--- ray/src/px/macbethcal.c 1995/10/11 18:52:00 2.3 +++ ray/src/px/macbethcal.c 2003/07/27 22:12:03 2.20 @@ -1,25 +1,52 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: macbethcal.c,v 2.20 2003/07/27 22:12:03 schorsch Exp $"; #endif - /* * Calibrate a scanned MacBeth Color Checker Chart * - * Produce a .cal file suitable for use with pcomb. + * Produce a .cal file suitable for use with pcomb, + * or .cwp file suitable for use with pcwarp. + * + * Warping code depends on conformance of COLOR and W3VEC types. */ #include -#ifdef MSDOS -#include -#endif +#include +#include + +#include "platform.h" #include "color.h" #include "resolu.h" #include "pmap.h" +#include "warp3d.h" - /* MacBeth colors (CIE 1931, absolute white) */ - /* computed from spectral measurements */ + /* MacBeth colors */ +#define DarkSkin 0 +#define LightSkin 1 +#define BlueSky 2 +#define Foliage 3 +#define BlueFlower 4 +#define BluishGreen 5 +#define Orange 6 +#define PurplishBlue 7 +#define ModerateRed 8 +#define Purple 9 +#define YellowGreen 10 +#define OrangeYellow 11 +#define Blue 12 +#define Green 13 +#define Red 14 +#define Yellow 15 +#define Magenta 16 +#define Cyan 17 +#define White 18 +#define Neutral8 19 +#define Neutral65 20 +#define Neutral5 21 +#define Neutral35 22 +#define Black 23 + /* computed from 5nm spectral measurements */ + /* CIE 1931 2 degree obs, equal-energy white */ float mbxyY[24][3] = { {0.462, 0.3769, 0.0932961}, /* DarkSkin */ {0.4108, 0.3542, 0.410348}, /* LightSkin */ @@ -50,27 +77,52 @@ float mbxyY[24][3] = { COLOR mbRGB[24]; /* MacBeth RGB values */ #define NMBNEU 6 /* Number of MacBeth neutral colors */ -short mbneu[NMBNEU] = {23,22,21,20,19,18}; -#define NMBMOD 16 /* Number of MacBeth unsaturated colors */ -short mbmod[NMBMOD] = {0,1,2,3,4,5,6,7,8,9,10,11,19,20,21,22}; -#define NMBSAT 6 /* Number of MacBeth saturated colors */ -short mbsat[NMBSAT] = {14,12,13,15,16,17}; +short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White}; +#define NEUFLGS (1L< 2 && !strcmp(argv[1], "-d")) { /* debug output */ - if ((debugfp = fopen(argv[2], "w")) == NULL) { - perror(argv[2]); - exit(1); + for (i = 1; i < argc && argv[i][0] == '-'; i++) + switch (argv[i][1]) { + case 'd': /* debug output */ + i++; + if (badarg(argc-i, argv+i, "s")) + goto userr; + if ((debugfp = fopen(argv[i], "w")) == NULL) { + perror(argv[i]); + exit(1); + } + SET_FILE_BINARY(debugfp); + newheader("RADIANCE", debugfp); /* start */ + printargs(argc, argv, debugfp); /* header */ + break; + case 'p': /* picture position */ + if (badarg(argc-i-1, argv+i+1, "iiiiiiii")) + goto userr; + bounds[0][0] = atoi(argv[++i]); + bounds[0][1] = atoi(argv[++i]); + bounds[1][0] = atoi(argv[++i]); + bounds[1][1] = atoi(argv[++i]); + bounds[2][0] = atoi(argv[++i]); + bounds[2][1] = atoi(argv[++i]); + bounds[3][0] = atoi(argv[++i]); + bounds[3][1] = atoi(argv[++i]); + scanning = 2; + break; + case 'P': /* pick position */ + scanning = 3; + break; + case 'i': /* irradiance factor */ + i++; + if (badarg(argc-i, argv+i, "f")) + goto userr; + irrad = atof(argv[i]); + break; + case 'm': /* raw map output */ + rawmap = 1; + break; + case 'c': /* color input */ + scanning = 0; + break; + default: + goto userr; } -#ifdef MSDOS - setmode(fileno(debugfp), O_BINARY); -#endif - newheader("RADIANCE", debugfp); - printargs(argc, argv, debugfp); - argv += 2; - argc -= 2; - } - if (argc != 3 && argc != 11) - goto userr; - if (strcmp(argv[1], "-") && freopen(argv[1], "r", stdin) == NULL) { - perror(argv[1]); + /* open files */ + if (i < argc && freopen(argv[i], "r", stdin) == NULL) { + perror(argv[i]); exit(1); } - if (strcmp(argv[2], "-") && freopen(argv[2], "w", stdout) == NULL) { - perror(argv[2]); + if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) { + perror(argv[i+1]); exit(1); } -#ifdef MSDOS - setmode(fileno(stdin), O_BINARY); -#endif - if (checkheader(stdin, COLRFMT, NULL) < 0 || - fgetresolu(&xmax, &ymax, stdin) < 0) { - fprintf(stderr, "%s: bad input picture\n", progname); - exit(1); - } - /* get chart boundaries */ - if (argc == 11) { - for (i = 0; i < 4; i++) { - if (!isint(argv[2*i+3]) | !isint(argv[2*i+4])) + if (scanning) { /* load input picture header */ + SET_FILE_BINARY(stdin); + if (checkheader(stdin, COLRFMT, NULL) < 0 || + fgetresolu(&xmax, &ymax, stdin) < 0) { + fprintf(stderr, "%s: bad input picture\n", progname); + exit(1); + } + if (scanning == 3) { + if (i >= argc) goto userr; - bounds[i][0] = atoi(argv[2*i+3]); - bounds[i][1] = atoi(argv[2*i+4]); + pickchartpos(argv[i]); + scanning = 2; } - } else { + } else { /* else set default xmax and ymax */ + xmax = 512; + ymax = 2*512/3; + } + if (scanning != 2) { /* use default boundaries */ bounds[0][0] = bounds[2][0] = .029*xmax + .5; bounds[0][1] = bounds[1][1] = .956*ymax + .5; bounds[1][0] = bounds[3][0] = .971*xmax + .5; bounds[2][1] = bounds[3][1] = .056*ymax + .5; } init(); /* initialize */ - getcolors(); /* get picture colors */ + if (scanning) /* get picture colors */ + getpicture(); + else + getcolors(); compute(); /* compute color mapping */ - putmapping(); /* put out color mapping */ - putdebug(); /* put out debug picture */ + if (rawmap) { /* print out raw correspondence */ + register int j; + + printf("# Color correspondence produced by:\n#\t\t"); + printargs(argc, argv, stdout); + printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + for (j = 0; j < 24; j++) + printf("%f %f %f %f %f %f\n", + colval(inpRGB[j],RED), colval(inpRGB[j],GRN), + colval(inpRGB[j],BLU), colval(mbRGB[j],RED), + colval(mbRGB[j],GRN), colval(mbRGB[j],BLU)); + if (scanning && debugfp != NULL) + cwarp(); /* color warp for debugging */ + } else { /* print color mapping */ + /* print header */ + printf("{\n\tColor correction file computed by:\n\t\t"); + printargs(argc, argv, stdout); + printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + if (!scanning) + printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("}\n"); + putmapping(); /* put out color mapping */ + } + if (debugfp != NULL) { /* put out debug picture */ + if (scanning) + picdebug(); + else + clrdebug(); + } exit(0); userr: - fprintf(stderr, "Usage: %s [-d dbg.pic] input.pic output.cal [xul yul xur yur xll yll xlr ylr]\n", + fprintf(stderr, +"Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n", progname); + fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n", + progname); exit(1); } @@ -139,6 +261,7 @@ userr: init() /* initialize */ { double quad[4][2]; + register int i; /* make coordinate transformation */ quad[0][0] = bounds[0][0]; quad[0][1] = bounds[0][1]; @@ -153,12 +276,18 @@ init() /* initialize */ fprintf(stderr, "%s: bad chart boundaries\n", progname); exit(1); } + /* map MacBeth colors to RGB space */ + for (i = 0; i < 24; i++) { + xyY2RGB(mbRGB[i], mbxyY[i]); + scalecolor(mbRGB[i], irrad); + } } int -chartndx(x, y) /* find color number for position */ +chartndx(x, y, np) /* find color number for position */ int x, y; +int *np; { double ipos[3], cpos[3]; int ix, iy; @@ -171,25 +300,30 @@ int x, y; cpos[0] /= cpos[2]; cpos[1] /= cpos[2]; if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.) - return(-1); + return(RG_BORD); ix = cpos[0]; iy = cpos[1]; fx = cpos[0] - ix; fy = cpos[1] - iy; - if (fx < .35 || fx >= .65 || fy < .35 || fy >= .65) - return(-1); - return(iy*6 + ix); + *np = iy*6 + ix; + if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65) + return(RG_CENT); + if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95) + return(RG_BORD); + if (fx >= 0.5) /* right side is corrected */ + return(RG_CORR); + return(RG_ORIG); /* left side is original */ } -getcolors() /* load in picture colors */ +getpicture() /* load in picture colors */ { COLR *scanln; COLOR pval; int ccount[24]; double d; - int y; - register int x, i; + int y, i; + register int x; scanln = (COLR *)malloc(xmax*sizeof(COLR)); if (scanln == NULL) { @@ -197,7 +331,7 @@ getcolors() /* load in picture colors */ exit(1); } for (i = 0; i < 24; i++) { - setcolor(picRGB[i], 0., 0., 0.); + setcolor(inpRGB[i], 0., 0., 0.); ccount[i] = 0; } for (y = ymax-1; y >= 0; y--) { @@ -206,78 +340,149 @@ getcolors() /* load in picture colors */ progname); exit(1); } - for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i >= 0) { + for (x = 0; x < xmax; x++) + if (chartndx(x, y, &i) == RG_CENT) { colr_color(pval, scanln[x]); - addcolor(picRGB[i], pval); + addcolor(inpRGB[i], pval); ccount[i]++; } + } + for (i = 0; i < 24; i++) { /* compute averages */ + if (ccount[i] == 0) + continue; + d = 1./ccount[i]; + scalecolor(inpRGB[i], d); + inpflags |= 1L< 24) || + fgetval(stdin, 'f', &xyYin[0]) != 1 || + fgetval(stdin, 'f', &xyYin[1]) != 1 || + fgetval(stdin, 'f', &xyYin[2]) != 1 || + (xyYin[0] < 0.) | (xyYin[1] < 0.) || + xyYin[0] + xyYin[1] > 1.) { + fprintf(stderr, "%s: bad color input data\n", + progname); + exit(1); } + if (n == 0) { /* calibration white */ + xyY2RGB(whiteclr, xyYin); + gotwhite++; + } else { /* standard color */ + n--; + xyY2RGB(inpRGB[n], xyYin); + inpflags |= 1L< 0 && colval(x,i) < colval(bramp[--n][0],i)) - ; - cv[i] = ((colval(bramp[n+1][0],i) - colval(x,i)) * + for (n = 0; n < NMBNEU-2; n++) + if (colval(x,i) < colval(bramp[n+1][0],i)) + break; + colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) * colval(bramp[n][1],i) + (colval(x,i) - colval(bramp[n][0],i)) * colval(bramp[n+1][1],i)) / (colval(bramp[n+1][0],i) - colval(bramp[n][0],i)); - if (cv[i] < 0.) cv[i] = 0.; } - setcolor(y, cv[0], cv[1], cv[2]); } compute() /* compute color mapping */ { - COLOR clrin[NMBMOD], clrout[NMBMOD]; + COLOR clrin[24], clrout[24]; + long cflags; COLOR ctmp; - double d; - register int i; - /* map MacBeth colors to RGB space */ - for (i = 0; i < 24; i++) { - d = mbxyY[i][2] / mbxyY[i][1]; - ctmp[0] = mbxyY[i][0] * d; - ctmp[1] = mbxyY[i][2]; - ctmp[2] = (1. - mbxyY[i][0] - mbxyY[i][1]) * d; - cie_rgb(mbRGB[i], ctmp); + register int i, n; + /* did we get what we need? */ + if ((inpflags & REQFLGS) != REQFLGS) { + fprintf(stderr, "%s: missing required input colors\n", + progname); + exit(1); } /* compute piecewise luminance curve */ for (i = 0; i < NMBNEU; i++) { - copycolor(bramp[i][0], picRGB[mbneu[i]]); + copycolor(bramp[i][0], inpRGB[mbneu[i]]); copycolor(bramp[i][1], mbRGB[mbneu[i]]); } - /* compute color matrix */ - for (i = 0; i < NMBMOD; i++) { - bresp(clrin[i], picRGB[mbmod[i]]); - copycolor(clrout[i], mbRGB[mbmod[i]]); - } - compsoln(clrin, clrout, NMBMOD); + /* compute color space gamut */ + if (scanning) { + copycolor(colmin, cblack); + copycolor(colmax, cwhite); + scalecolor(colmax, irrad); + } else + for (i = 0; i < 3; i++) { + colval(colmin,i) = colval(bramp[0][0],i) - + colval(bramp[0][1],i) * + (colval(bramp[1][0],i)-colval(bramp[0][0],i)) / + (colval(bramp[1][1],i)-colval(bramp[1][0],i)); + colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) + + (1.-colval(bramp[NMBNEU-2][1],i)) * + (colval(bramp[NMBNEU-1][0],i) - + colval(bramp[NMBNEU-2][0],i)) / + (colval(bramp[NMBNEU-1][1],i) - + colval(bramp[NMBNEU-2][1],i)); + } + /* compute color mapping */ + do { + cflags = inpflags & ~gmtflags; + n = 0; /* compute transform matrix */ + for (i = 0; i < 24; i++) + if (cflags & 1L< 0.99 && irrad < 1.01) /* check gamut */ + for (i = 0; i < 24; i++) + if (cflags & 1L< 3) */ -COLOR cin[], cout[]; -int n; + + +cwarp() /* compute color warp map */ { - double *au[NMBMOD], *v[3], vv[3][3], auv[NMBMOD][3], w[3]; - double b[NMBMOD]; - register int i, j; + register int i; - if (n > NMBMOD) { - fprintf(stderr, "%s: inconsistent code!\n", progname); - exit(1); - } - for (i = 0; i < n; i++) /* assign rectangular matrix A */ - for (j = 0; j < 3; j++) - auv[i][j] = colval(cin[i],j); - /* svdcmp indexing requires pointer offsets */ - for (j = 0; j < 3; j++) - v[j] = vv[j] - 1; - for (i = 0; i < n; i++) - au[i] = auv[i] - 1; - /* compute singular value decomposition */ -fprintf(stderr, "A:\n"); -for (i = 1; i <= n; i++) -fprintf(stderr, "%g %g %g\n", (au-1)[i][1], (au-1)[i][2], (au-1)[i][3]); - svdcmp(au-1, n, 3, w-1, v-1); -fprintf(stderr, "U:\n"); -for (i = 0; i < n; i++) -fprintf(stderr, "%g %g %g\n", auv[i][0], auv[i][1], auv[i][2]); -fprintf(stderr, "V:\n"); -for (i = 0; i < 3; i++) -fprintf(stderr, "%g %g %g\n", vv[i][0], vv[i][1], vv[i][2]); -fprintf(stderr, "W: %g %g %g\n", w[0], w[1], w[2]); - /* zero out small weights */ - for (j = 0; j < 3; j++) - if (w[j] < 1e-4) - w[j] = 0.; - /* back substitution for each row vector */ - for (j = 0; j < 3; j++) { - for (i = 0; i < n; i++) - b[i] = colval(cout[i],j); - svbksb(au-1, w-1, v-1, n, 3, b-1, solmat[j]-1); - } + if ((wcor = new3dw(W3EXACT)) == NULL) + goto memerr; + for (i = 0; i < 24; i++) + if (!add3dpt(wcor, inpRGB[i], mbRGB[i])) + goto memerr; + return; +memerr: + perror(progname); + exit(1); } -#endif +int cvtcolor(cout, cin) /* convert color according to our mapping */ COLOR cout, cin; { - double r, g, b; + COLOR ctmp; + int clipped; - bresp(cout, cin); - r = colval(cout,0)*solmat[0][0] + colval(cout,1)*solmat[0][1] - + colval(cout,2)*solmat[0][2]; - if (r < 0) r = 0; - g = colval(cout,0)*solmat[1][0] + colval(cout,1)*solmat[1][1] - + colval(cout,2)*solmat[1][2]; - if (g < 0) g = 0; - b = colval(cout,0)*solmat[2][0] + colval(cout,1)*solmat[2][1] - + colval(cout,2)*solmat[2][2]; - if (b < 0) b = 0; - setcolor(cout, r, g, b); + if (wcor != NULL) { + clipped = warp3d(cout, cin, wcor); + clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax); + } else if (scanning) { + bresp(ctmp, cin); + clipped = cresp(cout, ctmp); + } else { + clipped = cresp(ctmp, cin); + bresp(cout, ctmp); + } + return(clipped); } -putdebug() /* put out debugging picture */ +int +cresp(cout, cin) /* transform color according to matrix */ +COLOR cout, cin; { + colortrans(cout, solmat, cin); + return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax)); +} + + +xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */ +COLOR rgbout; +register float xyYin[3]; +{ + COLOR ctmp; + double d; + + d = xyYin[2] / xyYin[1]; + ctmp[0] = xyYin[0] * d; + ctmp[1] = xyYin[2]; + ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d; + /* allow negative values */ + colortrans(rgbout, xyz2rgbmat, ctmp); +} + + +picdebug() /* put out debugging picture */ +{ + static COLOR blkcol = BLKCOLOR; COLOR *scan; - int y; - register int x, i; + int y, i; + register int x, rg; - if (debugfp == NULL) - return; if (fseek(stdin, 0L, 0) == EOF) { fprintf(stderr, "%s: cannot seek on input picture\n", progname); exit(1); @@ -440,8 +672,10 @@ putdebug() /* put out debugging picture */ exit(1); } /* finish debug header */ + fputformat(COLRFMT, debugfp); putc('\n', debugfp); fprtresolu(xmax, ymax, debugfp); + /* write debug picture */ for (y = ymax-1; y >= 0; y--) { if (freadscan(scan, xmax, stdin) < 0) { fprintf(stderr, "%s: error rereading input picture\n", @@ -449,11 +683,18 @@ putdebug() /* put out debugging picture */ exit(1); } for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i < 0) + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<= 0; y--) { + for (x = 0; x < xmax; x++) { + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<
