (((int) 1)<<alphabiasshift)
| 286 |
int alphadec; /* biased by 10 bits */
| 287 |
| 288 |
/* radbias and alpharadbias used for radpower calculation */
| 289 |
#define radbiasshift 8
| 290 |
#define radbias (((int) 1)<<radbiasshift)
| 291 |
#define alpharadbshift (alphabiasshift+radbiasshift)
| 292 |
#define alpharadbias (((int) 1)<<alpharadbshift)
| 293 |
| 294 |
/* four primes near 500 - assume no image has a length so large */
| 295 |
/* that it is divisible by all four primes */
| 296 |
#define prime1 499
| 297 |
#define prime2 491
| 298 |
#define prime3 487
| 299 |
#define prime4 503
| 300 |
| 301 |
typedef int pixel[4]; /* BGRc */
| 302 |
pixel network[256];
| 303 |
| 304 |
int netindex[256]; /* for network lookup - really 256 */
| 305 |
| 306 |
int bias [256]; /* bias and freq arrays for learning */
| 307 |
int freq [256];
| 308 |
int radpower[initrad]; /* radpower for precomputation */
| 309 |
| 310 |
| 311 |
/* initialise network in range (0,0,0) to (255,255,255) */
| 312 |
| 313 |
static void
| 314 |
initnet(void)
| 315 |
| 316 |
register int i;
| 317 |
register int *p;
| 318 |
| 319 |
for (i=0; i<netsize; i++) {
| 320 |
p = network[i];
| 321 |
p[0] = p[1] = p[2] = (i << (netbiasshift+8))/netsize;
| 322 |
freq[i] = intbias/netsize; /* 1/netsize */
| 323 |
bias[i] = 0;
| 324 |
| 325 |
| 326 |
| 327 |
| 328 |
/* do after unbias - insertion sort of network and build netindex[0..255] */
| 329 |
| 330 |
static void
| 331 |
inxbuild(void)
| 332 |
| 333 |
register int i,j,smallpos,smallval;
| 334 |
register int *p,*q;
| 335 |
int previouscol,startpos;
| 336 |
| 337 |
previouscol = 0;
| 338 |
startpos = 0;
| 339 |
| 340 |
p = network[i];
| 341 |
smallpos = i;
| 342 |
smallval = p[1]; /* index on g */
| 343 |
/* find smallest in i..netsize-1 */
| 344 |
for (j=i+1; j<netsize; j++) {
| 345 |
q = network[j];
| 346 |
if (q[1] < smallval) { /* index on g */
| 347 |
smallpos = j;
| 348 |
smallval = q[1]; /* index on g */
| 349 |
| 350 |
| 351 |
q = network[smallpos];
| 352 |
/* swap p (i) and q (smallpos) entries */
| 353 |
if (i != smallpos) {
| 354 |
j = q[0]; q[0] = p[0]; p[0] = j;
| 355 |
j = q[1]; q[1] = p[1]; p[1] = j;
| 356 |
j = q[2]; q[2] = p[2]; p[2] = j;
| 357 |
j = q[3]; q[3] = p[3]; p[3] = j;
| 358 |
| 359 |
/* smallval entry is now in position i */
| 360 |
if (smallval != previouscol) {
| 361 |
netindex[previouscol] = (startpos+i)>>1;
| 362 |
for (j=previouscol+1; j<smallval; j++) netindex[j] = i;
| 363 |
previouscol = smallval;
| 364 |
startpos = i;
| 365 |
| 366 |
| 367 |
netindex[previouscol] = (startpos+maxnetpos)>>1;
| 368 |
for (j=previouscol+1; j<256; j++) netindex[j] = maxnetpos; /* really 256 */
| 369 |
| 370 |
| 371 |
| 372 |
static int
| 373 |
inxsearch( /* accepts real BGR values after net is unbiased */
| 374 |
register int b,
| 375 |
register int g,
| 376 |
register int r
| 377 |
| 378 |
| 379 |
register int i,j,dist,a,bestd;
| 380 |
register int *p;
| 381 |
int best;
| 382 |
| 383 |
bestd = 1000; /* biggest possible dist is 256*3 */
| 384 |
best = -1;
| 385 |
i = netindex[g]; /* index on g */
| 386 |
j = i-1; /* start at netindex[g] and work outwards */
| 387 |
| 388 |
while ((i<netsize) || (j>=0)) {
| 389 |
if (i<netsize) {
| 390 |
p = network[i];
| 391 |
dist = p[1] - g; /* inx key */
| 392 |
if (dist >= bestd) i = netsize; /* stop iter */
| 393 |
else {
| 394 |
i++;
| 395 |
if (dist<0) dist = -dist;
| 396 |
a = p[0] - b; if (a<0) a = -a;
| 397 |
dist += a;
| 398 |
if (dist<bestd) {
| 399 |
a = p[2] - r; if (a<0) a = -a;
| 400 |
dist += a;
| 401 |
if (dist<bestd) {bestd=dist; best=p[3];}
| 402 |
| 403 |
| 404 |
| 405 |
if (j>=0) {
| 406 |
p = network[j];
| 407 |
dist = g - p[1]; /* inx key - reverse dif */
| 408 |
if (dist >= bestd) j = -1; /* stop iter */
| 409 |
else {
| 410 |
j--;
| 411 |
| 412 |
| 413 |
dist += a;
| 414 |
if (dist<bestd) {
| 415 |
| 416 |
dist += a;
| 417 |
| 418 |
| 419 |
| 420 |
| 421 |
| 422 |
return(best);
| 423 |
| 424 |
| 425 |
| 426 |
/* finds closest neuron (min dist) and updates freq */
| 427 |
/* finds best neuron (min dist-bias) and returns position */
| 428 |
/* for frequently chosen neurons, freq[i] is high and bias[i] is negative */
| 429 |
/* bias[i] = gamma*((1/netsize)-freq[i]) */
| 430 |
| 431 |
static int
| 432 |
contest( /* accepts biased BGR values */
| 433 |
register int b,
| 434 |
register int g,
| 435 |
register int r
| 436 |
| 437 |
| 438 |
register int i,dist,a,biasdist,betafreq;
| 439 |
int bestpos,bestbiaspos,bestd,bestbiasd;
| 440 |
register int *p,*f, *n;
| 441 |
| 442 |
bestd = ~(((int) 1)<<31);
| 443 |
bestbiasd = bestd;
| 444 |
bestpos = -1;
| 445 |
bestbiaspos = bestpos;
| 446 |
p = bias;
| 447 |
f = freq;
| 448 |
| 449 |
| 450 |
n = network[i];
| 451 |
dist = n[0] - b; if (dist<0) dist = -dist;
| 452 |
a = n[1] - g; if (a<0) a = -a;
| 453 |
dist += a;
| 454 |
a = n[2] - r; if (a<0) a = -a;
| 455 |
dist += a;
| 456 |
if (dist<bestd) {bestd=dist; bestpos=i;}
| 457 |
biasdist = dist - ((*p)>>(intbiasshift-netbiasshift));
| 458 |
if (biasdist<bestbiasd) {bestbiasd=biasdist; bestbiaspos=i;}
| 459 |
betafreq = (*f >> betashift);
| 460 |
*f++ -= betafreq;
| 461 |
*p++ += (betafreq<<gammashift);
| 462 |
| 463 |
freq[bestpos] += beta;
| 464 |
bias[bestpos] -= betagamma;
| 465 |
return(bestbiaspos);
| 466 |
| 467 |
| 468 |
| 469 |
/* move neuron i towards (b,g,r) by factor alpha */
| 470 |
| 471 |
static void
| 472 |
altersingle( /* accepts biased BGR values */
| 473 |
register int alpha,
| 474 |
register int i,
| 475 |
register int b,
| 476 |
register int g,
| 477 |
register int r
| 478 |
| 479 |
| 480 |
register int *n;
| 481 |
| 482 |
n = network[i]; /* alter hit neuron */
| 483 |
*n -= (alpha*(*n - b)) / initalpha;
| 484 |
n++;
| 485 |
*n -= (alpha*(*n - g)) / initalpha;
| 486 |
n++;
| 487 |
*n -= (alpha*(*n - r)) / initalpha;
| 488 |
| 489 |
| 490 |
| 491 |
/* move neurons adjacent to i towards (b,g,r) by factor */
| 492 |
/* alpha*(1-((i-j)^2/[r]^2)) precomputed as radpower[|i-j|]*/
| 493 |
| 494 |
static void
| 495 |
alterneigh( /* accents biased BGR values */
| 496 |
int rad,
| 497 |
int i,
| 498 |
register int b,
| 499 |
register int g,
| 500 |
register int r
| 501 |
| 502 |
| 503 |
register int j,k,lo,hi,a;
| 504 |
register int *p, *q;
| 505 |
| 506 |
lo = i-rad; if (lo<-1) lo= -1;
| 507 |
hi = i+rad; if (hi>netsize) hi=netsize;
| 508 |
| 509 |
j = i+1;
| 510 |
k = i-1;
| 511 |
q = radpower;
| 512 |
while ((j<hi) || (k>lo)) {
| 513 |
a = (*(++q));
| 514 |
if (j<hi) {
| 515 |
p = network[j];
| 516 |
*p -= (a*(*p - b)) / alpharadbias;
| 517 |
p++;
| 518 |
*p -= (a*(*p - g)) / alpharadbias;
| 519 |
p++;
| 520 |
*p -= (a*(*p - r)) / alpharadbias;
| 521 |
j++;
| 522 |
| 523 |
if (k>lo) {
| 524 |
p = network[k];
| 525 |
| 526 |
p++;
| 527 |
| 528 |
p++;
| 529 |
| 530 |
k--;
| 531 |
| 532 |
| 533 |
| 534 |
| 535 |
| 536 |
static void
| 537 |
learn(void)
| 538 |
| 539 |
register int i,j,b,g,r;
| 540 |
int radius,rad,alpha,step,delta,samplepixels;
| 541 |
register unsigned char *p;
| 542 |
unsigned char *lim;
| 543 |
| 544 |
alphadec = 30 + ((samplefac-1)/3);
| 545 |
p = thepicture;
| 546 |
lim = thepicture + lengthcount;
| 547 |
samplepixels = lengthcount/(3*samplefac);
| 548 |
delta = samplepixels/ncycles;
| 549 |
alpha = initalpha;
| 550 |
radius = initradius;
| 551 |
| 552 |
rad = radius >> radiusbiasshift;
| 553 |
if (rad <= 1) rad = 0;
| 554 |
for (i=0; i<rad; i++)
| 555 |
radpower[i] = alpha*(((rad*rad - i*i)*radbias)/(rad*rad));
| 556 |
| 557 |
if ((lengthcount%prime1) != 0) step = 3*prime1;
| 558 |
else {
| 559 |
if ((lengthcount%prime2) !=0) step = 3*prime2;
| 560 |
else {
| 561 |
if ((lengthcount%prime3) !=0) step = 3*prime3;
| 562 |
else step = 3*prime4;
| 563 |
| 564 |
| 565 |
| 566 |
i = 0;
| 567 |
while (i < samplepixels) {
| 568 |
b = p[0] << netbiasshift;
| 569 |
g = p[1] << netbiasshift;
| 570 |
r = p[2] << netbiasshift;
| 571 |
j = contest(b,g,r);
| 572 |
| 573 |
altersingle(alpha,j,b,g,r);
| 574 |
if (rad) alterneigh(rad,j,b,g,r); /* alter neighbours */
| 575 |
| 576 |
p += step;
| 577 |
if (p >= lim) p -= lengthcount;
| 578 |
| 579 |
i++;
| 580 |
if (i%delta == 0) {
| 581 |
alpha -= alpha / alphadec;
| 582 |
radius -= radius / radiusdec;
| 583 |
| 584 |
| 585 |
for (j=0; j<rad; j++)
| 586 |
radpower[j] = alpha*(((rad*rad - j*j)*radbias)/(rad*rad));
| 587 |
| 588 |
| 589 |
| 590 |
| 591 |
/* unbias network to give 0..255 entries */
| 592 |
/* which can then be used for colour map */
| 593 |
/* and record position i to prepare for sort */
| 594 |
| 595 |
static void
| 596 |
unbiasnet(void)
| 597 |
| 598 |
int i,j;
| 599 |
| 600 |
| 601 |
for (j=0; j<3; j++)
| 602 |
network[i][j] >>= netbiasshift;
| 603 |
network[i][3] = i; /* record colour no */
| 604 |
| 605 |
| 606 |
| 607 |
| 608 |
/* Don't do this until the network has been unbiased (GW) */
| 609 |
| 610 |
static void
| 611 |
cpyclrtab(void)
| 612 |
| 613 |
register int i,j,k;
| 614 |
| 615 |
for (j=0; j<netsize; j++) {
| 616 |
k = network[j][3];
| 617 |
| 618 |
clrtab[k][i] = network[j][2-i];
| 619 |
| 620 |
