root/radiance/ray/src/px/macbethcal.c
Revision: 2.12
Committed: Thu Jan 30 19:14:11 1997 UTC (28 years, 4 months ago) by greg
Changes since 2.11: +5 -3 lines
changed colortrans() to optionally allow negative results
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb.
11 */
12
13 #include <stdio.h>
14 #ifdef MSDOS
15 #include <fcntl.h>
16 #endif
17 #include "color.h"
18 #include "resolu.h"
19 #include "pmap.h"
20
21 /* MacBeth colors */
22 #define DarkSkin 0
23 #define LightSkin 1
24 #define BlueSky 2
25 #define Foliage 3
26 #define BlueFlower 4
27 #define BluishGreen 5
28 #define Orange 6
29 #define PurplishBlue 7
30 #define ModerateRed 8
31 #define Purple 9
32 #define YellowGreen 10
33 #define OrangeYellow 11
34 #define Blue 12
35 #define Green 13
36 #define Red 14
37 #define Yellow 15
38 #define Magenta 16
39 #define Cyan 17
40 #define White 18
41 #define Neutral8 19
42 #define Neutral65 20
43 #define Neutral5 21
44 #define Neutral35 22
45 #define Black 23
46 /* computed from 5nm spectral measurements */
47 /* CIE 1931 2 degree obs, equal-energy white */
48 float mbxyY[24][3] = {
49 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
50 {0.4108, 0.3542, 0.410348}, /* LightSkin */
51 {0.2626, 0.267, 0.181554}, /* BlueSky */
52 {0.36, 0.4689, 0.108447}, /* Foliage */
53 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
54 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
55 {0.52, 0.4197, 0.357899}, /* Orange */
56 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
57 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
58 {0.3361, 0.2249, 0.0600102}, /* Purple */
59 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
60 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
61 {0.2026, 0.1369, 0.0529249}, /* Blue */
62 {0.3007, 0.4822, 0.221226}, /* Green */
63 {0.5805, 0.3238, 0.162167}, /* Red */
64 {0.4617, 0.472, 0.64909}, /* Yellow */
65 {0.4178, 0.2625, 0.233662}, /* Magenta */
66 {0.2038, 0.2508, 0.167275}, /* Cyan */
67 {0.3358, 0.337, 0.916877}, /* White */
68 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
69 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
70 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
71 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
72 {0.3346, 0.3349, 0.0308383} /* Black */
73 };
74
75 COLOR mbRGB[24]; /* MacBeth RGB values */
76
77 #define NMBNEU 6 /* Number of MacBeth neutral colors */
78 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
79
80 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
81 1L<<Neutral5|1L<<Neutral35|1L<<Black)
82
83 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
84 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
85 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
86
87 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
88 1L<<BluishGreen|1L<<ModerateRed)
89
90 #define REQFLGS NEUFLGS /* need these colors */
91 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
92
93 #define RG_BORD 0 /* patch border */
94 #define RG_CENT 01 /* central region of patch */
95 #define RG_ORIG 02 /* original color region */
96 #define RG_CORR 04 /* corrected color region */
97
98 int scanning = 1; /* scanned input (or recorded output)? */
99
100 int xmax, ymax; /* input image dimensions */
101 int bounds[4][2]; /* image coordinates of chart corners */
102 double imgxfm[3][3]; /* coordinate transformation matrix */
103
104 COLOR inpRGB[24]; /* measured or scanned input colors */
105 long inpflags = 0; /* flags of which colors were input */
106 long gmtflags = 0; /* flags of out-of-gamut colors */
107
108 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
109 double solmat[3][3]; /* color mapping matrix */
110
111 FILE *debugfp = NULL; /* debug output picture */
112 char *progname;
113
114 extern char *malloc();
115
116
117 main(argc, argv)
118 int argc;
119 char **argv;
120 {
121 int i;
122
123 progname = argv[0];
124 for (i = 1; i < argc && argv[i][0] == '-'; i++)
125 switch (argv[i][1]) {
126 case 'd': /* debug output */
127 i++;
128 if (badarg(argc-i, argv+i, "s"))
129 goto userr;
130 if ((debugfp = fopen(argv[i], "w")) == NULL) {
131 perror(argv[i]);
132 exit(1);
133 }
134 #ifdef MSDOS
135 setmode(fileno(debugfp), O_BINARY);
136 #endif
137 newheader("RADIANCE", debugfp); /* start */
138 printargs(argc, argv, debugfp); /* header */
139 break;
140 case 'p': /* picture position */
141 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
142 goto userr;
143 bounds[0][0] = atoi(argv[++i]);
144 bounds[0][1] = atoi(argv[++i]);
145 bounds[1][0] = atoi(argv[++i]);
146 bounds[1][1] = atoi(argv[++i]);
147 bounds[2][0] = atoi(argv[++i]);
148 bounds[2][1] = atoi(argv[++i]);
149 bounds[3][0] = atoi(argv[++i]);
150 bounds[3][1] = atoi(argv[++i]);
151 scanning = 2;
152 break;
153 case 'c': /* color input */
154 scanning = 0;
155 break;
156 default:
157 goto userr;
158 }
159 /* open files */
160 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
161 perror(argv[1]);
162 exit(1);
163 }
164 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
165 perror(argv[2]);
166 exit(1);
167 }
168 if (scanning) { /* load input picture header */
169 #ifdef MSDOS
170 setmode(fileno(stdin), O_BINARY);
171 #endif
172 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
173 fgetresolu(&xmax, &ymax, stdin) < 0) {
174 fprintf(stderr, "%s: bad input picture\n", progname);
175 exit(1);
176 }
177 } else { /* else set default xmax and ymax */
178 xmax = 512;
179 ymax = 2*512/3;
180 }
181 if (scanning != 2) { /* use default boundaries */
182 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
183 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
184 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
185 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
186 }
187 init(); /* initialize */
188 if (scanning) /* get picture colors */
189 getpicture();
190 else
191 getcolors();
192 compute(); /* compute color mapping */
193 /* print comment */
194 printf("{\n\tColor correction file computed by:\n\t\t");
195 printargs(argc, argv, stdout);
196 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
197 i+1 < argc ? argv[i+1] : "{this_file}");
198 if (!scanning)
199 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
200 i+1 < argc ? argv[i+1] : "{this_file}");
201 printf("}\n");
202 putmapping(); /* put out color mapping */
203 if (debugfp != NULL) /* put out debug picture */
204 if (scanning)
205 picdebug();
206 else
207 clrdebug();
208 exit(0);
209 userr:
210 fprintf(stderr,
211 "Usage: %s [-d dbg.pic][-p xul yul xur yur xll yll xlr ylr] input.pic [output.cal]\n",
212 progname);
213 fprintf(stderr, " or: %s [-d dbg.pic] -c [xyY.dat [output.cal]]\n",
214 progname);
215 exit(1);
216 }
217
218
219 init() /* initialize */
220 {
221 double quad[4][2];
222 register int i;
223 /* make coordinate transformation */
224 quad[0][0] = bounds[0][0];
225 quad[0][1] = bounds[0][1];
226 quad[1][0] = bounds[1][0];
227 quad[1][1] = bounds[1][1];
228 quad[2][0] = bounds[3][0];
229 quad[2][1] = bounds[3][1];
230 quad[3][0] = bounds[2][0];
231 quad[3][1] = bounds[2][1];
232
233 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
234 fprintf(stderr, "%s: bad chart boundaries\n", progname);
235 exit(1);
236 }
237 /* map MacBeth colors to RGB space */
238 for (i = 0; i < 24; i++)
239 xyY2RGB(mbRGB[i], mbxyY[i]);
240 }
241
242
243 int
244 chartndx(x, y, np) /* find color number for position */
245 int x, y;
246 int *np;
247 {
248 double ipos[3], cpos[3];
249 int ix, iy;
250 double fx, fy;
251
252 ipos[0] = x;
253 ipos[1] = y;
254 ipos[2] = 1;
255 mx3d_transform(ipos, imgxfm, cpos);
256 cpos[0] /= cpos[2];
257 cpos[1] /= cpos[2];
258 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
259 return(RG_BORD);
260 ix = cpos[0];
261 iy = cpos[1];
262 fx = cpos[0] - ix;
263 fy = cpos[1] - iy;
264 *np = iy*6 + ix;
265 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
266 return(RG_CENT);
267 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
268 return(RG_BORD);
269 if (fx >= 0.5) /* right side is corrected */
270 return(RG_CORR);
271 return(RG_ORIG); /* left side is original */
272 }
273
274
275 getpicture() /* load in picture colors */
276 {
277 COLR *scanln;
278 COLOR pval;
279 int ccount[24];
280 double d;
281 int y, i;
282 register int x;
283
284 scanln = (COLR *)malloc(xmax*sizeof(COLR));
285 if (scanln == NULL) {
286 perror(progname);
287 exit(1);
288 }
289 for (i = 0; i < 24; i++) {
290 setcolor(inpRGB[i], 0., 0., 0.);
291 ccount[i] = 0;
292 }
293 for (y = ymax-1; y >= 0; y--) {
294 if (freadcolrs(scanln, xmax, stdin) < 0) {
295 fprintf(stderr, "%s: error reading input picture\n",
296 progname);
297 exit(1);
298 }
299 for (x = 0; x < xmax; x++)
300 if (chartndx(x, y, &i) == RG_CENT) {
301 colr_color(pval, scanln[x]);
302 addcolor(inpRGB[i], pval);
303 ccount[i]++;
304 }
305 }
306 for (i = 0; i < 24; i++) { /* compute averages */
307 if (ccount[i] == 0)
308 continue;
309 d = 1./ccount[i];
310 scalecolor(inpRGB[i], d);
311 inpflags |= 1L<<i;
312 }
313 free((char *)scanln);
314 }
315
316
317 getcolors() /* get xyY colors from standard input */
318 {
319 int gotwhite = 0;
320 COLOR whiteclr;
321 int n;
322 float xyYin[3];
323
324 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
325 if (n < 0 | n > 24 ||
326 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
327 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
328 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
329 xyYin[0] < 0. | xyYin[1] < 0. ||
330 xyYin[0] + xyYin[1] > 1.) {
331 fprintf(stderr, "%s: bad color input data\n",
332 progname);
333 exit(1);
334 }
335 if (n == 0) { /* calibration white */
336 xyY2RGB(whiteclr, xyYin);
337 gotwhite++;
338 } else { /* standard color */
339 n--;
340 xyY2RGB(inpRGB[n], xyYin);
341 inpflags |= 1L<<n;
342 }
343 }
344 /* normalize colors */
345 if (!gotwhite) {
346 if (!(inpflags & 1L<<White)) {
347 fprintf(stderr, "%s: missing input for White\n",
348 progname);
349 exit(1);
350 }
351 setcolor(whiteclr,
352 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
353 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
354 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
355 }
356 for (n = 0; n < 24; n++)
357 if (inpflags & 1L<<n)
358 setcolor(inpRGB[n],
359 colval(inpRGB[n],RED)/colval(whiteclr,RED),
360 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
361 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
362 }
363
364
365 bresp(y, x) /* piecewise linear interpolation of primaries */
366 COLOR y, x;
367 {
368 register int i, n;
369
370 for (i = 0; i < 3; i++) {
371 for (n = 0; n < NMBNEU-2; n++)
372 if (colval(x,i) < colval(bramp[n+1][0],i))
373 break;
374 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
375 colval(bramp[n][1],i) +
376 (colval(x,i) - colval(bramp[n][0],i)) *
377 colval(bramp[n+1][1],i)) /
378 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
379 }
380 }
381
382
383 compute() /* compute color mapping */
384 {
385 COLOR clrin[24], clrout[24];
386 long cflags;
387 COLOR ctmp;
388 register int i, j, n;
389 /* did we get what we need? */
390 if ((inpflags & REQFLGS) != REQFLGS) {
391 fprintf(stderr, "%s: missing required input colors\n",
392 progname);
393 exit(1);
394 }
395 /* compute piecewise luminance curve */
396 for (i = 0; i < NMBNEU; i++) {
397 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
398 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
399 }
400 /* compute color mapping */
401 do {
402 cflags = inpflags & ~gmtflags;
403 n = 0; /* compute transform matrix */
404 for (i = 0; i < 24; i++)
405 if (cflags & 1L<<i) {
406 bresp(clrin[n], inpRGB[i]);
407 copycolor(clrout[n], mbRGB[i]);
408 n++;
409 }
410 compsoln(clrin, clrout, n);
411 /* check out-of-gamut colors */
412 for (i = 0; i < 24; i++)
413 if (cflags & 1L<<i) {
414 cvtcolor(ctmp, mbRGB[i]);
415 for (j = 0; j < 3; j++)
416 if (colval(ctmp,j) <= 1e-6 ||
417 colval(ctmp,j) >= 1.-1e-6) {
418 gmtflags |= 1L<<i;
419 break;
420 }
421 }
422 } while (cflags & gmtflags);
423 if (gmtflags & MODFLGS)
424 fprintf(stderr,
425 "%s: warning - some moderate colors are out of gamut\n",
426 progname);
427 }
428
429
430 putmapping() /* put out color mapping for pcomb -f */
431 {
432 static char cchar[3] = {'r', 'g', 'b'};
433 register int i, j;
434 /* print brightness mapping */
435 for (j = 0; j < 3; j++) {
436 printf("%cxa(i) : select(i", cchar[j]);
437 for (i = 0; i < NMBNEU; i++)
438 printf(",%g", colval(bramp[i][0],j));
439 printf(");\n");
440 printf("%cya(i) : select(i", cchar[j]);
441 for (i = 0; i < NMBNEU; i++)
442 printf(",%g", colval(bramp[i][1],j));
443 printf(");\n");
444 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
445 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
446 cchar[j], cchar[j]);
447 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
448 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
449 cchar[j], scanning?'n':'o', cchar[j],
450 cchar[j], cchar[j], cchar[j], cchar[j]);
451 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
452 cchar[j], cchar[j], cchar[j],
453 cchar[j], cchar[j]);
454 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
455 cchar[j], cchar[j], cchar[j], cchar[j]);
456 }
457 /* print color mapping */
458 if (scanning) {
459 printf("r = ri(1); g = gi(1); b = bi(1);\n");
460 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
461 solmat[0][0], solmat[0][1], solmat[0][2]);
462 printf("go = %g*rn + %g*gn + %g*bn ;\n",
463 solmat[1][0], solmat[1][1], solmat[1][2]);
464 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
465 solmat[2][0], solmat[2][1], solmat[2][2]);
466 } else {
467 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
468 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
469 solmat[0][0], solmat[0][1], solmat[0][2]);
470 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
471 solmat[1][0], solmat[1][1], solmat[1][2]);
472 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
473 solmat[2][0], solmat[2][1], solmat[2][2]);
474 }
475 }
476
477
478 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
479 COLOR cin[], cout[];
480 int n;
481 {
482 extern double mx3d_adjoint(), fabs();
483 double mat[3][3], invmat[3][3];
484 double det;
485 double colv[3], rowv[3];
486 register int i, j, k;
487
488 if (n < 3) {
489 fprintf(stderr, "%s: too few colors to match!\n", progname);
490 exit(1);
491 }
492 if (n == 3)
493 for (i = 0; i < 3; i++)
494 for (j = 0; j < 3; j++)
495 mat[i][j] = colval(cin[j],i);
496 else { /* compute A^t A */
497 for (i = 0; i < 3; i++)
498 for (j = i; j < 3; j++) {
499 mat[i][j] = 0.;
500 for (k = 0; k < n; k++)
501 mat[i][j] += colval(cin[k],i) *
502 colval(cin[k],j);
503 }
504 for (i = 1; i < 3; i++) /* using symmetry */
505 for (j = 0; j < i; j++)
506 mat[i][j] = mat[j][i];
507 }
508 det = mx3d_adjoint(mat, invmat);
509 if (fabs(det) < 1e-4) {
510 fprintf(stderr, "%s: cannot compute color mapping\n",
511 progname);
512 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
513 solmat[0][1] = solmat[0][2] = solmat[1][0] =
514 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
515 return;
516 }
517 for (i = 0; i < 3; i++)
518 for (j = 0; j < 3; j++)
519 invmat[i][j] /= det;
520 for (i = 0; i < 3; i++) {
521 if (n == 3)
522 for (j = 0; j < 3; j++)
523 colv[j] = colval(cout[j],i);
524 else
525 for (j = 0; j < 3; j++) {
526 colv[j] = 0.;
527 for (k = 0; k < n; k++)
528 colv[j] += colval(cout[k],i) *
529 colval(cin[k],j);
530 }
531 mx3d_transform(colv, invmat, rowv);
532 for (j = 0; j < 3; j++)
533 solmat[i][j] = rowv[j];
534 }
535 }
536
537
538 cvtcolor(cout, cin) /* convert color according to our mapping */
539 COLOR cout, cin;
540 {
541 COLOR ctmp;
542
543 if (scanning) {
544 bresp(ctmp, cin);
545 cresp(cout, ctmp);
546 } else {
547 cresp(ctmp, cin);
548 bresp(cout, ctmp);
549 }
550 if (colval(cout,RED) < 0.)
551 colval(cout,RED) = 0.;
552 if (colval(cout,GRN) < 0.)
553 colval(cout,GRN) = 0.;
554 if (colval(cout,BLU) < 0.)
555 colval(cout,BLU) = 0.;
556 }
557
558
559 cresp(cout, cin) /* transform color according to matrix */
560 COLOR cout, cin;
561 {
562 double r, g, b;
563
564 r = colval(cin,0)*solmat[0][0] + colval(cin,1)*solmat[0][1]
565 + colval(cin,2)*solmat[0][2];
566 g = colval(cin,0)*solmat[1][0] + colval(cin,1)*solmat[1][1]
567 + colval(cin,2)*solmat[1][2];
568 b = colval(cin,0)*solmat[2][0] + colval(cin,1)*solmat[2][1]
569 + colval(cin,2)*solmat[2][2];
570 setcolor(cout, r, g, b);
571 }
572
573
574 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
575 COLOR rgbout;
576 register float xyYin[3];
577 {
578 COLOR ctmp;
579 double d;
580
581 d = xyYin[2] / xyYin[1];
582 ctmp[0] = xyYin[0] * d;
583 ctmp[1] = xyYin[2];
584 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
585 cie_rgb(rgbout, ctmp);
586 /* allow negative values */
587 colortrans(rgbout, xyz2rgbmat, ctmp, 0);
588 }
589
590
591 picdebug() /* put out debugging picture */
592 {
593 static COLOR blkcol = BLKCOLOR;
594 COLOR *scan;
595 int y, i;
596 register int x, rg;
597
598 if (fseek(stdin, 0L, 0) == EOF) {
599 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
600 exit(1);
601 }
602 getheader(stdin, NULL, NULL); /* skip input header */
603 fgetresolu(&xmax, &ymax, stdin);
604 /* allocate scanline */
605 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
606 if (scan == NULL) {
607 perror(progname);
608 exit(1);
609 }
610 /* finish debug header */
611 fputformat(COLRFMT, debugfp);
612 putc('\n', debugfp);
613 fprtresolu(xmax, ymax, debugfp);
614 /* write debug picture */
615 for (y = ymax-1; y >= 0; y--) {
616 if (freadscan(scan, xmax, stdin) < 0) {
617 fprintf(stderr, "%s: error rereading input picture\n",
618 progname);
619 exit(1);
620 }
621 for (x = 0; x < xmax; x++) {
622 rg = chartndx(x, y, &i);
623 if (rg == RG_CENT) {
624 if (!(1L<<i & gmtflags) || (x+y)&07)
625 copycolor(scan[x], mbRGB[i]);
626 else
627 copycolor(scan[x], blkcol);
628 } else if (rg == RG_CORR)
629 cvtcolor(scan[x], scan[x]);
630 else if (rg != RG_ORIG)
631 copycolor(scan[x], blkcol);
632 }
633 if (fwritescan(scan, xmax, debugfp) < 0) {
634 fprintf(stderr, "%s: error writing debugging picture\n",
635 progname);
636 exit(1);
637 }
638 }
639 /* clean up */
640 fclose(debugfp);
641 free((char *)scan);
642 }
643
644
645 clrdebug() /* put out debug picture from color input */
646 {
647 static COLR blkclr = BLKCOLR;
648 COLR mbclr[24], cvclr[24], orclr[24];
649 COLR *scan;
650 COLOR ctmp;
651 int y, i;
652 register int x, rg;
653 /* convert colors */
654 for (i = 0; i < 24; i++) {
655 setcolr(mbclr[i], colval(mbRGB[i],RED),
656 colval(mbRGB[i],GRN), colval(mbRGB[i],BLU));
657 if (inpflags & 1L<<i) {
658 setcolr(orclr[i], colval(inpRGB[i],RED),
659 colval(inpRGB[i],GRN),
660 colval(inpRGB[i],BLU));
661 cvtcolor(ctmp, inpRGB[i]);
662 setcolr(cvclr[i], colval(ctmp,RED),
663 colval(ctmp,GRN), colval(ctmp,BLU));
664 }
665 }
666 /* allocate scanline */
667 scan = (COLR *)malloc(xmax*sizeof(COLR));
668 if (scan == NULL) {
669 perror(progname);
670 exit(1);
671 }
672 /* finish debug header */
673 fputformat(COLRFMT, debugfp);
674 putc('\n', debugfp);
675 fprtresolu(xmax, ymax, debugfp);
676 /* write debug picture */
677 for (y = ymax-1; y >= 0; y--) {
678 for (x = 0; x < xmax; x++) {
679 rg = chartndx(x, y, &i);
680 if (rg == RG_CENT) {
681 if (!(1L<<i & gmtflags) || (x+y)&07)
682 copycolr(scan[x], mbclr[i]);
683 else
684 copycolr(scan[x], blkclr);
685 } else if (rg == RG_BORD || !(1L<<i & inpflags))
686 copycolr(scan[x], blkclr);
687 else if (rg == RG_ORIG)
688 copycolr(scan[x], orclr[i]);
689 else /* rg == RG_CORR */
690 copycolr(scan[x], cvclr[i]);
691 }
692 if (fwritecolrs(scan, xmax, debugfp) < 0) {
693 fprintf(stderr, "%s: error writing debugging picture\n",
694 progname);
695 exit(1);
696 }
697 }
698 /* clean up */
699 fclose(debugfp);
700 free((char *)scan);
701 }
