root/radiance/ray/src/px/macbethcal.c
Revision: 2.18
Committed: Thu Jun 5 19:29:34 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.17: +6 -11 lines
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.17 2003/02/22 02:07:27 greg Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <stdio.h>
14 #include <math.h>
15 #include <time.h>
16
17 #include "platform.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "pmap.h"
21 #include "warp3d.h"
22
23 /* MacBeth colors */
24 #define DarkSkin 0
25 #define LightSkin 1
26 #define BlueSky 2
27 #define Foliage 3
28 #define BlueFlower 4
29 #define BluishGreen 5
30 #define Orange 6
31 #define PurplishBlue 7
32 #define ModerateRed 8
33 #define Purple 9
34 #define YellowGreen 10
35 #define OrangeYellow 11
36 #define Blue 12
37 #define Green 13
38 #define Red 14
39 #define Yellow 15
40 #define Magenta 16
41 #define Cyan 17
42 #define White 18
43 #define Neutral8 19
44 #define Neutral65 20
45 #define Neutral5 21
46 #define Neutral35 22
47 #define Black 23
48 /* computed from 5nm spectral measurements */
49 /* CIE 1931 2 degree obs, equal-energy white */
50 float mbxyY[24][3] = {
51 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
52 {0.4108, 0.3542, 0.410348}, /* LightSkin */
53 {0.2626, 0.267, 0.181554}, /* BlueSky */
54 {0.36, 0.4689, 0.108447}, /* Foliage */
55 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
56 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
57 {0.52, 0.4197, 0.357899}, /* Orange */
58 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
59 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
60 {0.3361, 0.2249, 0.0600102}, /* Purple */
61 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
62 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
63 {0.2026, 0.1369, 0.0529249}, /* Blue */
64 {0.3007, 0.4822, 0.221226}, /* Green */
65 {0.5805, 0.3238, 0.162167}, /* Red */
66 {0.4617, 0.472, 0.64909}, /* Yellow */
67 {0.4178, 0.2625, 0.233662}, /* Magenta */
68 {0.2038, 0.2508, 0.167275}, /* Cyan */
69 {0.3358, 0.337, 0.916877}, /* White */
70 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
71 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
72 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
73 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
74 {0.3346, 0.3349, 0.0308383} /* Black */
75 };
76
77 COLOR mbRGB[24]; /* MacBeth RGB values */
78
79 #define NMBNEU 6 /* Number of MacBeth neutral colors */
80 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
81
82 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
83 1L<<Neutral5|1L<<Neutral35|1L<<Black)
84
85 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
86 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
87 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
88
89 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
90 1L<<BluishGreen|1L<<ModerateRed)
91
92 #define REQFLGS NEUFLGS /* need these colors */
93 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
94
95 #define RG_BORD 0 /* patch border */
96 #define RG_CENT 01 /* central region of patch */
97 #define RG_ORIG 02 /* original color region */
98 #define RG_CORR 04 /* corrected color region */
99
100 #ifndef DISPCOM
101 #define DISPCOM "ximage -op %s"
102 #endif
103
104 int scanning = 1; /* scanned input (or recorded output)? */
105 double irrad = 1.0; /* irradiance multiplication factor */
106 int rawmap = 0; /* put out raw color mapping? */
107
108 int xmax, ymax; /* input image dimensions */
109 int bounds[4][2]; /* image coordinates of chart corners */
110 double imgxfm[3][3]; /* coordinate transformation matrix */
111
112 COLOR inpRGB[24]; /* measured or scanned input colors */
113 long inpflags = 0; /* flags of which colors were input */
114 long gmtflags = 0; /* flags of out-of-gamut colors */
115
116 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
117 COLORMAT solmat; /* color mapping matrix */
118 COLOR colmin, colmax; /* gamut limits */
119
120 WARP3D *wcor = NULL; /* color space warp */
121
122 FILE *debugfp = NULL; /* debug output picture */
123 char *progname;
124
125
126 main(argc, argv)
127 int argc;
128 char **argv;
129 {
130 int i;
131
132 progname = argv[0];
133 for (i = 1; i < argc && argv[i][0] == '-'; i++)
134 switch (argv[i][1]) {
135 case 'd': /* debug output */
136 i++;
137 if (badarg(argc-i, argv+i, "s"))
138 goto userr;
139 if ((debugfp = fopen(argv[i], "w")) == NULL) {
140 perror(argv[i]);
141 exit(1);
142 }
143 SET_FILE_BINARY(debugfp);
144 newheader("RADIANCE", debugfp); /* start */
145 printargs(argc, argv, debugfp); /* header */
146 break;
147 case 'p': /* picture position */
148 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
149 goto userr;
150 bounds[0][0] = atoi(argv[++i]);
151 bounds[0][1] = atoi(argv[++i]);
152 bounds[1][0] = atoi(argv[++i]);
153 bounds[1][1] = atoi(argv[++i]);
154 bounds[2][0] = atoi(argv[++i]);
155 bounds[2][1] = atoi(argv[++i]);
156 bounds[3][0] = atoi(argv[++i]);
157 bounds[3][1] = atoi(argv[++i]);
158 scanning = 2;
159 break;
160 case 'P': /* pick position */
161 scanning = 3;
162 break;
163 case 'i': /* irradiance factor */
164 i++;
165 if (badarg(argc-i, argv+i, "f"))
166 goto userr;
167 irrad = atof(argv[i]);
168 break;
169 case 'm': /* raw map output */
170 rawmap = 1;
171 break;
172 case 'c': /* color input */
173 scanning = 0;
174 break;
175 default:
176 goto userr;
177 }
178 /* open files */
179 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
180 perror(argv[i]);
181 exit(1);
182 }
183 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
184 perror(argv[i+1]);
185 exit(1);
186 }
187 if (scanning) { /* load input picture header */
188 SET_FILE_BINARY(stdin);
189 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
190 fgetresolu(&xmax, &ymax, stdin) < 0) {
191 fprintf(stderr, "%s: bad input picture\n", progname);
192 exit(1);
193 }
194 if (scanning == 3) {
195 if (i >= argc)
196 goto userr;
197 pickchartpos(argv[i]);
198 scanning = 2;
199 }
200 } else { /* else set default xmax and ymax */
201 xmax = 512;
202 ymax = 2*512/3;
203 }
204 if (scanning != 2) { /* use default boundaries */
205 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
206 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
207 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
208 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
209 }
210 init(); /* initialize */
211 if (scanning) /* get picture colors */
212 getpicture();
213 else
214 getcolors();
215 compute(); /* compute color mapping */
216 if (rawmap) { /* print out raw correspondence */
217 register int j;
218
219 printf("# Color correspondence produced by:\n#\t\t");
220 printargs(argc, argv, stdout);
221 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
222 i+1 < argc ? argv[i+1] : "{this_file}");
223 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
224 i+1 < argc ? argv[i+1] : "{this_file}");
225 for (j = 0; j < 24; j++)
226 printf("%f %f %f %f %f %f\n",
227 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
228 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
229 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
230 if (scanning && debugfp != NULL)
231 cwarp(); /* color warp for debugging */
232 } else { /* print color mapping */
233 /* print header */
234 printf("{\n\tColor correction file computed by:\n\t\t");
235 printargs(argc, argv, stdout);
236 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
237 i+1 < argc ? argv[i+1] : "{this_file}");
238 if (!scanning)
239 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
240 i+1 < argc ? argv[i+1] : "{this_file}");
241 printf("}\n");
242 putmapping(); /* put out color mapping */
243 }
244 if (debugfp != NULL) /* put out debug picture */
245 if (scanning)
246 picdebug();
247 else
248 clrdebug();
249 exit(0);
250 userr:
251 fprintf(stderr,
252 "Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
253 progname);
254 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
255 progname);
256 exit(1);
257 }
258
259
260 init() /* initialize */
261 {
262 double quad[4][2];
263 register int i;
264 /* make coordinate transformation */
265 quad[0][0] = bounds[0][0];
266 quad[0][1] = bounds[0][1];
267 quad[1][0] = bounds[1][0];
268 quad[1][1] = bounds[1][1];
269 quad[2][0] = bounds[3][0];
270 quad[2][1] = bounds[3][1];
271 quad[3][0] = bounds[2][0];
272 quad[3][1] = bounds[2][1];
273
274 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
275 fprintf(stderr, "%s: bad chart boundaries\n", progname);
276 exit(1);
277 }
278 /* map MacBeth colors to RGB space */
279 for (i = 0; i < 24; i++) {
280 xyY2RGB(mbRGB[i], mbxyY[i]);
281 scalecolor(mbRGB[i], irrad);
282 }
283 }
284
285
286 int
287 chartndx(x, y, np) /* find color number for position */
288 int x, y;
289 int *np;
290 {
291 double ipos[3], cpos[3];
292 int ix, iy;
293 double fx, fy;
294
295 ipos[0] = x;
296 ipos[1] = y;
297 ipos[2] = 1;
298 mx3d_transform(ipos, imgxfm, cpos);
299 cpos[0] /= cpos[2];
300 cpos[1] /= cpos[2];
301 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
302 return(RG_BORD);
303 ix = cpos[0];
304 iy = cpos[1];
305 fx = cpos[0] - ix;
306 fy = cpos[1] - iy;
307 *np = iy*6 + ix;
308 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
309 return(RG_CENT);
310 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
311 return(RG_BORD);
312 if (fx >= 0.5) /* right side is corrected */
313 return(RG_CORR);
314 return(RG_ORIG); /* left side is original */
315 }
316
317
318 getpicture() /* load in picture colors */
319 {
320 COLR *scanln;
321 COLOR pval;
322 int ccount[24];
323 double d;
324 int y, i;
325 register int x;
326
327 scanln = (COLR *)malloc(xmax*sizeof(COLR));
328 if (scanln == NULL) {
329 perror(progname);
330 exit(1);
331 }
332 for (i = 0; i < 24; i++) {
333 setcolor(inpRGB[i], 0., 0., 0.);
334 ccount[i] = 0;
335 }
336 for (y = ymax-1; y >= 0; y--) {
337 if (freadcolrs(scanln, xmax, stdin) < 0) {
338 fprintf(stderr, "%s: error reading input picture\n",
339 progname);
340 exit(1);
341 }
342 for (x = 0; x < xmax; x++)
343 if (chartndx(x, y, &i) == RG_CENT) {
344 colr_color(pval, scanln[x]);
345 addcolor(inpRGB[i], pval);
346 ccount[i]++;
347 }
348 }
349 for (i = 0; i < 24; i++) { /* compute averages */
350 if (ccount[i] == 0)
351 continue;
352 d = 1./ccount[i];
353 scalecolor(inpRGB[i], d);
354 inpflags |= 1L<<i;
355 }
356 free((void *)scanln);
357 }
358
359
360 getcolors() /* get xyY colors from standard input */
361 {
362 int gotwhite = 0;
363 COLOR whiteclr;
364 int n;
365 float xyYin[3];
366
367 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
368 if (n < 0 | n > 24 ||
369 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
370 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
371 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
372 xyYin[0] < 0. | xyYin[1] < 0. ||
373 xyYin[0] + xyYin[1] > 1.) {
374 fprintf(stderr, "%s: bad color input data\n",
375 progname);
376 exit(1);
377 }
378 if (n == 0) { /* calibration white */
379 xyY2RGB(whiteclr, xyYin);
380 gotwhite++;
381 } else { /* standard color */
382 n--;
383 xyY2RGB(inpRGB[n], xyYin);
384 inpflags |= 1L<<n;
385 }
386 }
387 /* normalize colors */
388 if (!gotwhite) {
389 if (!(inpflags & 1L<<White)) {
390 fprintf(stderr, "%s: missing input for White\n",
391 progname);
392 exit(1);
393 }
394 setcolor(whiteclr,
395 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
396 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
397 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
398 }
399 for (n = 0; n < 24; n++)
400 if (inpflags & 1L<<n)
401 setcolor(inpRGB[n],
402 colval(inpRGB[n],RED)/colval(whiteclr,RED),
403 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
404 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
405 }
406
407
408 bresp(y, x) /* piecewise linear interpolation of primaries */
409 COLOR y, x;
410 {
411 register int i, n;
412
413 for (i = 0; i < 3; i++) {
414 for (n = 0; n < NMBNEU-2; n++)
415 if (colval(x,i) < colval(bramp[n+1][0],i))
416 break;
417 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
418 colval(bramp[n][1],i) +
419 (colval(x,i) - colval(bramp[n][0],i)) *
420 colval(bramp[n+1][1],i)) /
421 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
422 }
423 }
424
425
426 compute() /* compute color mapping */
427 {
428 COLOR clrin[24], clrout[24];
429 long cflags;
430 COLOR ctmp;
431 register int i, n;
432 /* did we get what we need? */
433 if ((inpflags & REQFLGS) != REQFLGS) {
434 fprintf(stderr, "%s: missing required input colors\n",
435 progname);
436 exit(1);
437 }
438 /* compute piecewise luminance curve */
439 for (i = 0; i < NMBNEU; i++) {
440 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
441 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
442 }
443 /* compute color space gamut */
444 if (scanning) {
445 copycolor(colmin, cblack);
446 copycolor(colmax, cwhite);
447 scalecolor(colmax, irrad);
448 } else
449 for (i = 0; i < 3; i++) {
450 colval(colmin,i) = colval(bramp[0][0],i) -
451 colval(bramp[0][1],i) *
452 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
453 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
454 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
455 (1.-colval(bramp[NMBNEU-2][1],i)) *
456 (colval(bramp[NMBNEU-1][0],i) -
457 colval(bramp[NMBNEU-2][0],i)) /
458 (colval(bramp[NMBNEU-1][1],i) -
459 colval(bramp[NMBNEU-2][1],i));
460 }
461 /* compute color mapping */
462 do {
463 cflags = inpflags & ~gmtflags;
464 n = 0; /* compute transform matrix */
465 for (i = 0; i < 24; i++)
466 if (cflags & 1L<<i) {
467 bresp(clrin[n], inpRGB[i]);
468 copycolor(clrout[n], mbRGB[i]);
469 n++;
470 }
471 compsoln(clrin, clrout, n);
472 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
473 for (i = 0; i < 24; i++)
474 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
475 gmtflags |= 1L<<i;
476 } while (cflags & gmtflags);
477 if (gmtflags & MODFLGS)
478 fprintf(stderr,
479 "%s: warning - some moderate colors are out of gamut\n",
480 progname);
481 }
482
483
484 putmapping() /* put out color mapping */
485 {
486 static char cchar[3] = {'r', 'g', 'b'};
487 register int i, j;
488 /* print brightness mapping */
489 for (j = 0; j < 3; j++) {
490 printf("%cxa(i) : select(i", cchar[j]);
491 for (i = 0; i < NMBNEU; i++)
492 printf(",%g", colval(bramp[i][0],j));
493 printf(");\n");
494 printf("%cya(i) : select(i", cchar[j]);
495 for (i = 0; i < NMBNEU; i++)
496 printf(",%g", colval(bramp[i][1],j));
497 printf(");\n");
498 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
499 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
500 cchar[j], cchar[j]);
501 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
502 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
503 cchar[j], scanning?'n':'o', cchar[j],
504 cchar[j], cchar[j], cchar[j], cchar[j]);
505 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
506 cchar[j], cchar[j], cchar[j],
507 cchar[j], cchar[j]);
508 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
509 cchar[j], cchar[j], cchar[j], cchar[j]);
510 }
511 /* print color mapping */
512 if (scanning) {
513 printf("r = ri(1); g = gi(1); b = bi(1);\n");
514 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
515 solmat[0][0], solmat[0][1], solmat[0][2]);
516 printf("go = %g*rn + %g*gn + %g*bn ;\n",
517 solmat[1][0], solmat[1][1], solmat[1][2]);
518 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
519 solmat[2][0], solmat[2][1], solmat[2][2]);
520 } else {
521 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
522 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
523 solmat[0][0], solmat[0][1], solmat[0][2]);
524 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
525 solmat[1][0], solmat[1][1], solmat[1][2]);
526 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
527 solmat[2][0], solmat[2][1], solmat[2][2]);
528 }
529 }
530
531
532 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
533 COLOR cin[], cout[];
534 int n;
535 {
536 extern double mx3d_adjoint(), fabs();
537 double mat[3][3], invmat[3][3];
538 double det;
539 double colv[3], rowv[3];
540 register int i, j, k;
541
542 if (n < 3) {
543 fprintf(stderr, "%s: too few colors to match!\n", progname);
544 exit(1);
545 }
546 if (n == 3)
547 for (i = 0; i < 3; i++)
548 for (j = 0; j < 3; j++)
549 mat[i][j] = colval(cin[j],i);
550 else { /* compute A^t A */
551 for (i = 0; i < 3; i++)
552 for (j = i; j < 3; j++) {
553 mat[i][j] = 0.;
554 for (k = 0; k < n; k++)
555 mat[i][j] += colval(cin[k],i) *
556 colval(cin[k],j);
557 }
558 for (i = 1; i < 3; i++) /* using symmetry */
559 for (j = 0; j < i; j++)
560 mat[i][j] = mat[j][i];
561 }
562 det = mx3d_adjoint(mat, invmat);
563 if (fabs(det) < 1e-4) {
564 fprintf(stderr, "%s: cannot compute color mapping\n",
565 progname);
566 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
567 solmat[0][1] = solmat[0][2] = solmat[1][0] =
568 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
569 return;
570 }
571 for (i = 0; i < 3; i++)
572 for (j = 0; j < 3; j++)
573 invmat[i][j] /= det;
574 for (i = 0; i < 3; i++) {
575 if (n == 3)
576 for (j = 0; j < 3; j++)
577 colv[j] = colval(cout[j],i);
578 else
579 for (j = 0; j < 3; j++) {
580 colv[j] = 0.;
581 for (k = 0; k < n; k++)
582 colv[j] += colval(cout[k],i) *
583 colval(cin[k],j);
584 }
585 mx3d_transform(colv, invmat, rowv);
586 for (j = 0; j < 3; j++)
587 solmat[i][j] = rowv[j];
588 }
589 }
590
591
592 cwarp() /* compute color warp map */
593 {
594 register int i;
595
596 if ((wcor = new3dw(W3EXACT)) == NULL)
597 goto memerr;
598 for (i = 0; i < 24; i++)
599 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
600 goto memerr;
601 return;
602 memerr:
603 perror(progname);
604 exit(1);
605 }
606
607
608 int
609 cvtcolor(cout, cin) /* convert color according to our mapping */
610 COLOR cout, cin;
611 {
612 COLOR ctmp;
613 int clipped;
614
615 if (wcor != NULL) {
616 clipped = warp3d(cout, cin, wcor);
617 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
618 } else if (scanning) {
619 bresp(ctmp, cin);
620 clipped = cresp(cout, ctmp);
621 } else {
622 clipped = cresp(ctmp, cin);
623 bresp(cout, ctmp);
624 }
625 return(clipped);
626 }
627
628
629 int
630 cresp(cout, cin) /* transform color according to matrix */
631 COLOR cout, cin;
632 {
633 colortrans(cout, solmat, cin);
634 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
635 }
636
637
638 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
639 COLOR rgbout;
640 register float xyYin[3];
641 {
642 COLOR ctmp;
643 double d;
644
645 d = xyYin[2] / xyYin[1];
646 ctmp[0] = xyYin[0] * d;
647 ctmp[1] = xyYin[2];
648 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
649 /* allow negative values */
650 colortrans(rgbout, xyz2rgbmat, ctmp);
651 }
652
653
654 picdebug() /* put out debugging picture */
655 {
656 static COLOR blkcol = BLKCOLOR;
657 COLOR *scan;
658 int y, i;
659 register int x, rg;
660
661 if (fseek(stdin, 0L, 0) == EOF) {
662 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
663 exit(1);
664 }
665 getheader(stdin, NULL, NULL); /* skip input header */
666 fgetresolu(&xmax, &ymax, stdin);
667 /* allocate scanline */
668 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
669 if (scan == NULL) {
670 perror(progname);
671 exit(1);
672 }
673 /* finish debug header */
674 fputformat(COLRFMT, debugfp);
675 putc('\n', debugfp);
676 fprtresolu(xmax, ymax, debugfp);
677 /* write debug picture */
678 for (y = ymax-1; y >= 0; y--) {
679 if (freadscan(scan, xmax, stdin) < 0) {
680 fprintf(stderr, "%s: error rereading input picture\n",
681 progname);
682 exit(1);
683 }
684 for (x = 0; x < xmax; x++) {
685 rg = chartndx(x, y, &i);
686 if (rg == RG_CENT) {
687 if (!(1L<<i & gmtflags) || (x+y)&07) {
688 copycolor(scan[x], mbRGB[i]);
689 clipgamut(scan[x], bright(scan[x]),
690 CGAMUT, colmin, colmax);
691 } else
692 copycolor(scan[x], blkcol);
693 } else if (rg == RG_CORR)
694 cvtcolor(scan[x], scan[x]);
695 else if (rg != RG_ORIG)
696 copycolor(scan[x], blkcol);
697 }
698 if (fwritescan(scan, xmax, debugfp) < 0) {
699 fprintf(stderr, "%s: error writing debugging picture\n",
700 progname);
701 exit(1);
702 }
703 }
704 /* clean up */
705 fclose(debugfp);
706 free((void *)scan);
707 }
708
709
710 clrdebug() /* put out debug picture from color input */
711 {
712 static COLR blkclr = BLKCOLR;
713 COLR mbclr[24], cvclr[24], orclr[24];
714 COLR *scan;
715 COLOR ctmp, ct2;
716 int y, i;
717 register int x, rg;
718 /* convert colors */
719 for (i = 0; i < 24; i++) {
720 copycolor(ctmp, mbRGB[i]);
721 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
722 setcolr(mbclr[i], colval(ctmp,RED),
723 colval(ctmp,GRN), colval(ctmp,BLU));
724 if (inpflags & 1L<<i) {
725 copycolor(ctmp, inpRGB[i]);
726 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
727 setcolr(orclr[i], colval(ctmp,RED),
728 colval(ctmp,GRN), colval(ctmp,BLU));
729 if (rawmap)
730 copycolr(cvclr[i], mbclr[i]);
731 else {
732 bresp(ctmp, inpRGB[i]);
733 colortrans(ct2, solmat, ctmp);
734 clipgamut(ct2, bright(ct2), CGAMUT,
735 cblack, cwhite);
736 setcolr(cvclr[i], colval(ct2,RED),
737 colval(ct2,GRN),
738 colval(ct2,BLU));
739 }
740 }
741 }
742 /* allocate scanline */
743 scan = (COLR *)malloc(xmax*sizeof(COLR));
744 if (scan == NULL) {
745 perror(progname);
746 exit(1);
747 }
748 /* finish debug header */
749 fputformat(COLRFMT, debugfp);
750 putc('\n', debugfp);
751 fprtresolu(xmax, ymax, debugfp);
752 /* write debug picture */
753 for (y = ymax-1; y >= 0; y--) {
754 for (x = 0; x < xmax; x++) {
755 rg = chartndx(x, y, &i);
756 if (rg == RG_CENT) {
757 if (!(1L<<i & gmtflags) || (x+y)&07)
758 copycolr(scan[x], mbclr[i]);
759 else
760 copycolr(scan[x], blkclr);
761 } else if (rg == RG_BORD || !(1L<<i & inpflags))
762 copycolr(scan[x], blkclr);
763 else if (rg == RG_ORIG)
764 copycolr(scan[x], orclr[i]);
765 else /* rg == RG_CORR */
766 copycolr(scan[x], cvclr[i]);
767 }
768 if (fwritecolrs(scan, xmax, debugfp) < 0) {
769 fprintf(stderr, "%s: error writing debugging picture\n",
770 progname);
771 exit(1);
772 }
773 }
774 /* clean up */
775 fclose(debugfp);
776 free((void *)scan);
777 }
778
779
780 getpos(name, bnds, fp) /* get boundary position */
781 char *name;
782 int bnds[2];
783 FILE *fp;
784 {
785 char buf[64];
786
787 fprintf(stderr, "\tSelect corner: %s\n", name);
788 if (fgets(buf, sizeof(buf), fp) == NULL ||
789 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
790 fprintf(stderr, "%s: read error from display process\n",
791 progname);
792 exit(1);
793 }
794 }
795
796
797 pickchartpos(pfn) /* display picture and pick chart location */
798 char *pfn;
799 {
800 char combuf[512];
801 FILE *pfp;
802
803 sprintf(combuf, DISPCOM, pfn);
804 if ((pfp = popen(combuf, "r")) == NULL) {
805 perror(combuf);
806 exit(1);
807 }
808 fputs("Use middle mouse button to select chart corners:\n", stderr);
809 getpos("upper left (dark skin)", bounds[0], pfp);
810 getpos("upper right (bluish green)", bounds[1], pfp);
811 getpos("lower left (white)", bounds[2], pfp);
812 getpos("lower right (black)", bounds[3], pfp);
813 fputs("Got it -- quit display program.\n", stderr);
814 pclose(pfp);
815 }
