--- ray/src/px/macbethcal.c 1995/10/11 10:40:13 2.1 +++ ray/src/px/macbethcal.c 2004/03/28 20:33:13 2.23 @@ -1,25 +1,55 @@ -/* Copyright (c) 1995 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: macbethcal.c,v 2.23 2004/03/28 20:33:13 schorsch Exp $"; #endif - /* * Calibrate a scanned MacBeth Color Checker Chart * - * Produce a .cal file suitable for use with pcomb. + * Produce a .cal file suitable for use with pcomb, + * or .cwp file suitable for use with pcwarp. + * + * Warping code depends on conformance of COLOR and W3VEC types. */ #include -#ifdef MSDOS -#include -#endif +#include +#include + +#include "platform.h" +#include "rtprocess.h" +#include "rtio.h" #include "color.h" #include "resolu.h" #include "pmap.h" +#include "warp3d.h" +#include "mx3.h" - /* MacBeth colors (CIE 1931, absolute white) */ - /* computed from spectral measurements */ + /* MacBeth colors */ +#define DarkSkin 0 +#define LightSkin 1 +#define BlueSky 2 +#define Foliage 3 +#define BlueFlower 4 +#define BluishGreen 5 +#define Orange 6 +#define PurplishBlue 7 +#define ModerateRed 8 +#define Purple 9 +#define YellowGreen 10 +#define OrangeYellow 11 +#define Blue 12 +#define Green 13 +#define Red 14 +#define Yellow 15 +#define Magenta 16 +#define Cyan 17 +#define White 18 +#define Neutral8 19 +#define Neutral65 20 +#define Neutral5 21 +#define Neutral35 22 +#define Black 23 + /* computed from 5nm spectral measurements */ + /* CIE 1931 2 degree obs, equal-energy white */ float mbxyY[24][3] = { {0.462, 0.3769, 0.0932961}, /* DarkSkin */ {0.4108, 0.3542, 0.410348}, /* LightSkin */ @@ -50,97 +80,212 @@ float mbxyY[24][3] = { COLOR mbRGB[24]; /* MacBeth RGB values */ #define NMBNEU 6 /* Number of MacBeth neutral colors */ -short mbneu[NMBNEU] = {23,22,21,20,19,18}; -#define NMBMOD 3 /* Number of MacBeth moderate colors */ -short mbmod[NMBMOD] = {1,3,2}; -#define NMBSAT 6 /* Number of MacBeth saturated colors */ -short mbsat[NMBSAT] = {14,12,13,15,16,17}; +short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White}; +#define NEUFLGS (1L< 2 && !strcmp(argv[1], "-d")) { /* debug output */ - if ((debugfp = fopen(argv[2], "w")) == NULL) { - perror(argv[2]); - exit(1); + for (i = 1; i < argc && argv[i][0] == '-'; i++) + switch (argv[i][1]) { + case 'd': /* debug output */ + i++; + if (badarg(argc-i, argv+i, "s")) + goto userr; + if ((debugfp = fopen(argv[i], "w")) == NULL) { + perror(argv[i]); + exit(1); + } + SET_FILE_BINARY(debugfp); + newheader("RADIANCE", debugfp); /* start */ + printargs(argc, argv, debugfp); /* header */ + break; + case 'p': /* picture position */ + if (badarg(argc-i-1, argv+i+1, "iiiiiiii")) + goto userr; + bounds[0][0] = atoi(argv[++i]); + bounds[0][1] = atoi(argv[++i]); + bounds[1][0] = atoi(argv[++i]); + bounds[1][1] = atoi(argv[++i]); + bounds[2][0] = atoi(argv[++i]); + bounds[2][1] = atoi(argv[++i]); + bounds[3][0] = atoi(argv[++i]); + bounds[3][1] = atoi(argv[++i]); + scanning = 2; + break; + case 'P': /* pick position */ + scanning = 3; + break; + case 'i': /* irradiance factor */ + i++; + if (badarg(argc-i, argv+i, "f")) + goto userr; + irrad = atof(argv[i]); + break; + case 'm': /* raw map output */ + rawmap = 1; + break; + case 'c': /* color input */ + scanning = 0; + break; + default: + goto userr; } -#ifdef MSDOS - setmode(fileno(debugfp), O_BINARY); -#endif - newheader("RADIANCE", debugfp); - printargs(argc, argv, debugfp); - argv += 2; - argc -= 2; - } - if (argc != 3 && argc != 11) - goto userr; - if (strcmp(argv[1], "-") && freopen(argv[1], "r", stdin) == NULL) { - perror(argv[1]); + /* open files */ + if (i < argc && freopen(argv[i], "r", stdin) == NULL) { + perror(argv[i]); exit(1); } - if (strcmp(argv[2], "-") && freopen(argv[2], "w", stdout) == NULL) { - perror(argv[2]); + if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) { + perror(argv[i+1]); exit(1); } -#ifdef MSDOS - setmode(fileno(stdin), O_BINARY); -#endif - if (checkheader(stdin, COLRFMT, NULL) < 0 || - fgetresolu(&xmax, &ymax, stdin) < 0) { - fprintf(stderr, "%s: bad input picture\n", progname); - exit(1); - } - /* get chart boundaries */ - if (argc == 11) { - for (i = 0; i < 4; i++) { - if (!isint(argv[2*i+3]) | !isint(argv[2*i+4])) + if (scanning) { /* load input picture header */ + SET_FILE_BINARY(stdin); + if (checkheader(stdin, COLRFMT, NULL) < 0 || + fgetresolu(&xmax, &ymax, stdin) < 0) { + fprintf(stderr, "%s: bad input picture\n", progname); + exit(1); + } + if (scanning == 3) { + if (i >= argc) goto userr; - bounds[i][0] = atoi(argv[2*i+3]); - bounds[i][1] = atoi(argv[2*i+4]); + pickchartpos(argv[i]); + scanning = 2; } - } else { + } else { /* else set default xmax and ymax */ + xmax = 512; + ymax = 2*512/3; + } + if (scanning != 2) { /* use default boundaries */ bounds[0][0] = bounds[2][0] = .029*xmax + .5; bounds[0][1] = bounds[1][1] = .956*ymax + .5; bounds[1][0] = bounds[3][0] = .971*xmax + .5; bounds[2][1] = bounds[3][1] = .056*ymax + .5; } init(); /* initialize */ - getcolors(); /* get picture colors */ - putmapping(); /* put out color mapping */ - putdebug(); /* put out debug picture */ + if (scanning) /* get picture colors */ + getpicture(); + else + getcolors(); + compute(); /* compute color mapping */ + if (rawmap) { /* print out raw correspondence */ + register int j; + + printf("# Color correspondence produced by:\n#\t\t"); + printargs(argc, argv, stdout); + printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + for (j = 0; j < 24; j++) + printf("%f %f %f %f %f %f\n", + colval(inpRGB[j],RED), colval(inpRGB[j],GRN), + colval(inpRGB[j],BLU), colval(mbRGB[j],RED), + colval(mbRGB[j],GRN), colval(mbRGB[j],BLU)); + if (scanning && debugfp != NULL) + cwarp(); /* color warp for debugging */ + } else { /* print color mapping */ + /* print header */ + printf("{\n\tColor correction file computed by:\n\t\t"); + printargs(argc, argv, stdout); + printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + if (!scanning) + printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n", + i+1 < argc ? argv[i+1] : "{this_file}"); + printf("}\n"); + putmapping(); /* put out color mapping */ + } + if (debugfp != NULL) { /* put out debug picture */ + if (scanning) + picdebug(); + else + clrdebug(); + } exit(0); userr: - fprintf(stderr, "Usage: %s [-d dbg.pic] input.pic output.cal [xul yul xur yur xll yll xlr ylr]\n", + fprintf(stderr, +"Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n", progname); + fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n", + progname); exit(1); + return 1; /* pro forma return */ } -init() /* initialize */ +static void +init(void) /* initialize */ { double quad[4][2]; - COLOR ctmp; - double d; - int i; + register int i; /* make coordinate transformation */ quad[0][0] = bounds[0][0]; quad[0][1] = bounds[0][1]; @@ -157,18 +302,18 @@ init() /* initialize */ } /* map MacBeth colors to RGB space */ for (i = 0; i < 24; i++) { - d = mbxyY[i][2] / mbxyY[i][1]; - ctmp[0] = mbxyY[i][0] * d; - ctmp[1] = mbxyY[i][2]; - ctmp[2] = (1. - mbxyY[i][0] - mbxyY[i][1]) * d; - cie_rgb(mbRGB[i], ctmp); + xyY2RGB(mbRGB[i], mbxyY[i]); + scalecolor(mbRGB[i], irrad); } } -int -chartndx(x, y) /* find color number for position */ -int x, y; +static int +chartndx( /* find color number for position */ + int x, + int y, + int *np +) { double ipos[3], cpos[3]; int ix, iy; @@ -181,25 +326,31 @@ int x, y; cpos[0] /= cpos[2]; cpos[1] /= cpos[2]; if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.) - return(-1); + return(RG_BORD); ix = cpos[0]; iy = cpos[1]; fx = cpos[0] - ix; fy = cpos[1] - iy; - if (fx < .35 || fx >= .65 || fy < .35 || fy >= .65) - return(-1); - return(iy*6 + ix); + *np = iy*6 + ix; + if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65) + return(RG_CENT); + if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95) + return(RG_BORD); + if (fx >= 0.5) /* right side is corrected */ + return(RG_CORR); + return(RG_ORIG); /* left side is original */ } -getcolors() /* load in picture colors */ +static void +getpicture(void) /* load in picture colors */ { COLR *scanln; COLOR pval; int ccount[24]; double d; - int y; - register int x, i; + int y, i; + register int x; scanln = (COLR *)malloc(xmax*sizeof(COLR)); if (scanln == NULL) { @@ -207,7 +358,7 @@ getcolors() /* load in picture colors */ exit(1); } for (i = 0; i < 24; i++) { - setcolor(picRGB[i], 0., 0., 0.); + setcolor(inpRGB[i], 0., 0., 0.); ccount[i] = 0; } for (y = ymax-1; y >= 0; y--) { @@ -216,101 +367,235 @@ getcolors() /* load in picture colors */ progname); exit(1); } - for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i >= 0) { + for (x = 0; x < xmax; x++) + if (chartndx(x, y, &i) == RG_CENT) { colr_color(pval, scanln[x]); - addcolor(picRGB[i], pval); + addcolor(inpRGB[i], pval); ccount[i]++; } + } + for (i = 0; i < 24; i++) { /* compute averages */ + if (ccount[i] == 0) + continue; + d = 1./ccount[i]; + scalecolor(inpRGB[i], d); + inpflags |= 1L< 24) || + fgetval(stdin, 'f', &xyYin[0]) != 1 || + fgetval(stdin, 'f', &xyYin[1]) != 1 || + fgetval(stdin, 'f', &xyYin[2]) != 1 || + (xyYin[0] < 0.) | (xyYin[1] < 0.) || + xyYin[0] + xyYin[1] > 1.) { + fprintf(stderr, "%s: bad color input data\n", + progname); + exit(1); } + if (n == 0) { /* calibration white */ + xyY2RGB(whiteclr, xyYin); + gotwhite++; + } else { /* standard color */ + n--; + xyY2RGB(inpRGB[n], xyYin); + inpflags |= 1L< 0 && x < bramp[--n][0]) - ; - return( ((bramp[n+1][0] - x)*bramp[n][1] + - (x - bramp[n][0])*bramp[n+1][1]) / - (bramp[n+1][0] - bramp[n][0]) ); + for (i = 0; i < 3; i++) { + for (n = 0; n < NMBNEU-2; n++) + if (colval(x,i) < colval(bramp[n+1][0],i)) + break; + colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) * + colval(bramp[n][1],i) + + (colval(x,i) - colval(bramp[n][0],i)) * + colval(bramp[n+1][1],i)) / + (colval(bramp[n+1][0],i) - colval(bramp[n][0],i)); + } } -putmapping() /* compute and print mapping for pcomb -f */ +static void +compute(void) /* compute color mapping */ { - float clrin[NMBMOD][3], clrout[NMBMOD][3]; - register int i, j; + COLOR clrin[24], clrout[24]; + long cflags; + COLOR ctmp; + register int i, n; + /* did we get what we need? */ + if ((inpflags & REQFLGS) != REQFLGS) { + fprintf(stderr, "%s: missing required input colors\n", + progname); + exit(1); + } /* compute piecewise luminance curve */ for (i = 0; i < NMBNEU; i++) { - bramp[i][0] = bright(picRGB[mbneu[i]]); - bramp[i][1] = bright(mbRGB[mbneu[i]]); + copycolor(bramp[i][0], inpRGB[mbneu[i]]); + copycolor(bramp[i][1], mbRGB[mbneu[i]]); } - /* compute color matrix */ - for (i = 0; i < NMBMOD; i++) - for (j = 0; j < 3; j++) { - clrin[i][j] = bresp(picRGB[mbmod[i]][j]); - clrout[i][j] = mbRGB[mbmod[i]][j]; + /* compute color space gamut */ + if (scanning) { + copycolor(colmin, cblack); + copycolor(colmax, cwhite); + scalecolor(colmax, irrad); + } else + for (i = 0; i < 3; i++) { + colval(colmin,i) = colval(bramp[0][0],i) - + colval(bramp[0][1],i) * + (colval(bramp[1][0],i)-colval(bramp[0][0],i)) / + (colval(bramp[1][1],i)-colval(bramp[1][0],i)); + colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) + + (1.-colval(bramp[NMBNEU-2][1],i)) * + (colval(bramp[NMBNEU-1][0],i) - + colval(bramp[NMBNEU-2][0],i)) / + (colval(bramp[NMBNEU-1][1],i) - + colval(bramp[NMBNEU-2][1],i)); } - compsoln(clrin, clrout, NMBMOD); + /* compute color mapping */ + do { + cflags = inpflags & ~gmtflags; + n = 0; /* compute transform matrix */ + for (i = 0; i < 24; i++) + if (cflags & 1L< 0.99 && irrad < 1.01) /* check gamut */ + for (i = 0; i < 24; i++) + if (cflags & 1L<= 0; y--) { if (freadscan(scan, xmax, stdin) < 0) { fprintf(stderr, "%s: error rereading input picture\n", @@ -382,11 +727,18 @@ putdebug() /* put out debugging picture */ exit(1); } for (x = 0; x < xmax; x++) { - i = chartndx(x, y); - if (i < 0) + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<= 0; y--) { + for (x = 0; x < xmax; x++) { + rg = chartndx(x, y, &i); + if (rg == RG_CENT) { + if (!(1L<
