root/radiance/ray/src/px/macbethcal.c
Revision: 2.31
Committed: Tue Jun 3 21:31:51 2025 UTC (2 weeks, 5 days ago) by greg
Changes since 2.30: +2 -3 lines
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.30 2024/02/22 17:45:54 greg Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <math.h>
14
15 #include "platform.h"
16 #include "paths.h"
17 #include "rtio.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "pmap.h"
21 #include "warp3d.h"
22 #include "mx3.h"
23
24 /* MacBeth colors */
25 #define DarkSkin 0
26 #define LightSkin 1
27 #define BlueSky 2
28 #define Foliage 3
29 #define BlueFlower 4
30 #define BluishGreen 5
31 #define Orange 6
32 #define PurplishBlue 7
33 #define ModerateRed 8
34 #define Purple 9
35 #define YellowGreen 10
36 #define OrangeYellow 11
37 #define Blue 12
38 #define Green 13
39 #define Red 14
40 #define Yellow 15
41 #define Magenta 16
42 #define Cyan 17
43 #define White 18
44 #define Neutral8 19
45 #define Neutral65 20
46 #define Neutral5 21
47 #define Neutral35 22
48 #define Black 23
49 /* computed from 10nm spectral measurements */
50 /* CIE 1931 2 degree obs, equal-energy white */
51 float mbxyY[24][3] = {
52 {0.421236, 0.361196, 0.103392}, /* DarkSkin */
53 {0.40868, 0.358157, 0.352867}, /* LightSkin */
54 {0.265063, 0.271424, 0.185124}, /* BlueSky */
55 {0.362851, 0.43055, 0.132625}, /* Foliage */
56 {0.28888, 0.260851, 0.233138}, /* BlueFlower */
57 {0.277642, 0.365326, 0.416443}, /* BluishGreen */
58 {0.524965, 0.40068, 0.312039}, /* Orange */
59 {0.225018, 0.190392, 0.114999}, /* PurplishBlue */
60 {0.487199, 0.315372, 0.198616}, /* ModerateRed */
61 {0.314245, 0.227231, 0.0646047}, /* Purple */
62 {0.396202, 0.489732, 0.440724}, /* YellowGreen */
63 {0.493297, 0.435299, 0.43444}, /* OrangeYellow */
64 {0.198191, 0.149265, 0.0588122}, /* Blue */
65 {0.322838, 0.487601, 0.229258}, /* Green */
66 {0.561833, 0.321165, 0.126978}, /* Red */
67 {0.468113, 0.467021, 0.605289}, /* Yellow */
68 {0.397128, 0.248535, 0.201761}, /* Magenta */
69 {0.209552, 0.276256, 0.190917}, /* Cyan */
70 {0.337219, 0.339042, 0.912482}, /* White */
71 {0.333283, 0.335077, 0.588297}, /* Neutral.8 */
72 {0.332747, 0.334371, 0.3594}, /* Neutral.65 */
73 {0.331925, 0.334202, 0.19114}, /* Neutral.5 */
74 {0.330408, 0.332615, 0.0892964}, /* Neutral.35 */
75 {0.331841, 0.331405, 0.0319541}, /* Black */
76 };
77
78 COLOR mbRGB[24]; /* MacBeth RGB values */
79
80 #define NMBNEU 6 /* Number of MacBeth neutral colors */
81 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
82
83 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
84 1L<<Neutral5|1L<<Neutral35|1L<<Black)
85
86 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
87 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
88 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
89
90 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
91 1L<<BluishGreen|1L<<ModerateRed)
92
93 #define REQFLGS NEUFLGS /* need these colors */
94 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
95
96 #define RG_BORD 0 /* patch border */
97 #define RG_CENT 01 /* central region of patch */
98 #define RG_ORIG 02 /* original color region */
99 #define RG_CORR 04 /* corrected color region */
100
101 #ifndef DISPCOM
102 #define DISPCOM "ximage -e auto -op \"%s\""
103 #endif
104
105 int scanning = 1; /* scanned input (or recorded output)? */
106 double irrad = 1.0; /* irradiance multiplication factor */
107 int rawmap = 0; /* put out raw color mapping? */
108
109 int xmax, ymax; /* input image dimensions */
110 int bounds[4][2]; /* image coordinates of chart corners */
111 double imgxfm[3][3]; /* coordinate transformation matrix */
112
113 COLOR inpRGB[24]; /* measured or scanned input colors */
114 long inpflags = 0; /* flags of which colors were input */
115 long gmtflags = 0; /* flags of out-of-gamut colors */
116
117 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
118 COLORMAT solmat; /* color mapping matrix */
119 COLOR colmin, colmax; /* gamut limits */
120
121 WARP3D *wcor = NULL; /* color space warp */
122
123 FILE *debugfp = NULL; /* debug output picture */
124
125 static void init(void);
126 static int chartndx(int x, int y, int *np);
127 static void getpicture(void);
128 static void getcolors(void);
129 static void bresp(COLOR y, COLOR x);
130 static void ibresp(COLOR y, COLOR x);
131 static void compute(void);
132 static void putmapping(void);
133 static void compsoln(COLOR cin[], COLOR cout[], int n);
134 static void cwarp(void);
135 static int cvtcolor(COLOR cout, COLOR cin);
136 static int cresp(COLOR cout, COLOR cin);
137 static void xyY2RGB(COLOR rgbout, float xyYin[3]);
138 static void picdebug(void);
139 static void clrdebug(void);
140 static void getpos(char *name, int bnds[2], FILE *fp);
141 static void pickchartpos(char *pfn);
142
143
144 int
145 main(
146 int argc,
147 char **argv
148 )
149 {
150 int i;
151
152 fixargv0(argv[0]); /* sets global progname */
153 for (i = 1; i < argc && argv[i][0] == '-'; i++)
154 switch (argv[i][1]) {
155 case 'd': /* debug output */
156 i++;
157 if (badarg(argc-i, argv+i, "s"))
158 goto userr;
159 if ((debugfp = fopen(argv[i], "w")) == NULL) {
160 perror(argv[i]);
161 exit(1);
162 }
163 SET_FILE_BINARY(debugfp);
164 newheader("RADIANCE", debugfp); /* start */
165 printargs(argc, argv, debugfp); /* header */
166 break;
167 case 'p': /* picture position */
168 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
169 goto userr;
170 bounds[0][0] = atoi(argv[++i]);
171 bounds[0][1] = atoi(argv[++i]);
172 bounds[1][0] = atoi(argv[++i]);
173 bounds[1][1] = atoi(argv[++i]);
174 bounds[2][0] = atoi(argv[++i]);
175 bounds[2][1] = atoi(argv[++i]);
176 bounds[3][0] = atoi(argv[++i]);
177 bounds[3][1] = atoi(argv[++i]);
178 scanning = 2;
179 break;
180 case 'P': /* pick position */
181 scanning = 3;
182 break;
183 case 'i': /* irradiance factor */
184 i++;
185 if (badarg(argc-i, argv+i, "f"))
186 goto userr;
187 irrad = atof(argv[i]);
188 break;
189 case 'm': /* raw map output */
190 rawmap = 1;
191 break;
192 case 'c': /* color input */
193 scanning = 0;
194 break;
195 default:
196 goto userr;
197 }
198 /* open files */
199 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
200 perror(argv[i]);
201 exit(1);
202 }
203 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
204 perror(argv[i+1]);
205 exit(1);
206 }
207 if (scanning) { /* load input picture header */
208 SET_FILE_BINARY(stdin);
209 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
210 fgetresolu(&xmax, &ymax, stdin) < 0) {
211 fprintf(stderr, "%s: bad input picture\n", progname);
212 exit(1);
213 }
214 if (scanning == 3) {
215 if (i >= argc)
216 goto userr;
217 pickchartpos(argv[i]);
218 scanning = 2;
219 }
220 } else { /* else set default xmax and ymax */
221 xmax = 512;
222 ymax = 2*512/3;
223 }
224 if (scanning != 2) { /* use default boundaries */
225 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
226 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
227 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
228 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
229 }
230 init(); /* initialize */
231 if (scanning) /* get picture colors */
232 getpicture();
233 else
234 getcolors();
235 compute(); /* compute color mapping */
236 if (rawmap) { /* print out raw correspondence */
237 int j;
238
239 printf("# Color correspondence produced by:\n#\t\t");
240 printargs(argc, argv, stdout);
241 printf("#\tUsage: pcwarp %s uncorrected.hdr > corrected.hdr\n",
242 i+1 < argc ? argv[i+1] : "{this_file}");
243 printf("#\t Or: pcond [options] -m %s orig.hdr > output.hdr\n",
244 i+1 < argc ? argv[i+1] : "{this_file}");
245 for (j = 0; j < 24; j++)
246 printf("%f %f %f %f %f %f\n",
247 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
248 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
249 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
250 if (scanning && debugfp != NULL)
251 cwarp(); /* color warp for debugging */
252 } else { /* print color mapping */
253 /* print header */
254 printf("{\n\tColor correction file computed by:\n\t\t");
255 printargs(argc, argv, stdout);
256 printf("\n\tUsage: pcomb -f %s uncorrected.hdr > corrected.hdr\n",
257 i+1 < argc ? argv[i+1] : "{this_file}");
258 if (!scanning)
259 printf("\t Or: pcond [options] -f %s orig.hdr > output.hdr\n",
260 i+1 < argc ? argv[i+1] : "{this_file}");
261 printf("}\n");
262 putmapping(); /* put out color mapping */
263 }
264 if (debugfp != NULL) { /* put out debug picture */
265 if (scanning)
266 picdebug();
267 else
268 clrdebug();
269 }
270 exit(0);
271 userr:
272 fprintf(stderr,
273 "Usage: %s [-d dbg.hdr][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.hdr [output.{cal|cwp}]\n",
274 progname);
275 fprintf(stderr, " or: %s [-d dbg.hdr][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
276 progname);
277 exit(1);
278 return 1; /* pro forma return */
279 }
280
281
282 static void
283 init(void) /* initialize */
284 {
285 double quad[4][2];
286 int i;
287 /* make coordinate transformation */
288 quad[0][0] = bounds[0][0];
289 quad[0][1] = bounds[0][1];
290 quad[1][0] = bounds[1][0];
291 quad[1][1] = bounds[1][1];
292 quad[2][0] = bounds[3][0];
293 quad[2][1] = bounds[3][1];
294 quad[3][0] = bounds[2][0];
295 quad[3][1] = bounds[2][1];
296
297 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
298 fprintf(stderr, "%s: bad chart boundaries\n", progname);
299 exit(1);
300 }
301 /* map MacBeth colors to RGB space */
302 for (i = 0; i < 24; i++) {
303 xyY2RGB(mbRGB[i], mbxyY[i]);
304 scalecolor(mbRGB[i], irrad);
305 }
306 }
307
308
309 static int
310 chartndx( /* find color number for position */
311 int x,
312 int y,
313 int *np
314 )
315 {
316 double ipos[3], cpos[3];
317 int ix, iy;
318 double fx, fy;
319
320 ipos[0] = x;
321 ipos[1] = y;
322 ipos[2] = 1;
323 mx3d_transform(ipos, imgxfm, cpos);
324 cpos[0] /= cpos[2];
325 cpos[1] /= cpos[2];
326 if ((cpos[0] < 0.) | (cpos[0] >= 6.) | (cpos[1] < 0.) | (cpos[1] >= 4.))
327 return(RG_BORD);
328 ix = cpos[0];
329 iy = cpos[1];
330 fx = cpos[0] - ix;
331 fy = cpos[1] - iy;
332 *np = iy*6 + ix;
333 if ((fx >= 0.35) & (fx < 0.65) & (fy >= 0.35) & (fy < 0.65))
334 return(RG_CENT);
335 if ((fx < 0.05) | (fx >= 0.95) | (fy < 0.05) | (fy >= 0.95))
336 return(RG_BORD);
337 if (fx >= 0.5) /* right side is corrected */
338 return(RG_CORR);
339 return(RG_ORIG); /* left side is original */
340 }
341
342
343 static void
344 getpicture(void) /* load in picture colors */
345 {
346 COLR *scanln;
347 COLOR pval;
348 int ccount[24];
349 double d;
350 int y, i;
351 int x;
352
353 scanln = (COLR *)malloc(xmax*sizeof(COLR));
354 if (scanln == NULL) {
355 perror(progname);
356 exit(1);
357 }
358 for (i = 0; i < 24; i++) {
359 setcolor(inpRGB[i], 0., 0., 0.);
360 ccount[i] = 0;
361 }
362 for (y = ymax-1; y >= 0; y--) {
363 if (freadcolrs(scanln, xmax, stdin) < 0) {
364 fprintf(stderr, "%s: error reading input picture\n",
365 progname);
366 exit(1);
367 }
368 for (x = 0; x < xmax; x++)
369 if (chartndx(x, y, &i) == RG_CENT) {
370 colr_color(pval, scanln[x]);
371 addcolor(inpRGB[i], pval);
372 ccount[i]++;
373 }
374 }
375 for (i = 0; i < 24; i++) { /* compute averages */
376 if (ccount[i] == 0)
377 continue;
378 d = 1./ccount[i];
379 scalecolor(inpRGB[i], d);
380 inpflags |= 1L<<i;
381 }
382 free((void *)scanln);
383 }
384
385
386 static void
387 getcolors(void) /* get xyY colors from standard input */
388 {
389 int gotwhite = 0;
390 COLOR whiteclr;
391 int n;
392 float xyYin[3];
393
394 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
395 if ((n < 0) | (n > 24) ||
396 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
397 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
398 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
399 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
400 xyYin[0] + xyYin[1] > 1.) {
401 fprintf(stderr, "%s: bad color input data\n",
402 progname);
403 exit(1);
404 }
405 if (n == 0) { /* calibration white */
406 xyY2RGB(whiteclr, xyYin);
407 gotwhite++;
408 } else { /* standard color */
409 n--;
410 xyY2RGB(inpRGB[n], xyYin);
411 inpflags |= 1L<<n;
412 }
413 }
414 /* normalize colors */
415 if (!gotwhite) {
416 if (!(inpflags & 1L<<White)) {
417 fprintf(stderr, "%s: missing input for White\n",
418 progname);
419 exit(1);
420 }
421 setcolor(whiteclr,
422 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
423 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
424 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
425 }
426 for (n = 0; n < 24; n++)
427 if (inpflags & 1L<<n)
428 setcolor(inpRGB[n],
429 colval(inpRGB[n],RED)/colval(whiteclr,RED),
430 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
431 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
432 }
433
434
435 static void
436 bresp( /* piecewise linear interpolation of primaries */
437 COLOR y, /* y is linear output */
438 COLOR x /* x is non-linear input */
439 )
440 {
441 int i, n;
442
443 for (i = 0; i < 3; i++) {
444 for (n = 0; n < NMBNEU-2; n++)
445 if (colval(x,i) < colval(bramp[n+1][0],i))
446 break;
447 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
448 colval(bramp[n][1],i) +
449 (colval(x,i) - colval(bramp[n][0],i)) *
450 colval(bramp[n+1][1],i)) /
451 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
452 }
453 }
454
455
456 static void
457 ibresp( /* inverse mapping (delinearization) */
458 COLOR x, /* x is non-linear output */
459 COLOR y /* y is linear input */
460 )
461 {
462 int i, n;
463
464 for (i = 0; i < 3; i++) {
465 for (n = 0; n < NMBNEU-2; n++)
466 if (colval(y,i) < colval(bramp[n+1][1],i))
467 break;
468 colval(x,i) = ((colval(bramp[n+1][1],i) - colval(y,i)) *
469 colval(bramp[n][0],i) +
470 (colval(y,i) - colval(bramp[n][1],i)) *
471 colval(bramp[n+1][0],i)) /
472 (colval(bramp[n+1][1],i) - colval(bramp[n][1],i));
473 }
474 }
475
476
477 static void
478 compute(void) /* compute color mapping */
479 {
480 COLOR clrin[24], clrout[24];
481 long cflags;
482 COLOR ctmp;
483 int i, n;
484 /* did we get what we need? */
485 if ((inpflags & REQFLGS) != REQFLGS) {
486 fprintf(stderr, "%s: missing required input colors\n",
487 progname);
488 exit(1);
489 }
490 /* compute piecewise luminance curve */
491 for (i = 0; i < NMBNEU; i++) {
492 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
493 for (n = 3*(i>0); n--; )
494 if (colval(bramp[i][0],n) <=
495 colval(bramp[i-1][0],n)+1e-7) {
496 fprintf(stderr,
497 "%s: non-increasing neutral patch\n", progname);
498 exit(1);
499 }
500 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
501 }
502 /* compute color space gamut */
503 copycolor(colmin, cblack);
504 copycolor(colmax, cwhite);
505 scalecolor(colmax, irrad);
506 if (!scanning) {
507 ibresp(colmin, colmin);
508 ibresp(colmax, colmax);
509 }
510 /* compute color mapping */
511 do {
512 cflags = inpflags & ~gmtflags;
513 n = 0; /* compute transform matrix */
514 for (i = 0; i < 24; i++) {
515 if (!(cflags & 1L<<i))
516 continue;
517 if (scanning) {
518 bresp(clrin[n], inpRGB[i]);
519 copycolor(clrout[n], mbRGB[i]);
520 } else {
521 copycolor(clrin[n], inpRGB[i]);
522 ibresp(clrout[n], mbRGB[i]);
523 }
524 n++;
525 }
526 compsoln(clrin, clrout, n);
527 for (i = 0; i < 24; i++) /* check gamut */
528 if (cflags & 1L<<i && cvtcolor(ctmp, inpRGB[i]))
529 gmtflags |= 1L<<i;
530 } while (cflags & gmtflags);
531
532 if (gmtflags & MODFLGS)
533 fprintf(stderr,
534 "%s: warning - some moderate colors are out of gamut\n",
535 progname);
536 }
537
538
539 static void
540 putmapping(void) /* put out color mapping */
541 {
542 static char cchar[3] = {'r', 'g', 'b'};
543 int i, j;
544 /* print brightness mapping */
545 for (j = 0; j < 3; j++) {
546 printf("%cxa(i) : select(i", cchar[j]);
547 for (i = 0; i < NMBNEU; i++)
548 printf(",%g", colval(bramp[i][0],j));
549 printf(");\n");
550 printf("%cya(i) : select(i", cchar[j]);
551 for (i = 0; i < NMBNEU; i++)
552 printf(",%g", colval(bramp[i][1],j));
553 printf(");\n");
554 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
555 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
556 cchar[j], cchar[j]);
557 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
558 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
559 cchar[j], scanning?'n':'o', cchar[j],
560 cchar[j], cchar[j], cchar[j], cchar[j]);
561 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
562 cchar[j], cchar[j], cchar[j],
563 cchar[j], cchar[j]);
564 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
565 cchar[j], cchar[j], cchar[j], cchar[j]);
566 }
567 /* print color mapping */
568 if (scanning) {
569 printf("r = ri(1); g = gi(1); b = bi(1);\n");
570 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
571 solmat[0][0], solmat[0][1], solmat[0][2]);
572 printf("go = %g*rn + %g*gn + %g*bn ;\n",
573 solmat[1][0], solmat[1][1], solmat[1][2]);
574 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
575 solmat[2][0], solmat[2][1], solmat[2][2]);
576 } else {
577 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
578 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
579 solmat[0][0], solmat[0][1], solmat[0][2]);
580 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
581 solmat[1][0], solmat[1][1], solmat[1][2]);
582 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
583 solmat[2][0], solmat[2][1], solmat[2][2]);
584 }
585 }
586
587
588 static void
589 compsoln( /* solve 3xN system using least-squares */
590 COLOR cin[],
591 COLOR cout[],
592 int n
593 )
594 {
595 extern double mx3d_adjoint(), fabs();
596 double mat[3][3], invmat[3][3];
597 double det;
598 double colv[3], rowv[3];
599 int i, j, k;
600
601 if (n < 3) {
602 fprintf(stderr, "%s: too few colors to match!\n", progname);
603 exit(1);
604 }
605 if (n == 3)
606 for (i = 0; i < 3; i++)
607 for (j = 0; j < 3; j++)
608 mat[i][j] = colval(cin[j],i);
609 else { /* compute A^t A */
610 for (i = 0; i < 3; i++)
611 for (j = i; j < 3; j++) {
612 mat[i][j] = 0.;
613 for (k = 0; k < n; k++)
614 mat[i][j] += colval(cin[k],i) *
615 colval(cin[k],j);
616 }
617 for (i = 1; i < 3; i++) /* using symmetry */
618 for (j = 0; j < i; j++)
619 mat[i][j] = mat[j][i];
620 }
621 det = mx3d_adjoint(mat, invmat);
622 if (fabs(det) < 1e-4) {
623 fprintf(stderr, "%s: cannot compute color mapping\n",
624 progname);
625 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
626 solmat[0][1] = solmat[0][2] = solmat[1][0] =
627 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
628 return;
629 }
630 for (i = 0; i < 3; i++)
631 for (j = 0; j < 3; j++)
632 invmat[i][j] /= det;
633 for (i = 0; i < 3; i++) {
634 if (n == 3)
635 for (j = 0; j < 3; j++)
636 colv[j] = colval(cout[j],i);
637 else
638 for (j = 0; j < 3; j++) {
639 colv[j] = 0.;
640 for (k = 0; k < n; k++)
641 colv[j] += colval(cout[k],i) *
642 colval(cin[k],j);
643 }
644 mx3d_transform(colv, invmat, rowv);
645 for (j = 0; j < 3; j++)
646 solmat[i][j] = rowv[j];
647 }
648 }
649
650
651 static void
652 cwarp(void) /* compute color warp map */
653 {
654 int i;
655
656 if ((wcor = new3dw(W3EXACT)) == NULL)
657 goto memerr;
658 for (i = 0; i < 24; i++)
659 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
660 goto memerr;
661 return;
662 memerr:
663 perror(progname);
664 exit(1);
665 }
666
667
668 static int
669 cvtcolor( /* convert color according to our mapping */
670 COLOR cout,
671 COLOR cin
672 )
673 {
674 COLOR ctmp;
675 int clipped;
676
677 if (wcor != NULL) {
678 clipped = warp3d(cout, cin, wcor);
679 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
680 } else if (scanning) {
681 bresp(ctmp, cin);
682 clipped = cresp(cout, ctmp);
683 } else {
684 clipped = cresp(ctmp, cin);
685 bresp(cout, ctmp);
686 }
687 return(clipped);
688 }
689
690
691 static int
692 cresp( /* transform color according to matrix */
693 COLOR cout,
694 COLOR cin
695 )
696 {
697 colortrans(cout, solmat, cin);
698 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
699 }
700
701
702 static void
703 xyY2RGB( /* convert xyY to RGB */
704 COLOR rgbout,
705 float xyYin[3]
706 )
707 {
708 COLOR ctmp;
709 double d;
710
711 d = xyYin[2] / xyYin[1];
712 ctmp[0] = xyYin[0] * d;
713 ctmp[1] = xyYin[2];
714 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
715 /* allow negative values */
716 colortrans(rgbout, xyz2rgbmat, ctmp);
717 }
718
719
720 static void
721 picdebug(void) /* put out debugging picture */
722 {
723 static COLOR blkcol = BLKCOLOR;
724 COLOR *scan;
725 int y, i;
726 int x, rg;
727
728 if (fseek(stdin, 0L, 0) == EOF) {
729 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
730 exit(1);
731 }
732 getheader(stdin, NULL, NULL); /* skip input header */
733 fgetresolu(&xmax, &ymax, stdin);
734 /* allocate scanline */
735 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
736 if (scan == NULL) {
737 perror(progname);
738 exit(1);
739 }
740 /* finish debug header */
741 fputformat(COLRFMT, debugfp);
742 putc('\n', debugfp);
743 fprtresolu(xmax, ymax, debugfp);
744 /* write debug picture */
745 for (y = ymax-1; y >= 0; y--) {
746 if (freadscan(scan, xmax, stdin) < 0) {
747 fprintf(stderr, "%s: error rereading input picture\n",
748 progname);
749 exit(1);
750 }
751 for (x = 0; x < xmax; x++) {
752 rg = chartndx(x, y, &i);
753 if (rg == RG_CENT) {
754 if (!(1L<<i & gmtflags) || (x+y)&07) {
755 copycolor(scan[x], mbRGB[i]);
756 clipgamut(scan[x], bright(scan[x]),
757 CGAMUT, colmin, colmax);
758 } else
759 copycolor(scan[x], blkcol);
760 } else if (rg == RG_CORR)
761 cvtcolor(scan[x], scan[x]);
762 else if (rg != RG_ORIG)
763 copycolor(scan[x], blkcol);
764 }
765 if (fwritescan(scan, xmax, debugfp) < 0) {
766 fprintf(stderr, "%s: error writing debugging picture\n",
767 progname);
768 exit(1);
769 }
770 }
771 /* clean up */
772 fclose(debugfp);
773 free((void *)scan);
774 }
775
776
777 static void
778 clrdebug(void) /* put out debug picture from color input */
779 {
780 static COLR blkclr = BLKCOLR;
781 COLR mbclr[24], cvclr[24], orclr[24];
782 COLR *scan;
783 COLOR ctmp, ct2;
784 int y, i;
785 int x, rg;
786 /* convert colors */
787 for (i = 0; i < 24; i++) {
788 copycolor(ctmp, mbRGB[i]);
789 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
790 setcolr(mbclr[i], colval(ctmp,RED),
791 colval(ctmp,GRN), colval(ctmp,BLU));
792 if (inpflags & 1L<<i) {
793 copycolor(ctmp, inpRGB[i]);
794 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
795 setcolr(orclr[i], colval(ctmp,RED),
796 colval(ctmp,GRN), colval(ctmp,BLU));
797 if (rawmap)
798 copycolr(cvclr[i], mbclr[i]);
799 else {
800 bresp(ctmp, inpRGB[i]);
801 colortrans(ct2, solmat, ctmp);
802 clipgamut(ct2, bright(ct2), CGAMUT,
803 cblack, cwhite);
804 setcolr(cvclr[i], colval(ct2,RED),
805 colval(ct2,GRN),
806 colval(ct2,BLU));
807 }
808 }
809 }
810 /* allocate scanline */
811 scan = (COLR *)malloc(xmax*sizeof(COLR));
812 if (scan == NULL) {
813 perror(progname);
814 exit(1);
815 }
816 /* finish debug header */
817 fputformat(COLRFMT, debugfp);
818 putc('\n', debugfp);
819 fprtresolu(xmax, ymax, debugfp);
820 /* write debug picture */
821 for (y = ymax-1; y >= 0; y--) {
822 for (x = 0; x < xmax; x++) {
823 rg = chartndx(x, y, &i);
824 if (rg == RG_CENT) {
825 if (!(1L<<i & gmtflags) || (x+y)&07)
826 copycolr(scan[x], mbclr[i]);
827 else
828 copycolr(scan[x], blkclr);
829 } else if (rg == RG_BORD || !(1L<<i & inpflags))
830 copycolr(scan[x], blkclr);
831 else if (rg == RG_ORIG)
832 copycolr(scan[x], orclr[i]);
833 else /* rg == RG_CORR */
834 copycolr(scan[x], cvclr[i]);
835 }
836 if (fwritecolrs(scan, xmax, debugfp) < 0) {
837 fprintf(stderr, "%s: error writing debugging picture\n",
838 progname);
839 exit(1);
840 }
841 }
842 /* clean up */
843 fclose(debugfp);
844 free((void *)scan);
845 }
846
847
848 static void
849 getpos( /* get boundary position */
850 char *name,
851 int bnds[2],
852 FILE *fp
853 )
854 {
855 char buf[64];
856
857 fprintf(stderr, "\tSelect corner: %s\n", name);
858 if (fgets(buf, sizeof(buf), fp) == NULL ||
859 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
860 fprintf(stderr, "%s: read error from display process\n",
861 progname);
862 exit(1);
863 }
864 }
865
866
867 static void
868 pickchartpos( /* display picture and pick chart location */
869 char *pfn
870 )
871 {
872 char combuf[PATH_MAX];
873 FILE *pfp;
874
875 sprintf(combuf, DISPCOM, pfn);
876 if ((pfp = popen(combuf, "r")) == NULL) {
877 perror(combuf);
878 exit(1);
879 }
880 fputs("Use middle mouse button to select chart corners:\n", stderr);
881 getpos("upper left (dark skin)", bounds[0], pfp);
882 getpos("upper right (bluish green)", bounds[1], pfp);
883 getpos("lower left (white)", bounds[2], pfp);
884 getpos("lower right (black)", bounds[3], pfp);
885 fputs("Got it -- quit display program.\n", stderr);
886 pclose(pfp);
887 }
