root/radiance/ray/src/px/mt160r.c
Changes since 2.7: +26 -14 lines
Diff to previous 2.7 , to selected 1.8
Changes since 2.6: +5 -10 lines
Diff to previous 2.6 , to selected 1.8
Changes since 2.5: +2 -4 lines
Diff to previous 2.5 , to selected 1.8
Mon Aug 2 14:39:10 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.4: +0 -3 lines
Diff to previous 2.4 , to selected 1.8
removed questionable line buffer setting
Mon Sep 21 12:13:29 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +12 -4 lines
Diff to previous 2.3 , to selected 1.8
Changes for PC port
Wed Jan 29 15:18:34 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +4 -0 lines
Diff to previous 2.2 , to selected 1.8
removed line buffering of output
Mon Dec 23 22:35:30 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 1.8
removed unnecessary static declarations
Tue Nov 12 16:04:57 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.9 , to selected 1.8
Mon Nov 11 14:01:28 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.8
Revision 1.8 - (view) (download) (annotate) - [selected]
Mon May 6 13:14:21 1991 UTC (33 years, 1 month ago) by greg
Diff to previous 1.7
improved dithering slightly
Thu Apr 18 14:35:09 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.6: +4 -1 lines
Diff to previous 1.6 , to selected 1.8
Fri Jan 26 08:17:31 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.5 , to selected 1.8
Thu Jan 25 08:28:33 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +1 -3 lines
Diff to previous 1.4 , to selected 1.8
Fri Oct 20 20:35:59 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +2 -3 lines
Diff to previous 1.3 , to selected 1.8
change to color normalization calls
Fri Oct 20 16:44:32 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.2: +14 -13 lines
Diff to previous 1.2 , to selected 1.8
eliminated unnecessary use of floating point color
Tue Sep 12 13:04:18 1989 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +1 -2 lines
Diff to previous 1.1 , to selected 1.8
Thu Feb 2 10:49:20 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.8
