--- ray/src/px/macbethcal.c 1995/10/11 10:40:13 2.1 +++ ray/src/px/macbethcal.c 1995/10/17 11:05:17 2.6 @@ -18,8 +18,33 @@ static char SCCSid[] = "$SunId$ LBL"; #include "resolu.h" #include "pmap.h" - /* MacBeth colors (CIE 1931, absolute white) */ - /* computed from spectral measurements */ + /* MacBeth colors */ +#define DarkSkin 0 +#define LightSkin 1 +#define BlueSky 2 +#define Foliage 3 +#define BlueFlower 4 +#define BluishGreen 5 +#define Orange 6 +#define PurplishBlue 7 +#define ModerateRed 8 +#define Purple 9 +#define YellowGreen 10 +#define OrangeYellow 11 +#define Blue 12 +#define Green 13 +#define Red 14 +#define Yellow 15 +#define Magenta 16 +#define Cyan 17 +#define White 18 +#define Neutral8 19 +#define Neutral65 20 +#define Neutral5 21 +#define Neutral35 22 +#define Black 23 + /* computed from 5nm spectral measurements */ + /* CIE 1931 2 degree obs, equal-energy white */ float mbxyY[24][3] = { {0.462, 0.3769, 0.0932961}, /* DarkSkin */ {0.4108, 0.3542, 0.410348}, /* LightSkin */ @@ -50,22 +75,31 @@ float mbxyY[24][3] = { COLOR mbRGB[24]; /* MacBeth RGB values */ #define NMBNEU 6 /* Number of MacBeth neutral colors */ -short mbneu[NMBNEU] = {23,22,21,20,19,18}; -#define NMBMOD 3 /* Number of MacBeth moderate colors */ -short mbmod[NMBMOD] = {1,3,2}; -#define NMBSAT 6 /* Number of MacBeth saturated colors */ -short mbsat[NMBSAT] = {14,12,13,15,16,17}; +short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White}; +#define NMBMOD 16 /* Number of MacBeth unsaturated colors */ +short mbmod[NMBMOD] = { + DarkSkin,LightSkin,BlueSky,Foliage,BlueFlower,BluishGreen, + PurplishBlue,ModerateRed,YellowGreen,OrangeYellow, + Black,Neutral35,Neutral5,Neutral65,Neutral8,White + }; + +#define NMBSAT 8 /* Number of MacBeth saturated colors */ +short mbsat[NMBSAT] = { + Red,Green,Blue,Magenta,Yellow,Cyan, + Orange,Purple + }; + int xmax, ymax; /* input image dimensions */ int bounds[4][2]; /* image coordinates of chart corners */ double imgxfm[3][3]; /* coordinate transformation matrix */ COLOR picRGB[24]; /* picture colors */ -double bramp[NMBNEU][2]; /* brightness ramp */ +COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */ double solmat[3][3]; /* color mapping matrix */ -FILE *debugfp = NULL; +FILE *debugfp = NULL; /* debug output picture */ char *progname; extern char *malloc(); @@ -125,6 +159,10 @@ char **argv; } init(); /* initialize */ getcolors(); /* get picture colors */ + compute(); /* compute color mapping */ + /* print comment */ + printf("{ Color correction file computed by %s }\n", progname); + printf("{ from scanned MacBetch color chart %s }\n", argv[1]); putmapping(); /* put out color mapping */ putdebug(); /* put out debug picture */ exit(0); @@ -138,9 +176,6 @@ userr: init() /* initialize */ { double quad[4][2]; - COLOR ctmp; - double d; - int i; /* make coordinate transformation */ quad[0][0] = bounds[0][0]; quad[0][1] = bounds[0][1]; @@ -155,14 +190,6 @@ init() /* initialize */ fprintf(stderr, "%s: bad chart boundaries\n", progname); exit(1); } - /* map MacBeth colors to RGB space */ - for (i = 0; i < 24; i++) { - d = mbxyY[i][2] / mbxyY[i][1]; - ctmp[0] = mbxyY[i][0] * d; - ctmp[1] = mbxyY[i][2]; - ctmp[2] = (1. - mbxyY[i][0] - mbxyY[i][1]) * d; - cie_rgb(mbRGB[i], ctmp); - } } @@ -238,79 +265,123 @@ getcolors() /* load in picture colors */ } -double -bresp(x) /* piecewise linear interpolation of brightness */ -double x; +bresp(y, x) /* piecewise linear interpolation of primaries */ +COLOR y, x; { - register int n = NMBNEU; + double cv[3]; + register int i, n; - while (n > 0 && x < bramp[--n][0]) - ; - return( ((bramp[n+1][0] - x)*bramp[n][1] + - (x - bramp[n][0])*bramp[n+1][1]) / - (bramp[n+1][0] - bramp[n][0]) ); + for (i = 0; i < 3; i++) { + for (n = 0; n < NMBNEU-2; n++) + if (colval(x,i) < colval(bramp[n+1][0],i)) + break; + cv[i] = ((colval(bramp[n+1][0],i) - colval(x,i)) * + colval(bramp[n][1],i) + + (colval(x,i) - colval(bramp[n][0],i)) * + colval(bramp[n+1][1],i)) / + (colval(bramp[n+1][0],i) - colval(bramp[n][0],i)); + if (cv[i] < 0.) cv[i] = 0.; + } + setcolor(y, cv[0], cv[1], cv[2]); } -putmapping() /* compute and print mapping for pcomb -f */ +compute() /* compute color mapping */ { - float clrin[NMBMOD][3], clrout[NMBMOD][3]; - register int i, j; + COLOR clrin[NMBMOD], clrout[NMBMOD]; + COLOR ctmp; + double d; + register int i; + /* map MacBeth colors to RGB space */ + for (i = 0; i < 24; i++) { + d = mbxyY[i][2] / mbxyY[i][1]; + ctmp[0] = mbxyY[i][0] * d; + ctmp[1] = mbxyY[i][2]; + ctmp[2] = (1. - mbxyY[i][0] - mbxyY[i][1]) * d; + cie_rgb(mbRGB[i], ctmp); + } /* compute piecewise luminance curve */ for (i = 0; i < NMBNEU; i++) { - bramp[i][0] = bright(picRGB[mbneu[i]]); - bramp[i][1] = bright(mbRGB[mbneu[i]]); + copycolor(bramp[i][0], picRGB[mbneu[i]]); + copycolor(bramp[i][1], mbRGB[mbneu[i]]); } /* compute color matrix */ - for (i = 0; i < NMBMOD; i++) - for (j = 0; j < 3; j++) { - clrin[i][j] = bresp(picRGB[mbmod[i]][j]); - clrout[i][j] = mbRGB[mbmod[i]][j]; - } + for (i = 0; i < NMBMOD; i++) { + bresp(clrin[i], picRGB[mbmod[i]]); + copycolor(clrout[i], mbRGB[mbmod[i]]); + } compsoln(clrin, clrout, NMBMOD); +} + + +putmapping() /* put out color mapping for pcomb -f */ +{ + static char cchar[3] = {'r', 'g', 'b'}; + register int i, j; /* print brightness mapping */ - printf("xval(i) : select(i, 0"); - for (i = 0; i < NMBNEU; i++) - printf(", %g", bramp[i][0]); - printf(");\n"); - printf("yval(i) : select(i, 0"); - for (i = 0; i < NMBNEU; i++) - printf(", %g", bramp[i][1]); - printf(");\n"); - printf("ifind(x,f,n) : if(1.5-n, 1, if(x-f(n), n, ifind(x,f,n-1)));\n"); - printf("binterp(i,x) : ((xval(i+1)-x)*yval(i) + (x-xval(i))*yval(i+1))/\n"); - printf("\t\t(xval(i+1) - xval(i));\n"); - printf("bresp(x) : binterp(ifind(x,xval,xval(0)-1), x);\n"); - printf("nred = bresp(ri(1));\n"); - printf("ngrn = bresp(gi(1));\n"); - printf("nblu = bresp(bi(1));\n"); + for (j = 0; j < 3; j++) { + printf("%cxa(i) : select(i", cchar[j]); + for (i = 0; i < NMBNEU; i++) + printf(",%g", colval(bramp[i][0],j)); + printf(");\n"); + printf("%cya(i) : select(i", cchar[j]); + for (i = 0; i < NMBNEU; i++) + printf(",%g", colval(bramp[i][1],j)); + printf(");\n"); + printf("%c = %ci(1);\n", cchar[j], cchar[j]); + printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n", + cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j], + cchar[j], cchar[j]); + printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]); + printf("%cn = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ", + cchar[j], cchar[j], cchar[j], + cchar[j], cchar[j], cchar[j]); + printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n", + cchar[j], cchar[j], cchar[j], + cchar[j], cchar[j]); + printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n", + cchar[j], cchar[j], cchar[j], cchar[j]); + } /* print color mapping */ - printf("ro = %g*nred + %g*ngrn + %g*nblu\n", - solmat[0][0], solmat[1][0], solmat[2][0]); - printf("go = %g*nred + %g*ngrn + %g*nblu\n", - solmat[0][1], solmat[1][1], solmat[2][1]); - printf("bo = %g*nred + %g*ngrn + %g*nblu\n", - solmat[0][2], solmat[1][2], solmat[2][2]); + printf("ro = %g*rn + %g*gn + %g*bn ;\n", + solmat[0][0], solmat[0][1], solmat[0][2]); + printf("go = %g*rn + %g*gn + %g*bn ;\n", + solmat[1][0], solmat[1][1], solmat[1][2]); + printf("bo = %g*rn + %g*gn + %g*bn ;\n", + solmat[2][0], solmat[2][1], solmat[2][2]); } -compsoln(cin, cout, n) /* solve 3x3 system */ -float cin[][3], cout[][3]; +compsoln(cin, cout, n) /* solve 3xN system using least-squares */ +COLOR cin[], cout[]; int n; { extern double mx3d_adjoint(), fabs(); double mat[3][3], invmat[3][3]; double det; double colv[3], rowv[3]; - register int i, j; + register int i, j, k; - if (n != 3) { + if (n < 3 | n > NMBMOD) { fprintf(stderr, "%s: inconsistent code!\n", progname); exit(1); } - for (i = 0; i < 3; i++) - for (j = 0; j < 3; j++) - mat[i][j] = cin[j][i]; + if (n == 3) + for (i = 0; i < 3; i++) + for (j = 0; j < 3; j++) + mat[i][j] = colval(cin[j],i); + else { /* compute A^t A */ + for (i = 0; i < 3; i++) + for (j = i; j < 3; j++) { + mat[i][j] = 0.; + for (k = 0; k < n; k++) + mat[i][j] += colval(cin[k],i) * + colval(cin[k],j); + } + for (i = 1; i < 3; i++) /* using symmetry */ + for (j = 0; j < i; j++) + mat[i][j] = mat[j][i]; + } det = mx3d_adjoint(mat, invmat); if (fabs(det) < 1e-4) { fprintf(stderr, "%s: cannot compute color mapping\n", @@ -324,11 +395,19 @@ int n; for (j = 0; j < 3; j++) invmat[i][j] /= det; for (i = 0; i < 3; i++) { + if (n == 3) + for (j = 0; j < 3; j++) + colv[j] = colval(cout[j],i); + else + for (j = 0; j < 3; j++) { + colv[j] = 0.; + for (k = 0; k < n; k++) + colv[j] += colval(cout[k],i) * + colval(cin[k],j); + } + mx3d_transform(colv, invmat, rowv); for (j = 0; j < 3; j++) - rowv[j] = cout[j][i]; - mx3d_transform(rowv, invmat, colv); - for (j = 0; j < 3; j++) - solmat[j][i] = colv[j]; + solmat[i][j] = rowv[j]; } } @@ -337,18 +416,18 @@ cvtcolor(cout, cin) /* convert color according to our COLOR cout, cin; { double r, g, b; - double r1, g1, b1; - r = bresp(colval(cin,RED)); - g = bresp(colval(cin,GRN)); - b = bresp(colval(cin,BLU)); - r1 = r*solmat[0][0] + g*solmat[1][0] + b*solmat[2][0]; - if (r1 < 0) r1 = 0; - g1 = r*solmat[0][1] + g*solmat[1][1] + b*solmat[2][1]; - if (g1 < 0) g1 = 0; - b1 = r*solmat[0][2] + g*solmat[1][2] + b*solmat[2][2]; - if (b1 < 0) b1 = 0; - setcolor(cout, r1, g1, b1); + bresp(cout, cin); + r = colval(cout,0)*solmat[0][0] + colval(cout,1)*solmat[0][1] + + colval(cout,2)*solmat[0][2]; + if (r < 0) r = 0; + g = colval(cout,0)*solmat[1][0] + colval(cout,1)*solmat[1][1] + + colval(cout,2)*solmat[1][2]; + if (g < 0) g = 0; + b = colval(cout,0)*solmat[2][0] + colval(cout,1)*solmat[2][1] + + colval(cout,2)*solmat[2][2]; + if (b < 0) b = 0; + setcolor(cout, r, g, b); } @@ -373,6 +452,7 @@ putdebug() /* put out debugging picture */ exit(1); } /* finish debug header */ + fputformat(COLRFMT, debugfp); putc('\n', debugfp); fprtresolu(xmax, ymax, debugfp); for (y = ymax-1; y >= 0; y--) {
