root/radiance/ray/src/px/macbethcal.c
Revision: 2.22
Committed: Mon Nov 10 12:28:56 2003 UTC (21 years, 3 months ago) by schorsch
Changes since 2.21: +3 -3 lines
Fixed size of command line buffers, and allow spaces in input file paths.
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.21 2003/10/27 10:24:51 schorsch Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <stdio.h>
14 #include <math.h>
15 #include <time.h>
16
17 #include "platform.h"
18 #include "rtprocess.h"
19 #include "color.h"
20 #include "resolu.h"
21 #include "pmap.h"
22 #include "warp3d.h"
23
24 /* MacBeth colors */
25 #define DarkSkin 0
26 #define LightSkin 1
27 #define BlueSky 2
28 #define Foliage 3
29 #define BlueFlower 4
30 #define BluishGreen 5
31 #define Orange 6
32 #define PurplishBlue 7
33 #define ModerateRed 8
34 #define Purple 9
35 #define YellowGreen 10
36 #define OrangeYellow 11
37 #define Blue 12
38 #define Green 13
39 #define Red 14
40 #define Yellow 15
41 #define Magenta 16
42 #define Cyan 17
43 #define White 18
44 #define Neutral8 19
45 #define Neutral65 20
46 #define Neutral5 21
47 #define Neutral35 22
48 #define Black 23
49 /* computed from 5nm spectral measurements */
50 /* CIE 1931 2 degree obs, equal-energy white */
51 float mbxyY[24][3] = {
52 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
53 {0.4108, 0.3542, 0.410348}, /* LightSkin */
54 {0.2626, 0.267, 0.181554}, /* BlueSky */
55 {0.36, 0.4689, 0.108447}, /* Foliage */
56 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
57 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
58 {0.52, 0.4197, 0.357899}, /* Orange */
59 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
60 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
61 {0.3361, 0.2249, 0.0600102}, /* Purple */
62 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
63 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
64 {0.2026, 0.1369, 0.0529249}, /* Blue */
65 {0.3007, 0.4822, 0.221226}, /* Green */
66 {0.5805, 0.3238, 0.162167}, /* Red */
67 {0.4617, 0.472, 0.64909}, /* Yellow */
68 {0.4178, 0.2625, 0.233662}, /* Magenta */
69 {0.2038, 0.2508, 0.167275}, /* Cyan */
70 {0.3358, 0.337, 0.916877}, /* White */
71 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
72 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
73 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
74 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
75 {0.3346, 0.3349, 0.0308383} /* Black */
76 };
77
78 COLOR mbRGB[24]; /* MacBeth RGB values */
79
80 #define NMBNEU 6 /* Number of MacBeth neutral colors */
81 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
82
83 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
84 1L<<Neutral5|1L<<Neutral35|1L<<Black)
85
86 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
87 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
88 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
89
90 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
91 1L<<BluishGreen|1L<<ModerateRed)
92
93 #define REQFLGS NEUFLGS /* need these colors */
94 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
95
96 #define RG_BORD 0 /* patch border */
97 #define RG_CENT 01 /* central region of patch */
98 #define RG_ORIG 02 /* original color region */
99 #define RG_CORR 04 /* corrected color region */
100
101 #ifndef DISPCOM
102 #define DISPCOM "ximage -op \"%s\""
103 #endif
104
105 int scanning = 1; /* scanned input (or recorded output)? */
106 double irrad = 1.0; /* irradiance multiplication factor */
107 int rawmap = 0; /* put out raw color mapping? */
108
109 int xmax, ymax; /* input image dimensions */
110 int bounds[4][2]; /* image coordinates of chart corners */
111 double imgxfm[3][3]; /* coordinate transformation matrix */
112
113 COLOR inpRGB[24]; /* measured or scanned input colors */
114 long inpflags = 0; /* flags of which colors were input */
115 long gmtflags = 0; /* flags of out-of-gamut colors */
116
117 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
118 COLORMAT solmat; /* color mapping matrix */
119 COLOR colmin, colmax; /* gamut limits */
120
121 WARP3D *wcor = NULL; /* color space warp */
122
123 FILE *debugfp = NULL; /* debug output picture */
124 char *progname;
125
126
127 main(argc, argv)
128 int argc;
129 char **argv;
130 {
131 int i;
132
133 progname = argv[0];
134 for (i = 1; i < argc && argv[i][0] == '-'; i++)
135 switch (argv[i][1]) {
136 case 'd': /* debug output */
137 i++;
138 if (badarg(argc-i, argv+i, "s"))
139 goto userr;
140 if ((debugfp = fopen(argv[i], "w")) == NULL) {
141 perror(argv[i]);
142 exit(1);
143 }
144 SET_FILE_BINARY(debugfp);
145 newheader("RADIANCE", debugfp); /* start */
146 printargs(argc, argv, debugfp); /* header */
147 break;
148 case 'p': /* picture position */
149 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
150 goto userr;
151 bounds[0][0] = atoi(argv[++i]);
152 bounds[0][1] = atoi(argv[++i]);
153 bounds[1][0] = atoi(argv[++i]);
154 bounds[1][1] = atoi(argv[++i]);
155 bounds[2][0] = atoi(argv[++i]);
156 bounds[2][1] = atoi(argv[++i]);
157 bounds[3][0] = atoi(argv[++i]);
158 bounds[3][1] = atoi(argv[++i]);
159 scanning = 2;
160 break;
161 case 'P': /* pick position */
162 scanning = 3;
163 break;
164 case 'i': /* irradiance factor */
165 i++;
166 if (badarg(argc-i, argv+i, "f"))
167 goto userr;
168 irrad = atof(argv[i]);
169 break;
170 case 'm': /* raw map output */
171 rawmap = 1;
172 break;
173 case 'c': /* color input */
174 scanning = 0;
175 break;
176 default:
177 goto userr;
178 }
179 /* open files */
180 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
181 perror(argv[i]);
182 exit(1);
183 }
184 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
185 perror(argv[i+1]);
186 exit(1);
187 }
188 if (scanning) { /* load input picture header */
189 SET_FILE_BINARY(stdin);
190 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
191 fgetresolu(&xmax, &ymax, stdin) < 0) {
192 fprintf(stderr, "%s: bad input picture\n", progname);
193 exit(1);
194 }
195 if (scanning == 3) {
196 if (i >= argc)
197 goto userr;
198 pickchartpos(argv[i]);
199 scanning = 2;
200 }
201 } else { /* else set default xmax and ymax */
202 xmax = 512;
203 ymax = 2*512/3;
204 }
205 if (scanning != 2) { /* use default boundaries */
206 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
207 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
208 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
209 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
210 }
211 init(); /* initialize */
212 if (scanning) /* get picture colors */
213 getpicture();
214 else
215 getcolors();
216 compute(); /* compute color mapping */
217 if (rawmap) { /* print out raw correspondence */
218 register int j;
219
220 printf("# Color correspondence produced by:\n#\t\t");
221 printargs(argc, argv, stdout);
222 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
223 i+1 < argc ? argv[i+1] : "{this_file}");
224 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
225 i+1 < argc ? argv[i+1] : "{this_file}");
226 for (j = 0; j < 24; j++)
227 printf("%f %f %f %f %f %f\n",
228 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
229 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
230 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
231 if (scanning && debugfp != NULL)
232 cwarp(); /* color warp for debugging */
233 } else { /* print color mapping */
234 /* print header */
235 printf("{\n\tColor correction file computed by:\n\t\t");
236 printargs(argc, argv, stdout);
237 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
238 i+1 < argc ? argv[i+1] : "{this_file}");
239 if (!scanning)
240 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
241 i+1 < argc ? argv[i+1] : "{this_file}");
242 printf("}\n");
243 putmapping(); /* put out color mapping */
244 }
245 if (debugfp != NULL) { /* put out debug picture */
246 if (scanning)
247 picdebug();
248 else
249 clrdebug();
250 }
251 exit(0);
252 userr:
253 fprintf(stderr,
254 "Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
255 progname);
256 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
257 progname);
258 exit(1);
259 }
260
261
262 init() /* initialize */
263 {
264 double quad[4][2];
265 register int i;
266 /* make coordinate transformation */
267 quad[0][0] = bounds[0][0];
268 quad[0][1] = bounds[0][1];
269 quad[1][0] = bounds[1][0];
270 quad[1][1] = bounds[1][1];
271 quad[2][0] = bounds[3][0];
272 quad[2][1] = bounds[3][1];
273 quad[3][0] = bounds[2][0];
274 quad[3][1] = bounds[2][1];
275
276 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
277 fprintf(stderr, "%s: bad chart boundaries\n", progname);
278 exit(1);
279 }
280 /* map MacBeth colors to RGB space */
281 for (i = 0; i < 24; i++) {
282 xyY2RGB(mbRGB[i], mbxyY[i]);
283 scalecolor(mbRGB[i], irrad);
284 }
285 }
286
287
288 int
289 chartndx(x, y, np) /* find color number for position */
290 int x, y;
291 int *np;
292 {
293 double ipos[3], cpos[3];
294 int ix, iy;
295 double fx, fy;
296
297 ipos[0] = x;
298 ipos[1] = y;
299 ipos[2] = 1;
300 mx3d_transform(ipos, imgxfm, cpos);
301 cpos[0] /= cpos[2];
302 cpos[1] /= cpos[2];
303 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
304 return(RG_BORD);
305 ix = cpos[0];
306 iy = cpos[1];
307 fx = cpos[0] - ix;
308 fy = cpos[1] - iy;
309 *np = iy*6 + ix;
310 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
311 return(RG_CENT);
312 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
313 return(RG_BORD);
314 if (fx >= 0.5) /* right side is corrected */
315 return(RG_CORR);
316 return(RG_ORIG); /* left side is original */
317 }
318
319
320 getpicture() /* load in picture colors */
321 {
322 COLR *scanln;
323 COLOR pval;
324 int ccount[24];
325 double d;
326 int y, i;
327 register int x;
328
329 scanln = (COLR *)malloc(xmax*sizeof(COLR));
330 if (scanln == NULL) {
331 perror(progname);
332 exit(1);
333 }
334 for (i = 0; i < 24; i++) {
335 setcolor(inpRGB[i], 0., 0., 0.);
336 ccount[i] = 0;
337 }
338 for (y = ymax-1; y >= 0; y--) {
339 if (freadcolrs(scanln, xmax, stdin) < 0) {
340 fprintf(stderr, "%s: error reading input picture\n",
341 progname);
342 exit(1);
343 }
344 for (x = 0; x < xmax; x++)
345 if (chartndx(x, y, &i) == RG_CENT) {
346 colr_color(pval, scanln[x]);
347 addcolor(inpRGB[i], pval);
348 ccount[i]++;
349 }
350 }
351 for (i = 0; i < 24; i++) { /* compute averages */
352 if (ccount[i] == 0)
353 continue;
354 d = 1./ccount[i];
355 scalecolor(inpRGB[i], d);
356 inpflags |= 1L<<i;
357 }
358 free((void *)scanln);
359 }
360
361
362 getcolors() /* get xyY colors from standard input */
363 {
364 int gotwhite = 0;
365 COLOR whiteclr;
366 int n;
367 float xyYin[3];
368
369 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
370 if ((n < 0) | (n > 24) ||
371 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
372 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
373 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
374 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
375 xyYin[0] + xyYin[1] > 1.) {
376 fprintf(stderr, "%s: bad color input data\n",
377 progname);
378 exit(1);
379 }
380 if (n == 0) { /* calibration white */
381 xyY2RGB(whiteclr, xyYin);
382 gotwhite++;
383 } else { /* standard color */
384 n--;
385 xyY2RGB(inpRGB[n], xyYin);
386 inpflags |= 1L<<n;
387 }
388 }
389 /* normalize colors */
390 if (!gotwhite) {
391 if (!(inpflags & 1L<<White)) {
392 fprintf(stderr, "%s: missing input for White\n",
393 progname);
394 exit(1);
395 }
396 setcolor(whiteclr,
397 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
398 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
399 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
400 }
401 for (n = 0; n < 24; n++)
402 if (inpflags & 1L<<n)
403 setcolor(inpRGB[n],
404 colval(inpRGB[n],RED)/colval(whiteclr,RED),
405 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
406 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
407 }
408
409
410 bresp(y, x) /* piecewise linear interpolation of primaries */
411 COLOR y, x;
412 {
413 register int i, n;
414
415 for (i = 0; i < 3; i++) {
416 for (n = 0; n < NMBNEU-2; n++)
417 if (colval(x,i) < colval(bramp[n+1][0],i))
418 break;
419 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
420 colval(bramp[n][1],i) +
421 (colval(x,i) - colval(bramp[n][0],i)) *
422 colval(bramp[n+1][1],i)) /
423 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
424 }
425 }
426
427
428 compute() /* compute color mapping */
429 {
430 COLOR clrin[24], clrout[24];
431 long cflags;
432 COLOR ctmp;
433 register int i, n;
434 /* did we get what we need? */
435 if ((inpflags & REQFLGS) != REQFLGS) {
436 fprintf(stderr, "%s: missing required input colors\n",
437 progname);
438 exit(1);
439 }
440 /* compute piecewise luminance curve */
441 for (i = 0; i < NMBNEU; i++) {
442 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
443 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
444 }
445 /* compute color space gamut */
446 if (scanning) {
447 copycolor(colmin, cblack);
448 copycolor(colmax, cwhite);
449 scalecolor(colmax, irrad);
450 } else
451 for (i = 0; i < 3; i++) {
452 colval(colmin,i) = colval(bramp[0][0],i) -
453 colval(bramp[0][1],i) *
454 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
455 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
456 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
457 (1.-colval(bramp[NMBNEU-2][1],i)) *
458 (colval(bramp[NMBNEU-1][0],i) -
459 colval(bramp[NMBNEU-2][0],i)) /
460 (colval(bramp[NMBNEU-1][1],i) -
461 colval(bramp[NMBNEU-2][1],i));
462 }
463 /* compute color mapping */
464 do {
465 cflags = inpflags & ~gmtflags;
466 n = 0; /* compute transform matrix */
467 for (i = 0; i < 24; i++)
468 if (cflags & 1L<<i) {
469 bresp(clrin[n], inpRGB[i]);
470 copycolor(clrout[n], mbRGB[i]);
471 n++;
472 }
473 compsoln(clrin, clrout, n);
474 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
475 for (i = 0; i < 24; i++)
476 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
477 gmtflags |= 1L<<i;
478 } while (cflags & gmtflags);
479 if (gmtflags & MODFLGS)
480 fprintf(stderr,
481 "%s: warning - some moderate colors are out of gamut\n",
482 progname);
483 }
484
485
486 putmapping() /* put out color mapping */
487 {
488 static char cchar[3] = {'r', 'g', 'b'};
489 register int i, j;
490 /* print brightness mapping */
491 for (j = 0; j < 3; j++) {
492 printf("%cxa(i) : select(i", cchar[j]);
493 for (i = 0; i < NMBNEU; i++)
494 printf(",%g", colval(bramp[i][0],j));
495 printf(");\n");
496 printf("%cya(i) : select(i", cchar[j]);
497 for (i = 0; i < NMBNEU; i++)
498 printf(",%g", colval(bramp[i][1],j));
499 printf(");\n");
500 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
501 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
502 cchar[j], cchar[j]);
503 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
504 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
505 cchar[j], scanning?'n':'o', cchar[j],
506 cchar[j], cchar[j], cchar[j], cchar[j]);
507 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
508 cchar[j], cchar[j], cchar[j],
509 cchar[j], cchar[j]);
510 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
511 cchar[j], cchar[j], cchar[j], cchar[j]);
512 }
513 /* print color mapping */
514 if (scanning) {
515 printf("r = ri(1); g = gi(1); b = bi(1);\n");
516 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
517 solmat[0][0], solmat[0][1], solmat[0][2]);
518 printf("go = %g*rn + %g*gn + %g*bn ;\n",
519 solmat[1][0], solmat[1][1], solmat[1][2]);
520 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
521 solmat[2][0], solmat[2][1], solmat[2][2]);
522 } else {
523 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
524 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
525 solmat[0][0], solmat[0][1], solmat[0][2]);
526 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
527 solmat[1][0], solmat[1][1], solmat[1][2]);
528 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
529 solmat[2][0], solmat[2][1], solmat[2][2]);
530 }
531 }
532
533
534 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
535 COLOR cin[], cout[];
536 int n;
537 {
538 extern double mx3d_adjoint(), fabs();
539 double mat[3][3], invmat[3][3];
540 double det;
541 double colv[3], rowv[3];
542 register int i, j, k;
543
544 if (n < 3) {
545 fprintf(stderr, "%s: too few colors to match!\n", progname);
546 exit(1);
547 }
548 if (n == 3)
549 for (i = 0; i < 3; i++)
550 for (j = 0; j < 3; j++)
551 mat[i][j] = colval(cin[j],i);
552 else { /* compute A^t A */
553 for (i = 0; i < 3; i++)
554 for (j = i; j < 3; j++) {
555 mat[i][j] = 0.;
556 for (k = 0; k < n; k++)
557 mat[i][j] += colval(cin[k],i) *
558 colval(cin[k],j);
559 }
560 for (i = 1; i < 3; i++) /* using symmetry */
561 for (j = 0; j < i; j++)
562 mat[i][j] = mat[j][i];
563 }
564 det = mx3d_adjoint(mat, invmat);
565 if (fabs(det) < 1e-4) {
566 fprintf(stderr, "%s: cannot compute color mapping\n",
567 progname);
568 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
569 solmat[0][1] = solmat[0][2] = solmat[1][0] =
570 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
571 return;
572 }
573 for (i = 0; i < 3; i++)
574 for (j = 0; j < 3; j++)
575 invmat[i][j] /= det;
576 for (i = 0; i < 3; i++) {
577 if (n == 3)
578 for (j = 0; j < 3; j++)
579 colv[j] = colval(cout[j],i);
580 else
581 for (j = 0; j < 3; j++) {
582 colv[j] = 0.;
583 for (k = 0; k < n; k++)
584 colv[j] += colval(cout[k],i) *
585 colval(cin[k],j);
586 }
587 mx3d_transform(colv, invmat, rowv);
588 for (j = 0; j < 3; j++)
589 solmat[i][j] = rowv[j];
590 }
591 }
592
593
594 cwarp() /* compute color warp map */
595 {
596 register int i;
597
598 if ((wcor = new3dw(W3EXACT)) == NULL)
599 goto memerr;
600 for (i = 0; i < 24; i++)
601 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
602 goto memerr;
603 return;
604 memerr:
605 perror(progname);
606 exit(1);
607 }
608
609
610 int
611 cvtcolor(cout, cin) /* convert color according to our mapping */
612 COLOR cout, cin;
613 {
614 COLOR ctmp;
615 int clipped;
616
617 if (wcor != NULL) {
618 clipped = warp3d(cout, cin, wcor);
619 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
620 } else if (scanning) {
621 bresp(ctmp, cin);
622 clipped = cresp(cout, ctmp);
623 } else {
624 clipped = cresp(ctmp, cin);
625 bresp(cout, ctmp);
626 }
627 return(clipped);
628 }
629
630
631 int
632 cresp(cout, cin) /* transform color according to matrix */
633 COLOR cout, cin;
634 {
635 colortrans(cout, solmat, cin);
636 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
637 }
638
639
640 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
641 COLOR rgbout;
642 register float xyYin[3];
643 {
644 COLOR ctmp;
645 double d;
646
647 d = xyYin[2] / xyYin[1];
648 ctmp[0] = xyYin[0] * d;
649 ctmp[1] = xyYin[2];
650 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
651 /* allow negative values */
652 colortrans(rgbout, xyz2rgbmat, ctmp);
653 }
654
655
656 picdebug() /* put out debugging picture */
657 {
658 static COLOR blkcol = BLKCOLOR;
659 COLOR *scan;
660 int y, i;
661 register int x, rg;
662
663 if (fseek(stdin, 0L, 0) == EOF) {
664 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
665 exit(1);
666 }
667 getheader(stdin, NULL, NULL); /* skip input header */
668 fgetresolu(&xmax, &ymax, stdin);
669 /* allocate scanline */
670 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
671 if (scan == NULL) {
672 perror(progname);
673 exit(1);
674 }
675 /* finish debug header */
676 fputformat(COLRFMT, debugfp);
677 putc('\n', debugfp);
678 fprtresolu(xmax, ymax, debugfp);
679 /* write debug picture */
680 for (y = ymax-1; y >= 0; y--) {
681 if (freadscan(scan, xmax, stdin) < 0) {
682 fprintf(stderr, "%s: error rereading input picture\n",
683 progname);
684 exit(1);
685 }
686 for (x = 0; x < xmax; x++) {
687 rg = chartndx(x, y, &i);
688 if (rg == RG_CENT) {
689 if (!(1L<<i & gmtflags) || (x+y)&07) {
690 copycolor(scan[x], mbRGB[i]);
691 clipgamut(scan[x], bright(scan[x]),
692 CGAMUT, colmin, colmax);
693 } else
694 copycolor(scan[x], blkcol);
695 } else if (rg == RG_CORR)
696 cvtcolor(scan[x], scan[x]);
697 else if (rg != RG_ORIG)
698 copycolor(scan[x], blkcol);
699 }
700 if (fwritescan(scan, xmax, debugfp) < 0) {
701 fprintf(stderr, "%s: error writing debugging picture\n",
702 progname);
703 exit(1);
704 }
705 }
706 /* clean up */
707 fclose(debugfp);
708 free((void *)scan);
709 }
710
711
712 clrdebug() /* put out debug picture from color input */
713 {
714 static COLR blkclr = BLKCOLR;
715 COLR mbclr[24], cvclr[24], orclr[24];
716 COLR *scan;
717 COLOR ctmp, ct2;
718 int y, i;
719 register int x, rg;
720 /* convert colors */
721 for (i = 0; i < 24; i++) {
722 copycolor(ctmp, mbRGB[i]);
723 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
724 setcolr(mbclr[i], colval(ctmp,RED),
725 colval(ctmp,GRN), colval(ctmp,BLU));
726 if (inpflags & 1L<<i) {
727 copycolor(ctmp, inpRGB[i]);
728 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
729 setcolr(orclr[i], colval(ctmp,RED),
730 colval(ctmp,GRN), colval(ctmp,BLU));
731 if (rawmap)
732 copycolr(cvclr[i], mbclr[i]);
733 else {
734 bresp(ctmp, inpRGB[i]);
735 colortrans(ct2, solmat, ctmp);
736 clipgamut(ct2, bright(ct2), CGAMUT,
737 cblack, cwhite);
738 setcolr(cvclr[i], colval(ct2,RED),
739 colval(ct2,GRN),
740 colval(ct2,BLU));
741 }
742 }
743 }
744 /* allocate scanline */
745 scan = (COLR *)malloc(xmax*sizeof(COLR));
746 if (scan == NULL) {
747 perror(progname);
748 exit(1);
749 }
750 /* finish debug header */
751 fputformat(COLRFMT, debugfp);
752 putc('\n', debugfp);
753 fprtresolu(xmax, ymax, debugfp);
754 /* write debug picture */
755 for (y = ymax-1; y >= 0; y--) {
756 for (x = 0; x < xmax; x++) {
757 rg = chartndx(x, y, &i);
758 if (rg == RG_CENT) {
759 if (!(1L<<i & gmtflags) || (x+y)&07)
760 copycolr(scan[x], mbclr[i]);
761 else
762 copycolr(scan[x], blkclr);
763 } else if (rg == RG_BORD || !(1L<<i & inpflags))
764 copycolr(scan[x], blkclr);
765 else if (rg == RG_ORIG)
766 copycolr(scan[x], orclr[i]);
767 else /* rg == RG_CORR */
768 copycolr(scan[x], cvclr[i]);
769 }
770 if (fwritecolrs(scan, xmax, debugfp) < 0) {
771 fprintf(stderr, "%s: error writing debugging picture\n",
772 progname);
773 exit(1);
774 }
775 }
776 /* clean up */
777 fclose(debugfp);
778 free((void *)scan);
779 }
780
781
782 getpos(name, bnds, fp) /* get boundary position */
783 char *name;
784 int bnds[2];
785 FILE *fp;
786 {
787 char buf[64];
788
789 fprintf(stderr, "\tSelect corner: %s\n", name);
790 if (fgets(buf, sizeof(buf), fp) == NULL ||
791 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
792 fprintf(stderr, "%s: read error from display process\n",
793 progname);
794 exit(1);
795 }
796 }
797
798
799 pickchartpos(pfn) /* display picture and pick chart location */
800 char *pfn;
801 {
802 char combuf[PATH_MAX];
803 FILE *pfp;
804
805 sprintf(combuf, DISPCOM, pfn);
806 if ((pfp = popen(combuf, "r")) == NULL) {
807 perror(combuf);
808 exit(1);
809 }
810 fputs("Use middle mouse button to select chart corners:\n", stderr);
811 getpos("upper left (dark skin)", bounds[0], pfp);
812 getpos("upper right (bluish green)", bounds[1], pfp);
813 getpos("lower left (white)", bounds[2], pfp);
814 getpos("lower right (black)", bounds[3], pfp);
815 fputs("Got it -- quit display program.\n", stderr);
816 pclose(pfp);
817 }
