root/radiance/ray/src/px/macbethcal.c
Revision: 2.20
Committed: Sun Jul 27 22:12:03 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: macbethcal.c,v 2.19 2003/07/21 22:30:18 schorsch Exp $";
5 * Calibrate a scanned MacBeth Color Checker Chart
6 *
7 * Produce a .cal file suitable for use with pcomb,
8 * or .cwp file suitable for use with pcwarp.
9 *
10 * Warping code depends on conformance of COLOR and W3VEC types.
11 */
12
13 #include <stdio.h>
14 #include <math.h>
15 #include <time.h>
16
17 #include "platform.h"
18 #include "color.h"
19 #include "resolu.h"
20 #include "pmap.h"
21 #include "warp3d.h"
22
23 /* MacBeth colors */
24 #define DarkSkin 0
25 #define LightSkin 1
26 #define BlueSky 2
27 #define Foliage 3
28 #define BlueFlower 4
29 #define BluishGreen 5
30 #define Orange 6
31 #define PurplishBlue 7
32 #define ModerateRed 8
33 #define Purple 9
34 #define YellowGreen 10
35 #define OrangeYellow 11
36 #define Blue 12
37 #define Green 13
38 #define Red 14
39 #define Yellow 15
40 #define Magenta 16
41 #define Cyan 17
42 #define White 18
43 #define Neutral8 19
44 #define Neutral65 20
45 #define Neutral5 21
46 #define Neutral35 22
47 #define Black 23
48 /* computed from 5nm spectral measurements */
49 /* CIE 1931 2 degree obs, equal-energy white */
50 float mbxyY[24][3] = {
51 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
52 {0.4108, 0.3542, 0.410348}, /* LightSkin */
53 {0.2626, 0.267, 0.181554}, /* BlueSky */
54 {0.36, 0.4689, 0.108447}, /* Foliage */
55 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
56 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
57 {0.52, 0.4197, 0.357899}, /* Orange */
58 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
59 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
60 {0.3361, 0.2249, 0.0600102}, /* Purple */
61 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
62 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
63 {0.2026, 0.1369, 0.0529249}, /* Blue */
64 {0.3007, 0.4822, 0.221226}, /* Green */
65 {0.5805, 0.3238, 0.162167}, /* Red */
66 {0.4617, 0.472, 0.64909}, /* Yellow */
67 {0.4178, 0.2625, 0.233662}, /* Magenta */
68 {0.2038, 0.2508, 0.167275}, /* Cyan */
69 {0.3358, 0.337, 0.916877}, /* White */
70 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
71 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
72 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
73 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
74 {0.3346, 0.3349, 0.0308383} /* Black */
75 };
76
77 COLOR mbRGB[24]; /* MacBeth RGB values */
78
79 #define NMBNEU 6 /* Number of MacBeth neutral colors */
80 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
81
82 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
83 1L<<Neutral5|1L<<Neutral35|1L<<Black)
84
85 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
86 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
87 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
88
89 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
90 1L<<BluishGreen|1L<<ModerateRed)
91
92 #define REQFLGS NEUFLGS /* need these colors */
93 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
94
95 #define RG_BORD 0 /* patch border */
96 #define RG_CENT 01 /* central region of patch */
97 #define RG_ORIG 02 /* original color region */
98 #define RG_CORR 04 /* corrected color region */
99
100 #ifndef DISPCOM
101 #define DISPCOM "ximage -op %s"
102 #endif
103
104 int scanning = 1; /* scanned input (or recorded output)? */
105 double irrad = 1.0; /* irradiance multiplication factor */
106 int rawmap = 0; /* put out raw color mapping? */
107
108 int xmax, ymax; /* input image dimensions */
109 int bounds[4][2]; /* image coordinates of chart corners */
110 double imgxfm[3][3]; /* coordinate transformation matrix */
111
112 COLOR inpRGB[24]; /* measured or scanned input colors */
113 long inpflags = 0; /* flags of which colors were input */
114 long gmtflags = 0; /* flags of out-of-gamut colors */
115
116 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
117 COLORMAT solmat; /* color mapping matrix */
118 COLOR colmin, colmax; /* gamut limits */
119
120 WARP3D *wcor = NULL; /* color space warp */
121
122 FILE *debugfp = NULL; /* debug output picture */
123 char *progname;
124
125
126 main(argc, argv)
127 int argc;
128 char **argv;
129 {
130 int i;
131
132 progname = argv[0];
133 for (i = 1; i < argc && argv[i][0] == '-'; i++)
134 switch (argv[i][1]) {
135 case 'd': /* debug output */
136 i++;
137 if (badarg(argc-i, argv+i, "s"))
138 goto userr;
139 if ((debugfp = fopen(argv[i], "w")) == NULL) {
140 perror(argv[i]);
141 exit(1);
142 }
143 SET_FILE_BINARY(debugfp);
144 newheader("RADIANCE", debugfp); /* start */
145 printargs(argc, argv, debugfp); /* header */
146 break;
147 case 'p': /* picture position */
148 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
149 goto userr;
150 bounds[0][0] = atoi(argv[++i]);
151 bounds[0][1] = atoi(argv[++i]);
152 bounds[1][0] = atoi(argv[++i]);
153 bounds[1][1] = atoi(argv[++i]);
154 bounds[2][0] = atoi(argv[++i]);
155 bounds[2][1] = atoi(argv[++i]);
156 bounds[3][0] = atoi(argv[++i]);
157 bounds[3][1] = atoi(argv[++i]);
158 scanning = 2;
159 break;
160 case 'P': /* pick position */
161 scanning = 3;
162 break;
163 case 'i': /* irradiance factor */
164 i++;
165 if (badarg(argc-i, argv+i, "f"))
166 goto userr;
167 irrad = atof(argv[i]);
168 break;
169 case 'm': /* raw map output */
170 rawmap = 1;
171 break;
172 case 'c': /* color input */
173 scanning = 0;
174 break;
175 default:
176 goto userr;
177 }
178 /* open files */
179 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
180 perror(argv[i]);
181 exit(1);
182 }
183 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
184 perror(argv[i+1]);
185 exit(1);
186 }
187 if (scanning) { /* load input picture header */
188 SET_FILE_BINARY(stdin);
189 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
190 fgetresolu(&xmax, &ymax, stdin) < 0) {
191 fprintf(stderr, "%s: bad input picture\n", progname);
192 exit(1);
193 }
194 if (scanning == 3) {
195 if (i >= argc)
196 goto userr;
197 pickchartpos(argv[i]);
198 scanning = 2;
199 }
200 } else { /* else set default xmax and ymax */
201 xmax = 512;
202 ymax = 2*512/3;
203 }
204 if (scanning != 2) { /* use default boundaries */
205 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
206 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
207 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
208 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
209 }
210 init(); /* initialize */
211 if (scanning) /* get picture colors */
212 getpicture();
213 else
214 getcolors();
215 compute(); /* compute color mapping */
216 if (rawmap) { /* print out raw correspondence */
217 register int j;
218
219 printf("# Color correspondence produced by:\n#\t\t");
220 printargs(argc, argv, stdout);
221 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
222 i+1 < argc ? argv[i+1] : "{this_file}");
223 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
224 i+1 < argc ? argv[i+1] : "{this_file}");
225 for (j = 0; j < 24; j++)
226 printf("%f %f %f %f %f %f\n",
227 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
228 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
229 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
230 if (scanning && debugfp != NULL)
231 cwarp(); /* color warp for debugging */
232 } else { /* print color mapping */
233 /* print header */
234 printf("{\n\tColor correction file computed by:\n\t\t");
235 printargs(argc, argv, stdout);
236 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
237 i+1 < argc ? argv[i+1] : "{this_file}");
238 if (!scanning)
239 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
240 i+1 < argc ? argv[i+1] : "{this_file}");
241 printf("}\n");
242 putmapping(); /* put out color mapping */
243 }
244 if (debugfp != NULL) { /* put out debug picture */
245 if (scanning)
246 picdebug();
247 else
248 clrdebug();
249 }
250 exit(0);
251 userr:
252 fprintf(stderr,
253 "Usage: %s [-d dbg.pic][-P | -p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
254 progname);
255 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
256 progname);
257 exit(1);
258 }
259
260
261 init() /* initialize */
262 {
263 double quad[4][2];
264 register int i;
265 /* make coordinate transformation */
266 quad[0][0] = bounds[0][0];
267 quad[0][1] = bounds[0][1];
268 quad[1][0] = bounds[1][0];
269 quad[1][1] = bounds[1][1];
270 quad[2][0] = bounds[3][0];
271 quad[2][1] = bounds[3][1];
272 quad[3][0] = bounds[2][0];
273 quad[3][1] = bounds[2][1];
274
275 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
276 fprintf(stderr, "%s: bad chart boundaries\n", progname);
277 exit(1);
278 }
279 /* map MacBeth colors to RGB space */
280 for (i = 0; i < 24; i++) {
281 xyY2RGB(mbRGB[i], mbxyY[i]);
282 scalecolor(mbRGB[i], irrad);
283 }
284 }
285
286
287 int
288 chartndx(x, y, np) /* find color number for position */
289 int x, y;
290 int *np;
291 {
292 double ipos[3], cpos[3];
293 int ix, iy;
294 double fx, fy;
295
296 ipos[0] = x;
297 ipos[1] = y;
298 ipos[2] = 1;
299 mx3d_transform(ipos, imgxfm, cpos);
300 cpos[0] /= cpos[2];
301 cpos[1] /= cpos[2];
302 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
303 return(RG_BORD);
304 ix = cpos[0];
305 iy = cpos[1];
306 fx = cpos[0] - ix;
307 fy = cpos[1] - iy;
308 *np = iy*6 + ix;
309 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
310 return(RG_CENT);
311 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
312 return(RG_BORD);
313 if (fx >= 0.5) /* right side is corrected */
314 return(RG_CORR);
315 return(RG_ORIG); /* left side is original */
316 }
317
318
319 getpicture() /* load in picture colors */
320 {
321 COLR *scanln;
322 COLOR pval;
323 int ccount[24];
324 double d;
325 int y, i;
326 register int x;
327
328 scanln = (COLR *)malloc(xmax*sizeof(COLR));
329 if (scanln == NULL) {
330 perror(progname);
331 exit(1);
332 }
333 for (i = 0; i < 24; i++) {
334 setcolor(inpRGB[i], 0., 0., 0.);
335 ccount[i] = 0;
336 }
337 for (y = ymax-1; y >= 0; y--) {
338 if (freadcolrs(scanln, xmax, stdin) < 0) {
339 fprintf(stderr, "%s: error reading input picture\n",
340 progname);
341 exit(1);
342 }
343 for (x = 0; x < xmax; x++)
344 if (chartndx(x, y, &i) == RG_CENT) {
345 colr_color(pval, scanln[x]);
346 addcolor(inpRGB[i], pval);
347 ccount[i]++;
348 }
349 }
350 for (i = 0; i < 24; i++) { /* compute averages */
351 if (ccount[i] == 0)
352 continue;
353 d = 1./ccount[i];
354 scalecolor(inpRGB[i], d);
355 inpflags |= 1L<<i;
356 }
357 free((void *)scanln);
358 }
359
360
361 getcolors() /* get xyY colors from standard input */
362 {
363 int gotwhite = 0;
364 COLOR whiteclr;
365 int n;
366 float xyYin[3];
367
368 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
369 if ((n < 0) | (n > 24) ||
370 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
371 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
372 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
373 (xyYin[0] < 0.) | (xyYin[1] < 0.) ||
374 xyYin[0] + xyYin[1] > 1.) {
375 fprintf(stderr, "%s: bad color input data\n",
376 progname);
377 exit(1);
378 }
379 if (n == 0) { /* calibration white */
380 xyY2RGB(whiteclr, xyYin);
381 gotwhite++;
382 } else { /* standard color */
383 n--;
384 xyY2RGB(inpRGB[n], xyYin);
385 inpflags |= 1L<<n;
386 }
387 }
388 /* normalize colors */
389 if (!gotwhite) {
390 if (!(inpflags & 1L<<White)) {
391 fprintf(stderr, "%s: missing input for White\n",
392 progname);
393 exit(1);
394 }
395 setcolor(whiteclr,
396 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
397 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
398 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
399 }
400 for (n = 0; n < 24; n++)
401 if (inpflags & 1L<<n)
402 setcolor(inpRGB[n],
403 colval(inpRGB[n],RED)/colval(whiteclr,RED),
404 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
405 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
406 }
407
408
409 bresp(y, x) /* piecewise linear interpolation of primaries */
410 COLOR y, x;
411 {
412 register int i, n;
413
414 for (i = 0; i < 3; i++) {
415 for (n = 0; n < NMBNEU-2; n++)
416 if (colval(x,i) < colval(bramp[n+1][0],i))
417 break;
418 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
419 colval(bramp[n][1],i) +
420 (colval(x,i) - colval(bramp[n][0],i)) *
421 colval(bramp[n+1][1],i)) /
422 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
423 }
424 }
425
426
427 compute() /* compute color mapping */
428 {
429 COLOR clrin[24], clrout[24];
430 long cflags;
431 COLOR ctmp;
432 register int i, n;
433 /* did we get what we need? */
434 if ((inpflags & REQFLGS) != REQFLGS) {
435 fprintf(stderr, "%s: missing required input colors\n",
436 progname);
437 exit(1);
438 }
439 /* compute piecewise luminance curve */
440 for (i = 0; i < NMBNEU; i++) {
441 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
442 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
443 }
444 /* compute color space gamut */
445 if (scanning) {
446 copycolor(colmin, cblack);
447 copycolor(colmax, cwhite);
448 scalecolor(colmax, irrad);
449 } else
450 for (i = 0; i < 3; i++) {
451 colval(colmin,i) = colval(bramp[0][0],i) -
452 colval(bramp[0][1],i) *
453 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
454 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
455 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
456 (1.-colval(bramp[NMBNEU-2][1],i)) *
457 (colval(bramp[NMBNEU-1][0],i) -
458 colval(bramp[NMBNEU-2][0],i)) /
459 (colval(bramp[NMBNEU-1][1],i) -
460 colval(bramp[NMBNEU-2][1],i));
461 }
462 /* compute color mapping */
463 do {
464 cflags = inpflags & ~gmtflags;
465 n = 0; /* compute transform matrix */
466 for (i = 0; i < 24; i++)
467 if (cflags & 1L<<i) {
468 bresp(clrin[n], inpRGB[i]);
469 copycolor(clrout[n], mbRGB[i]);
470 n++;
471 }
472 compsoln(clrin, clrout, n);
473 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
474 for (i = 0; i < 24; i++)
475 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
476 gmtflags |= 1L<<i;
477 } while (cflags & gmtflags);
478 if (gmtflags & MODFLGS)
479 fprintf(stderr,
480 "%s: warning - some moderate colors are out of gamut\n",
481 progname);
482 }
483
484
485 putmapping() /* put out color mapping */
486 {
487 static char cchar[3] = {'r', 'g', 'b'};
488 register int i, j;
489 /* print brightness mapping */
490 for (j = 0; j < 3; j++) {
491 printf("%cxa(i) : select(i", cchar[j]);
492 for (i = 0; i < NMBNEU; i++)
493 printf(",%g", colval(bramp[i][0],j));
494 printf(");\n");
495 printf("%cya(i) : select(i", cchar[j]);
496 for (i = 0; i < NMBNEU; i++)
497 printf(",%g", colval(bramp[i][1],j));
498 printf(");\n");
499 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
500 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
501 cchar[j], cchar[j]);
502 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
503 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
504 cchar[j], scanning?'n':'o', cchar[j],
505 cchar[j], cchar[j], cchar[j], cchar[j]);
506 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
507 cchar[j], cchar[j], cchar[j],
508 cchar[j], cchar[j]);
509 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
510 cchar[j], cchar[j], cchar[j], cchar[j]);
511 }
512 /* print color mapping */
513 if (scanning) {
514 printf("r = ri(1); g = gi(1); b = bi(1);\n");
515 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
516 solmat[0][0], solmat[0][1], solmat[0][2]);
517 printf("go = %g*rn + %g*gn + %g*bn ;\n",
518 solmat[1][0], solmat[1][1], solmat[1][2]);
519 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
520 solmat[2][0], solmat[2][1], solmat[2][2]);
521 } else {
522 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
523 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
524 solmat[0][0], solmat[0][1], solmat[0][2]);
525 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
526 solmat[1][0], solmat[1][1], solmat[1][2]);
527 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
528 solmat[2][0], solmat[2][1], solmat[2][2]);
529 }
530 }
531
532
533 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
534 COLOR cin[], cout[];
535 int n;
536 {
537 extern double mx3d_adjoint(), fabs();
538 double mat[3][3], invmat[3][3];
539 double det;
540 double colv[3], rowv[3];
541 register int i, j, k;
542
543 if (n < 3) {
544 fprintf(stderr, "%s: too few colors to match!\n", progname);
545 exit(1);
546 }
547 if (n == 3)
548 for (i = 0; i < 3; i++)
549 for (j = 0; j < 3; j++)
550 mat[i][j] = colval(cin[j],i);
551 else { /* compute A^t A */
552 for (i = 0; i < 3; i++)
553 for (j = i; j < 3; j++) {
554 mat[i][j] = 0.;
555 for (k = 0; k < n; k++)
556 mat[i][j] += colval(cin[k],i) *
557 colval(cin[k],j);
558 }
559 for (i = 1; i < 3; i++) /* using symmetry */
560 for (j = 0; j < i; j++)
561 mat[i][j] = mat[j][i];
562 }
563 det = mx3d_adjoint(mat, invmat);
564 if (fabs(det) < 1e-4) {
565 fprintf(stderr, "%s: cannot compute color mapping\n",
566 progname);
567 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
568 solmat[0][1] = solmat[0][2] = solmat[1][0] =
569 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
570 return;
571 }
572 for (i = 0; i < 3; i++)
573 for (j = 0; j < 3; j++)
574 invmat[i][j] /= det;
575 for (i = 0; i < 3; i++) {
576 if (n == 3)
577 for (j = 0; j < 3; j++)
578 colv[j] = colval(cout[j],i);
579 else
580 for (j = 0; j < 3; j++) {
581 colv[j] = 0.;
582 for (k = 0; k < n; k++)
583 colv[j] += colval(cout[k],i) *
584 colval(cin[k],j);
585 }
586 mx3d_transform(colv, invmat, rowv);
587 for (j = 0; j < 3; j++)
588 solmat[i][j] = rowv[j];
589 }
590 }
591
592
593 cwarp() /* compute color warp map */
594 {
595 register int i;
596
597 if ((wcor = new3dw(W3EXACT)) == NULL)
598 goto memerr;
599 for (i = 0; i < 24; i++)
600 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
601 goto memerr;
602 return;
603 memerr:
604 perror(progname);
605 exit(1);
606 }
607
608
609 int
610 cvtcolor(cout, cin) /* convert color according to our mapping */
611 COLOR cout, cin;
612 {
613 COLOR ctmp;
614 int clipped;
615
616 if (wcor != NULL) {
617 clipped = warp3d(cout, cin, wcor);
618 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
619 } else if (scanning) {
620 bresp(ctmp, cin);
621 clipped = cresp(cout, ctmp);
622 } else {
623 clipped = cresp(ctmp, cin);
624 bresp(cout, ctmp);
625 }
626 return(clipped);
627 }
628
629
630 int
631 cresp(cout, cin) /* transform color according to matrix */
632 COLOR cout, cin;
633 {
634 colortrans(cout, solmat, cin);
635 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
636 }
637
638
639 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
640 COLOR rgbout;
641 register float xyYin[3];
642 {
643 COLOR ctmp;
644 double d;
645
646 d = xyYin[2] / xyYin[1];
647 ctmp[0] = xyYin[0] * d;
648 ctmp[1] = xyYin[2];
649 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
650 /* allow negative values */
651 colortrans(rgbout, xyz2rgbmat, ctmp);
652 }
653
654
655 picdebug() /* put out debugging picture */
656 {
657 static COLOR blkcol = BLKCOLOR;
658 COLOR *scan;
659 int y, i;
660 register int x, rg;
661
662 if (fseek(stdin, 0L, 0) == EOF) {
663 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
664 exit(1);
665 }
666 getheader(stdin, NULL, NULL); /* skip input header */
667 fgetresolu(&xmax, &ymax, stdin);
668 /* allocate scanline */
669 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
670 if (scan == NULL) {
671 perror(progname);
672 exit(1);
673 }
674 /* finish debug header */
675 fputformat(COLRFMT, debugfp);
676 putc('\n', debugfp);
677 fprtresolu(xmax, ymax, debugfp);
678 /* write debug picture */
679 for (y = ymax-1; y >= 0; y--) {
680 if (freadscan(scan, xmax, stdin) < 0) {
681 fprintf(stderr, "%s: error rereading input picture\n",
682 progname);
683 exit(1);
684 }
685 for (x = 0; x < xmax; x++) {
686 rg = chartndx(x, y, &i);
687 if (rg == RG_CENT) {
688 if (!(1L<<i & gmtflags) || (x+y)&07) {
689 copycolor(scan[x], mbRGB[i]);
690 clipgamut(scan[x], bright(scan[x]),
691 CGAMUT, colmin, colmax);
692 } else
693 copycolor(scan[x], blkcol);
694 } else if (rg == RG_CORR)
695 cvtcolor(scan[x], scan[x]);
696 else if (rg != RG_ORIG)
697 copycolor(scan[x], blkcol);
698 }
699 if (fwritescan(scan, xmax, debugfp) < 0) {
700 fprintf(stderr, "%s: error writing debugging picture\n",
701 progname);
702 exit(1);
703 }
704 }
705 /* clean up */
706 fclose(debugfp);
707 free((void *)scan);
708 }
709
710
711 clrdebug() /* put out debug picture from color input */
712 {
713 static COLR blkclr = BLKCOLR;
714 COLR mbclr[24], cvclr[24], orclr[24];
715 COLR *scan;
716 COLOR ctmp, ct2;
717 int y, i;
718 register int x, rg;
719 /* convert colors */
720 for (i = 0; i < 24; i++) {
721 copycolor(ctmp, mbRGB[i]);
722 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
723 setcolr(mbclr[i], colval(ctmp,RED),
724 colval(ctmp,GRN), colval(ctmp,BLU));
725 if (inpflags & 1L<<i) {
726 copycolor(ctmp, inpRGB[i]);
727 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
728 setcolr(orclr[i], colval(ctmp,RED),
729 colval(ctmp,GRN), colval(ctmp,BLU));
730 if (rawmap)
731 copycolr(cvclr[i], mbclr[i]);
732 else {
733 bresp(ctmp, inpRGB[i]);
734 colortrans(ct2, solmat, ctmp);
735 clipgamut(ct2, bright(ct2), CGAMUT,
736 cblack, cwhite);
737 setcolr(cvclr[i], colval(ct2,RED),
738 colval(ct2,GRN),
739 colval(ct2,BLU));
740 }
741 }
742 }
743 /* allocate scanline */
744 scan = (COLR *)malloc(xmax*sizeof(COLR));
745 if (scan == NULL) {
746 perror(progname);
747 exit(1);
748 }
749 /* finish debug header */
750 fputformat(COLRFMT, debugfp);
751 putc('\n', debugfp);
752 fprtresolu(xmax, ymax, debugfp);
753 /* write debug picture */
754 for (y = ymax-1; y >= 0; y--) {
755 for (x = 0; x < xmax; x++) {
756 rg = chartndx(x, y, &i);
757 if (rg == RG_CENT) {
758 if (!(1L<<i & gmtflags) || (x+y)&07)
759 copycolr(scan[x], mbclr[i]);
760 else
761 copycolr(scan[x], blkclr);
762 } else if (rg == RG_BORD || !(1L<<i & inpflags))
763 copycolr(scan[x], blkclr);
764 else if (rg == RG_ORIG)
765 copycolr(scan[x], orclr[i]);
766 else /* rg == RG_CORR */
767 copycolr(scan[x], cvclr[i]);
768 }
769 if (fwritecolrs(scan, xmax, debugfp) < 0) {
770 fprintf(stderr, "%s: error writing debugging picture\n",
771 progname);
772 exit(1);
773 }
774 }
775 /* clean up */
776 fclose(debugfp);
777 free((void *)scan);
778 }
779
780
781 getpos(name, bnds, fp) /* get boundary position */
782 char *name;
783 int bnds[2];
784 FILE *fp;
785 {
786 char buf[64];
787
788 fprintf(stderr, "\tSelect corner: %s\n", name);
789 if (fgets(buf, sizeof(buf), fp) == NULL ||
790 sscanf(buf, "%d %d", &bnds[0], &bnds[1]) != 2) {
791 fprintf(stderr, "%s: read error from display process\n",
792 progname);
793 exit(1);
794 }
795 }
796
797
798 pickchartpos(pfn) /* display picture and pick chart location */
799 char *pfn;
800 {
801 char combuf[512];
802 FILE *pfp;
803
804 sprintf(combuf, DISPCOM, pfn);
805 if ((pfp = popen(combuf, "r")) == NULL) {
806 perror(combuf);
807 exit(1);
808 }
809 fputs("Use middle mouse button to select chart corners:\n", stderr);
810 getpos("upper left (dark skin)", bounds[0], pfp);
811 getpos("upper right (bluish green)", bounds[1], pfp);
812 getpos("lower left (white)", bounds[2], pfp);
813 getpos("lower right (black)", bounds[3], pfp);
814 fputs("Got it -- quit display program.\n", stderr);
815 pclose(pfp);
816 }
