root/radiance/ray/src/px/macbethcal.c
Revision: 2.15
Committed: Thu Feb 6 11:36:53 1997 UTC (27 years, 4 months ago) by greg
minor correction in usage message
1 /* Copyright (c) 1997 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Calibrate a scanned MacBeth Color Checker Chart
9 *
10 * Produce a .cal file suitable for use with pcomb,
11 * or .cwp file suitable for use with pcwarp.
12 *
13 * Warping code depends on conformance of COLOR and W3VEC types.
14 */
15
16 #include <stdio.h>
17 #include <math.h>
18 #ifdef MSDOS
19 #include <fcntl.h>
20 #endif
21 #include "color.h"
22 #include "resolu.h"
23 #include "pmap.h"
24 #include "warp3d.h"
25
26 /* MacBeth colors */
27 #define DarkSkin 0
28 #define LightSkin 1
29 #define BlueSky 2
30 #define Foliage 3
31 #define BlueFlower 4
32 #define BluishGreen 5
33 #define Orange 6
34 #define PurplishBlue 7
35 #define ModerateRed 8
36 #define Purple 9
37 #define YellowGreen 10
38 #define OrangeYellow 11
39 #define Blue 12
40 #define Green 13
41 #define Red 14
42 #define Yellow 15
43 #define Magenta 16
44 #define Cyan 17
45 #define White 18
46 #define Neutral8 19
47 #define Neutral65 20
48 #define Neutral5 21
49 #define Neutral35 22
50 #define Black 23
51 /* computed from 5nm spectral measurements */
52 /* CIE 1931 2 degree obs, equal-energy white */
53 float mbxyY[24][3] = {
54 {0.462, 0.3769, 0.0932961}, /* DarkSkin */
55 {0.4108, 0.3542, 0.410348}, /* LightSkin */
56 {0.2626, 0.267, 0.181554}, /* BlueSky */
57 {0.36, 0.4689, 0.108447}, /* Foliage */
58 {0.2977, 0.2602, 0.248407}, /* BlueFlower */
59 {0.2719, 0.3485, 0.401156}, /* BluishGreen */
60 {0.52, 0.4197, 0.357899}, /* Orange */
61 {0.229, 0.1866, 0.103911}, /* PurplishBlue */
62 {0.4909, 0.3262, 0.242615}, /* ModerateRed */
63 {0.3361, 0.2249, 0.0600102}, /* Purple */
64 {0.3855, 0.4874, 0.42963}, /* YellowGreen */
65 {0.4853, 0.4457, 0.476343}, /* OrangeYellow */
66 {0.2026, 0.1369, 0.0529249}, /* Blue */
67 {0.3007, 0.4822, 0.221226}, /* Green */
68 {0.5805, 0.3238, 0.162167}, /* Red */
69 {0.4617, 0.472, 0.64909}, /* Yellow */
70 {0.4178, 0.2625, 0.233662}, /* Magenta */
71 {0.2038, 0.2508, 0.167275}, /* Cyan */
72 {0.3358, 0.337, 0.916877}, /* White */
73 {0.3338, 0.3348, 0.604678}, /* Neutral.8 */
74 {0.3333, 0.3349, 0.364566}, /* Neutral.65 */
75 {0.3353, 0.3359, 0.200238}, /* Neutral.5 */
76 {0.3363, 0.336, 0.0878721}, /* Neutral.35 */
77 {0.3346, 0.3349, 0.0308383} /* Black */
78 };
79
80 COLOR mbRGB[24]; /* MacBeth RGB values */
81
82 #define NMBNEU 6 /* Number of MacBeth neutral colors */
83 short mbneu[NMBNEU] = {Black,Neutral35,Neutral5,Neutral65,Neutral8,White};
84
85 #define NEUFLGS (1L<<White|1L<<Neutral8|1L<<Neutral65| \
86 1L<<Neutral5|1L<<Neutral35|1L<<Black)
87
88 #define SATFLGS (1L<<Red|1L<<Green|1L<<Blue|1L<<Magenta|1L<<Yellow| \
89 1L<<Cyan|1L<<Orange|1L<<Purple|1L<<PurplishBlue| \
90 1L<<YellowGreen|1<<OrangeYellow|1L<<BlueFlower)
91
92 #define UNSFLGS (1L<<DarkSkin|1L<<LightSkin|1L<<BlueSky|1L<<Foliage| \
93 1L<<BluishGreen|1L<<ModerateRed)
94
95 #define REQFLGS NEUFLGS /* need these colors */
96 #define MODFLGS (NEUFLGS|UNSFLGS) /* should be in gamut */
97
98 #define RG_BORD 0 /* patch border */
99 #define RG_CENT 01 /* central region of patch */
100 #define RG_ORIG 02 /* original color region */
101 #define RG_CORR 04 /* corrected color region */
102
103 int scanning = 1; /* scanned input (or recorded output)? */
104 double irrad = 1.0; /* irradiance multiplication factor */
105 int rawmap = 0; /* put out raw color mapping? */
106
107 int xmax, ymax; /* input image dimensions */
108 int bounds[4][2]; /* image coordinates of chart corners */
109 double imgxfm[3][3]; /* coordinate transformation matrix */
110
111 COLOR inpRGB[24]; /* measured or scanned input colors */
112 long inpflags = 0; /* flags of which colors were input */
113 long gmtflags = 0; /* flags of out-of-gamut colors */
114
115 COLOR bramp[NMBNEU][2]; /* brightness ramp (per primary) */
116 COLORMAT solmat; /* color mapping matrix */
117 COLOR colmin, colmax; /* gamut limits */
118
119 WARP3D *wcor = NULL; /* color space warp */
120
121 FILE *debugfp = NULL; /* debug output picture */
122 char *progname;
123
124 extern char *malloc();
125
126
127 main(argc, argv)
128 int argc;
129 char **argv;
130 {
131 int i;
132
133 progname = argv[0];
134 for (i = 1; i < argc && argv[i][0] == '-'; i++)
135 switch (argv[i][1]) {
136 case 'd': /* debug output */
137 i++;
138 if (badarg(argc-i, argv+i, "s"))
139 goto userr;
140 if ((debugfp = fopen(argv[i], "w")) == NULL) {
141 perror(argv[i]);
142 exit(1);
143 }
144 #ifdef MSDOS
145 setmode(fileno(debugfp), O_BINARY);
146 #endif
147 newheader("RADIANCE", debugfp); /* start */
148 printargs(argc, argv, debugfp); /* header */
149 break;
150 case 'p': /* picture position */
151 if (badarg(argc-i-1, argv+i+1, "iiiiiiii"))
152 goto userr;
153 bounds[0][0] = atoi(argv[++i]);
154 bounds[0][1] = atoi(argv[++i]);
155 bounds[1][0] = atoi(argv[++i]);
156 bounds[1][1] = atoi(argv[++i]);
157 bounds[2][0] = atoi(argv[++i]);
158 bounds[2][1] = atoi(argv[++i]);
159 bounds[3][0] = atoi(argv[++i]);
160 bounds[3][1] = atoi(argv[++i]);
161 scanning = 2;
162 break;
163 case 'i': /* irradiance factor */
164 i++;
165 if (badarg(argc-i, argv+i, "f"))
166 goto userr;
167 irrad = atof(argv[i]);
168 break;
169 case 'm': /* raw map output */
170 rawmap = 1;
171 break;
172 case 'c': /* color input */
173 scanning = 0;
174 break;
175 default:
176 goto userr;
177 }
178 /* open files */
179 if (i < argc && freopen(argv[i], "r", stdin) == NULL) {
180 perror(argv[i]);
181 exit(1);
182 }
183 if (i+1 < argc && freopen(argv[i+1], "w", stdout) == NULL) {
184 perror(argv[i+1]);
185 exit(1);
186 }
187 if (scanning) { /* load input picture header */
188 #ifdef MSDOS
189 setmode(fileno(stdin), O_BINARY);
190 #endif
191 if (checkheader(stdin, COLRFMT, NULL) < 0 ||
192 fgetresolu(&xmax, &ymax, stdin) < 0) {
193 fprintf(stderr, "%s: bad input picture\n", progname);
194 exit(1);
195 }
196 } else { /* else set default xmax and ymax */
197 xmax = 512;
198 ymax = 2*512/3;
199 }
200 if (scanning != 2) { /* use default boundaries */
201 bounds[0][0] = bounds[2][0] = .029*xmax + .5;
202 bounds[0][1] = bounds[1][1] = .956*ymax + .5;
203 bounds[1][0] = bounds[3][0] = .971*xmax + .5;
204 bounds[2][1] = bounds[3][1] = .056*ymax + .5;
205 }
206 init(); /* initialize */
207 if (scanning) /* get picture colors */
208 getpicture();
209 else
210 getcolors();
211 compute(); /* compute color mapping */
212 if (rawmap) { /* print out raw correspondence */
213 register int j;
214
215 printf("# Color correspondence produced by:\n#\t\t");
216 printargs(argc, argv, stdout);
217 printf("#\tUsage: pcwarp %s uncorrected.pic > corrected.pic\n",
218 i+1 < argc ? argv[i+1] : "{this_file}");
219 printf("#\t Or: pcond [options] -m %s orig.pic > output.pic\n",
220 i+1 < argc ? argv[i+1] : "{this_file}");
221 for (j = 0; j < 24; j++)
222 printf("%f %f %f %f %f %f\n",
223 colval(inpRGB[j],RED), colval(inpRGB[j],GRN),
224 colval(inpRGB[j],BLU), colval(mbRGB[j],RED),
225 colval(mbRGB[j],GRN), colval(mbRGB[j],BLU));
226 if (scanning && debugfp != NULL)
227 cwarp(); /* color warp for debugging */
228 } else { /* print color mapping */
229 /* print header */
230 printf("{\n\tColor correction file computed by:\n\t\t");
231 printargs(argc, argv, stdout);
232 printf("\n\tUsage: pcomb -f %s uncorrected.pic > corrected.pic\n",
233 i+1 < argc ? argv[i+1] : "{this_file}");
234 if (!scanning)
235 printf("\t Or: pcond [options] -f %s orig.pic > output.pic\n",
236 i+1 < argc ? argv[i+1] : "{this_file}");
237 printf("}\n");
238 putmapping(); /* put out color mapping */
239 }
240 if (debugfp != NULL) /* put out debug picture */
241 if (scanning)
242 picdebug();
243 else
244 clrdebug();
245 exit(0);
246 userr:
247 fprintf(stderr,
248 "Usage: %s [-d dbg.pic][-p xul yul xur yur xll yll xlr ylr][-i irrad][-m] input.pic [output.{cal|cwp}]\n",
249 progname);
250 fprintf(stderr, " or: %s [-d dbg.pic][-i irrad][-m] -c [xyY.dat [output.{cal|cwp}]]\n",
251 progname);
252 exit(1);
253 }
254
255
256 init() /* initialize */
257 {
258 double quad[4][2];
259 register int i;
260 /* make coordinate transformation */
261 quad[0][0] = bounds[0][0];
262 quad[0][1] = bounds[0][1];
263 quad[1][0] = bounds[1][0];
264 quad[1][1] = bounds[1][1];
265 quad[2][0] = bounds[3][0];
266 quad[2][1] = bounds[3][1];
267 quad[3][0] = bounds[2][0];
268 quad[3][1] = bounds[2][1];
269
270 if (pmap_quad_rect(0., 0., 6., 4., quad, imgxfm) == PMAP_BAD) {
271 fprintf(stderr, "%s: bad chart boundaries\n", progname);
272 exit(1);
273 }
274 /* map MacBeth colors to RGB space */
275 for (i = 0; i < 24; i++) {
276 xyY2RGB(mbRGB[i], mbxyY[i]);
277 scalecolor(mbRGB[i], irrad);
278 }
279 }
280
281
282 int
283 chartndx(x, y, np) /* find color number for position */
284 int x, y;
285 int *np;
286 {
287 double ipos[3], cpos[3];
288 int ix, iy;
289 double fx, fy;
290
291 ipos[0] = x;
292 ipos[1] = y;
293 ipos[2] = 1;
294 mx3d_transform(ipos, imgxfm, cpos);
295 cpos[0] /= cpos[2];
296 cpos[1] /= cpos[2];
297 if (cpos[0] < 0. || cpos[0] >= 6. || cpos[1] < 0. || cpos[1] >= 4.)
298 return(RG_BORD);
299 ix = cpos[0];
300 iy = cpos[1];
301 fx = cpos[0] - ix;
302 fy = cpos[1] - iy;
303 *np = iy*6 + ix;
304 if (fx >= 0.35 && fx < 0.65 && fy >= 0.35 && fy < 0.65)
305 return(RG_CENT);
306 if (fx < 0.05 || fx >= 0.95 || fy < 0.05 || fy >= 0.95)
307 return(RG_BORD);
308 if (fx >= 0.5) /* right side is corrected */
309 return(RG_CORR);
310 return(RG_ORIG); /* left side is original */
311 }
312
313
314 getpicture() /* load in picture colors */
315 {
316 COLR *scanln;
317 COLOR pval;
318 int ccount[24];
319 double d;
320 int y, i;
321 register int x;
322
323 scanln = (COLR *)malloc(xmax*sizeof(COLR));
324 if (scanln == NULL) {
325 perror(progname);
326 exit(1);
327 }
328 for (i = 0; i < 24; i++) {
329 setcolor(inpRGB[i], 0., 0., 0.);
330 ccount[i] = 0;
331 }
332 for (y = ymax-1; y >= 0; y--) {
333 if (freadcolrs(scanln, xmax, stdin) < 0) {
334 fprintf(stderr, "%s: error reading input picture\n",
335 progname);
336 exit(1);
337 }
338 for (x = 0; x < xmax; x++)
339 if (chartndx(x, y, &i) == RG_CENT) {
340 colr_color(pval, scanln[x]);
341 addcolor(inpRGB[i], pval);
342 ccount[i]++;
343 }
344 }
345 for (i = 0; i < 24; i++) { /* compute averages */
346 if (ccount[i] == 0)
347 continue;
348 d = 1./ccount[i];
349 scalecolor(inpRGB[i], d);
350 inpflags |= 1L<<i;
351 }
352 free((char *)scanln);
353 }
354
355
356 getcolors() /* get xyY colors from standard input */
357 {
358 int gotwhite = 0;
359 COLOR whiteclr;
360 int n;
361 float xyYin[3];
362
363 while (fgetval(stdin, 'i', &n) == 1) { /* read colors */
364 if (n < 0 | n > 24 ||
365 fgetval(stdin, 'f', &xyYin[0]) != 1 ||
366 fgetval(stdin, 'f', &xyYin[1]) != 1 ||
367 fgetval(stdin, 'f', &xyYin[2]) != 1 ||
368 xyYin[0] < 0. | xyYin[1] < 0. ||
369 xyYin[0] + xyYin[1] > 1.) {
370 fprintf(stderr, "%s: bad color input data\n",
371 progname);
372 exit(1);
373 }
374 if (n == 0) { /* calibration white */
375 xyY2RGB(whiteclr, xyYin);
376 gotwhite++;
377 } else { /* standard color */
378 n--;
379 xyY2RGB(inpRGB[n], xyYin);
380 inpflags |= 1L<<n;
381 }
382 }
383 /* normalize colors */
384 if (!gotwhite) {
385 if (!(inpflags & 1L<<White)) {
386 fprintf(stderr, "%s: missing input for White\n",
387 progname);
388 exit(1);
389 }
390 setcolor(whiteclr,
391 colval(inpRGB[White],RED)/colval(mbRGB[White],RED),
392 colval(inpRGB[White],GRN)/colval(mbRGB[White],GRN),
393 colval(inpRGB[White],BLU)/colval(mbRGB[White],BLU));
394 }
395 for (n = 0; n < 24; n++)
396 if (inpflags & 1L<<n)
397 setcolor(inpRGB[n],
398 colval(inpRGB[n],RED)/colval(whiteclr,RED),
399 colval(inpRGB[n],GRN)/colval(whiteclr,GRN),
400 colval(inpRGB[n],BLU)/colval(whiteclr,BLU));
401 }
402
403
404 bresp(y, x) /* piecewise linear interpolation of primaries */
405 COLOR y, x;
406 {
407 register int i, n;
408
409 for (i = 0; i < 3; i++) {
410 for (n = 0; n < NMBNEU-2; n++)
411 if (colval(x,i) < colval(bramp[n+1][0],i))
412 break;
413 colval(y,i) = ((colval(bramp[n+1][0],i) - colval(x,i)) *
414 colval(bramp[n][1],i) +
415 (colval(x,i) - colval(bramp[n][0],i)) *
416 colval(bramp[n+1][1],i)) /
417 (colval(bramp[n+1][0],i) - colval(bramp[n][0],i));
418 }
419 }
420
421
422 compute() /* compute color mapping */
423 {
424 COLOR clrin[24], clrout[24];
425 long cflags;
426 COLOR ctmp;
427 register int i, n;
428 /* did we get what we need? */
429 if ((inpflags & REQFLGS) != REQFLGS) {
430 fprintf(stderr, "%s: missing required input colors\n",
431 progname);
432 exit(1);
433 }
434 /* compute piecewise luminance curve */
435 for (i = 0; i < NMBNEU; i++) {
436 copycolor(bramp[i][0], inpRGB[mbneu[i]]);
437 copycolor(bramp[i][1], mbRGB[mbneu[i]]);
438 }
439 /* compute color space gamut */
440 if (scanning) {
441 copycolor(colmin, cblack);
442 copycolor(colmax, cwhite);
443 scalecolor(colmax, irrad);
444 } else
445 for (i = 0; i < 3; i++) {
446 colval(colmin,i) = colval(bramp[0][0],i) -
447 colval(bramp[0][1],i) *
448 (colval(bramp[1][0],i)-colval(bramp[0][0],i)) /
449 (colval(bramp[1][1],i)-colval(bramp[1][0],i));
450 colval(colmax,i) = colval(bramp[NMBNEU-2][0],i) +
451 (1.-colval(bramp[NMBNEU-2][1],i)) *
452 (colval(bramp[NMBNEU-1][0],i) -
453 colval(bramp[NMBNEU-2][0],i)) /
454 (colval(bramp[NMBNEU-1][1],i) -
455 colval(bramp[NMBNEU-2][1],i));
456 }
457 /* compute color mapping */
458 do {
459 cflags = inpflags & ~gmtflags;
460 n = 0; /* compute transform matrix */
461 for (i = 0; i < 24; i++)
462 if (cflags & 1L<<i) {
463 bresp(clrin[n], inpRGB[i]);
464 copycolor(clrout[n], mbRGB[i]);
465 n++;
466 }
467 compsoln(clrin, clrout, n);
468 if (irrad > 0.99 && irrad < 1.01) /* check gamut */
469 for (i = 0; i < 24; i++)
470 if (cflags & 1L<<i && cvtcolor(ctmp, mbRGB[i]))
471 gmtflags |= 1L<<i;
472 } while (cflags & gmtflags);
473 if (gmtflags & MODFLGS)
474 fprintf(stderr,
475 "%s: warning - some moderate colors are out of gamut\n",
476 progname);
477 }
478
479
480 putmapping() /* put out color mapping */
481 {
482 static char cchar[3] = {'r', 'g', 'b'};
483 register int i, j;
484 /* print brightness mapping */
485 for (j = 0; j < 3; j++) {
486 printf("%cxa(i) : select(i", cchar[j]);
487 for (i = 0; i < NMBNEU; i++)
488 printf(",%g", colval(bramp[i][0],j));
489 printf(");\n");
490 printf("%cya(i) : select(i", cchar[j]);
491 for (i = 0; i < NMBNEU; i++)
492 printf(",%g", colval(bramp[i][1],j));
493 printf(");\n");
494 printf("%cfi(n) = if(n-%g, %d, if(%cxa(n+1)-%c, n, %cfi(n+1)));\n",
495 cchar[j], NMBNEU-1.5, NMBNEU-1, cchar[j],
496 cchar[j], cchar[j]);
497 printf("%cndx = %cfi(1);\n", cchar[j], cchar[j]);
498 printf("%c%c = ((%cxa(%cndx+1)-%c)*%cya(%cndx) + ",
499 cchar[j], scanning?'n':'o', cchar[j],
500 cchar[j], cchar[j], cchar[j], cchar[j]);
501 printf("(%c-%cxa(%cndx))*%cya(%cndx+1)) /\n",
502 cchar[j], cchar[j], cchar[j],
503 cchar[j], cchar[j]);
504 printf("\t\t(%cxa(%cndx+1) - %cxa(%cndx)) ;\n",
505 cchar[j], cchar[j], cchar[j], cchar[j]);
506 }
507 /* print color mapping */
508 if (scanning) {
509 printf("r = ri(1); g = gi(1); b = bi(1);\n");
510 printf("ro = %g*rn + %g*gn + %g*bn ;\n",
511 solmat[0][0], solmat[0][1], solmat[0][2]);
512 printf("go = %g*rn + %g*gn + %g*bn ;\n",
513 solmat[1][0], solmat[1][1], solmat[1][2]);
514 printf("bo = %g*rn + %g*gn + %g*bn ;\n",
515 solmat[2][0], solmat[2][1], solmat[2][2]);
516 } else {
517 printf("r1 = ri(1); g1 = gi(1); b1 = bi(1);\n");
518 printf("r = %g*r1 + %g*g1 + %g*b1 ;\n",
519 solmat[0][0], solmat[0][1], solmat[0][2]);
520 printf("g = %g*r1 + %g*g1 + %g*b1 ;\n",
521 solmat[1][0], solmat[1][1], solmat[1][2]);
522 printf("b = %g*r1 + %g*g1 + %g*b1 ;\n",
523 solmat[2][0], solmat[2][1], solmat[2][2]);
524 }
525 }
526
527
528 compsoln(cin, cout, n) /* solve 3xN system using least-squares */
529 COLOR cin[], cout[];
530 int n;
531 {
532 extern double mx3d_adjoint(), fabs();
533 double mat[3][3], invmat[3][3];
534 double det;
535 double colv[3], rowv[3];
536 register int i, j, k;
537
538 if (n < 3) {
539 fprintf(stderr, "%s: too few colors to match!\n", progname);
540 exit(1);
541 }
542 if (n == 3)
543 for (i = 0; i < 3; i++)
544 for (j = 0; j < 3; j++)
545 mat[i][j] = colval(cin[j],i);
546 else { /* compute A^t A */
547 for (i = 0; i < 3; i++)
548 for (j = i; j < 3; j++) {
549 mat[i][j] = 0.;
550 for (k = 0; k < n; k++)
551 mat[i][j] += colval(cin[k],i) *
552 colval(cin[k],j);
553 }
554 for (i = 1; i < 3; i++) /* using symmetry */
555 for (j = 0; j < i; j++)
556 mat[i][j] = mat[j][i];
557 }
558 det = mx3d_adjoint(mat, invmat);
559 if (fabs(det) < 1e-4) {
560 fprintf(stderr, "%s: cannot compute color mapping\n",
561 progname);
562 solmat[0][0] = solmat[1][1] = solmat[2][2] = 1.;
563 solmat[0][1] = solmat[0][2] = solmat[1][0] =
564 solmat[1][2] = solmat[2][0] = solmat[2][1] = 0.;
565 return;
566 }
567 for (i = 0; i < 3; i++)
568 for (j = 0; j < 3; j++)
569 invmat[i][j] /= det;
570 for (i = 0; i < 3; i++) {
571 if (n == 3)
572 for (j = 0; j < 3; j++)
573 colv[j] = colval(cout[j],i);
574 else
575 for (j = 0; j < 3; j++) {
576 colv[j] = 0.;
577 for (k = 0; k < n; k++)
578 colv[j] += colval(cout[k],i) *
579 colval(cin[k],j);
580 }
581 mx3d_transform(colv, invmat, rowv);
582 for (j = 0; j < 3; j++)
583 solmat[i][j] = rowv[j];
584 }
585 }
586
587
588 cwarp() /* compute color warp map */
589 {
590 register int i;
591
592 if ((wcor = new3dw(W3EXACT)) == NULL)
593 goto memerr;
594 for (i = 0; i < 24; i++)
595 if (!add3dpt(wcor, inpRGB[i], mbRGB[i]))
596 goto memerr;
597 return;
598 memerr:
599 perror(progname);
600 exit(1);
601 }
602
603
604 int
605 cvtcolor(cout, cin) /* convert color according to our mapping */
606 COLOR cout, cin;
607 {
608 COLOR ctmp;
609 int clipped;
610
611 if (wcor != NULL) {
612 clipped = warp3d(cout, cin, wcor);
613 clipped |= clipgamut(cout,bright(cout),CGAMUT,colmin,colmax);
614 } else if (scanning) {
615 bresp(ctmp, cin);
616 clipped = cresp(cout, ctmp);
617 } else {
618 clipped = cresp(ctmp, cin);
619 bresp(cout, ctmp);
620 }
621 return(clipped);
622 }
623
624
625 int
626 cresp(cout, cin) /* transform color according to matrix */
627 COLOR cout, cin;
628 {
629 colortrans(cout, solmat, cin);
630 return(clipgamut(cout, bright(cout), CGAMUT, colmin, colmax));
631 }
632
633
634 xyY2RGB(rgbout, xyYin) /* convert xyY to RGB */
635 COLOR rgbout;
636 register float xyYin[3];
637 {
638 COLOR ctmp;
639 double d;
640
641 d = xyYin[2] / xyYin[1];
642 ctmp[0] = xyYin[0] * d;
643 ctmp[1] = xyYin[2];
644 ctmp[2] = (1. - xyYin[0] - xyYin[1]) * d;
645 /* allow negative values */
646 colortrans(rgbout, xyz2rgbmat, ctmp);
647 }
648
649
650 picdebug() /* put out debugging picture */
651 {
652 static COLOR blkcol = BLKCOLOR;
653 COLOR *scan;
654 int y, i;
655 register int x, rg;
656
657 if (fseek(stdin, 0L, 0) == EOF) {
658 fprintf(stderr, "%s: cannot seek on input picture\n", progname);
659 exit(1);
660 }
661 getheader(stdin, NULL, NULL); /* skip input header */
662 fgetresolu(&xmax, &ymax, stdin);
663 /* allocate scanline */
664 scan = (COLOR *)malloc(xmax*sizeof(COLOR));
665 if (scan == NULL) {
666 perror(progname);
667 exit(1);
668 }
669 /* finish debug header */
670 fputformat(COLRFMT, debugfp);
671 putc('\n', debugfp);
672 fprtresolu(xmax, ymax, debugfp);
673 /* write debug picture */
674 for (y = ymax-1; y >= 0; y--) {
675 if (freadscan(scan, xmax, stdin) < 0) {
676 fprintf(stderr, "%s: error rereading input picture\n",
677 progname);
678 exit(1);
679 }
680 for (x = 0; x < xmax; x++) {
681 rg = chartndx(x, y, &i);
682 if (rg == RG_CENT) {
683 if (!(1L<<i & gmtflags) || (x+y)&07) {
684 copycolor(scan[x], mbRGB[i]);
685 clipgamut(scan[x], bright(scan[x]),
686 CGAMUT, colmin, colmax);
687 } else
688 copycolor(scan[x], blkcol);
689 } else if (rg == RG_CORR)
690 cvtcolor(scan[x], scan[x]);
691 else if (rg != RG_ORIG)
692 copycolor(scan[x], blkcol);
693 }
694 if (fwritescan(scan, xmax, debugfp) < 0) {
695 fprintf(stderr, "%s: error writing debugging picture\n",
696 progname);
697 exit(1);
698 }
699 }
700 /* clean up */
701 fclose(debugfp);
702 free((char *)scan);
703 }
704
705
706 clrdebug() /* put out debug picture from color input */
707 {
708 static COLR blkclr = BLKCOLR;
709 COLR mbclr[24], cvclr[24], orclr[24];
710 COLR *scan;
711 COLOR ctmp, ct2;
712 int y, i;
713 register int x, rg;
714 /* convert colors */
715 for (i = 0; i < 24; i++) {
716 copycolor(ctmp, mbRGB[i]);
717 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
718 setcolr(mbclr[i], colval(ctmp,RED),
719 colval(ctmp,GRN), colval(ctmp,BLU));
720 if (inpflags & 1L<<i) {
721 copycolor(ctmp, inpRGB[i]);
722 clipgamut(ctmp, bright(ctmp), CGAMUT, cblack, cwhite);
723 setcolr(orclr[i], colval(ctmp,RED),
724 colval(ctmp,GRN), colval(ctmp,BLU));
725 if (rawmap)
726 copycolr(cvclr[i], mbclr[i]);
727 else {
728 bresp(ctmp, inpRGB[i]);
729 colortrans(ct2, solmat, ctmp);
730 clipgamut(ct2, bright(ct2), CGAMUT,
731 cblack, cwhite);
732 setcolr(cvclr[i], colval(ct2,RED),
733 colval(ct2,GRN),
734 colval(ct2,BLU));
735 }
736 }
737 }
738 /* allocate scanline */
739 scan = (COLR *)malloc(xmax*sizeof(COLR));
740 if (scan == NULL) {
741 perror(progname);
742 exit(1);
743 }
744 /* finish debug header */
745 fputformat(COLRFMT, debugfp);
746 putc('\n', debugfp);
747 fprtresolu(xmax, ymax, debugfp);
748 /* write debug picture */
749 for (y = ymax-1; y >= 0; y--) {
750 for (x = 0; x < xmax; x++) {
751 rg = chartndx(x, y, &i);
752 if (rg == RG_CENT) {
753 if (!(1L<<i & gmtflags) || (x+y)&07)
754 copycolr(scan[x], mbclr[i]);
755 else
756 copycolr(scan[x], blkclr);
757 } else if (rg == RG_BORD || !(1L<<i & inpflags))
758 copycolr(scan[x], blkclr);
759 else if (rg == RG_ORIG)
760 copycolr(scan[x], orclr[i]);
761 else /* rg == RG_CORR */
762 copycolr(scan[x], cvclr[i]);
763 }
764 if (fwritecolrs(scan, xmax, debugfp) < 0) {
765 fprintf(stderr, "%s: error writing debugging picture\n",
766 progname);
767 exit(1);
768 }
769 }
770 /* clean up */
771 fclose(debugfp);
772 free((char *)scan);
773 }
